SDK 2.9.2 - SSERTION FAIL @ WEST_TOPDIR/zephyr/subsys/bluetooth/host/hci_core.c:434
I have seen this assert since SDK 2.4.2 but less frequent. Now I had updated the code use the SDK 2.9.2, this assert made impossible to release it to production.
The point of the assert is on the function bt_hci_cmd_send_sync where it is waiting for 10s to take a semaphore.
    err = k_sem_take(&sync_sem, HCI_CMD_TIMEOUT);
    BT_ASSERT_MSG(err == 0,
              "Controller unresponsive, command opcode 0x%04x timeout with err %d",
              opcode, err);
There are many tickets about this issues, I try them all. The only change really helps was to remove all the hci call from the sys queue, but it is still happening a lot. I found the request to getthe connection RSSI is causing the assert.
I had work on this issue for a month now. I saw this assert when I testing in high traffic BLE environment. Each device has 4 BLE connections where each device send data to one connection every seconds and the RSSI is been request every 5 seconds.
The RTT logs shows the following pattern:
00> [00:03:54.294,860] <err> bt_hci_driver: No available ACL buffers!
00> [00:03:54.295,349] <err> bt_hci_driver: No available ACL buffers!
00> [00:03:54.295,837] <err> bt_hci_driver: No available ACL buffers!
00> [00:03:54.296,325] <err> bt_hci_driver: No available ACL buffers!
00> [00:03:54.296,844] <err> bt_hci_driver: No available ACL buffers!
00> [00:03:54.297,210] <err> bt_hci_driver: No available ACL buffers!
00> [00:03:54.297,729] <err> bt_hci_driver: No available ACL buffers!
00> [00:03:54.298,217] <err> bt_hci_driver: No available ACL buffers!
00> [00:03:54.298,706] <err> bt_hci_driver: No available ACL buffers!
00> [00:03:54.299,224] <err> bt_hci_driver: No available ACL buffers!
00> [00:03:54.299,713] <err> bt_hci_driver: No available ACL buffers!
00> [00:03:54.300,201] <err> bt_hci_driver: No available ACL buffers!
00> [00:03:54.300,750] <err> bt_hci_driver: No available ACL buffers!
00> ASSERTION FAIL @ WEST_TOPDIR/zephyr/subsys/bluetooth/host/hci_core.c:434
Here my main core .config file
# CONFIG_INPUT is not set
# CONFIG_WIFI is not set
# CONFIG_MIPI_DSI is not set
# CONFIG_SERIAL is not set
CONFIG_I2C=y
CONFIG_SPI=y
# CONFIG_MODEM is not set
# CONFIG_BT_SPI is not set
# CONFIG_BT_HCI_ACL_FLOW_CONTROL is not set
CONFIG_BT_HCI_VS=y
CONFIG_FLASH_LOAD_SIZE=0xf0000
CONFIG_SRAM_SIZE=448
CONFIG_FLASH_LOAD_OFFSET=0x10000
CONFIG_BT_HCI_IPC=y
# CONFIG_BT_CTLR is not set
CONFIG_BT_ECC=y
CONFIG_NUM_IRQS=69
CONFIG_SYS_CLOCK_HW_CYCLES_PER_SEC=32768
CONFIG_FLASH_SIZE=1024
CONFIG_FLASH_BASE_ADDRESS=0x0
CONFIG_MP_MAX_NUM_CPUS=1
CONFIG_SOC_RESET_HOOK=y
CONFIG_SYS_CLOCK_TICKS_PER_SEC=32768
CONFIG_ROM_START_OFFSET=0
CONFIG_PINCTRL=y
CONFIG_BUILD_OUTPUT_BIN=y
# CONFIG_BUILD_NO_GAP_FILL is not set
CONFIG_XIP=y
CONFIG_MAIN_STACK_SIZE=4096
CONFIG_IDLE_STACK_SIZE=320
CONFIG_HAS_FLASH_LOAD_OFFSET=y
# CONFIG_SRAM_VECTOR_TABLE is not set
CONFIG_TASK_WDT_HW_FALLBACK_DELAY=20
CONFIG_CPU_HAS_ARM_MPU=y
# CONFIG_COUNTER is not set
# CONFIG_SHARED_INTERRUPTS is not set
CONFIG_PM_DEVICE=y
CONFIG_TICKLESS_KERNEL=y
# CONFIG_FPU is not set
CONFIG_SYSTEM_WORKQUEUE_STACK_SIZE=4096
CONFIG_BT_USER_PHY_UPDATE=y
CONFIG_CLOCK_CONTROL=y
CONFIG_CLOCK_CONTROL_INIT_PRIORITY=30
CONFIG_USE_DT_CODE_PARTITION=y
# CONFIG_MULTI_LEVEL_INTERRUPTS is not set
CONFIG_GEN_IRQ_VECTOR_TABLE=y
# CONFIG_DYNAMIC_INTERRUPTS is not set
CONFIG_GEN_ISR_TABLES=y
CONFIG_INIT_STACKS=y
CONFIG_TIMESLICE_SIZE=0
# CONFIG_REGULATOR is not set
CONFIG_PM_DEVICE_SYSTEM_MANAGED=y
CONFIG_FLASH_FILL_BUFFER_SIZE=32
CONFIG_HW_STACK_PROTECTION=y
# CONFIG_HCI_NXP_ENABLE_AUTO_SLEEP is not set
# CONFIG_HCI_NXP_SET_CAL_DATA is not set
# CONFIG_MFD is not set
CONFIG_GPIO=y
# CONFIG_CPU_HAS_CUSTOM_FIXED_SOC_MPU_REGIONS is not set
CONFIG_TINYCRYPT=y
# CONFIG_CODE_DATA_RELOCATION_SRAM is not set
# CONFIG_MBEDTLS is not set
# CONFIG_MEMC is not set
CONFIG_KERNEL_ENTRY="__start"
# CONFIG_CACHE is not set
CONFIG_LOG=y
# CONFIG_CODE_DATA_RELOCATION is not set
# CONFIG_ROMSTART_RELOCATION_ROM is not set
CONFIG_DCACHE_LINE_SIZE=32
CONFIG_SOC="nrf5340"
# CONFIG_RESET is not set
CONFIG_ARCH_SW_ISR_TABLE_ALIGN=4
CONFIG_NRF_RTC_TIMER=y
CONFIG_IPC_SERVICE_BACKEND_RPMSG_SHMEM_RESET=y
CONFIG_LOG_DOMAIN_NAME=""
CONFIG_ASSERT=y
CONFIG_BUILD_OUTPUT_HEX=y
CONFIG_PM_DEVICE_POWER_DOMAIN=y
CONFIG_ARCH_HAS_CUSTOM_BUSY_WAIT=y
CONFIG_SOC_HAS_TIMING_FUNCTIONS=y
# CONFIG_SYSCON is not set
CONFIG_ENTROPY_INIT_PRIORITY=50
CONFIG_SOC_SERIES="nrf53"
CONFIG_SOC_FAMILY="nordic_nrf"
# CONFIG_INTC_MTK_ADSP is not set
# CONFIG_MTK_ADSP_TIMER is not set
CONFIG_COMMON_LIBC_MALLOC_ARENA_SIZE=-1
CONFIG_GEN_SW_ISR_TABLE=y
CONFIG_REBOOT=y
CONFIG_FLASH_INIT_PRIORITY=50
CONFIG_GEN_IRQ_START_VECTOR=0
CONFIG_SRAM_OFFSET=0
# CONFIG_POWER_DOMAIN is not set
# CONFIG_CONSOLE is not set
CONFIG_ARCH_IRQ_VECTOR_TABLE_ALIGN=4
CONFIG_SPI_NOR=y
CONFIG_ISR_STACK_SIZE=2048
# CONFIG_MCUBOOT_GENERATE_UNSIGNED_IMAGE is not set
# CONFIG_MCUBOOT_GENERATE_CONFIRMED_IMAGE is not set
# CONFIG_SCHED_CPU_MASK is not set
CONFIG_WATCHDOG=y
CONFIG_ICACHE_LINE_SIZE=32
CONFIG_PRIVILEGED_STACK_SIZE=1024
CONFIG_BT_BUF_ACL_TX_COUNT=20
CONFIG_BT_BUF_CMD_TX_SIZE=255
CONFIG_BT_BUF_EVT_RX_SIZE=255
CONFIG_BT_BUF_ACL_TX_SIZE=251
CONFIG_BT_BUF_ACL_RX_SIZE=251
CONFIG_BT_L2CAP_TX_MTU=247
# Devicetree Info
CONFIG_DT_HAS_ARM_ARMV8M_ITM_ENABLED=y
CONFIG_DT_HAS_ARM_ARMV8M_MPU_ENABLED=y
CONFIG_DT_HAS_ARM_CORTEX_M33F_ENABLED=y
CONFIG_DT_HAS_ARM_CRYPTOCELL_312_ENABLED=y
CONFIG_DT_HAS_ARM_V8M_NVIC_ENABLED=y
CONFIG_DT_HAS_FIXED_PARTITIONS_ENABLED=y
CONFIG_DT_HAS_GENERIC_FEM_TWO_CTRL_PINS_ENABLED=y
CONFIG_DT_HAS_GPIO_KEYS_ENABLED=y
CONFIG_DT_HAS_JEDEC_SPI_NOR_ENABLED=y
CONFIG_DT_HAS_MMIO_SRAM_ENABLED=y
CONFIG_DT_HAS_NORDIC_MBOX_NRF_IPC_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_CLOCK_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_CTRLAPPERI_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_DCNF_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_DPPIC_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_EGU_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_FICR_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_GPIO_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_GPIOTE_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_GPREGRET_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_IPC_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_KMU_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_MUTEX_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_OSCILLATORS_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_PINCTRL_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_POWER_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_RESET_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_SAADC_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_SPIM_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_SPIS_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_SPU_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_TIMER_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_TWIM_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_UICR_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_USBREG_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_VMC_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_WDT_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF53_FLASH_CONTROLLER_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF53X_REGULATORS_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF5X_REGULATOR_ENABLED=y
CONFIG_DT_HAS_SOC_NV_FLASH_ENABLED=y
CONFIG_DT_HAS_ST_ST25R3916_ENABLED=y
CONFIG_DT_HAS_ZEPHYR_BT_HCI_ENTROPY_ENABLED=y
CONFIG_DT_HAS_ZEPHYR_BT_HCI_IPC_ENABLED=y
CONFIG_DT_HAS_ZEPHYR_IPC_OPENAMP_STATIC_VRINGS_ENABLED=y
# end of Devicetree Info
# Modules
# Available modules.
# nrf (C:/ncs/v2.9.2/nrf)
CONFIG_NUM_METAIRQ_PRIORITIES=0
CONFIG_LOG_BUFFER_SIZE=8192
CONFIG_MPSL_WORK_STACK_SIZE=1024
# Nordic nRF Connect
CONFIG_HIDE_CHILD_PARENT_CONFIG=y
CONFIG_WARN_EXPERIMENTAL=y
CONFIG_MCUMGR_TRANSPORT_NETBUF_SIZE=1024
CONFIG_BT_BUF_CMD_TX_COUNT=10
CONFIG_INIT_ARCH_HW_AT_BOOT=y
CONFIG_NORDIC_QSPI_NOR_FLASH_LAYOUT_PAGE_SIZE=4096
# CONFIG_GETOPT is not set
# CONFIG_NCS_SAMPLES_DEFAULTS is not set
# CONFIG_NRF70_RADIO_TEST_COMBO is not set
CONFIG_NCS_INCLUDE_RPMSG_CHILD_IMAGE=y
CONFIG_NCS_SAMPLE_HCI_IPC_CHILD_IMAGE=y
# Image build variants
# CONFIG_NCS_MCUBOOT_IN_BUILD is not set
# end of Image build variants
# CONFIG_NCS_SAMPLE_MCUMGR_BT_OTA_DFU is not set
CONFIG_IMG_ERASE_PROGRESSIVELY=y
# CONFIG_MCUMGR_GRP_OS_MCUMGR_PARAMS is not set
# CONFIG_MCUMGR_GRP_ZBASIC is not set
CONFIG_UPDATEABLE_IMAGE_NUMBER=2
CONFIG_NRF53_UPGRADE_NETWORK_CORE=y
# CONFIG_NCS_SAMPLE_MCUMGR_BT_OTA_DFU_SPEEDUP is not set
# Subsystems
# Bootloader
# CONFIG_BUILD_S1_VARIANT is not set
# CONFIG_SECURE_BOOT is not set
CONFIG_PM_PARTITION_SIZE_PROVISION=0x280
# CONFIG_B0_MIN_PARTITION_SIZE is not set
CONFIG_PM_PARTITION_SIZE_B0_IMAGE=0x8000
# CONFIG_IS_SECURE_BOOTLOADER is not set
# CONFIG_NRF53_ENFORCE_IMAGE_VERSION_EQUALITY is not set
# Secure Boot firmware validation
CONFIG_SB_VALIDATION_INFO_MAGIC=0x86518483
CONFIG_SB_VALIDATION_POINTER_MAGIC=0x6919b47e
CONFIG_SB_VALIDATION_INFO_CRYPTO_ID=1
CONFIG_SB_VALIDATION_INFO_VERSION=2
CONFIG_SB_VALIDATION_METADATA_OFFSET=0
CONFIG_SB_VALIDATE_FW_SIGNATURE=y
# end of Secure Boot firmware validation
# CONFIG_SECURE_BOOT_STORAGE is not set
# CONFIG_MCUBOOT_COMPRESSED_IMAGE_SUPPORT_ENABLED is not set
# CONFIG_MCUBOOT_BOOTLOADER_SIGNATURE_TYPE_ED25519 is not set
# CONFIG_MCUBOOT_BOOTLOADER_SIGNATURE_TYPE_PURE is not set
# end of Bootloader
# Bluetooth Low Energy
CONFIG_BT_COMPANY_ID_NORDIC=0x0059
CONFIG_BT_COMPANY_ID=0x0059
CONFIG_BT_MAX_CONN=9
CONFIG_BT_LL_SOFTDEVICE_HEADERS_INCLUDE=y
CONFIG_BT_HCI_TX_STACK_SIZE=1024
CONFIG_BT_RX_STACK_SIZE=4096
# BLE Libraries
# CONFIG_BT_GATT_POOL is not set
CONFIG_BT_GATT_DM=y
CONFIG_BT_GATT_DM_WORKQ_OWN=y
# CONFIG_BT_GATT_DM_WORKQ_SYS is not set
CONFIG_BT_GATT_DM_WORKQ_STACK_SIZE=1300
CONFIG_BT_GATT_DM_WORKQ_PRIO=10
CONFIG_BT_GATT_DM_WORKQ_INIT_PRIO=50
CONFIG_BT_GATT_DM_MAX_ATTRS=35
# CONFIG_BT_GATT_DM_DATA_PRINT is not set
# CONFIG_BT_GATT_DM_LOG_LEVEL_OFF is not set
# CONFIG_BT_GATT_DM_LOG_LEVEL_ERR is not set
# CONFIG_BT_GATT_DM_LOG_LEVEL_WRN is not set
# CONFIG_BT_GATT_DM_LOG_LEVEL_INF is not set
# CONFIG_BT_GATT_DM_LOG_LEVEL_DBG is not set
CONFIG_BT_GATT_DM_LOG_LEVEL_DEFAULT=y
CONFIG_BT_GATT_DM_LOG_LEVEL=3
# CONFIG_BT_ADV_PROV is not set
CONFIG_BT_SCAN=y
CONFIG_BT_SCAN_NAME_MAX_LEN=32
CONFIG_BT_SCAN_SHORT_NAME_MAX_LEN=32
CONFIG_BT_SCAN_FILTER_ENABLE=y
CONFIG_BT_SCAN_MANUFACTURER_DATA_MAX_LEN=32
CONFIG_BT_SCAN_UUID_CNT=1
CONFIG_BT_SCAN_NAME_CNT=0
CONFIG_BT_SCAN_SHORT_NAME_CNT=0
CONFIG_BT_SCAN_ADDRESS_CNT=0
CONFIG_BT_SCAN_APPEARANCE_CNT=0
CONFIG_BT_SCAN_MANUFACTURER_DATA_CNT=0
# CONFIG_BT_SCAN_CONN_ATTEMPTS_FILTER is not set
# CONFIG_BT_SCAN_BLOCKLIST is not set
# CONFIG_BT_SCAN_LOG_LEVEL_OFF is not set
# CONFIG_BT_SCAN_LOG_LEVEL_ERR is not set
# CONFIG_BT_SCAN_LOG_LEVEL_WRN is not set
# CONFIG_BT_SCAN_LOG_LEVEL_INF is not set
# CONFIG_BT_SCAN_LOG_LEVEL_DBG is not set
CONFIG_BT_SCAN_LOG_LEVEL_DEFAULT=y
CONFIG_BT_SCAN_LOG_LEVEL=3
# CONFIG_BT_CONN_CTX is not set
CONFIG_BT_EXT_ADV_MAX_ADV_SET=3
# Bluetooth Services
# CONFIG_BT_AMS_CLIENT is not set
# CONFIG_BT_ANCS_CLIENT is not set
# CONFIG_BT_BAS_CLIENT is not set
# CONFIG_BT_CTS_CLIENT is not set
# CONFIG_BT_DFU_SMP is not set
# CONFIG_BT_GATTP is not set
# CONFIG_BT_HIDS is not set
# CONFIG_BT_HOGP is not set
# CONFIG_BT_LBS is not set
# CONFIG_BT_NSMS is not set
# CONFIG_BT_NUS is not set
# CONFIG_BT_NUS_CLIENT is not set
# CONFIG_BT_RSCS is not set
# CONFIG_BT_THROUGHPUT is not set
# CONFIG_BT_LATENCY is not set
# CONFIG_BT_LATENCY_CLIENT is not set
# CONFIG_BT_HRS_CLIENT is not set
# CONFIG_BT_DDFS is not set
# CONFIG_BT_MDS is not set
# CONFIG_BT_CGMS is not set
# CONFIG_BT_FAST_PAIR is not set
CONFIG_SYSTEM_WORKQUEUE_PRIORITY=-2
CONFIG_BT_GATT_AUTO_SEC_REQ=y
# end of Bluetooth Services
# BLE over nRF RPC
# CONFIG_BT_RPC is not set
CONFIG_HEAP_MEM_POOL_SIZE=2048
CONFIG_BT_DRIVERS=y
# CONFIG_BT_RPC_STACK is not set
CONFIG_BT_CENTRAL=y
CONFIG_BT_PERIPHERAL=y
CONFIG_BT_OBSERVER=y
CONFIG_BT_BROADCASTER=y
CONFIG_BT_CONN=y
# CONFIG_BT_REMOTE_VERSION is not set
CONFIG_BT_PHY_UPDATE=y
CONFIG_BT_DATA_LEN_UPDATE=y
CONFIG_BT_EXT_ADV=y
# CONFIG_BT_EXT_ADV_LEGACY_SUPPORT is not set
# CONFIG_BT_PER_ADV is not set
# CONFIG_BT_PER_ADV_SYNC is not set
# CONFIG_BT_PER_ADV_SYNC_RSP is not set
CONFIG_BT_LOG=y
# CONFIG_BT_LOG_LEVEL_OFF is not set
# CONFIG_BT_LOG_LEVEL_ERR is not set
# CONFIG_BT_LOG_LEVEL_WRN is not set
# CONFIG_BT_LOG_LEVEL_INF is not set
# CONFIG_BT_LOG_LEVEL_DBG is not set
CONFIG_BT_LOG_LEVEL_DEFAULT=y
CONFIG_BT_LOG_LEVEL=3
CONFIG_BT_HCI_DRIVER_LOG_LEVEL_INHERIT=y
CONFIG_BT_HCI_DRIVER_LOG_LEVEL=3
# CONFIG_BT_HCI_DRIVER_LOG_LEVEL_OFF is not set
# CONFIG_BT_HCI_DRIVER_LOG_LEVEL_ERR is not set
# CONFIG_BT_HCI_DRIVER_LOG_LEVEL_WRN is not set
# CONFIG_BT_HCI_DRIVER_LOG_LEVEL_INF is not set
# CONFIG_BT_HCI_DRIVER_LOG_LEVEL_DBG is not set
# CONFIG_BT_HCI_DRIVER_LOG_LEVEL_DEFAULT is not set
CONFIG_BT_RPA_LOG_LEVEL_INHERIT=y
CONFIG_BT_RPA_LOG_LEVEL=3
# CONFIG_BT_RPA_LOG_LEVEL_OFF is not set
# CONFIG_BT_RPA_LOG_LEVEL_ERR is not set
# CONFIG_BT_RPA_LOG_LEVEL_WRN is not set
# CONFIG_BT_RPA_LOG_LEVEL_INF is not set
# CONFIG_BT_RPA_LOG_LEVEL_DBG is not set
# CONFIG_BT_RPA_LOG_LEVEL_DEFAULT is not set
CONFIG_BT_CRYPTO_LOG_LEVEL_INHERIT=y
CONFIG_BT_CRYPTO_LOG_LEVEL=3
# CONFIG_BT_CRYPTO_LOG_LEVEL_OFF is not set
# CONFIG_BT_CRYPTO_LOG_LEVEL_ERR is not set
# CONFIG_BT_CRYPTO_LOG_LEVEL_WRN is not set
# CONFIG_BT_CRYPTO_LOG_LEVEL_INF is not set
# CONFIG_BT_CRYPTO_LOG_LEVEL_DBG is not set
# CONFIG_BT_CRYPTO_LOG_LEVEL_DEFAULT is not set
CONFIG_BT_ATT_LOG_LEVEL_INHERIT=y
CONFIG_BT_ATT_LOG_LEVEL=3
# CONFIG_BT_ATT_LOG_LEVEL_OFF is not set
# CONFIG_BT_ATT_LOG_LEVEL_ERR is not set
# CONFIG_BT_ATT_LOG_LEVEL_WRN is not set
# CONFIG_BT_ATT_LOG_LEVEL_INF is not set
# CONFIG_BT_ATT_LOG_LEVEL_DBG is not set
# CONFIG_BT_ATT_LOG_LEVEL_DEFAULT is not set
CONFIG_BT_GATT_LOG_LEVEL_INHERIT=y
CONFIG_BT_GATT_LOG_LEVEL=3
# CONFIG_BT_GATT_LOG_LEVEL_OFF is not set
# CONFIG_BT_GATT_LOG_LEVEL_ERR is not set
# CONFIG_BT_GATT_LOG_LEVEL_WRN is not set
# CONFIG_BT_GATT_LOG_LEVEL_INF is not set
# CONFIG_BT_GATT_LOG_LEVEL_DBG is not set
# CONFIG_BT_GATT_LOG_LEVEL_DEFAULT is not set
CONFIG_BT_L2CAP_LOG_LEVEL_INHERIT=y
CONFIG_BT_L2CAP_LOG_LEVEL=3
# CONFIG_BT_L2CAP_LOG_LEVEL_OFF is not set
# CONFIG_BT_L2CAP_LOG_LEVEL_ERR is not set
# CONFIG_BT_L2CAP_LOG_LEVEL_WRN is not set
# CONFIG_BT_L2CAP_LOG_LEVEL_INF is not set
# CONFIG_BT_L2CAP_LOG_LEVEL_DBG is not set
# CONFIG_BT_L2CAP_LOG_LEVEL_DEFAULT is not set
CONFIG_BT_SETTINGS_LOG_LEVEL_INHERIT=y
CONFIG_BT_SETTINGS_LOG_LEVEL=3
# CONFIG_BT_SETTINGS_LOG_LEVEL_OFF is not set
# CONFIG_BT_SETTINGS_LOG_LEVEL_ERR is not set
# CONFIG_BT_SETTINGS_LOG_LEVEL_WRN is not set
# CONFIG_BT_SETTINGS_LOG_LEVEL_INF is not set
# CONFIG_BT_SETTINGS_LOG_LEVEL_DBG is not set
# CONFIG_BT_SETTINGS_LOG_LEVEL_DEFAULT is not set
CONFIG_BT_HCI_CORE_LOG_LEVEL_INHERIT=y
CONFIG_BT_HCI_CORE_LOG_LEVEL=3
# CONFIG_BT_HCI_CORE_LOG_LEVEL_OFF is not set
# CONFIG_BT_HCI_CORE_LOG_LEVEL_ERR is not set
# CONFIG_BT_HCI_CORE_LOG_LEVEL_WRN is not set
# CONFIG_BT_HCI_CORE_LOG_LEVEL_INF is not set
# CONFIG_BT_HCI_CORE_LOG_LEVEL_DBG is not set
# CONFIG_BT_HCI_CORE_LOG_LEVEL_DEFAULT is not set
CONFIG_BT_CONN_LOG_LEVEL_INHERIT=y
CONFIG_BT_CONN_LOG_LEVEL=3
# CONFIG_BT_CONN_LOG_LEVEL_OFF is not set
# CONFIG_BT_CONN_LOG_LEVEL_ERR is not set
# CONFIG_BT_CONN_LOG_LEVEL_WRN is not set
# CONFIG_BT_CONN_LOG_LEVEL_INF is not set
# CONFIG_BT_CONN_LOG_LEVEL_DBG is not set
# CONFIG_BT_CONN_LOG_LEVEL_DEFAULT is not set
CONFIG_BT_KEYS_LOG_LEVEL_INHERIT=y
CONFIG_BT_KEYS_LOG_LEVEL=3
# CONFIG_BT_KEYS_LOG_LEVEL_OFF is not set
# CONFIG_BT_KEYS_LOG_LEVEL_ERR is not set
# CONFIG_BT_KEYS_LOG_LEVEL_WRN is not set
# CONFIG_BT_KEYS_LOG_LEVEL_INF is not set
# CONFIG_BT_KEYS_LOG_LEVEL_DBG is not set
# CONFIG_BT_KEYS_LOG_LEVEL_DEFAULT is not set
CONFIG_BT_SMP_LOG_LEVEL_INHERIT=y
CONFIG_BT_SMP_LOG_LEVEL=3
# CONFIG_BT_SMP_LOG_LEVEL_OFF is not set
# CONFIG_BT_SMP_LOG_LEVEL_ERR is not set
# CONFIG_BT_SMP_LOG_LEVEL_WRN is not set
# CONFIG_BT_SMP_LOG_LEVEL_INF is not set
# CONFIG_BT_SMP_LOG_LEVEL_DBG is not set
# CONFIG_BT_SMP_LOG_LEVEL_DEFAULT is not set
CONFIG_BT_SERVICE_LOG_LEVEL_INHERIT=y
CONFIG_BT_SERVICE_LOG_LEVEL=3
# CONFIG_BT_SERVICE_LOG_LEVEL_OFF is not set
# CONFIG_BT_SERVICE_LOG_LEVEL_ERR is not set
# CONFIG_BT_SERVICE_LOG_LEVEL_WRN is not set
# CONFIG_BT_SERVICE_LOG_LEVEL_INF is not set
# CONFIG_BT_SERVICE_LOG_LEVEL_DBG is not set
# CONFIG_BT_SERVICE_LOG_LEVEL_DEFAULT is not set
# CONFIG_BT_DIS is not set
# CONFIG_BT_CTS is not set
# CONFIG_BT_HRS is not set
# CONFIG_BT_TPS is not set
# CONFIG_BT_ZEPHYR_NUS is not set
# CONFIG_BT_IAS is not set
# CONFIG_BT_IAS_CLIENT is not set
# CONFIG_BT_OTS is not set
# CONFIG_BT_OTS_CLIENT is not set
# CONFIG_BT_BAS is not set
# CONFIG_BT_BAS_BLS is not set
CONFIG_BT_BUF_ACL_RX_COUNT=10
CONFIG_BT_BUF_EVT_RX_COUNT=10
CONFIG_BT_BUF_EVT_DISCARDABLE_SIZE=58
CONFIG_BT_BUF_EVT_DISCARDABLE_COUNT=3
CONFIG_BT_HAS_HCI_VS=y
# CONFIG_BT_HCI_VS_FATAL_ERROR is not set
# CONFIG_BT_HCI_VS_EXT_DETECT is not set
# CONFIG_BT_HCI_MESH_EXT is not set
# CONFIG_BT_WAIT_NOP is not set
CONFIG_BT_RPA=y
# CONFIG_BT_ASSERT is not set
# CONFIG_BT_HCI_ERR_TO_STR is not set
CONFIG_BT_DEBUG_NONE=y
# CONFIG_BT_DEBUG_MONITOR_UART is not set
# CONFIG_BT_DEBUG_MONITOR_RTT is not set
CONFIG_BT_LONG_WQ=y
CONFIG_BT_LONG_WQ_STACK_SIZE=1300
CONFIG_BT_LONG_WQ_PRIO=10
CONFIG_BT_LONG_WQ_INIT_PRIO=50
CONFIG_BT_HCI_HOST=y
# CONFIG_BT_HCI_TX_STACK_SIZE_WITH_PROMPT is not set
CONFIG_BT_HCI_TX_PRIO=7
# CONFIG_BT_RECV_WORKQ_SYS is not set
CONFIG_BT_RECV_WORKQ_BT=y
CONFIG_BT_RX_PRIO=8
CONFIG_BT_DRIVER_RX_HIGH_PRIO=6
# CONFIG_BT_CONN_TX_NOTIFY_WQ is not set
# CONFIG_BT_MESH is not set
# CONFIG_BT_AUDIO is not set
CONFIG_BT_HOST_CRYPTO=y
CONFIG_BT_HOST_CRYPTO_PRNG=y
CONFIG_BT_SETTINGS=y
CONFIG_BT_SETTINGS_CCC_LAZY_LOADING=y
CONFIG_BT_SETTINGS_DELAYED_STORE=y
CONFIG_BT_SETTINGS_DELAYED_STORE_MS=1000
CONFIG_BT_SETTINGS_CCC_STORE_ON_WRITE=y
CONFIG_BT_SETTINGS_CF_STORE_ON_WRITE=y
CONFIG_BT_SETTINGS_USE_PRINTK=y
CONFIG_BT_SETTINGS_CCC_STORE_MAX=48
CONFIG_BT_FILTER_ACCEPT_LIST=y
CONFIG_BT_LIM_ADV_TIMEOUT=30
CONFIG_BT_CONN_TX_USER_DATA_SIZE=16
CONFIG_BT_CONN_FRAG_COUNT=9
CONFIG_BT_CONN_TX_MAX=20
# CONFIG_BT_CONN_PARAM_ANY is not set
# CONFIG_BT_CONN_CHECK_NULL_BEFORE_CREATE is not set
# CONFIG_BT_AUTO_PHY_UPDATE is not set
CONFIG_BT_USER_DATA_LEN_UPDATE=y
# CONFIG_BT_AUTO_DATA_LEN_UPDATE is not set
# CONFIG_BT_REMOTE_INFO is not set
CONFIG_BT_SMP=y
# CONFIG_BT_SECURITY_ERR_TO_STR is not set
# CONFIG_BT_SMP_ERR_TO_STR is not set
# CONFIG_BT_PASSKEY_KEYPRESS is not set
# CONFIG_BT_PRIVACY is not set
# CONFIG_BT_SIGNING is not set
# CONFIG_BT_SMP_APP_PAIRING_ACCEPT is not set
# CONFIG_BT_SMP_SC_PAIR_ONLY is not set
# CONFIG_BT_SMP_SC_ONLY is not set
# CONFIG_BT_SMP_OOB_LEGACY_PAIR_ONLY is not set
# CONFIG_BT_SMP_DISABLE_LEGACY_JW_PASSKEY is not set
# CONFIG_BT_SMP_ALLOW_UNAUTH_OVERWRITE is not set
CONFIG_BT_ID_UNPAIR_MATCHING_BONDS=y
# CONFIG_BT_ID_ALLOW_UNAUTH_OVERWRITE is not set
# CONFIG_BT_FIXED_PASSKEY is not set
# CONFIG_BT_USE_DEBUG_KEYS is not set
CONFIG_BT_BONDABLE=y
# CONFIG_BT_BONDING_REQUIRED is not set
# CONFIG_BT_BONDABLE_PER_CONNECTION is not set
# CONFIG_BT_STORE_DEBUG_KEYS is not set
CONFIG_BT_SMP_ENFORCE_MITM=y
CONFIG_BT_KEYS_OVERWRITE_OLDEST=y
# CONFIG_BT_KEYS_SAVE_AGING_COUNTER_ON_PAIRING is not set
CONFIG_BT_SMP_MIN_ENC_KEY_SIZE=7
CONFIG_BT_L2CAP_TX_BUF_COUNT=20
CONFIG_BT_L2CAP_TX_FRAG_COUNT=2
CONFIG_BT_L2CAP_DYNAMIC_CHANNEL=y
# CONFIG_BT_L2CAP_ECRED is not set
# CONFIG_BT_L2CAP_SEG_RECV is not set
# CONFIG_BT_L2CAP_RECONFIGURE_EXPLICIT is not set
# CONFIG_BT_ATT_ERR_TO_STR is not set
CONFIG_BT_ATT_TX_COUNT=20
CONFIG_BT_ATT_PREPARE_COUNT=2
CONFIG_BT_ATT_RETRY_ON_SEC_ERR=y
# CONFIG_BT_ATT_SENT_CB_AFTER_TX is not set
CONFIG_BT_GATT_AUTO_RESUBSCRIBE=y
CONFIG_BT_GATT_SERVICE_CHANGED=y
# CONFIG_BT_GATT_DYNAMIC_DB is not set
CONFIG_BT_GATT_CACHING=y
# CONFIG_BT_GATT_NOTIFY_MULTIPLE is not set
# CONFIG_BT_GATT_ENFORCE_CHANGE_UNAWARE is not set
CONFIG_BT_GATT_ENFORCE_SUBSCRIPTION=y
CONFIG_BT_GATT_CLIENT=y
CONFIG_BT_GATT_READ_MULTIPLE=y
CONFIG_BT_GATT_READ_MULT_VAR_LEN=y
# CONFIG_BT_GATT_AUTO_DISCOVER_CCC is not set
# CONFIG_BT_GATT_AUTO_UPDATE_MTU is not set
# CONFIG_BT_GAP_AUTO_UPDATE_CONN_PARAMS is not set
CONFIG_BT_GAP_PERIPHERAL_PREF_PARAMS=y
CONFIG_BT_PERIPHERAL_PREF_MIN_INT=24
CONFIG_BT_PERIPHERAL_PREF_MAX_INT=40
CONFIG_BT_PERIPHERAL_PREF_LATENCY=0
CONFIG_BT_PERIPHERAL_PREF_TIMEOUT=42
# CONFIG_BT_GATT_AUTHORIZATION_CUSTOM is not set
CONFIG_BT_MAX_PAIRED=2
CONFIG_BT_CREATE_CONN_TIMEOUT=3
CONFIG_BT_CONN_PARAM_UPDATE_TIMEOUT=5000
CONFIG_BT_CONN_PARAM_RETRY_COUNT=3
CONFIG_BT_CONN_PARAM_RETRY_TIMEOUT=5000
CONFIG_BT_BACKGROUND_SCAN_INTERVAL=2048
CONFIG_BT_BACKGROUND_SCAN_WINDOW=18
CONFIG_BT_EXT_SCAN_BUF_SIZE=229
# CONFIG_BT_SCAN_WITH_IDENTITY is not set
# CONFIG_BT_SCAN_AND_INITIATE_IN_PARALLEL is not set
# CONFIG_BT_DEVICE_NAME_DYNAMIC is not set
CONFIG_BT_DEVICE_NAME="LLT_BLE_MESH"
# CONFIG_BT_DEVICE_APPEARANCE_DYNAMIC is not set
CONFIG_BT_DEVICE_APPEARANCE=0
CONFIG_BT_ID_MAX=1
# CONFIG_BT_DF is not set
# CONFIG_BT_TINYCRYPT_ECC is not set
# CONFIG_BT_HOST_CCM is not set
# CONFIG_BT_LOG_SNIFFER_INFO is not set
# CONFIG_BT_TESTING is not set
# CONFIG_BT_CLASSIC is not set
# CONFIG_BT_HCI_VS_EVT_USER is not set
CONFIG_BT_CRYPTO=y
# CONFIG_BT_SHELL is not set
# end of BLE over nRF RPC
# end of Bluetooth Low Energy
# DFU
# CONFIG_DFU_MULTI_IMAGE is not set
CONFIG_DFU_TARGET=y
CONFIG_DFU_TARGET_MCUBOOT=y
CONFIG_DFU_TARGET_STREAM=y
# CONFIG_DFU_TARGET_MCUBOOT_SAVE_PROGRESS is not set
# CONFIG_DFU_TARGET_STREAM_SAVE_PROGRESS is not set
# CONFIG_DFU_TARGET_LOG_LEVEL_OFF is not set
# CONFIG_DFU_TARGET_LOG_LEVEL_ERR is not set
# CONFIG_DFU_TARGET_LOG_LEVEL_WRN is not set
# CONFIG_DFU_TARGET_LOG_LEVEL_INF is not set
# CONFIG_DFU_TARGET_LOG_LEVEL_DBG is not set
CONFIG_DFU_TARGET_LOG_LEVEL_DEFAULT=y
CONFIG_DFU_TARGET_LOG_LEVEL=3
# end of DFU
# CONFIG_ESB is not set
# CONFIG_EMDS is not set
# Peripheral CPU DFU (PCD)
# CONFIG_PCD is not set
# CONFIG_PCD_APP is not set
CONFIG_PCD_VERSION_PAGE_BUF_SIZE=2046
# CONFIG_PCD_NET is not set
# end of Peripheral CPU DFU (PCD)
# Networking
# Application protocols
# nRF Cloud
# Transport
# CONFIG_NRF_CLOUD_REST is not set
# end of Transport
# Credentials
CONFIG_NRF_CLOUD_SEC_TAG=16842753
CONFIG_NRF_CLOUD_AWS_CA_CERT_SIZE_THRESHOLD=1150
CONFIG_NRF_CLOUD_COAP_CA_CERT_SIZE_THRESHOLD=550
# end of Credentials
# Client ID (nRF Cloud Device ID)
CONFIG_NRF_CLOUD_CLIENT_ID_SRC_COMPILE_TIME=y
# CONFIG_NRF_CLOUD_CLIENT_ID_SRC_RUNTIME is not set
CONFIG_NRF_CLOUD_CLIENT_ID="my-client-id"
# end of Client ID (nRF Cloud Device ID)
# Firmware Over-the-Air (FOTA) Updates
# CONFIG_NRF_CLOUD_FOTA is not set
CONFIG_FOTA_USE_NRF_CLOUD_SETTINGS_AREA=y
# CONFIG_NRF_CLOUD_FOTA_FULL_MODEM_UPDATE is not set
# CONFIG_NRF_CLOUD_FOTA_SMP is not set
# CONFIG_NRF_CLOUD_FOTA_LOG_LEVEL_OFF is not set
# CONFIG_NRF_CLOUD_FOTA_LOG_LEVEL_ERR is not set
# CONFIG_NRF_CLOUD_FOTA_LOG_LEVEL_WRN is not set
# CONFIG_NRF_CLOUD_FOTA_LOG_LEVEL_INF is not set
# CONFIG_NRF_CLOUD_FOTA_LOG_LEVEL_DBG is not set
CONFIG_NRF_CLOUD_FOTA_LOG_LEVEL_DEFAULT=y
CONFIG_NRF_CLOUD_FOTA_LOG_LEVEL=3
# end of Firmware Over-the-Air (FOTA) Updates
# Location
# Cellular/Wi-Fi
# CONFIG_NRF_CLOUD_LOCATION_PARSE_ANCHORS is not set
# CONFIG_NRF_CLOUD_WIFI_LOCATION_ENCODE_OPT_MAC_ONLY is not set
CONFIG_NRF_CLOUD_WIFI_LOCATION_ENCODE_OPT_MAC_RSSI=y
# CONFIG_NRF_CLOUD_WIFI_LOCATION_ENCODE_OPT_ALL is not set
# end of Cellular/Wi-Fi
# end of Location
# Alerts
# CONFIG_NRF_CLOUD_ALERT is not set
# CONFIG_NRF_CLOUD_ALERT_LOG_LEVEL_OFF is not set
# CONFIG_NRF_CLOUD_ALERT_LOG_LEVEL_ERR is not set
# CONFIG_NRF_CLOUD_ALERT_LOG_LEVEL_WRN is not set
# CONFIG_NRF_CLOUD_ALERT_LOG_LEVEL_INF is not set
# CONFIG_NRF_CLOUD_ALERT_LOG_LEVEL_DBG is not set
CONFIG_NRF_CLOUD_ALERT_LOG_LEVEL_DEFAULT=y
CONFIG_NRF_CLOUD_ALERT_LOG_LEVEL=3
# end of Alerts
# Logging
CONFIG_NRF_CLOUD_LOG_OUTPUT_LEVEL=1
# CONFIG_NRF_CLOUD_LOG_INCLUDE_LEVEL_0 is not set
CONFIG_NRF_CLOUD_LOG_BUF_SIZE=256
# CONFIG_NRF_CLOUD_LOG_LOG_LEVEL_OFF is not set
# CONFIG_NRF_CLOUD_LOG_LOG_LEVEL_ERR is not set
# CONFIG_NRF_CLOUD_LOG_LOG_LEVEL_WRN is not set
# CONFIG_NRF_CLOUD_LOG_LOG_LEVEL_INF is not set
# CONFIG_NRF_CLOUD_LOG_LOG_LEVEL_DBG is not set
CONFIG_NRF_CLOUD_LOG_LOG_LEVEL_DEFAULT=y
CONFIG_NRF_CLOUD_LOG_LOG_LEVEL=3
# end of Logging
# Device Shadow
# Send shadow info sections on initial connect (MQTT/CoAP)
# end of Send shadow info sections on initial connect (MQTT/CoAP)
# end of Device Shadow
CONFIG_NRF_CLOUD_PRINT_DETAILS=y
CONFIG_NRF_CLOUD_VERBOSE_DETAILS=y
# CONFIG_NRF_CLOUD_GATEWAY is not set
# CONFIG_NRF_CLOUD_LOG_LEVEL_OFF is not set
# CONFIG_NRF_CLOUD_LOG_LEVEL_ERR is not set
# CONFIG_NRF_CLOUD_LOG_LEVEL_WRN is not set
# CONFIG_NRF_CLOUD_LOG_LEVEL_INF is not set
# CONFIG_NRF_CLOUD_LOG_LEVEL_DBG is not set
CONFIG_NRF_CLOUD_LOG_LEVEL_DEFAULT=y
CONFIG_NRF_CLOUD_LOG_LEVEL=3
# end of nRF Cloud
# CONFIG_REST_CLIENT is not set
# CONFIG_DOWNLOAD_CLIENT is not set
# CONFIG_AWS_IOT is not set
# CONFIG_AWS_JOBS is not set
# CONFIG_AZURE_IOT_HUB is not set
# Self-Registration (Zi ZHu Ce)
# end of Self-Registration (Zi ZHu Ce)
# CONFIG_ICAL_PARSER is not set
# CONFIG_FTP_CLIENT is not set
# CONFIG_LWM2M_CLIENT_UTILS is not set
# CONFIG_WIFI_CREDENTIALS is not set
# CONFIG_WIFI_CREDENTIALS_STATIC is not set
# CONFIG_MQTT_HELPER is not set
# CONFIG_NRF_PROVISIONING is not set
# CONFIG_NRF_MCUMGR_SMP_CLIENT is not set
# end of Application protocols
# CONFIG_OPENTHREAD_RPC is not set
# end of Networking
# NFC
CONFIG_NFC_NDEF=y
CONFIG_NFC_NDEF_PARSER=y
# CONFIG_NFC_NDEF_PAYLOAD_TYPE_COMMON is not set
CONFIG_NFC_NDEF_MSG=y
CONFIG_NFC_NDEF_RECORD=y
# CONFIG_NFC_NDEF_LE_OOB_REC is not set
# CONFIG_NFC_NDEF_TEXT_RECORD is not set
# CONFIG_NFC_NDEF_TNEP_RECORD is not set
# CONFIG_NFC_NDEF_URI_MSG is not set
# CONFIG_NFC_NDEF_URI_REC is not set
# CONFIG_NFC_NDEF_CH_MSG is not set
# CONFIG_NFC_NDEF_CH_REC is not set
# CONFIG_NFC_NDEF_LAUNCHAPP_MSG is not set
# CONFIG_NFC_NDEF_LAUNCHAPP_REC is not set
CONFIG_NDEF_FILE_SIZE=1024
# CONFIG_NFC_NDEF_PARSER_LOG_LEVEL_OFF is not set
# CONFIG_NFC_NDEF_PARSER_LOG_LEVEL_ERR is not set
# CONFIG_NFC_NDEF_PARSER_LOG_LEVEL_WRN is not set
# CONFIG_NFC_NDEF_PARSER_LOG_LEVEL_INF is not set
# CONFIG_NFC_NDEF_PARSER_LOG_LEVEL_DBG is not set
CONFIG_NFC_NDEF_PARSER_LOG_LEVEL_DEFAULT=y
CONFIG_NFC_NDEF_PARSER_LOG_LEVEL=3
# CONFIG_NFC_NDEF_LE_OOB_REC_PARSER is not set
# CONFIG_NFC_NDEF_CH_PARSER is not set
CONFIG_NFC_T2T_PARSER=y
# CONFIG_NFC_T2T_PARSER_LOG_LEVEL_OFF is not set
# CONFIG_NFC_T2T_PARSER_LOG_LEVEL_ERR is not set
# CONFIG_NFC_T2T_PARSER_LOG_LEVEL_WRN is not set
# CONFIG_NFC_T2T_PARSER_LOG_LEVEL_INF is not set
# CONFIG_NFC_T2T_PARSER_LOG_LEVEL_DBG is not set
CONFIG_NFC_T2T_PARSER_LOG_LEVEL_DEFAULT=y
CONFIG_NFC_T2T_PARSER_LOG_LEVEL=3
# CONFIG_NFC_T4T_NDEF_FILE is not set
# CONFIG_NFC_T4T_ISODEP is not set
# CONFIG_NFC_T4T_APDU is not set
# CONFIG_NFC_T4T_CC_FILE is not set
# CONFIG_NFC_T4T_HL_PROCEDURE is not set
# CONFIG_NFC_PLATFORM is not set
# CONFIG_NFC_TNEP_TAG is not set
# CONFIG_NFC_TNEP_POLLER is not set
# CONFIG_NFC_TNEP_CH is not set
# CONFIG_NFC_RPC is not set
# end of NFC
CONFIG_APP_EVENT_MANAGER=y
CONFIG_APP_EVENT_MANAGER_REBOOT_ON_EVENT_ALLOC_FAIL=y
CONFIG_APP_EVENT_MANAGER_SHOW_EVENTS=y
# CONFIG_APP_EVENT_MANAGER_SHOW_EVENT_HANDLERS is not set
# CONFIG_APP_EVENT_MANAGER_TRACE_EVENT_DATA is not set
# CONFIG_APP_EVENT_MANAGER_LOG_LEVEL_OFF is not set
# CONFIG_APP_EVENT_MANAGER_LOG_LEVEL_ERR is not set
# CONFIG_APP_EVENT_MANAGER_LOG_LEVEL_WRN is not set
# CONFIG_APP_EVENT_MANAGER_LOG_LEVEL_INF is not set
# CONFIG_APP_EVENT_MANAGER_LOG_LEVEL_DBG is not set
CONFIG_APP_EVENT_MANAGER_LOG_LEVEL_DEFAULT=y
CONFIG_APP_EVENT_MANAGER_LOG_LEVEL=3
# CONFIG_APP_EVENT_MANAGER_USE_DEPRECATED_LOG_FUN is not set
CONFIG_APP_EVENT_MANAGER_LOG_EVENT_TYPE=y
CONFIG_APP_EVENT_MANAGER_MAX_EVENT_CNT=32
# CONFIG_APP_EVENT_MANAGER_PROVIDE_EVENT_SIZE is not set
# CONFIG_APP_EVENT_MANAGER_POSTINIT_HOOK is not set
# CONFIG_APP_EVENT_MANAGER_SUBMIT_HOOKS is not set
# CONFIG_APP_EVENT_MANAGER_PREPROCESS_HOOKS is not set
# CONFIG_APP_EVENT_MANAGER_POSTPROCESS_HOOKS is not set
# CONFIG_APP_EVENT_MANAGER_PROFILER_TRACER is not set
# CONFIG_EVENT_MANAGER_PROXY is not set
# CONFIG_NRF_PROFILER is not set
# CONFIG_FW_INFO is not set
# Debug
# CONFIG_CPU_LOAD is not set
# CONFIG_PPI_TRACE is not set
# end of Debug
# CONFIG_SHELL_BT_NUS is not set
# CONFIG_SHELL_IPC is not set
# Multiprotocol service layer (MPSL)
# CONFIG_MPSL_FEM_ONLY is not set
CONFIG_MPSL_FEM_ANY_SUPPORT=y
CONFIG_MPSL_FEM_GENERIC_TWO_CTRL_PINS_SUPPORT=y
CONFIG_MPSL_FEM_NCS_SUPPORTED_FEM_USED=y
CONFIG_MPSL_FEM_PIN_FORWARDER=y
CONFIG_MPSL_FEM_SIMPLE_GPIO=y
# CONFIG_MPSL_FEM_DEVICE_CONFIG_254 is not set
# CONFIG_MPSL_FEM_LOG_LEVEL_OFF is not set
# CONFIG_MPSL_FEM_LOG_LEVEL_ERR is not set
# CONFIG_MPSL_FEM_LOG_LEVEL_WRN is not set
# CONFIG_MPSL_FEM_LOG_LEVEL_INF is not set
# CONFIG_MPSL_FEM_LOG_LEVEL_DBG is not set
CONFIG_MPSL_FEM_LOG_LEVEL_DEFAULT=y
CONFIG_MPSL_FEM_LOG_LEVEL=3
CONFIG_MPSL_THREAD_COOP_PRIO=8
CONFIG_MPSL_TIMESLOT_SESSION_COUNT=0
# CONFIG_MPSL_ASSERT_HANDLER is not set
CONFIG_MPSL_LOW_PRIO_IRQN=26
CONFIG_MPSL_HFCLK_LATENCY=1400
# CONFIG_MPSL_LOG_LEVEL_OFF is not set
# CONFIG_MPSL_LOG_LEVEL_ERR is not set
# CONFIG_MPSL_LOG_LEVEL_WRN is not set
# CONFIG_MPSL_LOG_LEVEL_INF is not set
# CONFIG_MPSL_LOG_LEVEL_DBG is not set
CONFIG_MPSL_LOG_LEVEL_DEFAULT=y
CONFIG_MPSL_LOG_LEVEL=3
# end of Multiprotocol service layer (MPSL)
# Partition Manager
CONFIG_PARTITION_MANAGER_ENABLED=y
CONFIG_FLASH_MAP_CUSTOM=y
CONFIG_SRAM_BASE_ADDRESS=0x20000000
CONFIG_NRF_TRUSTZONE_FLASH_REGION_SIZE=0x4000
CONFIG_NRF_TRUSTZONE_RAM_REGION_SIZE=0x2000
# Zephyr subsystem configurations
CONFIG_RPMSG_NRF53_SRAM_SIZE=0x8000
CONFIG_PM_PARTITION_SIZE_SETTINGS_STORAGE=0x2000
# CONFIG_PM_PARTITION_REGION_SETTINGS_STORAGE_EXTERNAL is not set
CONFIG_PM_PARTITION_ALIGN_SETTINGS_STORAGE=0x4000
# end of Zephyr subsystem configurations
# NCS subsystem configurations
# CONFIG_PM_SINGLE_IMAGE is not set
CONFIG_PM_EXTERNAL_FLASH_HAS_DRIVER=y
CONFIG_PM_EXTERNAL_FLASH_BASE=0
CONFIG_PM_EXTERNAL_FLASH_ENABLED=y
CONFIG_PM_EXTERNAL_FLASH_PATH="/soc/peripheral@50000000/spi@a000/hg1_at25sl128a@0"
CONFIG_PM_EXTERNAL_FLASH_SIZE_BITS=134217728
CONFIG_PM_EXTERNAL_FLASH_MCUBOOT_SECONDARY=y
CONFIG_PM_OVERRIDE_EXTERNAL_DRIVER_CHECK=y
CONFIG_PM_SRAM_BASE=0x20000000
CONFIG_PM_SRAM_SIZE=0x80000
# end of Partition Manager
# nRF RPC (Remote Procedure Call) library
# end of nRF RPC (Remote Procedure Call) library
# CONFIG_ZIGBEE is not set
# Full Modem Firmware Update Management(FMFU)
# CONFIG_MGMT_FMFU_LOG_LEVEL_OFF is not set
# CONFIG_MGMT_FMFU_LOG_LEVEL_ERR is not set
# CONFIG_MGMT_FMFU_LOG_LEVEL_WRN is not set
# CONFIG_MGMT_FMFU_LOG_LEVEL_INF is not set
# CONFIG_MGMT_FMFU_LOG_LEVEL_DBG is not set
CONFIG_MGMT_FMFU_LOG_LEVEL_DEFAULT=y
CONFIG_MGMT_FMFU_LOG_LEVEL=3
# end of Full Modem Firmware Update Management(FMFU)
# CONFIG_CAF is not set
# Nordic IEEE 802.15.4
# end of Nordic IEEE 802.15.4
# CONFIG_DM_MODULE is not set
# nRF Security
# CONFIG_NORDIC_SECURITY_BACKEND is not set
# CONFIG_NRF_SECURITY is not set
# Nordic-added meta types
# Nordic added alg types
# CONFIG_PSA_WANT_ALG_ECDSA_ANY is not set
# CONFIG_PSA_WANT_ALG_ED25519PH is not set
# CONFIG_PSA_WANT_ALG_ED448PH is not set
# CONFIG_PSA_WANT_ALG_PURE_EDDSA is not set
# CONFIG_PSA_WANT_ALG_RSA_PKCS1V15_SIGN_RAW is not set
# CONFIG_PSA_WANT_ALG_RSA_PSS_ANY_SALT is not set
# CONFIG_PSA_WANT_ALG_SHA_512_224 is not set
# CONFIG_PSA_WANT_ALG_SHA_512_256 is not set
# CONFIG_PSA_WANT_ALG_SPAKE2P_HMAC is not set
# CONFIG_PSA_WANT_ALG_SPAKE2P_CMAC is not set
# CONFIG_PSA_WANT_ALG_SPAKE2P_MATTER is not set
# CONFIG_PSA_WANT_ALG_SRP_6 is not set
# CONFIG_PSA_WANT_ALG_SRP_PASSWORD_HASH is not set
# CONFIG_PSA_WANT_ALG_XTS is not set
# Nordic added ECC curve types
# CONFIG_PSA_WANT_ECC_BRAINPOOL_P_R1_160 is not set
# CONFIG_PSA_WANT_ECC_BRAINPOOL_P_R1_192 is not set
# CONFIG_PSA_WANT_ECC_BRAINPOOL_P_R1_224 is not set
# CONFIG_PSA_WANT_ECC_BRAINPOOL_P_R1_320 is not set
# CONFIG_PSA_WANT_ECC_TWISTED_EDWARDS_255 is not set
# CONFIG_PSA_WANT_ECC_TWISTED_EDWARDS_448 is not set
# CONFIG_PSA_WANT_ECC_SECP_K1_224 is not set
# CONFIG_PSA_WANT_ECC_SECP_R2_160 is not set
# CONFIG_PSA_WANT_ECC_SECT_K1_163 is not set
# CONFIG_PSA_WANT_ECC_SECT_K1_233 is not set
# CONFIG_PSA_WANT_ECC_SECT_K1_239 is not set
# CONFIG_PSA_WANT_ECC_SECT_K1_283 is not set
# CONFIG_PSA_WANT_ECC_SECT_K1_409 is not set
# CONFIG_PSA_WANT_ECC_SECT_K1_571 is not set
# CONFIG_PSA_WANT_ECC_SECT_R1_163 is not set
# CONFIG_PSA_WANT_ECC_SECT_R1_233 is not set
# CONFIG_PSA_WANT_ECC_SECT_R1_283 is not set
# CONFIG_PSA_WANT_ECC_SECT_R1_409 is not set
# CONFIG_PSA_WANT_ECC_SECT_R1_571 is not set
# CONFIG_PSA_WANT_ECC_SECT_R2_163 is not set
# CONFIG_PSA_WANT_ECC_FRP_V1_256 is not set
# CONFIG_PSA_WANT_ALG_CHACHA20 is not set
# CONFIG_PSA_WANT_ALG_SHAKE256_512 is not set
# Nordic addded RNG configuration
# CONFIG_PSA_WANT_GENERATE_RANDOM is not set
# Nordic added key types
# CONFIG_PSA_WANT_KEY_TYPE_PEPPER is not set
# CONFIG_PSA_WANT_KEY_TYPE_SPAKE2P_KEY_PAIR_IMPORT is not set
# CONFIG_PSA_WANT_KEY_TYPE_SPAKE2P_KEY_PAIR_EXPORT is not set
# CONFIG_PSA_WANT_KEY_TYPE_SPAKE2P_KEY_PAIR_GENERATE is not set
# CONFIG_PSA_WANT_KEY_TYPE_SPAKE2P_KEY_PAIR_DERIVE is not set
# CONFIG_PSA_WANT_KEY_TYPE_SPAKE2P_PUBLIC_KEY is not set
# CONFIG_PSA_WANT_KEY_TYPE_SRP_KEY_PAIR_IMPORT is not set
# CONFIG_PSA_WANT_KEY_TYPE_SRP_KEY_PAIR_EXPORT is not set
# CONFIG_PSA_WANT_KEY_TYPE_SRP_KEY_PAIR_GENERATE is not set
# CONFIG_PSA_WANT_KEY_TYPE_SRP_KEY_PAIR_DERIVE is not set
# CONFIG_PSA_WANT_KEY_TYPE_SRP_PUBLIC_KEY is not set
# end of nRF Security
# CONFIG_NET_CORE_MONITOR is not set
# Audio Modules
# CONFIG_AUDIO_MODULE_TEST is not set
CONFIG_AUDIO_MODULE_NAME_SIZE=20
# Log levels
# CONFIG_AUDIO_MODULE_LOG_LEVEL_OFF is not set
# CONFIG_AUDIO_MODULE_LOG_LEVEL_ERR is not set
# CONFIG_AUDIO_MODULE_LOG_LEVEL_WRN is not set
# CONFIG_AUDIO_MODULE_LOG_LEVEL_INF is not set
# CONFIG_AUDIO_MODULE_LOG_LEVEL_DBG is not set
CONFIG_AUDIO_MODULE_LOG_LEVEL_DEFAULT=y
CONFIG_AUDIO_MODULE_LOG_LEVEL=3
# end of Log levels
# end of Audio Modules
# Audio Modules
# CONFIG_AUDIO_MODULE_TEMPLATE is not set
# CONFIG_TRUSTED_STORAGE is not set
# Logging over RPC
# CONFIG_LOG_FORWARDER_RPC is not set
# CONFIG_LOG_BACKEND_RPC is not set
# end of Logging over RPC
# SUIT provisioning
# CONFIG_SUIT_MPI_GENERATE is not set
# end of SUIT provisioning
# CONFIG_SUIT is not set
# CONFIG_DULT is not set
# CONFIG_NRF_COMPRESS is not set
# MCUboot IDs (informative only, do not change)
CONFIG_MCUBOOT_APPLICATION_IMAGE_NUMBER=0
CONFIG_MCUBOOT_NETWORK_CORE_IMAGE_NUMBER=1
CONFIG_MCUBOOT_WIFI_PATCHES_IMAGE_NUMBER=-1
CONFIG_MCUBOOT_QSPI_XIP_IMAGE_NUMBER=-1
CONFIG_MCUBOOT_MCUBOOT_IMAGE_NUMBER=-1
# end of MCUboot IDs (informative only, do not change)
# end of Subsystems
# CONFIG_WFA_QT_LOG_LEVEL_OFF is not set
# CONFIG_WFA_QT_LOG_LEVEL_ERR is not set
# CONFIG_WFA_QT_LOG_LEVEL_WRN is not set
# CONFIG_WFA_QT_LOG_LEVEL_INF is not set
# CONFIG_WFA_QT_LOG_LEVEL_DBG is not set
CONFIG_WFA_QT_LOG_LEVEL_DEFAULT=y
CONFIG_WFA_QT_LOG_LEVEL=3
# CONFIG_WFA_QT_CONTROL_APP is not set
CONFIG_WFA_QT_THREAD_STACK_SIZE=5200
CONFIG_WFA_QT_REBOOT_TIMEOUT_MS=1000
CONFIG_WFA_QT_DEFAULT_INTERFACE="wlan0"
CONFIG_WPAS_READY_TIMEOUT_MS=10000
# Libraries
# Binary libraries
# end of Binary libraries
# CONFIG_AT_MONITOR is not set
# CONFIG_LTE_LINK_CONTROL is not set
CONFIG_NRF_SPU_FLASH_REGION_SIZE=0x4000
CONFIG_FPROTECT_BLOCK_SIZE=0x4000
# CONFIG_FPROTECT is not set
# CONFIG_AT_CMD_CUSTOM is not set
# CONFIG_DK_LIBRARY is not set
# CONFIG_AT_CMD_PARSER is not set
# CONFIG_AT_PARSER is not set
# CONFIG_MODEM_INFO is not set
# CONFIG_RESET_ON_FATAL_ERROR is not set
# CONFIG_SMS is not set
# CONFIG_DATE_TIME is not set
# CONFIG_HW_ID_LIBRARY is not set
# CONFIG_RAM_POWER_DOWN_LIBRARY is not set
# CONFIG_WAVE_GEN_LIB is not set
CONFIG_HW_UNIQUE_KEY_SUPPORTED=y
CONFIG_HW_UNIQUE_KEY_PARTITION_SIZE=0
# CONFIG_MODEM_JWT is not set
# CONFIG_LOCATION is not set
# CONFIG_QOS is not set
# CONFIG_SFLOAT is not set
# CONFIG_CONTIN_ARRAY is not set
# CONFIG_PCM_MIX is not set
# CONFIG_TONE is not set
# CONFIG_PSCM is not set
# CONFIG_DATA_FIFO is not set
# CONFIG_FEM_AL_LIB is not set
# CONFIG_SAMPLE_RATE_CONVERTER is not set
CONFIG_NCS_BOOT_BANNER=y
CONFIG_NCS_APPLICATION_BOOT_BANNER_STRING="My Application"
CONFIG_NCS_NCS_BOOT_BANNER_STRING="nRF Connect SDK"
CONFIG_NCS_ZEPHYR_BOOT_BANNER_STRING="Zephyr OS"
# end of Libraries
# Device Drivers
# CONFIG_BT_DRIVER_QUIRK_NO_AUTO_DLE is not set
CONFIG_ENTROPY_CC3XX=y
# CONFIG_FLASH_RPC is not set
CONFIG_HW_CC3XX=y
# CONFIG_ETH_RTT is not set
# CONFIG_SENSOR is not set
# CONFIG_NRF_SW_LPUART is not set
CONFIG_NRFX_GPIOTE_NUM_OF_EVT_HANDLERS=1
# CONFIG_IPC_UART is not set
# end of Device Drivers
# External libraries
# end of External libraries
# Test
CONFIG_ZTEST_MULTICORE_DEFAULT_SETTINGS=y
# CONFIG_UNITY is not set
# Mocks
# CONFIG_MOCK_NRF_MODEM_AT is not set
# CONFIG_MOCK_NRF_RPC is not set
# end of Mocks
# end of Test
# end of Nordic nRF Connect
CONFIG_ZEPHYR_NRF_MODULE=y
# end of nrf (C:/ncs/v2.9.2/nrf)
# mcuboot (C:/ncs/v2.9.2/bootloader/mcuboot)
# MCUboot
CONFIG_BOOT_SIGNATURE_KEY_FILE=""
# CONFIG_BOOT_BUILD_DIRECT_XIP_VARIANT is not set
# CONFIG_MCUBOOT_HARDWARE_DOWNGRADE_PREVENTION is not set
CONFIG_MCUBOOT_FLASH_WRITE_BLOCK_SIZE=4
CONFIG_DT_FLASH_WRITE_BLOCK_SIZE=4
# CONFIG_USE_NRF53_MULTI_IMAGE_WITHOUT_UPGRADE_ONLY is not set
# CONFIG_DFU_MULTI_IMAGE_PACKAGE_BUILD is not set
CONFIG_ADD_MCUBOOT_MEDIATE_SIM_FLASH_DTS=y
# CONFIG_MCUBOOT_USE_ALL_AVAILABLE_RAM is not set
# end of MCUboot
# CONFIG_XIP_SPLIT_IMAGE is not set
CONFIG_ZEPHYR_MCUBOOT_MODULE=y
# end of mcuboot (C:/ncs/v2.9.2/bootloader/mcuboot)
# mbedtls (C:/ncs/v2.9.2/modules/crypto/mbedtls)
CONFIG_ZEPHYR_MBEDTLS_MODULE=y
# end of mbedtls (C:/ncs/v2.9.2/modules/crypto/mbedtls)
# oberon-psa-crypto (C:/ncs/v2.9.2/modules/crypto/oberon-psa-crypto)
CONFIG_ZEPHYR_OBERON_PSA_CRYPTO_MODULE=y
# end of oberon-psa-crypto (C:/ncs/v2.9.2/modules/crypto/oberon-psa-crypto)
# trusted-firmware-m (C:/ncs/v2.9.2/modules/tee/tf-m/trusted-firmware-m)
CONFIG_TFM_BOARD="C:/ncs/v2.9.2/zephyr/modules/trusted-firmware-m/nordic/nrf5340_cpuapp"
CONFIG_BOOTLOADER_MCUBOOT=y
CONFIG_ZEPHYR_TRUSTED_FIRMWARE_M_MODULE=y
# end of trusted-firmware-m (C:/ncs/v2.9.2/modules/tee/tf-m/trusted-firmware-m)
CONFIG_ZEPHYR_PSA_ARCH_TESTS_MODULE=y
CONFIG_ZEPHYR_SOC_HWMV1_MODULE=y
# cjson (C:/ncs/v2.9.2/modules/lib/cjson)
# CONFIG_CJSON_LIB is not set
CONFIG_ZEPHYR_CJSON_MODULE=y
# end of cjson (C:/ncs/v2.9.2/modules/lib/cjson)
# azure-sdk-for-c (C:/ncs/v2.9.2/modules/lib/azure-sdk-for-c)
# CONFIG_AZURE_SDK is not set
CONFIG_ZEPHYR_AZURE_SDK_FOR_C_MODULE=y
# end of azure-sdk-for-c (C:/ncs/v2.9.2/modules/lib/azure-sdk-for-c)
# cirrus-logic (C:/ncs/v2.9.2/modules/hal/cirrus-logic)
# CONFIG_HW_CODEC_CIRRUS_LOGIC is not set
CONFIG_ZEPHYR_CIRRUS_LOGIC_MODULE=y
# end of cirrus-logic (C:/ncs/v2.9.2/modules/hal/cirrus-logic)
# openthread (C:/ncs/v2.9.2/modules/lib/openthread)
# CONFIG_OPENTHREAD is not set
CONFIG_ZEPHYR_OPENTHREAD_MODULE=y
# end of openthread (C:/ncs/v2.9.2/modules/lib/openthread)
# suit-generator (C:/ncs/v2.9.2/modules/lib/suit-generator)
CONFIG_SUIT_ENVELOPE_TEMPLATE_FILENAME=""
CONFIG_SUIT_ENVELOPE_TARGET=""
CONFIG_SUIT_ENVELOPE_OUTPUT_ARTIFACT="merged.hex"
# CONFIG_SUIT_RECOVERY is not set
CONFIG_SUIT_ENVELOPE_OUTPUT_MPI_MERGE=y
# CONFIG_SUIT_LOCAL_ENVELOPE_GENERATE is not set
# CONFIG_SUIT_DFU_CACHE_EXTRACT_IMAGE is not set
CONFIG_ZEPHYR_SUIT_GENERATOR_MODULE=y
# end of suit-generator (C:/ncs/v2.9.2/modules/lib/suit-generator)
# suit-processor (C:/ncs/v2.9.2/modules/lib/suit-processor)
# CONFIG_SUIT_PROCESSOR is not set
CONFIG_SUIT_PLATFORM_DRY_RUN_SUPPORT=y
CONFIG_ZEPHYR_SUIT_PROCESSOR_MODULE=y
# end of suit-processor (C:/ncs/v2.9.2/modules/lib/suit-processor)
# memfault-firmware-sdk (C:/ncs/v2.9.2/modules/lib/memfault-firmware-sdk)
# CONFIG_MEMFAULT is not set
CONFIG_ZEPHYR_MEMFAULT_FIRMWARE_SDK_MODULE=y
# end of memfault-firmware-sdk (C:/ncs/v2.9.2/modules/lib/memfault-firmware-sdk)
# coremark (C:/ncs/v2.9.2/modules/benchmark/coremark)
# CONFIG_COREMARK is not set
CONFIG_ZEPHYR_COREMARK_MODULE=y
# end of coremark (C:/ncs/v2.9.2/modules/benchmark/coremark)
# canopennode (C:/ncs/v2.9.2/modules/lib/canopennode)
CONFIG_ZEPHYR_CANOPENNODE_MODULE=y
# end of canopennode (C:/ncs/v2.9.2/modules/lib/canopennode)
# chre (C:/ncs/v2.9.2/modules/lib/chre)
CONFIG_ZEPHYR_CHRE_MODULE=y
# CONFIG_CHRE is not set
# end of chre (C:/ncs/v2.9.2/modules/lib/chre)
# lz4 (C:/ncs/v2.9.2/modules/lib/lz4)
CONFIG_ZEPHYR_LZ4_MODULE=y
# CONFIG_LZ4 is not set
# end of lz4 (C:/ncs/v2.9.2/modules/lib/lz4)
# nanopb (C:/ncs/v2.9.2/modules/lib/nanopb)
CONFIG_ZEPHYR_NANOPB_MODULE=y
# CONFIG_NANOPB is not set
# end of nanopb (C:/ncs/v2.9.2/modules/lib/nanopb)
CONFIG_ZEPHYR_TF_M_TESTS_MODULE=y
# zscilib (C:/ncs/v2.9.2/modules/lib/zscilib)
# CONFIG_ZSL is not set
CONFIG_ZEPHYR_ZSCILIB_MODULE=y
# end of zscilib (C:/ncs/v2.9.2/modules/lib/zscilib)
# cmsis (C:/ncs/v2.9.2/modules/hal/cmsis)
CONFIG_ZEPHYR_CMSIS_MODULE=y
CONFIG_HAS_CMSIS_CORE=y
CONFIG_HAS_CMSIS_CORE_M=y
# CONFIG_CMSIS_M_CHECK_DEVICE_DEFINES is not set
# end of cmsis (C:/ncs/v2.9.2/modules/hal/cmsis)
# cmsis-dsp (C:/ncs/v2.9.2/modules/lib/cmsis-dsp)
CONFIG_ZEPHYR_CMSIS_DSP_MODULE=y
# CONFIG_CMSIS_DSP is not set
# end of cmsis-dsp (C:/ncs/v2.9.2/modules/lib/cmsis-dsp)
# cmsis-nn (C:/ncs/v2.9.2/modules/lib/cmsis-nn)
CONFIG_ZEPHYR_CMSIS_NN_MODULE=y
# CONFIG_CMSIS_NN is not set
# end of cmsis-nn (C:/ncs/v2.9.2/modules/lib/cmsis-nn)
# fatfs (C:/ncs/v2.9.2/modules/fs/fatfs)
CONFIG_ZEPHYR_FATFS_MODULE=y
# end of fatfs (C:/ncs/v2.9.2/modules/fs/fatfs)
# hal_nordic (C:/ncs/v2.9.2/modules/hal/nordic)
CONFIG_ZEPHYR_HAL_NORDIC_MODULE=y
CONFIG_HAS_NORDIC_DRIVERS=y
# Nordic drivers
# CONFIG_NRF_802154_SOURCE_HAL_NORDIC is not set
# CONFIG_NRF_802154_SER_HOST is not set
# end of Nordic drivers
CONFIG_HAS_NRFX=y
# nrfx drivers
# nrfx drivers logging
# CONFIG_NRFX_CLOCK_LOG is not set
# CONFIG_NRFX_DPPI_LOG is not set
# CONFIG_NRFX_GPIOTE_LOG is not set
# CONFIG_NRFX_IPC_LOG is not set
# CONFIG_NRFX_NVMC_LOG is not set
# CONFIG_NRFX_PRS_LOG is not set
# CONFIG_NRFX_SAADC_LOG is not set
# CONFIG_NRFX_SPIM_LOG is not set
# CONFIG_NRFX_SPIS_LOG is not set
# CONFIG_NRFX_TWIM_LOG is not set
# CONFIG_NRFX_WDT_LOG is not set
# end of nrfx drivers logging
CONFIG_NRFX_CLOCK=y
CONFIG_NRFX_CLOCK_LFXO_TWO_STAGE_ENABLED=y
# CONFIG_NRFX_COMP is not set
CONFIG_NRFX_DPPI=y
CONFIG_NRFX_DPPI0=y
# CONFIG_NRFX_EGU0 is not set
# CONFIG_NRFX_EGU1 is not set
# CONFIG_NRFX_EGU2 is not set
# CONFIG_NRFX_EGU3 is not set
# CONFIG_NRFX_EGU4 is not set
# CONFIG_NRFX_EGU5 is not set
CONFIG_NRFX_GPIOTE=y
CONFIG_NRFX_GPIOTE0=y
# CONFIG_NRFX_GPIOTE1 is not set
CONFIG_NRFX_GPPI=y
# CONFIG_NRFX_I2S0 is not set
CONFIG_NRFX_IPC=y
# CONFIG_NRFX_NFCT is not set
CONFIG_NRFX_NVMC=y
# CONFIG_NRFX_PDM0 is not set
# CONFIG_NRFX_POWER is not set
# CONFIG_NRFX_PWM0 is not set
# CONFIG_NRFX_PWM1 is not set
# CONFIG_NRFX_PWM2 is not set
# CONFIG_NRFX_PWM3 is not set
# CONFIG_NRFX_QDEC0 is not set
# CONFIG_NRFX_QDEC1 is not set
# CONFIG_NRFX_QSPI is not set
# CONFIG_NRFX_RTC0 is not set
# CONFIG_NRFX_RTC1 is not set
CONFIG_NRFX_SAADC=y
CONFIG_NRFX_SPIM=y
# CONFIG_NRFX_SPIM0 is not set
CONFIG_NRFX_SPIM1=y
# CONFIG_NRFX_SPIM2 is not set
CONFIG_NRFX_SPIM4=y
CONFIG_NRFX_SPIS=y
CONFIG_NRFX_SPIS3=y
# CONFIG_NRFX_SYSTICK is not set
# CONFIG_NRFX_TIMER0 is not set
# CONFIG_NRFX_TIMER1 is not set
# CONFIG_NRFX_TIMER2 is not set
CONFIG_NRFX_TWIM=y
CONFIG_NRFX_TWIM0=y
# CONFIG_NRFX_TWIM1 is not set
CONFIG_NRFX_TWIM2=y
# CONFIG_NRFX_TWIM3 is not set
# CONFIG_NRFX_UARTE0 is not set
# CONFIG_NRFX_UARTE1 is not set
# CONFIG_NRFX_UARTE2 is not set
# CONFIG_NRFX_UARTE3 is not set
# CONFIG_NRFX_USBREG is not set
CONFIG_NRFX_WDT=y
CONFIG_NRFX_WDT0=y
# CONFIG_NRFX_WDT1 is not set
# Peripheral Resource Sharing module
CONFIG_NRFX_PRS=y
# CONFIG_NRFX_PRS_BOX_0 is not set
CONFIG_NRFX_PRS_BOX_1=y
# CONFIG_NRFX_PRS_BOX_2 is not set
# CONFIG_NRFX_PRS_BOX_3 is not set
# CONFIG_NRFX_PRS_BOX_4 is not set
# end of Peripheral Resource Sharing module
CONFIG_NRFX_RESERVED_RESOURCES_HEADER="nrfx_config_reserved_resources_ncs.h"
# end of hal_nordic (C:/ncs/v2.9.2/modules/hal/nordic)
# hal_st (C:/ncs/v2.9.2/modules/hal/st)
CONFIG_ZEPHYR_HAL_ST_MODULE=y
# end of hal_st (C:/ncs/v2.9.2/modules/hal/st)
CONFIG_ZEPHYR_HAL_WURTHELEKTRONIK_MODULE=y
# hostap (C:/ncs/v2.9.2/modules/lib/hostap)
# CONFIG_WIFI_NM_WPA_SUPPLICANT is not set
CONFIG_ZEPHYR_HOSTAP_MODULE=y
# end of hostap (C:/ncs/v2.9.2/modules/lib/hostap)
CONFIG_ZEPHYR_LIBMETAL_MODULE=y
# liblc3 (C:/ncs/v2.9.2/modules/lib/liblc3)
CONFIG_ZEPHYR_LIBLC3_MODULE=y
# end of liblc3 (C:/ncs/v2.9.2/modules/lib/liblc3)
# littlefs (C:/ncs/v2.9.2/modules/fs/littlefs)
CONFIG_ZEPHYR_LITTLEFS_MODULE=y
# end of littlefs (C:/ncs/v2.9.2/modules/fs/littlefs)
# loramac-node (C:/ncs/v2.9.2/modules/lib/loramac-node)
CONFIG_ZEPHYR_LORAMAC_NODE_MODULE=y
# CONFIG_HAS_SEMTECH_RADIO_DRIVERS is not set
# end of loramac-node (C:/ncs/v2.9.2/modules/lib/loramac-node)
# lvgl (C:/ncs/v2.9.2/modules/lib/gui/lvgl)
CONFIG_ZEPHYR_LVGL_MODULE=y
# end of lvgl (C:/ncs/v2.9.2/modules/lib/gui/lvgl)
CONFIG_ZEPHYR_MIPI_SYS_T_MODULE=y
# nrf_wifi (C:/ncs/v2.9.2/modules/lib/nrf_wifi)
CONFIG_ZEPHYR_NRF_WIFI_MODULE=y
# CONFIG_NRF70_BUSLIB is not set
# end of nrf_wifi (C:/ncs/v2.9.2/modules/lib/nrf_wifi)
CONFIG_ZEPHYR_OPEN_AMP_MODULE=y
# picolibc (C:/ncs/v2.9.2/modules/lib/picolibc)
# CONFIG_PICOLIBC_MODULE is not set
CONFIG_ZEPHYR_PICOLIBC_MODULE=y
# end of picolibc (C:/ncs/v2.9.2/modules/lib/picolibc)
# segger (C:/ncs/v2.9.2/modules/debug/segger)
CONFIG_ZEPHYR_SEGGER_MODULE=y
CONFIG_HAS_SEGGER_RTT=y
CONFIG_USE_SEGGER_RTT=y
CONFIG_SEGGER_RTT_CUSTOM_LOCKING=y
CONFIG_SEGGER_RTT_MAX_NUM_UP_BUFFERS=3
CONFIG_SEGGER_RTT_MAX_NUM_DOWN_BUFFERS=3
CONFIG_SEGGER_RTT_BUFFER_SIZE_UP=1024
CONFIG_SEGGER_RTT_BUFFER_SIZE_DOWN=16
CONFIG_SEGGER_RTT_PRINTF_BUFFER_SIZE=64
CONFIG_SEGGER_RTT_MODE_NO_BLOCK_SKIP=y
# CONFIG_SEGGER_RTT_MODE_NO_BLOCK_TRIM is not set
# CONFIG_SEGGER_RTT_MODE_BLOCK_IF_FIFO_FULL is not set
CONFIG_SEGGER_RTT_MODE=0
# CONFIG_SEGGER_RTT_MEMCPY_USE_BYTELOOP is not set
# CONFIG_SEGGER_RTT_SECTION_NONE is not set
# CONFIG_SEGGER_RTT_SECTION_DTCM is not set
# CONFIG_SEGGER_RTT_SECTION_CCM is not set
CONFIG_SEGGER_RTT_SECTION_CUSTOM=y
# CONFIG_SEGGER_RTT_SECTION_CUSTOM_DTS_REGION is not set
CONFIG_SEGGER_RTT_SECTION_CUSTOM_NAME=".rtt_buff_data"
# CONFIG_SEGGER_RTT_INIT_MODE_ALWAYS is not set
CONFIG_SEGGER_RTT_INIT_MODE_STRONG_CHECK=y
# CONFIG_SEGGER_RTT_INIT_MODE_WEAK_CHECK is not set
# end of segger (C:/ncs/v2.9.2/modules/debug/segger)
CONFIG_ZEPHYR_TINYCRYPT_MODULE=y
# uoscore-uedhoc (C:/ncs/v2.9.2/modules/lib/uoscore-uedhoc)
CONFIG_ZEPHYR_UOSCORE_UEDHOC_MODULE=y
# end of uoscore-uedhoc (C:/ncs/v2.9.2/modules/lib/uoscore-uedhoc)
# zcbor (C:/ncs/v2.9.2/modules/lib/zcbor)
CONFIG_ZEPHYR_ZCBOR_MODULE=y
CONFIG_ZCBOR=y
# CONFIG_ZCBOR_CANONICAL is not set
# CONFIG_ZCBOR_STOP_ON_ERROR is not set
# CONFIG_ZCBOR_VERBOSE is not set
CONFIG_ZCBOR_ASSERT=y
CONFIG_ZCBOR_MAX_STR_LEN=256
# end of zcbor (C:/ncs/v2.9.2/modules/lib/zcbor)
# nrfxlib (C:/ncs/v2.9.2/nrfxlib)
# Nordic nrfxlib
# nrf_modem (Modem library)
CONFIG_NRF_MODEM_SHMEM_CTRL_SIZE=0x4e8
# end of nrf_modem (Modem library)
# CONFIG_NFC_T2T_NRFXLIB is not set
# CONFIG_NFC_T4T_NRFXLIB is not set
# Crypto libraries for nRF5x SOCs.
CONFIG_NRFXLIB_CRYPTO=y
CONFIG_HAS_HW_NRF_CC3XX=y
# CONFIG_NRF_OBERON is not set
# CONFIG_NRF_CC310_BL is not set
CONFIG_NRF_CC3XX_PLATFORM=y
CONFIG_CC3XX_MUTEX_LOCK=y
# CONFIG_CC3XX_ATOMIC_LOCK is not set
# CONFIG_CC3XX_HW_MUTEX_LOCK is not set
# end of Crypto libraries for nRF5x SOCs.
# CONFIG_NRF_RPC is not set
CONFIG_NRF_802154_SOURCE_NRFXLIB=y
# CONFIG_GZLL is not set
# CONFIG_NRF_DM is not set
# CONFIG_NRF_FUEL_GAUGE is not set
# end of Nordic nrfxlib
CONFIG_ZEPHYR_NRFXLIB_MODULE=y
# end of nrfxlib (C:/ncs/v2.9.2/nrfxlib)
CONFIG_ZEPHYR_NRF_HW_MODELS_MODULE=y
# connectedhomeip (C:/ncs/v2.9.2/modules/lib/matter)
# CONFIG_CHIP is not set
CONFIG_ZEPHYR_CONNECTEDHOMEIP_MODULE=y
# end of connectedhomeip (C:/ncs/v2.9.2/modules/lib/matter)
CONFIG_LIBMETAL=y
CONFIG_LIBMETAL_SRC_PATH="libmetal"
# CONFIG_LVGL is not set
# CONFIG_HAS_MEC_HAL is not set
# CONFIG_HAS_MPFS_HAL is not set
# CONFIG_HAS_MEC5_HAL is not set
CONFIG_OPENAMP=y
CONFIG_OPENAMP_SRC_PATH="open-amp"
CONFIG_OPENAMP_MASTER=y
CONFIG_OPENAMP_SLAVE=y
# CONFIG_MIPI_SYST_LIB is not set
# CONFIG_HAS_TELINK_DRIVERS is not set
# CONFIG_TINYCRYPT_CTR_PRNG is not set
CONFIG_TINYCRYPT_SHA256=y
CONFIG_TINYCRYPT_SHA256_HMAC=y
CONFIG_TINYCRYPT_SHA256_HMAC_PRNG=y
# CONFIG_TINYCRYPT_ECC_DH is not set
# CONFIG_TINYCRYPT_ECC_DSA is not set
CONFIG_TINYCRYPT_AES=y
CONFIG_TINYCRYPT_AES_CBC=y
# CONFIG_TINYCRYPT_AES_CTR is not set
# CONFIG_TINYCRYPT_AES_CCM is not set
CONFIG_TINYCRYPT_AES_CMAC=y
CONFIG_MCUBOOT_CMAKE_WEST_SIGN_PARAMS="--quiet"
CONFIG_MCUBOOT_SIGNATURE_KEY_FILE="C:/ncs/v2.9.2/bootloader/mcuboot/root-ec-p256.pem"
CONFIG_MCUBOOT_ENCRYPTION_KEY_FILE=""
CONFIG_MCUBOOT_IMGTOOL_SIGN_VERSION="1.12.0+0"
CONFIG_MCUBOOT_IMGTOOL_OVERWRITE_ONLY=y
CONFIG_MCUBOOT_EXTRA_IMGTOOL_ARGS=""
# On board MCUboot operation mode
# CONFIG_MCUBOOT_BOOTLOADER_MODE_SINGLE_APP is not set
# CONFIG_MCUBOOT_BOOTLOADER_MODE_SWAP_WITHOUT_SCRATCH is not set
# CONFIG_MCUBOOT_BOOTLOADER_MODE_SWAP_SCRATCH is not set
CONFIG_MCUBOOT_BOOTLOADER_MODE_OVERWRITE_ONLY=y
# CONFIG_MCUBOOT_BOOTLOADER_MODE_DIRECT_XIP is not set
# CONFIG_MCUBOOT_BOOTLOADER_MODE_DIRECT_XIP_WITH_REVERT is not set
# CONFIG_MCUBOOT_BOOTLOADER_MODE_FIRMWARE_UPDATER is not set
CONFIG_MCUBOOT_BOOTLOADER_MODE_HAS_NO_DOWNGRADE=y
# CONFIG_MCUBOOT_BOOTLOADER_NO_DOWNGRADE is not set
# CONFIG_MCUBOOT_BOOTLOADER_USES_SHA512 is not set
# end of On board MCUboot operation mode
CONFIG_MCUBOOT_BOOTUTIL_LIB=y
CONFIG_MCUBOOT_BOOTUTIL_LIB_OWN_LOG=y
# CONFIG_MCUBOOT_UTIL_LOG_LEVEL_OFF is not set
# CONFIG_MCUBOOT_UTIL_LOG_LEVEL_ERR is not set
CONFIG_MCUBOOT_UTIL_LOG_LEVEL_WRN=y
# CONFIG_MCUBOOT_UTIL_LOG_LEVEL_INF is not set
# CONFIG_MCUBOOT_UTIL_LOG_LEVEL_DBG is not set
# CONFIG_MCUBOOT_UTIL_LOG_LEVEL_DEFAULT is not set
CONFIG_MCUBOOT_UTIL_LOG_LEVEL=2
CONFIG_BOOT_IMAGE_ACCESS_HOOKS=y
# Unavailable modules, please install those via the project manifest.
# hal_gigadevice module not available.
# Trusted-firmware-a module not available.
# THRIFT module not available.
# CONFIG_ACPI is not set
# end of Modules
CONFIG_BOARD="hg1_nrf5340"
CONFIG_BOARD_REVISION=""
CONFIG_BOARD_TARGET="hg1_nrf5340/nrf5340/cpuapp"
# CONFIG_NET_DRIVERS is not set
CONFIG_BOARD_HG1_NRF5340=y
CONFIG_BOARD_HG1_NRF5340_NRF5340_CPUAPP=y
CONFIG_BOARD_QUALIFIERS="nrf5340/cpuapp"
# Board Options
CONFIG_DOMAIN_CPUNET_BOARD="hg1_nrf5340/nrf5340/cpunet"
# end of Board Options
# Hardware Configuration
CONFIG_SOC_FAMILY_NORDIC_NRF=y
CONFIG_SOC_SERIES_NRF53X=y
CONFIG_SOC_NRF5340_CPUAPP=y
CONFIG_SOC_NRF5340_CPUAPP_QKAA=y
# CONFIG_BUILD_OUTPUT_INFO_HEADER is not set
CONFIG_HAS_HW_NRF_CC312=y
CONFIG_HAS_HW_NRF_CLOCK=y
CONFIG_HAS_HW_NRF_CTRLAP=y
CONFIG_HAS_HW_NRF_DCNF=y
CONFIG_HAS_HW_NRF_DPPIC=y
CONFIG_HAS_HW_NRF_EGU0=y
CONFIG_HAS_HW_NRF_EGU1=y
CONFIG_HAS_HW_NRF_EGU2=y
CONFIG_HAS_HW_NRF_EGU3=y
CONFIG_HAS_HW_NRF_EGU4=y
CONFIG_HAS_HW_NRF_EGU5=y
CONFIG_HAS_HW_NRF_GPIO0=y
CONFIG_HAS_HW_NRF_GPIO1=y
CONFIG_HAS_HW_NRF_GPIOTE0=y
CONFIG_HAS_HW_NRF_KMU=y
CONFIG_HAS_HW_NRF_MUTEX=y
CONFIG_HAS_HW_NRF_NVMC_PE=y
CONFIG_HAS_HW_NRF_OSCILLATORS=y
CONFIG_HAS_HW_NRF_POWER=y
CONFIG_HAS_HW_NRF_RESET=y
CONFIG_HAS_HW_NRF_SAADC=y
CONFIG_HAS_HW_NRF_SPIM4=y
CONFIG_HAS_HW_NRF_SPIS3=y
CONFIG_HAS_HW_NRF_SPU=y
CONFIG_HAS_HW_NRF_TIMER0=y
CONFIG_HAS_HW_NRF_TIMER1=y
CONFIG_HAS_HW_NRF_TIMER2=y
CONFIG_HAS_HW_NRF_TWIM0=y
CONFIG_HAS_HW_NRF_TWIM2=y
CONFIG_HAS_HW_NRF_USBREG=y
CONFIG_HAS_HW_NRF_VMC=y
CONFIG_HAS_HW_NRF_WDT0=y
# CONFIG_HAS_NORDIC_RAM_CTRL is not set
# CONFIG_NRF_SYS_EVENT is not set
CONFIG_SOC_NRF53_ANOMALY_160_WORKAROUND_NEEDED=y
CONFIG_SOC_NRF53_ANOMALY_160_WORKAROUND=y
CONFIG_SOC_NRF53_ANOMALY_168_WORKAROUND=y
# CONFIG_SOC_NRF53_ANOMALY_168_WORKAROUND_FOR_EXECUTION_FROM_RAM is not set
CONFIG_SOC_NRF53_RTC_PRETICK=y
CONFIG_SOC_NRF53_RTC_PRETICK_IPC_CH_FROM_NET=10
CONFIG_SOC_NRF53_RTC_PRETICK_IPC_CH_TO_NET=11
CONFIG_NRF_SPU_RAM_REGION_SIZE=0x2000
# CONFIG_SOC_NRF_GPIO_FORWARDER_FOR_NRF5340 is not set
CONFIG_SOC_NRF53_CPUNET_MGMT=y
CONFIG_SOC_NRF53_CPUNET_ENABLE=y
# CONFIG_BOARD_ENABLE_CPUNET is not set
CONFIG_SOC_ENABLE_LFXO=y
# CONFIG_SOC_LFXO_CAP_EXTERNAL is not set
# CONFIG_SOC_LFXO_CAP_INT_6PF is not set
CONFIG_SOC_LFXO_CAP_INT_7PF=y
# CONFIG_SOC_LFXO_CAP_INT_9PF is not set
CONFIG_SOC_HFXO_CAP_DEFAULT=y
# CONFIG_SOC_HFXO_CAP_EXTERNAL is not set
# CONFIG_SOC_HFXO_CAP_INTERNAL is not set
CONFIG_NRF_ENABLE_CACHE=y
CONFIG_NRF53_SYNC_RTC=y
# CONFIG_SYNC_RTC_LOG_LEVEL_OFF is not set
# CONFIG_SYNC_RTC_LOG_LEVEL_ERR is not set
# CONFIG_SYNC_RTC_LOG_LEVEL_WRN is not set
# CONFIG_SYNC_RTC_LOG_LEVEL_INF is not set
# CONFIG_SYNC_RTC_LOG_LEVEL_DBG is not set
CONFIG_SYNC_RTC_LOG_LEVEL_DEFAULT=y
CONFIG_SYNC_RTC_LOG_LEVEL=3
CONFIG_NRF53_SYNC_RTC_INIT_PRIORITY=90
CONFIG_NRF_RTC_TIMER_USER_CHAN_COUNT=1
CONFIG_NRF53_SYNC_RTC_LOG_TIMESTAMP=y
CONFIG_NRF53_SYNC_RTC_IPM_OUT=7
CONFIG_NRF53_SYNC_RTC_IPM_IN=8
CONFIG_IPM_MSG_CH_8_ENABLE=y
CONFIG_IPM_MSG_CH_8_RX=y
# CONFIG_SOC_NRF54H20_GPD is not set
# CONFIG_SOC_NRF54H20_NO_MRAM_LATENCY is not set
CONFIG_NRF_SOC_SECURE_SUPPORTED=y
# CONFIG_NFCT_PINS_AS_GPIOS is not set
CONFIG_NRF_APPROTECT_USE_UICR=y
# CONFIG_NRF_APPROTECT_LOCK is not set
# CONFIG_NRF_APPROTECT_USER_HANDLING is not set
CONFIG_NRF_SECURE_APPROTECT_USE_UICR=y
# CONFIG_NRF_SECURE_APPROTECT_LOCK is not set
# CONFIG_NRF_SECURE_APPROTECT_USER_HANDLING is not set
# CONFIG_NRF_TRACE_PORT is not set
CONFIG_GPIO_INIT_PRIORITY=40
# CONFIG_SOC_LOG_LEVEL_OFF is not set
# CONFIG_SOC_LOG_LEVEL_ERR is not set
# CONFIG_SOC_LOG_LEVEL_WRN is not set
# CONFIG_SOC_LOG_LEVEL_INF is not set
# CONFIG_SOC_LOG_LEVEL_DBG is not set
CONFIG_SOC_LOG_LEVEL_DEFAULT=y
CONFIG_SOC_LOG_LEVEL=3
# end of Hardware Configuration
CONFIG_SOC_COMPATIBLE_NRF=y
CONFIG_SOC_COMPATIBLE_NRF53X=y
CONFIG_SOC_COMPATIBLE_NRF5340_CPUAPP=y
CONFIG_ARCH="arm"
# CONFIG_EXTRA_EXCEPTION_INFO is not set
CONFIG_ARCH_HAS_SINGLE_THREAD_SUPPORT=y
CONFIG_CPU_CORTEX=y
CONFIG_KOBJECT_TEXT_AREA=256
CONFIG_ARM_MPU=y
CONFIG_ARM_MPU_REGION_MIN_ALIGN_AND_SIZE=32
CONFIG_MPU_ALLOW_FLASH_WRITE=y
# ARM Options
CONFIG_ARM_ON_ENTER_CPU_IDLE_HOOK=y
CONFIG_ARM_ON_EXIT_CPU_IDLE=y
CONFIG_CPU_CORTEX_M=y
# CONFIG_ARM_ZIMAGE_HEADER is not set
CONFIG_ISA_THUMB2=y
CONFIG_ASSEMBLER_ISA_THUMB2=y
CONFIG_COMPILER_ISA_THUMB2=y
CONFIG_STACK_ALIGN_DOUBLE_WORD=y
# CONFIG_RUNTIME_NMI is not set
# CONFIG_PLATFORM_SPECIFIC_INIT is not set
CONFIG_FAULT_DUMP=2
CONFIG_BUILTIN_STACK_GUARD=y
CONFIG_ARM_STACK_PROTECTION=y
CONFIG_FP16=y
CONFIG_FP16_IEEE=y
# CONFIG_FP16_ALT is not set
CONFIG_CPU_CORTEX_M33=y
CONFIG_CPU_CORTEX_M_HAS_SYSTICK=y
CONFIG_CPU_CORTEX_M_HAS_DWT=y
CONFIG_CPU_CORTEX_M_HAS_BASEPRI=y
CONFIG_CPU_CORTEX_M_HAS_VTOR=y
CONFIG_CPU_CORTEX_M_HAS_SPLIM=y
CONFIG_CPU_CORTEX_M_HAS_PROGRAMMABLE_FAULT_PRIOS=y
CONFIG_CPU_CORTEX_M_HAS_CMSE=y
CONFIG_ARMV7_M_ARMV8_M_MAINLINE=y
CONFIG_ARMV8_M_MAINLINE=y
CONFIG_ARMV8_M_SE=y
CONFIG_ARMV7_M_ARMV8_M_FP=y
CONFIG_ARMV8_M_DSP=y
# ARM Cortex-M0/M0+/M1/M3/M4/M7/M23/M33/M55 options
# CONFIG_ZERO_LATENCY_IRQS is not set
# CONFIG_SW_VECTOR_RELAY is not set
# CONFIG_CORTEX_M_DWT is not set
# CONFIG_CORTEX_M_DEBUG_MONITOR_HOOK is not set
# CONFIG_TRAP_UNALIGNED_ACCESS is not set
# end of ARM Cortex-M0/M0+/M1/M3/M4/M7/M23/M33/M55 options
CONFIG_NULL_POINTER_EXCEPTION_DETECTION_NONE=y
# CONFIG_NULL_POINTER_EXCEPTION_DETECTION_DWT is not set
# CONFIG_NULL_POINTER_EXCEPTION_DETECTION_MPU is not set
CONFIG_ARM_TRUSTZONE_M=y
# CONFIG_MPU_STACK_GUARD is not set
# CONFIG_MPU_DISABLE_BACKGROUND_MAP is not set
# CONFIG_CUSTOM_SECTION_ALIGN is not set
CONFIG_CUSTOM_SECTION_MIN_ALIGN_SIZE=32
CONFIG_CPU_HAS_NRF_IDAU=y
CONFIG_HAS_SWO=y
# end of ARM Options
CONFIG_ARM=y
CONFIG_ARCH_IS_SET=y
# General Architecture Options
# CONFIG_SEMIHOST is not set
# CONFIG_ARCH_LOG_LEVEL_OFF is not set
# CONFIG_ARCH_LOG_LEVEL_ERR is not set
# CONFIG_ARCH_LOG_LEVEL_WRN is not set
# CONFIG_ARCH_LOG_LEVEL_INF is not set
# CONFIG_ARCH_LOG_LEVEL_DBG is not set
CONFIG_ARCH_LOG_LEVEL_DEFAULT=y
CONFIG_ARCH_LOG_LEVEL=3
CONFIG_LITTLE_ENDIAN=y
# CONFIG_TRUSTED_EXECUTION_SECURE is not set
# CONFIG_TRUSTED_EXECUTION_NONSECURE is not set
# CONFIG_USERSPACE is not set
CONFIG_KOBJECT_DATA_AREA_RESERVE_EXTRA_PERCENT=100
CONFIG_KOBJECT_RODATA_AREA_EXTRA_BYTES=16
CONFIG_GEN_PRIV_STACKS=y
# CONFIG_STACK_GROWS_UP is not set
# CONFIG_FRAME_POINTER is not set
# Interrupt Configuration
CONFIG_ISR_TABLES_LOCAL_DECLARATION_SUPPORTED=y
# CONFIG_ISR_TABLES_LOCAL_DECLARATION is not set
CONFIG_IRQ_VECTOR_TABLE_JUMP_BY_ADDRESS=y
# CONFIG_IRQ_VECTOR_TABLE_JUMP_BY_CODE is not set
CONFIG_EXCEPTION_DEBUG=y
# CONFIG_SIMPLIFIED_EXCEPTION_CODES is not set
# end of Interrupt Configuration
# end of General Architecture Options
CONFIG_ARCH_HAS_TIMING_FUNCTIONS=y
CONFIG_ARCH_HAS_TRUSTED_EXECUTION=y
CONFIG_ARCH_HAS_STACK_PROTECTION=y
CONFIG_ARCH_HAS_USERSPACE=y
CONFIG_ARCH_HAS_EXECUTABLE_PAGE_BIT=y
CONFIG_ARCH_HAS_RAMFUNC_SUPPORT=y
CONFIG_ARCH_HAS_NESTED_EXCEPTION_DETECTION=y
CONFIG_ARCH_SUPPORTS_COREDUMP=y
CONFIG_ARCH_SUPPORTS_COREDUMP_THREADS=y
CONFIG_ARCH_SUPPORTS_ARCH_HW_INIT=y
CONFIG_ARCH_SUPPORTS_ROM_START=y
CONFIG_ARCH_HAS_EXTRA_EXCEPTION_INFO=y
CONFIG_ARCH_HAS_THREAD_LOCAL_STORAGE=y
CONFIG_ARCH_HAS_SUSPEND_TO_RAM=y
CONFIG_ARCH_HAS_THREAD_ABORT=y
CONFIG_ARCH_HAS_CODE_DATA_RELOCATION=y
CONFIG_CPU_HAS_TEE=y
CONFIG_CPU_HAS_FPU=y
CONFIG_CPU_HAS_MPU=y
CONFIG_MPU=y
# CONFIG_MPU_LOG_LEVEL_OFF is not set
# CONFIG_MPU_LOG_LEVEL_ERR is not set
# CONFIG_MPU_LOG_LEVEL_WRN is not set
# CONFIG_MPU_LOG_LEVEL_INF is not set
# CONFIG_MPU_LOG_LEVEL_DBG is not set
CONFIG_MPU_LOG_LEVEL_DEFAULT=y
CONFIG_MPU_LOG_LEVEL=3
CONFIG_MPU_REQUIRES_NON_OVERLAPPING_REGIONS=y
CONFIG_MPU_GAP_FILLING=y
CONFIG_SRAM_REGION_PERMISSIONS=y
# DSP Options
# end of DSP Options
# Floating Point Options
# end of Floating Point Options
# Cache Options
# end of Cache Options
CONFIG_TOOLCHAIN_HAS_BUILTIN_FFS=y
CONFIG_ARCH_HAS_CUSTOM_SWAP_TO_MAIN=y
# General Kernel Options
# CONFIG_KERNEL_LOG_LEVEL_OFF is not set
# CONFIG_KERNEL_LOG_LEVEL_ERR is not set
# CONFIG_KERNEL_LOG_LEVEL_WRN is not set
# CONFIG_KERNEL_LOG_LEVEL_INF is not set
# CONFIG_KERNEL_LOG_LEVEL_DBG is not set
CONFIG_KERNEL_LOG_LEVEL_DEFAULT=y
CONFIG_KERNEL_LOG_LEVEL=3
CONFIG_MULTITHREADING=y
CONFIG_NUM_COOP_PRIORITIES=16
CONFIG_NUM_PREEMPT_PRIORITIES=15
CONFIG_MAIN_THREAD_PRIORITY=-1
CONFIG_COOP_ENABLED=y
CONFIG_PREEMPT_ENABLED=y
CONFIG_PRIORITY_CEILING=-127
# CONFIG_SCHED_DEADLINE is not set
CONFIG_THREAD_STACK_INFO=y
# CONFIG_THREAD_CUSTOM_DATA is not set
# CONFIG_DYNAMIC_THREAD is not set
CONFIG_SCHED_DUMB=y
# CONFIG_SCHED_SCALABLE is not set
# CONFIG_SCHED_MULTIQ is not set
# CONFIG_WAITQ_SCALABLE is not set
CONFIG_WAITQ_DUMB=y
# Misc Kernel related options
CONFIG_LIBC_ERRNO=y
CONFIG_ERRNO=y
CONFIG_CURRENT_THREAD_USE_TLS=y
# end of Misc Kernel related options
# Kernel Debugging and Metrics
CONFIG_BOOT_DELAY=0
# CONFIG_BOOT_CLEAR_SCREEN is not set
CONFIG_THREAD_MONITOR=y
CONFIG_THREAD_NAME=y
CONFIG_THREAD_MAX_NAME_LEN=32
# CONFIG_THREAD_RUNTIME_STATS is not set
# end of Kernel Debugging and Metrics
# CONFIG_OBJ_CORE is not set
# System Work Queue Options
# CONFIG_SYSTEM_WORKQUEUE_NO_YIELD is not set
# end of System Work Queue Options
# Barrier Operations
CONFIG_BARRIER_OPERATIONS_ARCH=y
# end of Barrier Operations
# Atomic Operations
CONFIG_ATOMIC_OPERATIONS_BUILTIN=y
# end of Atomic Operations
# Timer API Options
CONFIG_TIMESLICING=y
CONFIG_TIMESLICE_PRIORITY=0
# CONFIG_TIMESLICE_PER_THREAD is not set
# end of Timer API Options
# Other Kernel Object Options
CONFIG_POLL=y
# CONFIG_MEM_SLAB_TRACE_MAX_UTILIZATION is not set
CONFIG_NUM_MBOX_ASYNC_MSGS=10
# CONFIG_EVENTS is not set
# CONFIG_PIPES is not set
CONFIG_KERNEL_MEM_POOL=y
# CONFIG_HEAP_MEM_POOL_IGNORE_MIN is not set
# end of Other Kernel Object Options
CONFIG_SWAP_NONATOMIC=y
CONFIG_SYS_CLOCK_EXISTS=y
CONFIG_TIMEOUT_64BIT=y
CONFIG_SYS_CLOCK_MAX_TIMEOUT_DAYS=365
# Security Options
# CONFIG_STACK_CANARIES is not set
CONFIG_STACK_POINTER_RANDOM=0
# end of Security Options
# Memory Domains
CONFIG_ARCH_MEM_DOMAIN_SUPPORTS_ISOLATED_STACKS=y
CONFIG_MEM_DOMAIN_ISOLATED_STACKS=y
# end of Memory Domains
# SMP Options
CONFIG_MP_NUM_CPUS=1
# CONFIG_TICKET_SPINLOCKS is not set
# end of SMP Options
CONFIG_TOOLCHAIN_SUPPORTS_THREAD_LOCAL_STORAGE=y
CONFIG_THREAD_LOCAL_STORAGE=y
CONFIG_TOOLCHAIN_SUPPORTS_STATIC_INIT_GNU=y
# CONFIG_STATIC_INIT_GNU is not set
# CONFIG_BOOTARGS is not set
# end of General Kernel Options
# Device Options
# CONFIG_DEVICE_DEPS is not set
# CONFIG_DEVICE_MUTABLE is not set
# CONFIG_DEVICE_DT_METADATA is not set
# end of Device Options
# Initialization Priorities
CONFIG_KERNEL_INIT_PRIORITY_OBJECTS=30
CONFIG_KERNEL_INIT_PRIORITY_LIBC=35
CONFIG_KERNEL_INIT_PRIORITY_DEFAULT=40
CONFIG_KERNEL_INIT_PRIORITY_DEVICE=50
CONFIG_APPLICATION_INIT_PRIORITY=90
# end of Initialization Priorities
# Virtual Memory Support
# end of Virtual Memory Support
# SoC and Board Hooks
# CONFIG_SOC_PREP_HOOK is not set
# CONFIG_SOC_EARLY_INIT_HOOK is not set
# CONFIG_SOC_LATE_INIT_HOOK is not set
# CONFIG_BOARD_EARLY_INIT_HOOK is not set
# CONFIG_BOARD_LATE_INIT_HOOK is not set
# end of SoC and Board Hooks
# Device Drivers
# CONFIG_ADC is not set
# CONFIG_AUDIO is not set
# CONFIG_AUXDISPLAY is not set
# CONFIG_BBRAM is not set
# Bluetooth HCI Driver Options
CONFIG_BT_HCI_INIT_PRIORITY=50
# CONFIG_HCI_NXP_SET_CAL_DATA_ANNEX100 is not set
CONFIG_FLASH=y
CONFIG_BT_DRV_TX_STACK_SIZE=256
CONFIG_BT_DRV_RX_STACK_SIZE=256
# CONFIG_CAN is not set
# CONFIG_CHARGER is not set
# CONFIG_CLOCK_CONTROL_LOG_LEVEL_OFF is not set
# CONFIG_CLOCK_CONTROL_LOG_LEVEL_ERR is not set
# CONFIG_CLOCK_CONTROL_LOG_LEVEL_WRN is not set
# CONFIG_CLOCK_CONTROL_LOG_LEVEL_INF is not set
# CONFIG_CLOCK_CONTROL_LOG_LEVEL_DBG is not set
CONFIG_CLOCK_CONTROL_LOG_LEVEL_DEFAULT=y
CONFIG_CLOCK_CONTROL_LOG_LEVEL=3
CONFIG_CLOCK_CONTROL_NRF=y
# CONFIG_CLOCK_CONTROL_NRF_K32SRC_RC is not set
CONFIG_CLOCK_CONTROL_NRF_K32SRC_XTAL=y
# CONFIG_CLOCK_CONTROL_NRF_K32SRC_SYNTH is not set
# CONFIG_CLOCK_CONTROL_NRF_K32SRC_500PPM is not set
# CONFIG_CLOCK_CONTROL_NRF_K32SRC_250PPM is not set
# CONFIG_CLOCK_CONTROL_NRF_K32SRC_150PPM is not set
# CONFIG_CLOCK_CONTROL_NRF_K32SRC_100PPM is not set
# CONFIG_CLOCK_CONTROL_NRF_K32SRC_75PPM is not set
CONFIG_CLOCK_CONTROL_NRF_K32SRC_50PPM=y
# CONFIG_CLOCK_CONTROL_NRF_K32SRC_30PPM is not set
# CONFIG_CLOCK_CONTROL_NRF_K32SRC_20PPM is not set
CONFIG_CLOCK_CONTROL_NRF_ACCURACY=50
# CONFIG_CLOCK_CONTROL_FIXED_RATE_CLOCK is not set
# CONFIG_COMPARATOR is not set
# CONFIG_COREDUMP_DEVICE is not set
# CONFIG_CRYPTO is not set
# CONFIG_DAC is not set
# CONFIG_DAI is not set
# CONFIG_DISK_DRIVERS is not set
# CONFIG_DISPLAY is not set
# CONFIG_DMA is not set
# CONFIG_DP_DRIVER is not set
# CONFIG_EDAC is not set
# CONFIG_EEPROM is not set
CONFIG_ENTROPY_GENERATOR=y
# CONFIG_ENTROPY_LOG_LEVEL_OFF is not set
# CONFIG_ENTROPY_LOG_LEVEL_ERR is not set
# CONFIG_ENTROPY_LOG_LEVEL_WRN is not set
# CONFIG_ENTROPY_LOG_LEVEL_INF is not set
# CONFIG_ENTROPY_LOG_LEVEL_DBG is not set
CONFIG_ENTROPY_LOG_LEVEL_DEFAULT=y
CONFIG_ENTROPY_LOG_LEVEL=3
CONFIG_ENTROPY_BT_HCI=y
CONFIG_ENTROPY_HAS_DRIVER=y
# CONFIG_ESPI is not set
# Firmware drivers
# CONFIG_ARM_SCMI is not set
# end of Firmware drivers
CONFIG_FLASH_HAS_DRIVER_ENABLED=y
CONFIG_FLASH_HAS_EX_OP=y
CONFIG_FLASH_HAS_EXPLICIT_ERASE=y
CONFIG_FLASH_HAS_PAGE_LAYOUT=y
CONFIG_FLASH_JESD216=y
# CONFIG_FLASH_JESD216_API is not set
CONFIG_FLASH_PAGE_LAYOUT=y
# CONFIG_FLASH_EX_OP_ENABLED is not set
CONFIG_SOC_FLASH_NRF=y
CONFIG_SOC_FLASH_NRF_RADIO_SYNC_NONE=y
# CONFIG_SOC_FLASH_NRF_PARTIAL_ERASE is not set
CONFIG_SOC_FLASH_NRF_UICR=y
# CONFIG_SOC_FLASH_NRF_EMULATE_ONE_BYTE_WRITE_ACCESS is not set
# MSPI flash device driver
# end of MSPI flash device driver
# CONFIG_SPI_NOR_SFDP_MINIMAL is not set
CONFIG_SPI_NOR_SFDP_DEVICETREE=y
# CONFIG_SPI_NOR_SFDP_RUNTIME is not set
CONFIG_SPI_NOR_INIT_PRIORITY=80
CONFIG_SPI_NOR_CS_WAIT_DELAY=0
CONFIG_SPI_NOR_SLEEP_WHILE_WAITING_UNTIL_READY=y
CONFIG_SPI_NOR_FLASH_LAYOUT_PAGE_SIZE=4096
# CONFIG_FLASH_LOG_LEVEL_OFF is not set
# CONFIG_FLASH_LOG_LEVEL_ERR is not set
# CONFIG_FLASH_LOG_LEVEL_WRN is not set
# CONFIG_FLASH_LOG_LEVEL_INF is not set
# CONFIG_FLASH_LOG_LEVEL_DBG is not set
CONFIG_FLASH_LOG_LEVEL_DEFAULT=y
CONFIG_FLASH_LOG_LEVEL=3
# CONFIG_FPGA is not set
# CONFIG_FUEL_GAUGE is not set
# CONFIG_GNSS is not set
# CONFIG_GPIO_LOG_LEVEL_OFF is not set
# CONFIG_GPIO_LOG_LEVEL_ERR is not set
# CONFIG_GPIO_LOG_LEVEL_WRN is not set
# CONFIG_GPIO_LOG_LEVEL_INF is not set
# CONFIG_GPIO_LOG_LEVEL_DBG is not set
CONFIG_GPIO_LOG_LEVEL_DEFAULT=y
CONFIG_GPIO_LOG_LEVEL=3
# CONFIG_GPIO_GET_DIRECTION is not set
# CONFIG_GPIO_GET_CONFIG is not set
# CONFIG_GPIO_HOGS is not set
# CONFIG_GPIO_ENABLE_DISABLE_INTERRUPT is not set
CONFIG_GPIO_NRFX=y
CONFIG_GPIO_NRFX_INTERRUPT=y
# CONFIG_HAPTICS is not set
# CONFIG_HWINFO is not set
# CONFIG_HWSPINLOCK is not set
# CONFIG_I2C_CALLBACK is not set
# CONFIG_I2C_RTIO is not set
# CONFIG_I2C_TARGET is not set
CONFIG_I2C_NRFX=y
CONFIG_I2C_NRFX_TWIM=y
CONFIG_I2C_NRFX_TRANSFER_TIMEOUT=500
CONFIG_I2C_INIT_PRIORITY=50
# CONFIG_I2C_LOG_LEVEL_OFF is not set
# CONFIG_I2C_LOG_LEVEL_ERR is not set
# CONFIG_I2C_LOG_LEVEL_WRN is not set
# CONFIG_I2C_LOG_LEVEL_INF is not set
# CONFIG_I2C_LOG_LEVEL_DBG is not set
CONFIG_I2C_LOG_LEVEL_DEFAULT=y
CONFIG_I2C_LOG_LEVEL=3
# CONFIG_I2S is not set
# CONFIG_I3C is not set
# Interrupt controller drivers
CONFIG_INTC_INIT_PRIORITY=40
# CONFIG_INTC_LOG_LEVEL_OFF is not set
# CONFIG_INTC_LOG_LEVEL_ERR is not set
# CONFIG_INTC_LOG_LEVEL_WRN is not set
# CONFIG_INTC_LOG_LEVEL_INF is not set
# CONFIG_INTC_LOG_LEVEL_DBG is not set
CONFIG_INTC_LOG_LEVEL_DEFAULT=y
CONFIG_INTC_LOG_LEVEL=3
# end of Interrupt controller drivers
# CONFIG_IPM is not set
# CONFIG_KSCAN is not set
# CONFIG_LED is not set
# CONFIG_LED_STRIP is not set
# CONFIG_LORA is not set
CONFIG_MBOX=y
CONFIG_MBOX_NRFX_IPC=y
CONFIG_MBOX_INIT_PRIORITY=40
# CONFIG_MBOX_LOG_LEVEL_OFF is not set
# CONFIG_MBOX_LOG_LEVEL_ERR is not set
# CONFIG_MBOX_LOG_LEVEL_WRN is not set
# CONFIG_MBOX_LOG_LEVEL_INF is not set
# CONFIG_MBOX_LOG_LEVEL_DBG is not set
CONFIG_MBOX_LOG_LEVEL_DEFAULT=y
CONFIG_MBOX_LOG_LEVEL=3
# CONFIG_MDIO is not set
# CONFIG_MIPI_DBI is not set
# Miscellaneous Drivers
# CONFIG_TIMEAWARE_GPIO is not set
# end of Miscellaneous Drivers
# CONFIG_MM_DRV is not set
# CONFIG_MSPI is not set
# CONFIG_PCIE is not set
# CONFIG_PCIE_ENDPOINT is not set
# CONFIG_PECI is not set
# CONFIG_PINCTRL_LOG_LEVEL_OFF is not set
# CONFIG_PINCTRL_LOG_LEVEL_ERR is not set
# CONFIG_PINCTRL_LOG_LEVEL_WRN is not set
# CONFIG_PINCTRL_LOG_LEVEL_INF is not set
# CONFIG_PINCTRL_LOG_LEVEL_DBG is not set
CONFIG_PINCTRL_LOG_LEVEL_DEFAULT=y
CONFIG_PINCTRL_LOG_LEVEL=3
CONFIG_PINCTRL_STORE_REG=y
# CONFIG_PINCTRL_DYNAMIC is not set
CONFIG_PINCTRL_NRF=y
# CONFIG_PM_CPU_OPS is not set
# CONFIG_PS2 is not set
# CONFIG_PTP_CLOCK is not set
# CONFIG_PWM is not set
# CONFIG_RETAINED_MEM is not set
# CONFIG_RTC is not set
# CONFIG_SDHC is not set
# CONFIG_SMBUS is not set
CONFIG_SPI_ASYNC=y
# CONFIG_SPI_RTIO is not set
CONFIG_SPI_SLAVE=y
# CONFIG_SPI_EXTENDED_MODES is not set
CONFIG_SPI_INIT_PRIORITY=50
CONFIG_SPI_COMPLETION_TIMEOUT_TOLERANCE=200
# CONFIG_SPI_LOG_LEVEL_OFF is not set
# CONFIG_SPI_LOG_LEVEL_ERR is not set
# CONFIG_SPI_LOG_LEVEL_WRN is not set
# CONFIG_SPI_LOG_LEVEL_INF is not set
# CONFIG_SPI_LOG_LEVEL_DBG is not set
CONFIG_SPI_LOG_LEVEL_DEFAULT=y
CONFIG_SPI_LOG_LEVEL=3
CONFIG_SPI_NRFX=y
CONFIG_SPI_NRFX_SPIM=y
CONFIG_SPI_NRFX_SPIS=y
CONFIG_SPI_NRFX_RAM_BUFFER_SIZE=8
CONFIG_SPI_NRFX_WAKE_TIMEOUT_US=200
# CONFIG_STEPPER is not set
# Timer drivers
# CONFIG_TIMER_READS_ITS_FREQUENCY_AT_RUNTIME is not set
# CONFIG_SYSTEM_CLOCK_SLOPPY_IDLE is not set
CONFIG_SYSTEM_CLOCK_INIT_PRIORITY=0
CONFIG_TICKLESS_CAPABLE=y
CONFIG_SYSTEM_TIMER_HAS_DISABLE_SUPPORT=y
# CONFIG_NRF_RTC_TIMER_TRIGGER_OVERFLOW is not set
# CONFIG_SYSTEM_CLOCK_NO_WAIT is not set
# CONFIG_SYSTEM_CLOCK_WAIT_FOR_AVAILABILITY is not set
CONFIG_SYSTEM_CLOCK_WAIT_FOR_STABILITY=y
# end of Timer drivers
# CONFIG_USB_BC12 is not set
# CONFIG_UDC_DRIVER is not set
# CONFIG_UHC_DRIVER is not set
# CONFIG_UVB is not set
# CONFIG_USB_DEVICE_DRIVER is not set
# CONFIG_NRF_USBD_COMMON_LOG_LEVEL_OFF is not set
# CONFIG_NRF_USBD_COMMON_LOG_LEVEL_ERR is not set
# CONFIG_NRF_USBD_COMMON_LOG_LEVEL_WRN is not set
# CONFIG_NRF_USBD_COMMON_LOG_LEVEL_INF is not set
# CONFIG_NRF_USBD_COMMON_LOG_LEVEL_DBG is not set
CONFIG_NRF_USBD_COMMON_LOG_LEVEL_DEFAULT=y
CONFIG_NRF_USBD_COMMON_LOG_LEVEL=3
# CONFIG_NRF_USBD_COMMON is not set
# CONFIG_USBC_TCPC_DRIVER is not set
# CONFIG_USBC_LOG_LEVEL_OFF is not set
# CONFIG_USBC_LOG_LEVEL_ERR is not set
# CONFIG_USBC_LOG_LEVEL_WRN is not set
# CONFIG_USBC_LOG_LEVEL_INF is not set
# CONFIG_USBC_LOG_LEVEL_DBG is not set
CONFIG_USBC_LOG_LEVEL_DEFAULT=y
CONFIG_USBC_LOG_LEVEL=3
# CONFIG_USBC_VBUS_DRIVER is not set
# CONFIG_USBC_PPC_DRIVER is not set
# CONFIG_VIDEO is not set
# CONFIG_VIRTUALIZATION is not set
# CONFIG_W1 is not set
# CONFIG_WDT_LOG_LEVEL_OFF is not set
# CONFIG_WDT_LOG_LEVEL_ERR is not set
# CONFIG_WDT_LOG_LEVEL_WRN is not set
# CONFIG_WDT_LOG_LEVEL_INF is not set
# CONFIG_WDT_LOG_LEVEL_DBG is not set
CONFIG_WDT_LOG_LEVEL_DEFAULT=y
CONFIG_WDT_LOG_LEVEL=3
CONFIG_WDT_NRFX=y
# CONFIG_WDT_NRFX_NO_IRQ is not set
# CONFIG_TEE is not set
# CONFIG_REQUIRES_FULL_LIBC is not set
# CONFIG_REQUIRES_FLOAT_PRINTF is not set
CONFIG_FULL_LIBC_SUPPORTED=y
CONFIG_MINIMAL_LIBC_SUPPORTED=y
CONFIG_NEWLIB_LIBC_SUPPORTED=y
CONFIG_PICOLIBC_SUPPORTED=y
# C Library
# CONFIG_MINIMAL_LIBC is not set
CONFIG_PICOLIBC=y
# CONFIG_NEWLIB_LIBC is not set
# CONFIG_EXTERNAL_LIBC is not set
CONFIG_HAS_NEWLIB_LIBC_NANO=y
CONFIG_COMMON_LIBC_ABORT=y
# CONFIG_COMMON_LIBC_ASCTIME_R is not set
# CONFIG_COMMON_LIBC_CTIME_R is not set
CONFIG_COMMON_LIBC_MALLOC=y
CONFIG_COMMON_LIBC_CALLOC=y
CONFIG_COMMON_LIBC_REALLOCARRAY=y
# CONFIG_COMMON_LIBC_REMOVE is not set
# CONFIG_PICOLIBC_USE_MODULE is not set
CONFIG_PICOLIBC_USE_TOOLCHAIN=y
CONFIG_PICOLIBC_IO_FLOAT=y
CONFIG_NEED_LIBC_MEM_PARTITION=y
# end of C Library
# C++ Language Support
# CONFIG_CPP is not set
# end of C++ Language Support
CONFIG_CRC=y
# Additional libraries
# Hash Function Support
# CONFIG_SYS_HASH_FUNC32 is not set
# end of Hash Function Support
# Hashmap (Hash Table) Support
# CONFIG_SYS_HASH_MAP is not set
# end of Hashmap (Hash Table) Support
# Heap and Memory Allocation
# CONFIG_SYS_HEAP_VALIDATE is not set
# CONFIG_SYS_HEAP_STRESS is not set
# CONFIG_SYS_HEAP_INFO is not set
CONFIG_SYS_HEAP_ALLOC_LOOPS=3
# CONFIG_SYS_HEAP_RUNTIME_STATS is not set
# CONFIG_SYS_HEAP_LISTENER is not set
# CONFIG_SYS_HEAP_SMALL_ONLY is not set
# CONFIG_SYS_HEAP_BIG_ONLY is not set
CONFIG_SYS_HEAP_AUTO=y
# CONFIG_MULTI_HEAP is not set
# CONFIG_SHARED_MULTI_HEAP is not set
# end of Heap and Memory Allocation
# Memory Blocks
# CONFIG_SYS_MEM_BLOCKS is not set
# end of Memory Blocks
CONFIG_NET_BUF=y
# CONFIG_NET_BUF_LOG is not set
# CONFIG_NET_BUF_LOG_LEVEL_OFF is not set
# CONFIG_NET_BUF_LOG_LEVEL_ERR is not set
# CONFIG_NET_BUF_LOG_LEVEL_WRN is not set
# CONFIG_NET_BUF_LOG_LEVEL_INF is not set
# CONFIG_NET_BUF_LOG_LEVEL_DBG is not set
CONFIG_NET_BUF_LOG_LEVEL_DEFAULT=y
CONFIG_NET_BUF_LOG_LEVEL=3
# CONFIG_NET_BUF_POOL_USAGE is not set
CONFIG_NET_BUF_ALIGNMENT=0
# OS Support Library
# CONFIG_FDTABLE is not set
CONFIG_ZVFS_OPEN_MAX=4
# CONFIG_PRINTK_SYNC is not set
CONFIG_MPSC_PBUF=y
# CONFIG_SPSC_PBUF is not set
# CONFIG_MPSC_CLEAR_ALLOCATED is not set
CONFIG_HAS_POWEROFF=y
CONFIG_POWEROFF=y
CONFIG_CBPRINTF_COMPLETE=y
# CONFIG_CBPRINTF_NANO is not set
CONFIG_CBPRINTF_FULL_INTEGRAL=y
# CONFIG_CBPRINTF_REDUCED_INTEGRAL is not set
CONFIG_CBPRINTF_FP_SUPPORT=y
# CONFIG_CBPRINTF_FP_A_SUPPORT is not set
# CONFIG_CBPRINTF_LIBC_SUBSTS is not set
# CONFIG_CBPRINTF_PACKAGE_LOG_LEVEL_OFF is not set
# CONFIG_CBPRINTF_PACKAGE_LOG_LEVEL_ERR is not set
# CONFIG_CBPRINTF_PACKAGE_LOG_LEVEL_WRN is not set
# CONFIG_CBPRINTF_PACKAGE_LOG_LEVEL_INF is not set
# CONFIG_CBPRINTF_PACKAGE_LOG_LEVEL_DBG is not set
CONFIG_CBPRINTF_PACKAGE_LOG_LEVEL_DEFAULT=y
CONFIG_CBPRINTF_PACKAGE_LOG_LEVEL=3
# CONFIG_CBPRINTF_PACKAGE_LONGDOUBLE is not set
CONFIG_CBPRINTF_CONVERT_CHECK_PTR=y
# CONFIG_ZVFS is not set
# end of OS Support Library
# POSIX API Support
# POSIX Options
# CONFIG_POSIX_API is not set
CONFIG_POSIX_AEP_CHOICE_NONE=y
# CONFIG_POSIX_AEP_CHOICE_BASE is not set
# CONFIG_POSIX_AEP_CHOICE_PSE51 is not set
# CONFIG_POSIX_AEP_CHOICE_PSE52 is not set
# CONFIG_POSIX_AEP_CHOICE_PSE53 is not set
# CONFIG_POSIX_ASYNCHRONOUS_IO is not set
# CONFIG_POSIX_BARRIERS is not set
# CONFIG_POSIX_C_LANG_SUPPORT_R is not set
# CONFIG_POSIX_C_LIB_EXT is not set
# POSIX device I/O
# CONFIG_POSIX_DEVICE_IO is not set
CONFIG_POSIX_OPEN_MAX=4
# end of POSIX device I/O
# CONFIG_POSIX_FD_MGMT is not set
# CONFIG_POSIX_FILE_SYSTEM is not set
# POSIX memory
CONFIG_POSIX_PAGE_SIZE=0x40
# CONFIG_POSIX_SHARED_MEMORY_OBJECTS is not set
# CONFIG_POSIX_MAPPED_FILES is not set
# CONFIG_POSIX_MEMORY_PROTECTION is not set
# end of POSIX memory
# CONFIG_POSIX_MESSAGE_PASSING is not set
# CONFIG_POSIX_SINGLE_PROCESS is not set
# CONFIG_POSIX_MULTI_PROCESS is not set
# CONFIG_POSIX_THREADS is not set
# CONFIG_POSIX_READER_WRITER_LOCKS is not set
# POSIX scheduler options
# CONFIG_POSIX_PRIORITY_SCHEDULING is not set
# end of POSIX scheduler options
# CONFIG_POSIX_SEMAPHORES is not set
# POSIX signals
# CONFIG_POSIX_REALTIME_SIGNALS is not set
# CONFIG_POSIX_SIGNALS is not set
# end of POSIX signals
# CONFIG_POSIX_SPIN_LOCKS is not set
# POSIX synchronized I/O
# CONFIG_POSIX_FSYNC is not set
# CONFIG_POSIX_SYNCHRONIZED_IO is not set
# end of POSIX synchronized I/O
# CONFIG_POSIX_TIMERS is not set
# X/Open system interfaces
# CONFIG_XOPEN_STREAMS is not set
# CONFIG_XSI_SYSTEM_LOGGING is not set
# CONFIG_XSI_THREADS_EXT is not set
# end of X/Open system interfaces
# Miscellaneous POSIX-related options
# CONFIG_EVENTFD is not set
# end of Miscellaneous POSIX-related options
# Deprecated POSIX options
CONFIG_EVENTFD_MAX=0
# CONFIG_FNMATCH is not set
CONFIG_MAX_PTHREAD_COUNT=0
CONFIG_MAX_PTHREAD_KEY_COUNT=0
CONFIG_MAX_TIMER_COUNT=0
CONFIG_MSG_COUNT_MAX=0
# CONFIG_POSIX_CLOCK is not set
# CONFIG_POSIX_FS is not set
CONFIG_POSIX_LIMITS_RTSIG_MAX=0
CONFIG_POSIX_MAX_FDS=4
CONFIG_POSIX_MAX_OPEN_FILES=4
# CONFIG_POSIX_MQUEUE is not set
# CONFIG_POSIX_PUTMSG is not set
# CONFIG_POSIX_SIGNAL is not set
# CONFIG_POSIX_SYSCONF is not set
# CONFIG_POSIX_UNAME is not set
# CONFIG_PTHREAD is not set
# CONFIG_PTHREAD_BARRIER is not set
# CONFIG_PTHREAD_COND is not set
# CONFIG_PTHREAD_IPC is not set
# CONFIG_PTHREAD_KEY is not set
# CONFIG_PTHREAD_MUTEX is not set
# CONFIG_PTHREAD_RWLOCK is not set
# CONFIG_PTHREAD_SPINLOCK is not set
# CONFIG_TIMER is not set
CONFIG_TIMER_DELAYTIMER_MAX=0
CONFIG_SEM_NAMELEN_MAX=0
CONFIG_SEM_VALUE_MAX=0
# end of Deprecated POSIX options
CONFIG_TC_PROVIDES_POSIX_C_LANG_SUPPORT_R=y
# end of POSIX Options
# POSIX Shell Utilities
# end of POSIX Shell Utilities
# end of POSIX API Support
# CONFIG_OPENAMP_RSC_TABLE is not set
# CONFIG_SMF is not set
CONFIG_LIBGCC_RTLIB=y
# Utility Library
# CONFIG_JSON_LIBRARY is not set
CONFIG_RING_BUFFER=y
CONFIG_NOTIFY=y
# CONFIG_BASE64 is not set
CONFIG_ONOFF=y
# CONFIG_WINSTREAM is not set
# CONFIG_UTF8 is not set
# end of Utility Library
# end of Additional libraries
# Subsystems and OS Services
# CONFIG_BINDESC is not set
CONFIG_BT=y
CONFIG_BT_HCI=y
# CONFIG_BT_CUSTOM is not set
# CONFIG_BT_HCI_RAW is not set
# CONFIG_BT_HCI_RAW_H4 is not set
# CONFIG_BT_HCI_RAW_CMD_EXT is not set
CONFIG_BT_CONN_TX=y
# CONFIG_BT_SCA_UPDATE is not set
# CONFIG_BT_TRANSMIT_POWER_CONTROL is not set
# CONFIG_BT_PATH_LOSS_MONITORING is not set
# CONFIG_BT_SUBRATING is not set
# CONFIG_BT_CHANNEL_SOUNDING is not set
# CONFIG_BT_ISO_PERIPHERAL is not set
# CONFIG_BT_ISO_CENTRAL is not set
# CONFIG_BT_ISO_BROADCASTER is not set
# CONFIG_BT_ISO_SYNC_RECEIVER is not set
# Bluetooth buffer configuration
# end of Bluetooth buffer configuration
# Bluetooth Host
# L2CAP Options
# end of L2CAP Options
# ATT and GATT Options
# end of ATT and GATT Options
# GATT Services
# end of GATT Services
# Bluetooth Classic Options
# end of Bluetooth Classic Options
# end of Bluetooth Host
# CONFIG_BT_EAD is not set
# Bluetooth logging
# Common
# end of Common
# Libraries
# end of Libraries
# Host
# end of Host
# Services
# end of Services
# end of Bluetooth logging
# Controller Area Network (CAN) bus subsystem
# end of Controller Area Network (CAN) bus subsystem
# CONFIG_CONSOLE_SUBSYS is not set
# CONFIG_DAP is not set
# System Monitoring Options
# CONFIG_THREAD_ANALYZER is not set
# end of System Monitoring Options
# Debugging Options
CONFIG_DEBUG=y
# CONFIG_STACK_USAGE is not set
CONFIG_STACK_SENTINEL=y
CONFIG_PRINTK=y
CONFIG_EARLY_CONSOLE=y
CONFIG_ASSERT_LEVEL=2
CONFIG_SPIN_VALIDATE=y
# CONFIG_FORCE_NO_ASSERT is not set
CONFIG_ASSERT_VERBOSE=y
# CONFIG_ASSERT_NO_FILE_INFO is not set
CONFIG_ASSERT_NO_COND_INFO=y
CONFIG_ASSERT_NO_MSG_INFO=y
# CONFIG_ASSERT_TEST is not set
# CONFIG_OVERRIDE_FRAME_POINTER_DEFAULT is not set
# CONFIG_DEBUG_INFO is not set
CONFIG_DEBUG_THREAD_INFO=y
# CONFIG_DEBUG_COREDUMP is not set
# CONFIG_SYMTAB is not set
# end of Debugging Options
# CONFIG_MIPI_STP_DECODER is not set
# CONFIG_CS_TRACE_DEFMT is not set
CONFIG_IMG_MANAGER=y
CONFIG_MCUBOOT_IMG_MANAGER=y
CONFIG_MCUBOOT_TRAILER_SWAP_TYPE=y
CONFIG_MCUBOOT_UPDATE_FOOTER_SIZE=0x1000
CONFIG_IMG_BLOCK_BUF_SIZE=512
# CONFIG_IMG_ENABLE_IMAGE_CHECK is not set
# CONFIG_IMG_MANAGER_LOG_LEVEL_OFF is not set
# CONFIG_IMG_MANAGER_LOG_LEVEL_ERR is not set
# CONFIG_IMG_MANAGER_LOG_LEVEL_WRN is not set
# CONFIG_IMG_MANAGER_LOG_LEVEL_INF is not set
# CONFIG_IMG_MANAGER_LOG_LEVEL_DBG is not set
CONFIG_IMG_MANAGER_LOG_LEVEL_DEFAULT=y
CONFIG_IMG_MANAGER_LOG_LEVEL=3
# CONFIG_DISK_ACCESS is not set
# CONFIG_DSP is not set
# CONFIG_EMUL is not set
# CONFIG_CHARACTER_FRAMEBUFFER is not set
# File Systems
# CONFIG_FILE_SYSTEM is not set
# CONFIG_FCB is not set
CONFIG_NVS=y
# CONFIG_NVS_LOOKUP_CACHE is not set
# CONFIG_NVS_DATA_CRC is not set
# CONFIG_NVS_LOG_LEVEL_OFF is not set
# CONFIG_NVS_LOG_LEVEL_ERR is not set
# CONFIG_NVS_LOG_LEVEL_WRN is not set
# CONFIG_NVS_LOG_LEVEL_INF is not set
# CONFIG_NVS_LOG_LEVEL_DBG is not set
CONFIG_NVS_LOG_LEVEL_DEFAULT=y
CONFIG_NVS_LOG_LEVEL=3
# CONFIG_ZMS is not set
# end of File Systems
# Inter Processor Communication
# CONFIG_RPMSG_SERVICE is not set
CONFIG_IPC_SERVICE=y
CONFIG_IPC_SERVICE_REG_BACKEND_PRIORITY=46
CONFIG_IPC_SERVICE_BACKEND_RPMSG=y
CONFIG_IPC_SERVICE_BACKEND_RPMSG_WQ_STACK_SIZE=1024
CONFIG_IPC_SERVICE_BACKEND_RPMSG_NUM_ENDPOINTS_PER_INSTANCE=2
CONFIG_IPC_SERVICE_RPMSG=y
CONFIG_IPC_SERVICE_STATIC_VRINGS=y
CONFIG_IPC_SERVICE_STATIC_VRINGS_MEM_ALIGNMENT=4
# CONFIG_IPC_SERVICE_ICMSG is not set
# CONFIG_IPC_SERVICE_ICMSG_ME is not set
# CONFIG_IPC_SERVICE_LOG_LEVEL_OFF is not set
# CONFIG_IPC_SERVICE_LOG_LEVEL_ERR is not set
# CONFIG_IPC_SERVICE_LOG_LEVEL_WRN is not set
# CONFIG_IPC_SERVICE_LOG_LEVEL_INF is not set
# CONFIG_IPC_SERVICE_LOG_LEVEL_DBG is not set
CONFIG_IPC_SERVICE_LOG_LEVEL_DEFAULT=y
CONFIG_IPC_SERVICE_LOG_LEVEL=3
# end of Inter Processor Communication
# CONFIG_JWT is not set
# CONFIG_LLEXT is not set
# Linkable loadable Extension Development Kit (EDK)
CONFIG_LLEXT_EDK_NAME="llext-edk"
# CONFIG_LLEXT_EDK_USERSPACE_ONLY is not set
# end of Linkable loadable Extension Development Kit (EDK)
# Logging
CONFIG_LOG_CORE_INIT_PRIORITY=0
CONFIG_LOG_MODE_DEFERRED=y
# CONFIG_LOG_MODE_IMMEDIATE is not set
# CONFIG_LOG_MODE_MINIMAL is not set
# CONFIG_LOG_FRONTEND is not set
# CONFIG_LOG_FRONTEND_OPT_API is not set
# CONFIG_LOG_CUSTOM_HEADER is not set
# CONFIG_LOG_MULTIDOMAIN is not set
# Logging levels filtering
# CONFIG_LOG_RUNTIME_FILTERING is not set
CONFIG_LOG_DEFAULT_LEVEL=3
CONFIG_LOG_OVERRIDE_LEVEL=0
CONFIG_LOG_MAX_LEVEL=4
# end of Logging levels filtering
# Processing
CONFIG_LOG_PRINTK=y
CONFIG_LOG_MODE_OVERFLOW=y
# CONFIG_LOG_BLOCK_IN_THREAD is not set
CONFIG_LOG_PROCESS_TRIGGER_THRESHOLD=10
CONFIG_LOG_PROCESS_THREAD=y
CONFIG_LOG_PROCESS_THREAD_STARTUP_DELAY_MS=0
CONFIG_LOG_PROCESS_THREAD_SLEEP_MS=1000
CONFIG_LOG_PROCESS_THREAD_STACK_SIZE=2048
# CONFIG_LOG_PROCESS_THREAD_CUSTOM_PRIORITY is not set
CONFIG_LOG_TRACE_SHORT_TIMESTAMP=y
# CONFIG_LOG_TIMESTAMP_64BIT is not set
# CONFIG_LOG_SPEED is not set
# end of Processing
# Output Formatting
# Prepend non-hexdump log message with function name
# CONFIG_LOG_FUNC_NAME_PREFIX_ERR is not set
# CONFIG_LOG_FUNC_NAME_PREFIX_WRN is not set
# CONFIG_LOG_FUNC_NAME_PREFIX_INF is not set
CONFIG_LOG_FUNC_NAME_PREFIX_DBG=y
# end of Prepend non-hexdump log message with function name
# CONFIG_LOG_MIPI_SYST_ENABLE is not set
# CONFIG_LOG_THREAD_ID_PREFIX is not set
# CONFIG_LOG_CUSTOM_FORMAT_SUPPORT is not set
CONFIG_LOG_BACKEND_SHOW_COLOR=y
# CONFIG_LOG_INFO_COLOR_GREEN is not set
# CONFIG_LOG_DBG_COLOR_BLUE is not set
CONFIG_LOG_TAG_MAX_LEN=0
CONFIG_LOG_BACKEND_SUPPORTS_FORMAT_TIMESTAMP=y
CONFIG_LOG_BACKEND_FORMAT_TIMESTAMP=y
# CONFIG_LOG_OUTPUT_FORMAT_LINUX_TIMESTAMP is not set
# CONFIG_LOG_OUTPUT_FORMAT_CUSTOM_TIMESTAMP is not set
# end of Output Formatting
# Backends
# CONFIG_LOG_BACKEND_BLE is not set
CONFIG_LOG_BACKEND_RTT=y
# CONFIG_LOG_BACKEND_RTT_MODE_DROP is not set
CONFIG_LOG_BACKEND_RTT_MODE_BLOCK=y
# CONFIG_LOG_BACKEND_RTT_MODE_OVERWRITE is not set
CONFIG_LOG_BACKEND_RTT_OUTPUT_TEXT=y
# CONFIG_LOG_BACKEND_RTT_OUTPUT_DICTIONARY is not set
# CONFIG_LOG_BACKEND_RTT_OUTPUT_CUSTOM is not set
CONFIG_LOG_BACKEND_RTT_OUTPUT_DEFAULT=0
CONFIG_LOG_BACKEND_RTT_OUTPUT_BUFFER_SIZE=16
CONFIG_LOG_BACKEND_RTT_RETRY_CNT=4
CONFIG_LOG_BACKEND_RTT_RETRY_DELAY_MS=5
CONFIG_LOG_BACKEND_RTT_BUFFER=0
# CONFIG_LOG_BACKEND_SWO is not set
# CONFIG_LOG_BACKEND_IPC_SERVICE is not set
# end of Backends
# Misc
CONFIG_LOG_USE_VLA=y
CONFIG_LOG_SIMPLE_MSG_OPTIMIZE=y
# CONFIG_LOG_ALWAYS_RUNTIME is not set
# CONFIG_LOG_FMT_SECTION is not set
# CONFIG_LOG_FMT_STRING_VALIDATE is not set
# CONFIG_LOG_MEM_UTILIZATION is not set
CONFIG_LOG_FAILURE_REPORT_PERIOD=1000
# end of Misc
CONFIG_LOG_OUTPUT=y
# end of Logging
CONFIG_MEM_ATTR=y
# CONFIG_MEM_ATTR_HEAP is not set
# Device Management
# Host command handler subsystem
# CONFIG_EC_HOST_CMD is not set
# end of Host command handler subsystem
CONFIG_MCUMGR=y
# CONFIG_MCUMGR_LOG_LEVEL_OFF is not set
# CONFIG_MCUMGR_LOG_LEVEL_ERR is not set
# CONFIG_MCUMGR_LOG_LEVEL_WRN is not set
# CONFIG_MCUMGR_LOG_LEVEL_INF is not set
# CONFIG_MCUMGR_LOG_LEVEL_DBG is not set
CONFIG_MCUMGR_LOG_LEVEL_DEFAULT=y
CONFIG_MCUMGR_LOG_LEVEL=3
# CONFIG_MCUMGR_MGMT_NOTIFICATION_HOOKS is not set
# CONFIG_MCUMGR_MGMT_HANDLER_USER_DATA is not set
# CONFIG_MCUMGR_MGMT_CUSTOM_PAYLOAD is not set
CONFIG_MCUMGR_SMP_CBOR_MAX_MAIN_MAP_ENTRIES=15
CONFIG_MCUMGR_SMP_CBOR_MIN_DECODING_LEVELS=2
CONFIG_MCUMGR_SMP_CBOR_MIN_DECODING_LEVEL_2=y
CONFIG_MCUMGR_SMP_CBOR_MAX_DECODING_LEVELS=2
CONFIG_MCUMGR_SMP_CBOR_MIN_ENCODING_LEVELS=0
CONFIG_MCUMGR_SMP_CBOR_MAX_ENCODING_LEVELS=0
CONFIG_MCUMGR_SMP_SUPPORT_ORIGINAL_PROTOCOL=y
# CONFIG_MCUMGR_SMP_VERBOSE_ERR_RESPONSE is not set
# CONFIG_MCUMGR_SMP_LEGACY_RC_BEHAVIOUR is not set
# SMP Client
# CONFIG_SMP_CLIENT is not set
# end of SMP Client
# Command Handlers
CONFIG_MCUMGR_GRP_IMG=y
# CONFIG_MCUMGR_GRP_IMG_USE_HEAP_FOR_FLASH_IMG_CONTEXT is not set
CONFIG_MCUMGR_GRP_IMG_UPDATABLE_IMAGE_NUMBER=2
# CONFIG_MCUMGR_GRP_IMG_VERBOSE_ERR is not set
CONFIG_MCUMGR_GRP_IMG_ALLOW_CONFIRM_NON_ACTIVE_IMAGE_SECONDARY=y
# CONFIG_MCUMGR_GRP_IMG_ALLOW_CONFIRM_NON_ACTIVE_IMAGE_ANY is not set
# CONFIG_MCUMGR_GRP_IMG_ALLOW_ERASE_PENDING is not set
# CONFIG_MCUMGR_GRP_IMG_DIRECT_UPLOAD is not set
# CONFIG_MCUMGR_GRP_IMG_REJECT_DIRECT_XIP_MISMATCHED_SLOT is not set
# CONFIG_MCUMGR_GRP_IMG_FRUGAL_LIST is not set
# CONFIG_MCUMGR_GRP_IMG_VERSION_CMP_USE_BUILD_NUMBER is not set
# CONFIG_MCUMGR_GRP_IMG_MUTEX is not set
CONFIG_MCUMGR_GRP_IMG_TOO_LARGE_DISABLED=y
# CONFIG_MCUMGR_GRP_IMG_TOO_LARGE_SYSBUILD is not set
CONFIG_MCUMGR_GRP_IMG_IMAGE_SLOT_STATE_STATES=15
# CONFIG_MCUMGR_GRP_IMG_LOG_LEVEL_OFF is not set
# CONFIG_MCUMGR_GRP_IMG_LOG_LEVEL_ERR is not set
# CONFIG_MCUMGR_GRP_IMG_LOG_LEVEL_WRN is not set
# CONFIG_MCUMGR_GRP_IMG_LOG_LEVEL_INF is not set
# CONFIG_MCUMGR_GRP_IMG_LOG_LEVEL_DBG is not set
CONFIG_MCUMGR_GRP_IMG_LOG_LEVEL_DEFAULT=y
CONFIG_MCUMGR_GRP_IMG_LOG_LEVEL=3
CONFIG_MCUMGR_GRP_OS=y
CONFIG_MCUMGR_GRP_OS_RESET_MS=250
# CONFIG_MCUMGR_GRP_OS_TASKSTAT is not set
CONFIG_MCUMGR_GRP_OS_ECHO=y
# CONFIG_MCUMGR_GRP_OS_INFO is not set
# CONFIG_MCUMGR_GRP_OS_BOOTLOADER_INFO is not set
# CONFIG_MCUMGR_GRP_OS_LOG_LEVEL_OFF is not set
# CONFIG_MCUMGR_GRP_OS_LOG_LEVEL_ERR is not set
# CONFIG_MCUMGR_GRP_OS_LOG_LEVEL_WRN is not set
# CONFIG_MCUMGR_GRP_OS_LOG_LEVEL_INF is not set
# CONFIG_MCUMGR_GRP_OS_LOG_LEVEL_DBG is not set
CONFIG_MCUMGR_GRP_OS_LOG_LEVEL_DEFAULT=y
CONFIG_MCUMGR_GRP_OS_LOG_LEVEL=3
# CONFIG_MCUMGR_GRP_ENUM is not set
# end of Command Handlers
# Transports and Transport Related Configuration Options
CONFIG_MCUMGR_TRANSPORT_WORKQUEUE_STACK_SIZE=2048
CONFIG_MCUMGR_TRANSPORT_WORKQUEUE_THREAD_PRIO=3
CONFIG_MCUMGR_TRANSPORT_NETBUF_COUNT=4
CONFIG_MCUMGR_TRANSPORT_NETBUF_MIN_USER_DATA_SIZE=4
CONFIG_MCUMGR_TRANSPORT_NETBUF_USER_DATA_SIZE=4
# CONFIG_MCUMGR_TRANSPORT_LOG_LEVEL_OFF is not set
# CONFIG_MCUMGR_TRANSPORT_LOG_LEVEL_ERR is not set
# CONFIG_MCUMGR_TRANSPORT_LOG_LEVEL_WRN is not set
# CONFIG_MCUMGR_TRANSPORT_LOG_LEVEL_INF is not set
# CONFIG_MCUMGR_TRANSPORT_LOG_LEVEL_DBG is not set
CONFIG_MCUMGR_TRANSPORT_LOG_LEVEL_DEFAULT=y
CONFIG_MCUMGR_TRANSPORT_LOG_LEVEL=3
# CONFIG_MCUMGR_TRANSPORT_BT is not set
# end of Transports and Transport Related Configuration Options
# CONFIG_OSDP is not set
# end of Device Management
# CONFIG_MODBUS is not set
# CONFIG_MODEM_MODULES is not set
# Networking
# CONFIG_NETWORKING is not set
# end of Networking
# Power Management
# CONFIG_PM_POLICY_LATENCY_STANDALONE is not set
# CONFIG_PM_DEVICE_LOG_LEVEL_OFF is not set
# CONFIG_PM_DEVICE_LOG_LEVEL_ERR is not set
# CONFIG_PM_DEVICE_LOG_LEVEL_WRN is not set
# CONFIG_PM_DEVICE_LOG_LEVEL_INF is not set
# CONFIG_PM_DEVICE_LOG_LEVEL_DBG is not set
CONFIG_PM_DEVICE_LOG_LEVEL_DEFAULT=y
CONFIG_PM_DEVICE_LOG_LEVEL=3
# CONFIG_PM_DEVICE_RUNTIME is not set
# end of Power Management
# Portability
# end of Portability
# CONFIG_PROFILING is not set
# Random Number Generators
CONFIG_TEST_RANDOM_GENERATOR=y
CONFIG_TIMER_RANDOM_INITIAL_STATE=123456789
CONFIG_TIMER_RANDOM_GENERATOR=y
# CONFIG_ENTROPY_DEVICE_RANDOM_GENERATOR is not set
# CONFIG_XOSHIRO_RANDOM_GENERATOR is not set
CONFIG_CSPRNG_ENABLED=y
CONFIG_HARDWARE_DEVICE_CS_GENERATOR=y
# CONFIG_CTR_DRBG_CSPRNG_GENERATOR is not set
# end of Random Number Generators
# CONFIG_RTIO is not set
# SD
# CONFIG_MMC_STACK is not set
# CONFIG_SDMMC_STACK is not set
# CONFIG_SDIO_STACK is not set
# end of SD
CONFIG_SETTINGS=y
# CONFIG_SETTINGS_LOG_LEVEL_OFF is not set
# CONFIG_SETTINGS_LOG_LEVEL_ERR is not set
# CONFIG_SETTINGS_LOG_LEVEL_WRN is not set
# CONFIG_SETTINGS_LOG_LEVEL_INF is not set
# CONFIG_SETTINGS_LOG_LEVEL_DBG is not set
CONFIG_SETTINGS_LOG_LEVEL_DEFAULT=y
CONFIG_SETTINGS_LOG_LEVEL=3
# CONFIG_SETTINGS_RUNTIME is not set
CONFIG_SETTINGS_DYNAMIC_HANDLERS=y
CONFIG_SETTINGS_NVS=y
# CONFIG_SETTINGS_NVS_NAME_CACHE is not set
# CONFIG_SETTINGS_CUSTOM is not set
# CONFIG_SETTINGS_NONE is not set
CONFIG_SETTINGS_NVS_SECTOR_SIZE_MULT=1
CONFIG_SETTINGS_NVS_SECTOR_COUNT=4
# CONFIG_SHELL is not set
# CONFIG_STATS is not set
# Storage
CONFIG_FLASH_MAP=y
# CONFIG_FLASH_AREA_CHECK_INTEGRITY is not set
# CONFIG_FLASH_MAP_LABELS is not set
CONFIG_STREAM_FLASH=y
CONFIG_STREAM_FLASH_ERASE=y
# CONFIG_STREAM_FLASH_PROGRESS is not set
# CONFIG_STREAM_FLASH_LOG_LEVEL_OFF is not set
# CONFIG_STREAM_FLASH_LOG_LEVEL_ERR is not set
# CONFIG_STREAM_FLASH_LOG_LEVEL_WRN is not set
# CONFIG_STREAM_FLASH_LOG_LEVEL_INF is not set
# CONFIG_STREAM_FLASH_LOG_LEVEL_DBG is not set
CONFIG_STREAM_FLASH_LOG_LEVEL_DEFAULT=y
CONFIG_STREAM_FLASH_LOG_LEVEL=3
# end of Storage
CONFIG_TASK_WDT=y
CONFIG_TASK_WDT_CHANNELS=5
CONFIG_TASK_WDT_HW_FALLBACK=y
CONFIG_TASK_WDT_MIN_TIMEOUT=100
# Testing
# CONFIG_ZTEST is not set
# CONFIG_ZTEST_MOCKING is not set
# CONFIG_ZTRESS is not set
# CONFIG_TEST is not set
# CONFIG_FORCE_COVERAGE is not set
# CONFIG_TEST_USERSPACE is not set
# end of Testing
# CONFIG_TIMING_FUNCTIONS is not set
# CONFIG_TRACING is not set
# CONFIG_USB_DEVICE_STACK is not set
# CONFIG_USB_DEVICE_STACK_NEXT is not set
# CONFIG_USB_HOST_STACK is not set
# CONFIG_USBC_STACK is not set
# CONFIG_ZBUS is not set
# CONFIG_MODULES is not set
# end of Subsystems and OS Services
CONFIG_TOOLCHAIN_ZEPHYR_0_17=y
CONFIG_TOOLCHAIN_ZEPHYR_SUPPORTS_THREAD_LOCAL_STORAGE=y
CONFIG_TOOLCHAIN_ZEPHYR_SUPPORTS_GNU_EXTENSIONS=y
# Build and Link Features
# Linker Options
# CONFIG_LINKER_ORPHAN_SECTION_PLACE is not set
CONFIG_LINKER_ORPHAN_SECTION_WARN=y
# CONFIG_LINKER_ORPHAN_SECTION_ERROR is not set
CONFIG_ROM_END_OFFSET=0x1000
CONFIG_LD_LINKER_SCRIPT_SUPPORTED=y
CONFIG_LD_LINKER_TEMPLATE=y
# CONFIG_CMAKE_LINKER_GENERATOR is not set
# CONFIG_HAVE_CUSTOM_LINKER_SCRIPT is not set
CONFIG_LINKER_SORT_BY_ALIGNMENT=y
# Linker Sections
# CONFIG_LINKER_USE_BOOT_SECTION is not set
# CONFIG_LINKER_USE_PINNED_SECTION is not set
CONFIG_LINKER_GENERIC_SECTIONS_PRESENT_AT_BOOT=y
CONFIG_LINKER_LAST_SECTION_ID=y
CONFIG_LINKER_LAST_SECTION_ID_PATTERN=0xE015E015
CONFIG_LINKER_USE_RELAX=y
# end of Linker Sections
CONFIG_LINKER_ITERABLE_SUBALIGN=4
CONFIG_LINKER_DEVNULL_SUPPORT=y
# CONFIG_LINKER_DEVNULL_MEMORY is not set
# end of Linker Options
# Compiler Options
# CONFIG_STD_C90 is not set
CONFIG_STD_C99=y
# CONFIG_STD_C11 is not set
# CONFIG_STD_C17 is not set
# CONFIG_STD_C23 is not set
CONFIG_TOOLCHAIN_SUPPORTS_GNU_EXTENSIONS=y
# CONFIG_GNU_C_EXTENSIONS is not set
# CONFIG_CODING_GUIDELINE_CHECK is not set
# CONFIG_COMPILER_FREESTANDING is not set
# CONFIG_SIZE_OPTIMIZATIONS is not set
# CONFIG_SIZE_OPTIMIZATIONS_AGGRESSIVE is not set
# CONFIG_SPEED_OPTIMIZATIONS is not set
CONFIG_DEBUG_OPTIMIZATIONS=y
# CONFIG_NO_OPTIMIZATIONS is not set
# CONFIG_COMPILER_WARNINGS_AS_ERRORS is not set
# CONFIG_COMPILER_SAVE_TEMPS is not set
CONFIG_COMPILER_TRACK_MACRO_EXPANSION=y
CONFIG_COMPILER_COLOR_DIAGNOSTICS=y
# CONFIG_FORTIFY_SOURCE_NONE is not set
CONFIG_FORTIFY_SOURCE_COMPILE_TIME=y
# CONFIG_FORTIFY_SOURCE_RUN_TIME is not set
CONFIG_COMPILER_OPT=""
# CONFIG_MISRA_SANE is not set
# end of Compiler Options
# CONFIG_ASSERT_ON_ERRORS is not set
# CONFIG_NO_RUNTIME_CHECKS is not set
CONFIG_RUNTIME_ERROR_CHECKS=y
# Build Options
CONFIG_KERNEL_BIN_NAME="zephyr"
CONFIG_OUTPUT_STAT=y
# CONFIG_OUTPUT_SYMBOLS is not set
# CONFIG_OUTPUT_DISASSEMBLY is not set
CONFIG_OUTPUT_PRINT_MEMORY_USAGE=y
# CONFIG_CLEANUP_INTERMEDIATE_FILES is not set
CONFIG_BUILD_GAP_FILL_PATTERN=0xFF
# CONFIG_BUILD_OUTPUT_HEX_GAP_FILL is not set
# CONFIG_BUILD_OUTPUT_EXE is not set
# CONFIG_BUILD_OUTPUT_S19 is not set
# CONFIG_BUILD_OUTPUT_S19_GAP_FILL is not set
# CONFIG_BUILD_OUTPUT_UF2 is not set
# CONFIG_BUILD_OUTPUT_STRIPPED is not set
# CONFIG_BUILD_OUTPUT_COMPRESS_DEBUG_SECTIONS is not set
# CONFIG_BUILD_ALIGN_LMA is not set
# CONFIG_APPLICATION_DEFINED_SYSCALL is not set
# CONFIG_MAKEFILE_EXPORTS is not set
# CONFIG_BUILD_OUTPUT_META is not set
CONFIG_BUILD_OUTPUT_STRIP_PATHS=y
CONFIG_CHECK_INIT_PRIORITIES=y
# CONFIG_EMIT_ALL_SYSCALLS is not set
# end of Build Options
CONFIG_WARN_DEPRECATED=y
CONFIG_EXPERIMENTAL=y
CONFIG_ENFORCE_ZEPHYR_STDINT=y
# end of Build and Link Features
# Boot Options
# CONFIG_IS_BOOTLOADER is not set
# CONFIG_BOOTLOADER_BOSSA is not set
# end of Boot Options
# Compatibility
CONFIG_LEGACY_GENERATED_INCLUDE_PATH=y
# end of Compatibility
# CONFIG_OFF_LOAD_STUDY_DATA_LED_ENABLE is not set
CONFIG_ALWAYS_POWER_9160=y
# CONFIG_FORCED_ANCHOR_MODE is not set
# CONFIG_MESH_APP_CHAT is not set
# CONFIG_MESH_APP_SB_SIM is not set
# CONFIG_MESH_APP_TOPOLOGY is not set
# CONFIG_NO_LID is not set
# CONFIG_FORCE_DEFAULT_USER_CFG is not set
# CONFIG_OTA_NO_RETRY is not set
# CONFIG_HG1_PATS_SIMULATOR is not set
# CONFIG_HG1_PATS_FORCED_PHASE_LINE is not set
# CONFIG_SKIP_BATT_RECOVERY is not set
# CONFIG_LLT_ENABLE_HCI_RSSI_READ is not set
CONFIG_HG1_ENABLE_OFFLOAD_STUDY_DATA=y
CONFIG_LLT_SERVER_ID=y
# BLK XFR
CONFIG_BLK_XFR_CLI=y
# CONFIG_BLK_XFR_SRV is not set
# end of BLK XFR
# BLK XFR
# end of BLK XFR
Here the net core .config file
# CONFIG_INPUT is not set
# CONFIG_WIFI is not set
# CONFIG_MIPI_DSI is not set
# CONFIG_SERIAL is not set
# CONFIG_I2C is not set
# CONFIG_SPI is not set
# CONFIG_MODEM is not set
# CONFIG_BT_SPI is not set
CONFIG_BT_HCI_ACL_FLOW_CONTROL=y
CONFIG_BT_HCI_VS=y
CONFIG_FLASH_LOAD_SIZE=0
CONFIG_SRAM_SIZE=64
CONFIG_FLASH_LOAD_OFFSET=0
CONFIG_BT_CTLR=y
CONFIG_BT_ECC=y
CONFIG_NUM_IRQS=30
CONFIG_SYS_CLOCK_HW_CYCLES_PER_SEC=32768
CONFIG_FLASH_SIZE=256
CONFIG_FLASH_BASE_ADDRESS=0x1000000
CONFIG_MP_MAX_NUM_CPUS=1
CONFIG_SOC_RESET_HOOK=y
CONFIG_SYS_CLOCK_TICKS_PER_SEC=32768
CONFIG_ROM_START_OFFSET=0
# CONFIG_PINCTRL is not set
CONFIG_BUILD_OUTPUT_BIN=y
# CONFIG_BUILD_NO_GAP_FILL is not set
CONFIG_XIP=y
CONFIG_MAIN_STACK_SIZE=512
CONFIG_IDLE_STACK_SIZE=256
CONFIG_HAS_FLASH_LOAD_OFFSET=y
# CONFIG_SRAM_VECTOR_TABLE is not set
CONFIG_CPU_HAS_ARM_MPU=y
# CONFIG_COUNTER is not set
# CONFIG_SHARED_INTERRUPTS is not set
# CONFIG_PM_DEVICE is not set
CONFIG_TICKLESS_KERNEL=y
CONFIG_SYSTEM_WORKQUEUE_STACK_SIZE=512
CONFIG_CLOCK_CONTROL=y
CONFIG_CLOCK_CONTROL_INIT_PRIORITY=30
# CONFIG_USE_DT_CODE_PARTITION is not set
# CONFIG_MULTI_LEVEL_INTERRUPTS is not set
CONFIG_GEN_IRQ_VECTOR_TABLE=y
# CONFIG_DYNAMIC_INTERRUPTS is not set
CONFIG_GEN_ISR_TABLES=y
# CONFIG_INIT_STACKS is not set
CONFIG_TIMESLICE_SIZE=0
# CONFIG_REGULATOR is not set
CONFIG_HW_STACK_PROTECTION=y
# CONFIG_HCI_NXP_ENABLE_AUTO_SLEEP is not set
# CONFIG_HCI_NXP_SET_CAL_DATA is not set
# CONFIG_MFD is not set
CONFIG_GPIO=y
# CONFIG_CPU_HAS_CUSTOM_FIXED_SOC_MPU_REGIONS is not set
CONFIG_TINYCRYPT=y
# CONFIG_CODE_DATA_RELOCATION_SRAM is not set
# CONFIG_MBEDTLS is not set
# CONFIG_MEMC is not set
CONFIG_KERNEL_ENTRY="__start"
# CONFIG_CACHE is not set
# CONFIG_LOG is not set
# CONFIG_CODE_DATA_RELOCATION is not set
# CONFIG_ROMSTART_RELOCATION_ROM is not set
CONFIG_DCACHE_LINE_SIZE=32
CONFIG_SOC="nrf5340"
# CONFIG_RESET is not set
CONFIG_ARCH_SW_ISR_TABLE_ALIGN=4
CONFIG_NRF_RTC_TIMER=y
# CONFIG_IPC_SERVICE_BACKEND_RPMSG_SHMEM_RESET is not set
CONFIG_LOG_DOMAIN_NAME="net"
# CONFIG_ASSERT is not set
CONFIG_BUILD_OUTPUT_HEX=y
CONFIG_ARCH_HAS_CUSTOM_BUSY_WAIT=y
CONFIG_SOC_HAS_TIMING_FUNCTIONS=y
# CONFIG_SYSCON is not set
CONFIG_ENTROPY_INIT_PRIORITY=50
CONFIG_SOC_SERIES="nrf53"
CONFIG_SOC_FAMILY="nordic_nrf"
# CONFIG_INTC_MTK_ADSP is not set
# CONFIG_MTK_ADSP_TIMER is not set
CONFIG_COMMON_LIBC_MALLOC_ARENA_SIZE=-1
CONFIG_GEN_SW_ISR_TABLE=y
# CONFIG_REBOOT is not set
CONFIG_GEN_IRQ_START_VECTOR=0
CONFIG_SRAM_OFFSET=0
# CONFIG_POWER_DOMAIN is not set
# CONFIG_CONSOLE is not set
CONFIG_ARCH_IRQ_VECTOR_TABLE_ALIGN=4
CONFIG_ISR_STACK_SIZE=2048
# CONFIG_SCHED_CPU_MASK is not set
# CONFIG_WATCHDOG is not set
CONFIG_ICACHE_LINE_SIZE=32
CONFIG_PRIVILEGED_STACK_SIZE=1024
CONFIG_BT_BUF_ACL_TX_COUNT=20
CONFIG_BT_BUF_CMD_TX_SIZE=255
CONFIG_BT_BUF_EVT_RX_SIZE=68
CONFIG_BT_BUF_ACL_TX_SIZE=251
CONFIG_BT_BUF_ACL_RX_SIZE=251
# Devicetree Info
CONFIG_DT_HAS_ARM_ARMV8M_MPU_ENABLED=y
CONFIG_DT_HAS_ARM_CORTEX_M33_ENABLED=y
CONFIG_DT_HAS_ARM_V8M_NVIC_ENABLED=y
CONFIG_DT_HAS_FIXED_PARTITIONS_ENABLED=y
CONFIG_DT_HAS_GENERIC_FEM_TWO_CTRL_PINS_ENABLED=y
CONFIG_DT_HAS_MMIO_SRAM_ENABLED=y
CONFIG_DT_HAS_NORDIC_BT_HCI_SDC_ENABLED=y
CONFIG_DT_HAS_NORDIC_MBOX_NRF_IPC_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_ACL_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_CCM_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_CLOCK_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_DPPIC_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_ECB_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_EGU_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_FICR_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_GPIO_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_GPIOTE_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_GPREGRET_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_IPC_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_PINCTRL_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_POWER_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_RADIO_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_RNG_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_SWI_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_TEMP_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_TIMER_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_UICR_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_VMC_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_WDT_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF53_FLASH_CONTROLLER_ENABLED=y
CONFIG_DT_HAS_SOC_NV_FLASH_ENABLED=y
CONFIG_DT_HAS_ZEPHYR_BT_HCI_ENTROPY_ENABLED=y
CONFIG_DT_HAS_ZEPHYR_IPC_OPENAMP_STATIC_VRINGS_ENABLED=y
CONFIG_DT_HAS_ZEPHYR_MEMORY_REGION_ENABLED=y
# end of Devicetree Info
# Modules
# Available modules.
# nrf (C:/ncs/v2.9.2/nrf)
CONFIG_NUM_METAIRQ_PRIORITIES=0
CONFIG_MPSL_WORK_STACK_SIZE=1024
# Nordic nRF Connect
CONFIG_HIDE_CHILD_PARENT_CONFIG=y
CONFIG_WARN_EXPERIMENTAL=y
CONFIG_BT_BUF_CMD_TX_COUNT=10
CONFIG_INIT_ARCH_HW_AT_BOOT=y
CONFIG_NORDIC_QSPI_NOR_FLASH_LAYOUT_PAGE_SIZE=2048
# CONFIG_GETOPT is not set
# CONFIG_NCS_SAMPLES_DEFAULTS is not set
# CONFIG_NCS_SAMPLE_EMPTY_APP_CORE_CHILD_IMAGE is not set
# CONFIG_NCS_SAMPLE_DTM_REMOTE_HCI_CHILD_IMAGE is not set
# Image build variants
# CONFIG_NCS_MCUBOOT_IN_BUILD is not set
# end of Image build variants
# CONFIG_NCS_SAMPLE_MCUMGR_BT_OTA_DFU_SPEEDUP is not set
CONFIG_BT_CTLR_DATA_LENGTH_MAX=251
# Subsystems
# Bootloader
# CONFIG_BUILD_S1_VARIANT is not set
CONFIG_SECURE_BOOT=y
CONFIG_BOOTLOADER_PROVISION_HEX=y
CONFIG_SB_PRIVATE_KEY_PROVIDED=y
CONFIG_SB_SIGNING_PYTHON=y
# CONFIG_SB_SIGNING_OPENSSL is not set
# CONFIG_SB_SIGNING_CUSTOM is not set
CONFIG_SB_SIGNING_KEY_FILE=""
CONFIG_SB_SIGNING_COMMAND=""
CONFIG_SB_SIGNING_PUBLIC_KEY=""
CONFIG_SB_PUBLIC_KEY_FILES=""
# CONFIG_SB_DEBUG_SIGNATURE_PUBLIC_KEY_LAST is not set
CONFIG_SB_MONOTONIC_COUNTER=y
CONFIG_SB_NUM_VER_COUNTER_SLOTS=240
CONFIG_PM_PARTITION_SIZE_PROVISION=0x280
# CONFIG_B0_MIN_PARTITION_SIZE is not set
CONFIG_PM_PARTITION_SIZE_B0_IMAGE=0x7800
# CONFIG_IS_SECURE_BOOTLOADER is not set
# Secure Boot firmware validation
CONFIG_SB_VALIDATION_INFO_MAGIC=0x86518483
CONFIG_SB_VALIDATION_POINTER_MAGIC=0x6919b47e
CONFIG_SB_VALIDATION_INFO_CRYPTO_ID=1
CONFIG_SB_VALIDATION_INFO_VERSION=2
CONFIG_SB_VALIDATION_METADATA_OFFSET=0
CONFIG_SB_VALIDATE_FW_HASH=y
# end of Secure Boot firmware validation
# CONFIG_SECURE_BOOT_STORAGE is not set
# CONFIG_MCUBOOT_COMPRESSED_IMAGE_SUPPORT_ENABLED is not set
# CONFIG_MCUBOOT_BOOTLOADER_SIGNATURE_TYPE_ED25519 is not set
# CONFIG_MCUBOOT_BOOTLOADER_SIGNATURE_TYPE_PURE is not set
# end of Bootloader
# Bluetooth Low Energy
CONFIG_BT_COMPANY_ID_NORDIC=0x0059
CONFIG_BT_COMPANY_ID=0x0059
CONFIG_BT_MAX_CONN=9
CONFIG_BT_LL_SOFTDEVICE_HEADERS_INCLUDE=y
CONFIG_BT_LL_SOFTDEVICE=y
CONFIG_BT_CTLR_DF_SUPPORT=y
# SoftDevice Controller
CONFIG_BT_LL_SOFTDEVICE_BUILD_TYPE_LIB=y
CONFIG_BT_HCI_TX_STACK_SIZE=1536
CONFIG_BT_RX_STACK_SIZE=768
# CONFIG_BT_CTLR_SDC_QOS_CHANNEL_SURVEY is not set
# CONFIG_BT_CTLR_SDC_ALLOW_PARALLEL_SCANNING_AND_INITIATING is not set
CONFIG_BT_CTLR_SDC_PERIPHERAL_COUNT=2
# CONFIG_BT_CTLR_SDC_MAX_CONN_EVENT_LEN_DEFAULT_OVERRIDE is not set
CONFIG_BT_CTLR_SDC_MAX_CONN_EVENT_LEN_DEFAULT=7500
CONFIG_BT_CTLR_SDC_CONN_EVENT_EXTEND_DEFAULT=y
CONFIG_BT_CTLR_SDC_CENTRAL_ACL_EVENT_SPACING_DEFAULT=7500
# CONFIG_BT_CTLR_SDC_PERIODIC_ADV_EVENT_LEN_DEFAULT_OVERRIDE is not set
CONFIG_BT_CTLR_SDC_PERIODIC_ADV_EVENT_LEN_DEFAULT=7500
CONFIG_BT_CTLR_SDC_TX_PACKET_COUNT=3
CONFIG_BT_CTLR_SDC_RX_PACKET_COUNT=2
CONFIG_BT_CTLR_SDC_SCAN_BUFFER_COUNT=3
CONFIG_BT_CTLR_SDC_PERIODIC_SYNC_BUFFER_COUNT=3
CONFIG_BT_CTLR_SDC_RX_PRIO=6
# CONFIG_BT_CTLR_DF is not set
CONFIG_BT_LL_SOFTDEVICE_MULTIROLE=y
CONFIG_BT_CTLR_FAL_SIZE=8
CONFIG_BT_CTLR_ECDH_LIB_OBERON=y
# CONFIG_BT_CTLR_ECDH_LIB_TINYCRYPT is not set
CONFIG_BT_CTLR_ECDH_STACK_SIZE=900
CONFIG_BT_CTLR_ECDH_IN_MPSL_WORK=y
# CONFIG_BT_CTLR_SDC_EVENT_TRIGGER is not set
# CONFIG_BT_CTLR_SDC_CONN_ANCHOR_POINT_REPORT is not set
CONFIG_BT_CTLR_SDC_BIG_RESERVED_TIME_US=1600
CONFIG_BT_CTLR_SDC_CIG_RESERVED_TIME_US=1300
CONFIG_BT_CTLR_SDC_CIS_SUBEVENT_LENGTH_US=0
# CONFIG_BT_CTLR_CHANNEL_SOUNDING is not set
# CONFIG_BT_CTLR_SDC_LE_POWER_CLASS_1 is not set
# end of SoftDevice Controller
# CONFIG_BT_RADIO_NOTIFICATION_CONN_CB is not set
# BLE Libraries
# CONFIG_BT_GATT_POOL is not set
# CONFIG_BT_GATT_DM is not set
# CONFIG_BT_ADV_PROV is not set
# CONFIG_BT_SCAN is not set
# CONFIG_BT_CONN_CTX is not set
# Bluetooth Services
# CONFIG_BT_AMS_CLIENT is not set
# CONFIG_BT_ANCS_CLIENT is not set
# CONFIG_BT_BAS_CLIENT is not set
# CONFIG_BT_BMS is not set
# CONFIG_BT_CTS_CLIENT is not set
# CONFIG_BT_DFU_SMP is not set
# CONFIG_BT_GATTP is not set
# CONFIG_BT_HIDS is not set
# CONFIG_BT_HOGP is not set
# CONFIG_BT_LBS is not set
# CONFIG_BT_NSMS is not set
# CONFIG_BT_NUS is not set
# CONFIG_BT_NUS_CLIENT is not set
# CONFIG_BT_RSCS is not set
# CONFIG_BT_THROUGHPUT is not set
# CONFIG_BT_LATENCY is not set
# CONFIG_BT_LATENCY_CLIENT is not set
# CONFIG_BT_HRS_CLIENT is not set
# CONFIG_BT_DDFS is not set
# CONFIG_BT_MDS is not set
# CONFIG_BT_CGMS is not set
# CONFIG_BT_FAST_PAIR is not set
CONFIG_SYSTEM_WORKQUEUE_PRIORITY=-1
# end of Bluetooth Services
# BLE over nRF RPC
CONFIG_HEAP_MEM_POOL_SIZE=8192
CONFIG_BT_DRIVERS=y
# CONFIG_BT_RPC_STACK is not set
CONFIG_BT_CENTRAL=y
CONFIG_BT_PERIPHERAL=y
CONFIG_BT_OBSERVER=y
CONFIG_BT_BROADCASTER=y
CONFIG_BT_CONN=y
CONFIG_BT_REMOTE_VERSION=y
CONFIG_BT_PHY_UPDATE=y
CONFIG_BT_DATA_LEN_UPDATE=y
# CONFIG_BT_EXT_ADV is not set
CONFIG_BT_BUF_ACL_RX_COUNT=10
CONFIG_BT_BUF_EVT_RX_COUNT=10
CONFIG_BT_BUF_EVT_DISCARDABLE_SIZE=43
CONFIG_BT_HAS_HCI_VS=y
# CONFIG_BT_HCI_VS_FATAL_ERROR is not set
# CONFIG_BT_HCI_MESH_EXT is not set
# CONFIG_BT_WAIT_NOP is not set
CONFIG_BT_RPA=y
CONFIG_BT_ASSERT=y
CONFIG_BT_ASSERT_VERBOSE=y
# CONFIG_BT_ASSERT_PANIC is not set
# CONFIG_BT_HCI_ERR_TO_STR is not set
CONFIG_BT_DEBUG_NONE=y
# CONFIG_BT_DEBUG_MONITOR_UART is not set
# CONFIG_BT_LONG_WQ is not set
# CONFIG_BT_HCI_TX_STACK_SIZE_WITH_PROMPT is not set
CONFIG_BT_HCI_TX_PRIO=7
# CONFIG_BT_RECV_WORKQ_SYS is not set
CONFIG_BT_RECV_WORKQ_BT=y
CONFIG_BT_RX_PRIO=8
CONFIG_BT_DRIVER_RX_HIGH_PRIO=6
# CONFIG_BT_CONN_TX_NOTIFY_WQ is not set
# CONFIG_BT_TINYCRYPT_ECC is not set
# CONFIG_BT_HOST_CCM is not set
# CONFIG_BT_LOG_SNIFFER_INFO is not set
# CONFIG_BT_TESTING is not set
# CONFIG_BT_HCI_VS_EVT_USER is not set
# CONFIG_BT_SHELL is not set
# end of BLE over nRF RPC
# end of Bluetooth Low Energy
# DFU
# CONFIG_DFU_MULTI_IMAGE is not set
# CONFIG_DFU_TARGET is not set
# end of DFU
# CONFIG_ESB is not set
# Peripheral CPU DFU (PCD)
# CONFIG_PCD is not set
# CONFIG_PCD_APP is not set
CONFIG_PCD_VERSION_PAGE_BUF_SIZE=2046
# CONFIG_PCD_NET is not set
# end of Peripheral CPU DFU (PCD)
# Networking
# Application protocols
# nRF Cloud
# Transport
# CONFIG_NRF_CLOUD_REST is not set
# end of Transport
# Credentials
CONFIG_NRF_CLOUD_SEC_TAG=16842753
CONFIG_NRF_CLOUD_AWS_CA_CERT_SIZE_THRESHOLD=1150
CONFIG_NRF_CLOUD_COAP_CA_CERT_SIZE_THRESHOLD=550
# end of Credentials
# Client ID (nRF Cloud Device ID)
CONFIG_NRF_CLOUD_CLIENT_ID_SRC_COMPILE_TIME=y
# CONFIG_NRF_CLOUD_CLIENT_ID_SRC_RUNTIME is not set
CONFIG_NRF_CLOUD_CLIENT_ID="my-client-id"
# end of Client ID (nRF Cloud Device ID)
# Firmware Over-the-Air (FOTA) Updates
# CONFIG_NRF_CLOUD_FOTA is not set
CONFIG_FOTA_USE_NRF_CLOUD_SETTINGS_AREA=y
# CONFIG_NRF_CLOUD_FOTA_FULL_MODEM_UPDATE is not set
# CONFIG_NRF_CLOUD_FOTA_SMP is not set
# end of Firmware Over-the-Air (FOTA) Updates
# Location
# Cellular/Wi-Fi
# CONFIG_NRF_CLOUD_LOCATION_PARSE_ANCHORS is not set
# CONFIG_NRF_CLOUD_WIFI_LOCATION_ENCODE_OPT_MAC_ONLY is not set
CONFIG_NRF_CLOUD_WIFI_LOCATION_ENCODE_OPT_MAC_RSSI=y
# CONFIG_NRF_CLOUD_WIFI_LOCATION_ENCODE_OPT_ALL is not set
# end of Cellular/Wi-Fi
# end of Location
# Alerts
# CONFIG_NRF_CLOUD_ALERT is not set
# end of Alerts
# Logging
CONFIG_NRF_CLOUD_LOG_OUTPUT_LEVEL=1
# CONFIG_NRF_CLOUD_LOG_INCLUDE_LEVEL_0 is not set
CONFIG_NRF_CLOUD_LOG_BUF_SIZE=256
# end of Logging
# Device Shadow
# Send shadow info sections on initial connect (MQTT/CoAP)
# end of Send shadow info sections on initial connect (MQTT/CoAP)
# end of Device Shadow
CONFIG_NRF_CLOUD_PRINT_DETAILS=y
CONFIG_NRF_CLOUD_VERBOSE_DETAILS=y
# CONFIG_NRF_CLOUD_GATEWAY is not set
# end of nRF Cloud
# CONFIG_REST_CLIENT is not set
# CONFIG_DOWNLOAD_CLIENT is not set
# CONFIG_AWS_IOT is not set
# CONFIG_AWS_JOBS is not set
# CONFIG_AZURE_IOT_HUB is not set
# Self-Registration (Zi ZHu Ce)
# end of Self-Registration (Zi ZHu Ce)
# CONFIG_ICAL_PARSER is not set
# CONFIG_FTP_CLIENT is not set
# CONFIG_LWM2M_CLIENT_UTILS is not set
# CONFIG_WIFI_CREDENTIALS is not set
# CONFIG_WIFI_CREDENTIALS_STATIC is not set
# CONFIG_MQTT_HELPER is not set
# CONFIG_NRF_MCUMGR_SMP_CLIENT is not set
# end of Application protocols
# CONFIG_OPENTHREAD_RPC is not set
# end of Networking
# NFC
# CONFIG_NFC_NDEF is not set
# CONFIG_NFC_NDEF_PARSER is not set
# CONFIG_NFC_NDEF_PAYLOAD_TYPE_COMMON is not set
# CONFIG_NFC_T2T_PARSER is not set
# CONFIG_NFC_T4T_NDEF_FILE is not set
# CONFIG_NFC_T4T_ISODEP is not set
# CONFIG_NFC_T4T_APDU is not set
# CONFIG_NFC_T4T_CC_FILE is not set
# CONFIG_NFC_T4T_HL_PROCEDURE is not set
# CONFIG_NFC_PLATFORM is not set
# CONFIG_NFC_TNEP_TAG is not set
# CONFIG_NFC_TNEP_POLLER is not set
# CONFIG_NFC_TNEP_CH is not set
# CONFIG_NFC_RPC is not set
# end of NFC
# CONFIG_APP_EVENT_MANAGER is not set
# CONFIG_NRF_PROFILER is not set
CONFIG_FW_INFO=y
# CONFIG_FW_INFO_API is not set
CONFIG_FW_INFO_OFFSET=0x200
CONFIG_FW_INFO_FIRMWARE_VERSION=1
CONFIG_FW_INFO_MAGIC_COMMON=0x281ee6de
CONFIG_FW_INFO_MAGIC_FIRMWARE_INFO=0x8fcebb4c
CONFIG_FW_INFO_MAGIC_EXT_API=0xb845acea
CONFIG_FW_INFO_HARDWARE_ID=53
CONFIG_FW_INFO_VERSION=2
CONFIG_FW_INFO_CRYPTO_ID=0
CONFIG_FW_INFO_MAGIC_COMPATIBILITY_ID=0
CONFIG_FW_INFO_MAGIC_LEN=12
CONFIG_FW_INFO_VALID_VAL=0x9102FFFF
CONFIG_EXT_API_PROVIDE_EXT_API_UNUSED=y
# CONFIG_EXT_API_PROVIDE_EXT_API_OPTIONAL is not set
# CONFIG_EXT_API_PROVIDE_EXT_API_REQUIRED is not set
# CONFIG_EXT_API_PROVIDE_EXT_API_ATLEAST_OPTIONAL is not set
# CONFIG_EXT_API_PROVIDE_EXT_API_ENABLED is not set
# Debug
# CONFIG_CPU_LOAD is not set
# CONFIG_PPI_TRACE is not set
# end of Debug
# CONFIG_SHELL_BT_NUS is not set
# CONFIG_SHELL_IPC is not set
# Multiprotocol service layer (MPSL)
# CONFIG_MPSL_FEM_ONLY is not set
CONFIG_MPSL_FEM_ANY_SUPPORT=y
CONFIG_MPSL_FEM_GENERIC_TWO_CTRL_PINS_SUPPORT=y
CONFIG_MPSL_FEM_NCS_SUPPORTED_FEM_USED=y
CONFIG_MPSL_FEM_API_AVAILABLE=y
CONFIG_MPSL_FEM=y
CONFIG_MPSL_FEM_SIMPLE_GPIO=y
# CONFIG_MPSL_FEM_POWER_MODEL is not set
CONFIG_MPSL_FEM_DEVICE_CONFIG_254=y
CONFIG_MPSL_FEM_INIT_PRIORITY=50
CONFIG_MPSL_THREAD_COOP_PRIO=6
CONFIG_MPSL_TIMESLOT_SESSION_COUNT=0
# CONFIG_MPSL_ASSERT_HANDLER is not set
# CONFIG_MPSL_TRIGGER_IPC_TASK_ON_RTC_START is not set
CONFIG_MPSL_LOW_PRIO_IRQN=26
CONFIG_MPSL_HFCLK_LATENCY=1400
# end of Multiprotocol service layer (MPSL)
# Partition Manager
CONFIG_PARTITION_MANAGER_ENABLED=y
CONFIG_FLASH_MAP_CUSTOM=y
CONFIG_SRAM_BASE_ADDRESS=0x21000000
# Zephyr subsystem configurations
# end of Zephyr subsystem configurations
# NCS subsystem configurations
# CONFIG_PM_SINGLE_IMAGE is not set
CONFIG_PM_EXTERNAL_FLASH_BASE=0
CONFIG_PM_EXTERNAL_FLASH_PATH=""
CONFIG_PM_EXTERNAL_FLASH_SIZE_BITS=0
# CONFIG_PM_OVERRIDE_EXTERNAL_DRIVER_CHECK is not set
CONFIG_PM_SRAM_BASE=0x21000000
CONFIG_PM_SRAM_SIZE=0x10000
# end of Partition Manager
# nRF RPC (Remote Procedure Call) library
# end of nRF RPC (Remote Procedure Call) library
# Full Modem Firmware Update Management(FMFU)
# end of Full Modem Firmware Update Management(FMFU)
# CONFIG_CAF is not set
# Nordic IEEE 802.15.4
# end of Nordic IEEE 802.15.4
# CONFIG_DM_MODULE is not set
# nRF Security
# CONFIG_NORDIC_SECURITY_BACKEND is not set
# CONFIG_NRF_SECURITY is not set
# Nordic-added meta types
# Nordic added alg types
# CONFIG_PSA_WANT_ALG_ECDSA_ANY is not set
# CONFIG_PSA_WANT_ALG_ED25519PH is not set
# CONFIG_PSA_WANT_ALG_ED448PH is not set
# CONFIG_PSA_WANT_ALG_PURE_EDDSA is not set
# CONFIG_PSA_WANT_ALG_RSA_PKCS1V15_SIGN_RAW is not set
# CONFIG_PSA_WANT_ALG_RSA_PSS_ANY_SALT is not set
# CONFIG_PSA_WANT_ALG_SHA_512_224 is not set
# CONFIG_PSA_WANT_ALG_SHA_512_256 is not set
# CONFIG_PSA_WANT_ALG_SPAKE2P_HMAC is not set
# CONFIG_PSA_WANT_ALG_SPAKE2P_CMAC is not set
# CONFIG_PSA_WANT_ALG_SPAKE2P_MATTER is not set
# CONFIG_PSA_WANT_ALG_SRP_6 is not set
# CONFIG_PSA_WANT_ALG_SRP_PASSWORD_HASH is not set
# CONFIG_PSA_WANT_ALG_XTS is not set
# Nordic added ECC curve types
# CONFIG_PSA_WANT_ECC_BRAINPOOL_P_R1_160 is not set
# CONFIG_PSA_WANT_ECC_BRAINPOOL_P_R1_192 is not set
# CONFIG_PSA_WANT_ECC_BRAINPOOL_P_R1_224 is not set
# CONFIG_PSA_WANT_ECC_BRAINPOOL_P_R1_320 is not set
# CONFIG_PSA_WANT_ECC_TWISTED_EDWARDS_255 is not set
# CONFIG_PSA_WANT_ECC_TWISTED_EDWARDS_448 is not set
# CONFIG_PSA_WANT_ECC_SECP_K1_224 is not set
# CONFIG_PSA_WANT_ECC_SECP_R2_160 is not set
# CONFIG_PSA_WANT_ECC_SECT_K1_163 is not set
# CONFIG_PSA_WANT_ECC_SECT_K1_233 is not set
# CONFIG_PSA_WANT_ECC_SECT_K1_239 is not set
# CONFIG_PSA_WANT_ECC_SECT_K1_283 is not set
# CONFIG_PSA_WANT_ECC_SECT_K1_409 is not set
# CONFIG_PSA_WANT_ECC_SECT_K1_571 is not set
# CONFIG_PSA_WANT_ECC_SECT_R1_163 is not set
# CONFIG_PSA_WANT_ECC_SECT_R1_233 is not set
# CONFIG_PSA_WANT_ECC_SECT_R1_283 is not set
# CONFIG_PSA_WANT_ECC_SECT_R1_409 is not set
# CONFIG_PSA_WANT_ECC_SECT_R1_571 is not set
# CONFIG_PSA_WANT_ECC_SECT_R2_163 is not set
# CONFIG_PSA_WANT_ECC_FRP_V1_256 is not set
# CONFIG_PSA_WANT_ALG_CHACHA20 is not set
# CONFIG_PSA_WANT_ALG_SHAKE256_512 is not set
# Nordic addded RNG configuration
# CONFIG_PSA_WANT_GENERATE_RANDOM is not set
# Nordic added key types
# CONFIG_PSA_WANT_KEY_TYPE_PEPPER is not set
# CONFIG_PSA_WANT_KEY_TYPE_SPAKE2P_KEY_PAIR_IMPORT is not set
# CONFIG_PSA_WANT_KEY_TYPE_SPAKE2P_KEY_PAIR_EXPORT is not set
# CONFIG_PSA_WANT_KEY_TYPE_SPAKE2P_KEY_PAIR_GENERATE is not set
# CONFIG_PSA_WANT_KEY_TYPE_SPAKE2P_KEY_PAIR_DERIVE is not set
# CONFIG_PSA_WANT_KEY_TYPE_SPAKE2P_PUBLIC_KEY is not set
# CONFIG_PSA_WANT_KEY_TYPE_SRP_KEY_PAIR_IMPORT is not set
# CONFIG_PSA_WANT_KEY_TYPE_SRP_KEY_PAIR_EXPORT is not set
# CONFIG_PSA_WANT_KEY_TYPE_SRP_KEY_PAIR_GENERATE is not set
# CONFIG_PSA_WANT_KEY_TYPE_SRP_KEY_PAIR_DERIVE is not set
# CONFIG_PSA_WANT_KEY_TYPE_SRP_PUBLIC_KEY is not set
# end of nRF Security
# CONFIG_NET_CORE_MONITOR is not set
# Audio Modules
# CONFIG_AUDIO_MODULE_TEST is not set
CONFIG_AUDIO_MODULE_NAME_SIZE=20
# Log levels
# end of Log levels
# end of Audio Modules
# Audio Modules
# CONFIG_AUDIO_MODULE_TEMPLATE is not set
# CONFIG_TRUSTED_STORAGE is not set
# Logging over RPC
# end of Logging over RPC
# SUIT provisioning
# CONFIG_SUIT_MPI_GENERATE is not set
# end of SUIT provisioning
# CONFIG_SUIT is not set
# CONFIG_DULT is not set
# CONFIG_NRF_COMPRESS is not set
# MCUboot IDs (informative only, do not change)
CONFIG_MCUBOOT_APPLICATION_IMAGE_NUMBER=-1
CONFIG_MCUBOOT_NETWORK_CORE_IMAGE_NUMBER=-1
CONFIG_MCUBOOT_WIFI_PATCHES_IMAGE_NUMBER=-1
CONFIG_MCUBOOT_QSPI_XIP_IMAGE_NUMBER=-1
CONFIG_MCUBOOT_MCUBOOT_IMAGE_NUMBER=-1
# end of MCUboot IDs (informative only, do not change)
# end of Subsystems
# CONFIG_WFA_QT_CONTROL_APP is not set
CONFIG_WFA_QT_THREAD_STACK_SIZE=5200
CONFIG_WFA_QT_REBOOT_TIMEOUT_MS=1000
CONFIG_WFA_QT_DEFAULT_INTERFACE="wlan0"
CONFIG_WPAS_READY_TIMEOUT_MS=10000
# Libraries
# Binary libraries
# end of Binary libraries
# CONFIG_AT_MONITOR is not set
# CONFIG_LTE_LINK_CONTROL is not set
CONFIG_NRF_ACL_FLASH_REGION_SIZE=0x800
CONFIG_FPROTECT_BLOCK_SIZE=0x800
# CONFIG_FPROTECT is not set
# CONFIG_AT_CMD_CUSTOM is not set
# CONFIG_DK_LIBRARY is not set
# CONFIG_AT_CMD_PARSER is not set
# CONFIG_AT_PARSER is not set
# CONFIG_MODEM_INFO is not set
CONFIG_MULTITHREADING_LOCK=y
# CONFIG_RESET_ON_FATAL_ERROR is not set
# CONFIG_SMS is not set
# CONFIG_DATE_TIME is not set
# CONFIG_HW_ID_LIBRARY is not set
# CONFIG_WAVE_GEN_LIB is not set
CONFIG_HW_UNIQUE_KEY_PARTITION_SIZE=0x800
# CONFIG_MODEM_JWT is not set
# CONFIG_LOCATION is not set
# CONFIG_QOS is not set
# CONFIG_SFLOAT is not set
# CONFIG_CONTIN_ARRAY is not set
# CONFIG_PCM_MIX is not set
# CONFIG_TONE is not set
# CONFIG_PSCM is not set
# CONFIG_DATA_FIFO is not set
# CONFIG_FEM_AL_LIB is not set
# CONFIG_SAMPLE_RATE_CONVERTER is not set
CONFIG_NCS_BOOT_BANNER=y
CONFIG_NCS_NCS_BOOT_BANNER_STRING="nRF Connect SDK"
CONFIG_NCS_ZEPHYR_BOOT_BANNER_STRING="Zephyr OS"
# end of Libraries
# Device Drivers
# CONFIG_BT_DRIVER_QUIRK_NO_AUTO_DLE is not set
# CONFIG_FLASH_RPC is not set
CONFIG_CLOCK_CONTROL_MPSL=y
CONFIG_SOC_FLASH_NRF_RADIO_SYNC_MPSL_TIMESLOT_SESSION_COUNT=0
# CONFIG_ETH_RTT is not set
# CONFIG_SENSOR is not set
# CONFIG_NRF_SW_LPUART is not set
CONFIG_NRFX_GPIOTE_NUM_OF_EVT_HANDLERS=1
# CONFIG_IPC_UART is not set
# end of Device Drivers
# External libraries
# end of External libraries
# Test
CONFIG_ZTEST_MULTICORE_DEFAULT_SETTINGS=y
# CONFIG_UNITY is not set
# Mocks
# CONFIG_MOCK_NRF_MODEM_AT is not set
# CONFIG_MOCK_NRF_RPC is not set
# end of Mocks
# end of Test
# end of Nordic nRF Connect
CONFIG_ZEPHYR_NRF_MODULE=y
# end of nrf (C:/ncs/v2.9.2/nrf)
# mcuboot (C:/ncs/v2.9.2/bootloader/mcuboot)
# MCUboot
CONFIG_BOOT_SIGNATURE_KEY_FILE=""
CONFIG_DT_FLASH_WRITE_BLOCK_SIZE=4
# CONFIG_USE_NRF53_MULTI_IMAGE_WITHOUT_UPGRADE_ONLY is not set
# end of MCUboot
CONFIG_ZEPHYR_MCUBOOT_MODULE=y
# end of mcuboot (C:/ncs/v2.9.2/bootloader/mcuboot)
# mbedtls (C:/ncs/v2.9.2/modules/crypto/mbedtls)
CONFIG_ZEPHYR_MBEDTLS_MODULE=y
# end of mbedtls (C:/ncs/v2.9.2/modules/crypto/mbedtls)
# oberon-psa-crypto (C:/ncs/v2.9.2/modules/crypto/oberon-psa-crypto)
CONFIG_ZEPHYR_OBERON_PSA_CRYPTO_MODULE=y
# end of oberon-psa-crypto (C:/ncs/v2.9.2/modules/crypto/oberon-psa-crypto)
# trusted-firmware-m (C:/ncs/v2.9.2/modules/tee/tf-m/trusted-firmware-m)
# CONFIG_BOOTLOADER_MCUBOOT is not set
CONFIG_ZEPHYR_TRUSTED_FIRMWARE_M_MODULE=y
# end of trusted-firmware-m (C:/ncs/v2.9.2/modules/tee/tf-m/trusted-firmware-m)
CONFIG_ZEPHYR_PSA_ARCH_TESTS_MODULE=y
CONFIG_ZEPHYR_SOC_HWMV1_MODULE=y
# cjson (C:/ncs/v2.9.2/modules/lib/cjson)
# CONFIG_CJSON_LIB is not set
CONFIG_ZEPHYR_CJSON_MODULE=y
# end of cjson (C:/ncs/v2.9.2/modules/lib/cjson)
# azure-sdk-for-c (C:/ncs/v2.9.2/modules/lib/azure-sdk-for-c)
# CONFIG_AZURE_SDK is not set
CONFIG_ZEPHYR_AZURE_SDK_FOR_C_MODULE=y
# end of azure-sdk-for-c (C:/ncs/v2.9.2/modules/lib/azure-sdk-for-c)
# cirrus-logic (C:/ncs/v2.9.2/modules/hal/cirrus-logic)
# CONFIG_HW_CODEC_CIRRUS_LOGIC is not set
CONFIG_ZEPHYR_CIRRUS_LOGIC_MODULE=y
# end of cirrus-logic (C:/ncs/v2.9.2/modules/hal/cirrus-logic)
# openthread (C:/ncs/v2.9.2/modules/lib/openthread)
# CONFIG_OPENTHREAD is not set
CONFIG_ZEPHYR_OPENTHREAD_MODULE=y
# end of openthread (C:/ncs/v2.9.2/modules/lib/openthread)
# suit-generator (C:/ncs/v2.9.2/modules/lib/suit-generator)
CONFIG_SUIT_ENVELOPE_TEMPLATE_FILENAME=""
CONFIG_SUIT_ENVELOPE_TARGET=""
CONFIG_SUIT_ENVELOPE_OUTPUT_ARTIFACT="merged.hex"
# CONFIG_SUIT_RECOVERY is not set
CONFIG_SUIT_ENVELOPE_OUTPUT_MPI_MERGE=y
# CONFIG_SUIT_LOCAL_ENVELOPE_GENERATE is not set
# CONFIG_SUIT_DFU_CACHE_EXTRACT_IMAGE is not set
CONFIG_ZEPHYR_SUIT_GENERATOR_MODULE=y
# end of suit-generator (C:/ncs/v2.9.2/modules/lib/suit-generator)
# suit-processor (C:/ncs/v2.9.2/modules/lib/suit-processor)
# CONFIG_SUIT_PROCESSOR is not set
CONFIG_SUIT_PLATFORM_DRY_RUN_SUPPORT=y
CONFIG_ZEPHYR_SUIT_PROCESSOR_MODULE=y
# end of suit-processor (C:/ncs/v2.9.2/modules/lib/suit-processor)
# memfault-firmware-sdk (C:/ncs/v2.9.2/modules/lib/memfault-firmware-sdk)
# CONFIG_MEMFAULT is not set
CONFIG_ZEPHYR_MEMFAULT_FIRMWARE_SDK_MODULE=y
# end of memfault-firmware-sdk (C:/ncs/v2.9.2/modules/lib/memfault-firmware-sdk)
# coremark (C:/ncs/v2.9.2/modules/benchmark/coremark)
# CONFIG_COREMARK is not set
CONFIG_ZEPHYR_COREMARK_MODULE=y
# end of coremark (C:/ncs/v2.9.2/modules/benchmark/coremark)
# canopennode (C:/ncs/v2.9.2/modules/lib/canopennode)
CONFIG_ZEPHYR_CANOPENNODE_MODULE=y
# end of canopennode (C:/ncs/v2.9.2/modules/lib/canopennode)
# chre (C:/ncs/v2.9.2/modules/lib/chre)
CONFIG_ZEPHYR_CHRE_MODULE=y
# CONFIG_CHRE is not set
# end of chre (C:/ncs/v2.9.2/modules/lib/chre)
# lz4 (C:/ncs/v2.9.2/modules/lib/lz4)
CONFIG_ZEPHYR_LZ4_MODULE=y
# CONFIG_LZ4 is not set
# end of lz4 (C:/ncs/v2.9.2/modules/lib/lz4)
# nanopb (C:/ncs/v2.9.2/modules/lib/nanopb)
CONFIG_ZEPHYR_NANOPB_MODULE=y
# CONFIG_NANOPB is not set
# end of nanopb (C:/ncs/v2.9.2/modules/lib/nanopb)
CONFIG_ZEPHYR_TF_M_TESTS_MODULE=y
# zscilib (C:/ncs/v2.9.2/modules/lib/zscilib)
# CONFIG_ZSL is not set
CONFIG_ZEPHYR_ZSCILIB_MODULE=y
# end of zscilib (C:/ncs/v2.9.2/modules/lib/zscilib)
# cmsis (C:/ncs/v2.9.2/modules/hal/cmsis)
CONFIG_ZEPHYR_CMSIS_MODULE=y
CONFIG_HAS_CMSIS_CORE=y
CONFIG_HAS_CMSIS_CORE_M=y
# CONFIG_CMSIS_M_CHECK_DEVICE_DEFINES is not set
# end of cmsis (C:/ncs/v2.9.2/modules/hal/cmsis)
# cmsis-dsp (C:/ncs/v2.9.2/modules/lib/cmsis-dsp)
CONFIG_ZEPHYR_CMSIS_DSP_MODULE=y
# CONFIG_CMSIS_DSP is not set
# end of cmsis-dsp (C:/ncs/v2.9.2/modules/lib/cmsis-dsp)
# cmsis-nn (C:/ncs/v2.9.2/modules/lib/cmsis-nn)
CONFIG_ZEPHYR_CMSIS_NN_MODULE=y
# CONFIG_CMSIS_NN is not set
# end of cmsis-nn (C:/ncs/v2.9.2/modules/lib/cmsis-nn)
# fatfs (C:/ncs/v2.9.2/modules/fs/fatfs)
CONFIG_ZEPHYR_FATFS_MODULE=y
# end of fatfs (C:/ncs/v2.9.2/modules/fs/fatfs)
# hal_nordic (C:/ncs/v2.9.2/modules/hal/nordic)
CONFIG_ZEPHYR_HAL_NORDIC_MODULE=y
CONFIG_HAS_NORDIC_DRIVERS=y
# Nordic drivers
# CONFIG_NRF_802154_SOURCE_HAL_NORDIC is not set
# CONFIG_NRF_802154_SER_RADIO is not set
# end of Nordic drivers
CONFIG_HAS_NRFX=y
# nrfx drivers
# CONFIG_NRFX_CLOCK is not set
CONFIG_NRFX_DPPI=y
CONFIG_NRFX_DPPI0=y
# CONFIG_NRFX_EGU0 is not set
CONFIG_NRFX_GPIOTE=y
CONFIG_NRFX_GPIOTE0=y
CONFIG_NRFX_GPPI=y
CONFIG_NRFX_IPC=y
CONFIG_NRFX_NVMC=y
# CONFIG_NRFX_POWER is not set
# CONFIG_NRFX_RNG is not set
# CONFIG_NRFX_RTC0 is not set
# CONFIG_NRFX_RTC1 is not set
# CONFIG_NRFX_SPIM0 is not set
# CONFIG_NRFX_SYSTICK is not set
# CONFIG_NRFX_TEMP is not set
# CONFIG_NRFX_TIMER0 is not set
# CONFIG_NRFX_TIMER1 is not set
# CONFIG_NRFX_TIMER2 is not set
# CONFIG_NRFX_TWIM0 is not set
# CONFIG_NRFX_UARTE0 is not set
# CONFIG_NRFX_WDT0 is not set
# Peripheral Resource Sharing module
# CONFIG_NRFX_PRS_BOX_0 is not set
# CONFIG_NRFX_PRS_BOX_1 is not set
# CONFIG_NRFX_PRS_BOX_2 is not set
# CONFIG_NRFX_PRS_BOX_3 is not set
# CONFIG_NRFX_PRS_BOX_4 is not set
# end of Peripheral Resource Sharing module
CONFIG_NRFX_RESERVED_RESOURCES_HEADER="nrfx_config_reserved_resources_ncs.h"
# end of nrfx drivers
# end of hal_nordic (C:/ncs/v2.9.2/modules/hal/nordic)
# hal_st (C:/ncs/v2.9.2/modules/hal/st)
CONFIG_ZEPHYR_HAL_ST_MODULE=y
# end of hal_st (C:/ncs/v2.9.2/modules/hal/st)
CONFIG_ZEPHYR_HAL_WURTHELEKTRONIK_MODULE=y
# hostap (C:/ncs/v2.9.2/modules/lib/hostap)
# CONFIG_WIFI_NM_WPA_SUPPLICANT is not set
CONFIG_ZEPHYR_HOSTAP_MODULE=y
# end of hostap (C:/ncs/v2.9.2/modules/lib/hostap)
CONFIG_ZEPHYR_LIBMETAL_MODULE=y
# liblc3 (C:/ncs/v2.9.2/modules/lib/liblc3)
CONFIG_ZEPHYR_LIBLC3_MODULE=y
# end of liblc3 (C:/ncs/v2.9.2/modules/lib/liblc3)
# littlefs (C:/ncs/v2.9.2/modules/fs/littlefs)
CONFIG_ZEPHYR_LITTLEFS_MODULE=y
# end of littlefs (C:/ncs/v2.9.2/modules/fs/littlefs)
# loramac-node (C:/ncs/v2.9.2/modules/lib/loramac-node)
CONFIG_ZEPHYR_LORAMAC_NODE_MODULE=y
# CONFIG_HAS_SEMTECH_RADIO_DRIVERS is not set
# end of loramac-node (C:/ncs/v2.9.2/modules/lib/loramac-node)
# lvgl (C:/ncs/v2.9.2/modules/lib/gui/lvgl)
CONFIG_ZEPHYR_LVGL_MODULE=y
# end of lvgl (C:/ncs/v2.9.2/modules/lib/gui/lvgl)
CONFIG_ZEPHYR_MIPI_SYS_T_MODULE=y
# nrf_wifi (C:/ncs/v2.9.2/modules/lib/nrf_wifi)
CONFIG_ZEPHYR_NRF_WIFI_MODULE=y
# CONFIG_NRF70_BUSLIB is not set
# end of nrf_wifi (C:/ncs/v2.9.2/modules/lib/nrf_wifi)
CONFIG_ZEPHYR_OPEN_AMP_MODULE=y
# picolibc (C:/ncs/v2.9.2/modules/lib/picolibc)
# CONFIG_PICOLIBC_MODULE is not set
CONFIG_ZEPHYR_PICOLIBC_MODULE=y
# end of picolibc (C:/ncs/v2.9.2/modules/lib/picolibc)
# segger (C:/ncs/v2.9.2/modules/debug/segger)
CONFIG_ZEPHYR_SEGGER_MODULE=y
CONFIG_HAS_SEGGER_RTT=y
# CONFIG_USE_SEGGER_RTT is not set
# end of segger (C:/ncs/v2.9.2/modules/debug/segger)
CONFIG_ZEPHYR_TINYCRYPT_MODULE=y
# uoscore-uedhoc (C:/ncs/v2.9.2/modules/lib/uoscore-uedhoc)
CONFIG_ZEPHYR_UOSCORE_UEDHOC_MODULE=y
# end of uoscore-uedhoc (C:/ncs/v2.9.2/modules/lib/uoscore-uedhoc)
# zcbor (C:/ncs/v2.9.2/modules/lib/zcbor)
CONFIG_ZEPHYR_ZCBOR_MODULE=y
# CONFIG_ZCBOR is not set
# end of zcbor (C:/ncs/v2.9.2/modules/lib/zcbor)
# nrfxlib (C:/ncs/v2.9.2/nrfxlib)
# Nordic nrfxlib
# nrf_modem (Modem library)
CONFIG_NRF_MODEM_SHMEM_CTRL_SIZE=0x4e8
# end of nrf_modem (Modem library)
# CONFIG_NFC_T2T_NRFXLIB is not set
# CONFIG_NFC_T4T_NRFXLIB is not set
CONFIG_MPSL=y
CONFIG_MPSL_BUILD_TYPE_LIB=y
CONFIG_MPSL_LIB_DIR="nrf53"
CONFIG_MPSL_LIB_FLOAT_ABI_DIR="soft-float"
# Crypto libraries for nRF5x SOCs.
CONFIG_NRFXLIB_CRYPTO=y
CONFIG_NRF_OBERON=y
# CONFIG_NRF_CC310_BL is not set
# end of Crypto libraries for nRF5x SOCs.
# CONFIG_NRF_RPC is not set
CONFIG_NRF_802154_SOURCE_NRFXLIB=y
# CONFIG_GZLL is not set
# CONFIG_NRF_DM is not set
# CONFIG_NRF_FUEL_GAUGE is not set
# end of Nordic nrfxlib
CONFIG_ZEPHYR_NRFXLIB_MODULE=y
# end of nrfxlib (C:/ncs/v2.9.2/nrfxlib)
CONFIG_ZEPHYR_NRF_HW_MODELS_MODULE=y
# connectedhomeip (C:/ncs/v2.9.2/modules/lib/matter)
# CONFIG_CHIP is not set
CONFIG_ZEPHYR_CONNECTEDHOMEIP_MODULE=y
# end of connectedhomeip (C:/ncs/v2.9.2/modules/lib/matter)
CONFIG_LIBMETAL=y
CONFIG_LIBMETAL_SRC_PATH="libmetal"
# CONFIG_LVGL is not set
# CONFIG_HAS_MEC_HAL is not set
# CONFIG_HAS_MPFS_HAL is not set
# CONFIG_HAS_MEC5_HAL is not set
CONFIG_OPENAMP=y
CONFIG_OPENAMP_SRC_PATH="open-amp"
CONFIG_OPENAMP_MASTER=y
CONFIG_OPENAMP_SLAVE=y
# CONFIG_MIPI_SYST_LIB is not set
# CONFIG_HAS_TELINK_DRIVERS is not set
# CONFIG_TINYCRYPT_CTR_PRNG is not set
# CONFIG_TINYCRYPT_SHA256 is not set
# CONFIG_TINYCRYPT_ECC_DH is not set
# CONFIG_TINYCRYPT_ECC_DSA is not set
CONFIG_TINYCRYPT_AES=y
# CONFIG_TINYCRYPT_AES_CBC is not set
# CONFIG_TINYCRYPT_AES_CTR is not set
# CONFIG_TINYCRYPT_AES_CCM is not set
# CONFIG_TINYCRYPT_AES_CMAC is not set
# CONFIG_MCUBOOT_BOOTUTIL_LIB is not set
# Unavailable modules, please install those via the project manifest.
# hal_gigadevice module not available.
# Trusted-firmware-a module not available.
# THRIFT module not available.
# CONFIG_ACPI is not set
# end of Modules
CONFIG_BOARD="hg1_nrf5340"
CONFIG_BOARD_REVISION=""
CONFIG_BOARD_TARGET="hg1_nrf5340/nrf5340/cpunet"
# CONFIG_NET_DRIVERS is not set
CONFIG_BOARD_HG1_NRF5340=y
CONFIG_BOARD_HG1_NRF5340_NRF5340_CPUNET=y
CONFIG_BOARD_QUALIFIERS="nrf5340/cpunet"
# Board Options
CONFIG_DOMAIN_CPUAPP_BOARD="hg1_nrf5340/nrf5340/cpuapp"
# end of Board Options
# Hardware Configuration
CONFIG_SOC_FAMILY_NORDIC_NRF=y
CONFIG_SOC_SERIES_NRF53X=y
CONFIG_SOC_NRF5340_CPUNET=y
CONFIG_SOC_NRF5340_CPUNET_QKAA=y
# CONFIG_BUILD_OUTPUT_INFO_HEADER is not set
CONFIG_HAS_HW_NRF_ACL=y
CONFIG_HAS_HW_NRF_CCM=y
CONFIG_HAS_HW_NRF_CCM_LFLEN_8BIT=y
CONFIG_HAS_HW_NRF_CCM_HEADERMASK=y
CONFIG_HAS_HW_NRF_CLOCK=y
CONFIG_HAS_HW_NRF_DPPIC=y
CONFIG_HAS_HW_NRF_ECB=y
CONFIG_HAS_HW_NRF_EGU0=y
CONFIG_HAS_HW_NRF_GPIO0=y
CONFIG_HAS_HW_NRF_GPIO1=y
CONFIG_HAS_HW_NRF_GPIOTE0=y
CONFIG_HAS_HW_NRF_NVMC_PE=y
CONFIG_HAS_HW_NRF_POWER=y
CONFIG_HAS_HW_NRF_RADIO_BLE_2M=y
CONFIG_HAS_HW_NRF_RADIO_BLE_CODED=y
CONFIG_HAS_HW_NRF_RADIO_DFE=y
CONFIG_HAS_HW_NRF_RADIO_IEEE802154=y
CONFIG_HAS_HW_NRF_RNG=y
CONFIG_HAS_HW_NRF_SWI0=y
CONFIG_HAS_HW_NRF_SWI1=y
CONFIG_HAS_HW_NRF_SWI2=y
CONFIG_HAS_HW_NRF_SWI3=y
CONFIG_HAS_HW_NRF_TEMP=y
CONFIG_HAS_HW_NRF_TIMER0=y
CONFIG_HAS_HW_NRF_TIMER1=y
CONFIG_HAS_HW_NRF_TIMER2=y
CONFIG_HAS_HW_NRF_VMC=y
CONFIG_HAS_HW_NRF_WDT0=y
# CONFIG_HAS_NORDIC_RAM_CTRL is not set
# CONFIG_NRF_SYS_EVENT is not set
CONFIG_SOC_NRF53_ANOMALY_160_WORKAROUND_NEEDED=y
CONFIG_SOC_NRF53_ANOMALY_160_WORKAROUND=y
CONFIG_SOC_NRF53_ANOMALY_168_WORKAROUND=y
CONFIG_SOC_NRF53_RTC_PRETICK=y
CONFIG_SOC_NRF53_RTC_PRETICK_IPC_CH_FROM_NET=10
CONFIG_SOC_NRF53_RTC_PRETICK_IPC_CH_TO_NET=11
CONFIG_NRF_ENABLE_CACHE=y
# CONFIG_NRF53_SYNC_RTC is not set
CONFIG_NRF_RTC_TIMER_USER_CHAN_COUNT=0
# CONFIG_SOC_NRF54H20_GPD is not set
# CONFIG_SOC_NRF54H20_NO_MRAM_LATENCY is not set
CONFIG_NRF_SOC_SECURE_SUPPORTED=y
CONFIG_NRF_APPROTECT_USE_UICR=y
# CONFIG_NRF_APPROTECT_LOCK is not set
# CONFIG_NRF_APPROTECT_USER_HANDLING is not set
# CONFIG_NRF_TRACE_PORT is not set
CONFIG_GPIO_INIT_PRIORITY=40
# end of Hardware Configuration
CONFIG_SOC_COMPATIBLE_NRF=y
CONFIG_SOC_COMPATIBLE_NRF53X=y
CONFIG_SOC_COMPATIBLE_NRF5340_CPUNET=y
CONFIG_ARCH="arm"
# CONFIG_EXTRA_EXCEPTION_INFO is not set
CONFIG_ARCH_HAS_SINGLE_THREAD_SUPPORT=y
CONFIG_CPU_CORTEX=y
CONFIG_KOBJECT_TEXT_AREA=256
CONFIG_ARM_MPU=y
CONFIG_ARM_MPU_REGION_MIN_ALIGN_AND_SIZE=32
# CONFIG_MPU_ALLOW_FLASH_WRITE is not set
# ARM Options
CONFIG_ARM_ON_ENTER_CPU_IDLE_HOOK=y
CONFIG_ARM_ON_ENTER_CPU_IDLE_PREPARE_HOOK=y
CONFIG_ARM_ON_EXIT_CPU_IDLE=y
CONFIG_CPU_CORTEX_M=y
# CONFIG_ARM_ZIMAGE_HEADER is not set
CONFIG_ISA_THUMB2=y
CONFIG_ASSEMBLER_ISA_THUMB2=y
CONFIG_COMPILER_ISA_THUMB2=y
CONFIG_STACK_ALIGN_DOUBLE_WORD=y
# CONFIG_RUNTIME_NMI is not set
# CONFIG_PLATFORM_SPECIFIC_INIT is not set
CONFIG_FAULT_DUMP=2
CONFIG_BUILTIN_STACK_GUARD=y
CONFIG_ARM_STACK_PROTECTION=y
CONFIG_FP16=y
CONFIG_FP16_IEEE=y
# CONFIG_FP16_ALT is not set
CONFIG_CPU_CORTEX_M33=y
CONFIG_CPU_CORTEX_M_HAS_SYSTICK=y
CONFIG_CPU_CORTEX_M_HAS_DWT=y
CONFIG_CPU_CORTEX_M_HAS_BASEPRI=y
CONFIG_CPU_CORTEX_M_HAS_VTOR=y
CONFIG_CPU_CORTEX_M_HAS_SPLIM=y
CONFIG_CPU_CORTEX_M_HAS_PROGRAMMABLE_FAULT_PRIOS=y
CONFIG_CPU_CORTEX_M_HAS_CMSE=y
CONFIG_ARMV7_M_ARMV8_M_MAINLINE=y
CONFIG_ARMV8_M_MAINLINE=y
# ARM Cortex-M0/M0+/M1/M3/M4/M7/M23/M33/M55 options
CONFIG_ZERO_LATENCY_IRQS=y
CONFIG_ZERO_LATENCY_LEVELS=1
# CONFIG_SW_VECTOR_RELAY is not set
# CONFIG_CORTEX_M_DWT is not set
# CONFIG_CORTEX_M_DEBUG_MONITOR_HOOK is not set
# CONFIG_TRAP_UNALIGNED_ACCESS is not set
# end of ARM Cortex-M0/M0+/M1/M3/M4/M7/M23/M33/M55 options
CONFIG_NULL_POINTER_EXCEPTION_DETECTION_NONE=y
# CONFIG_NULL_POINTER_EXCEPTION_DETECTION_DWT is not set
# CONFIG_NULL_POINTER_EXCEPTION_DETECTION_MPU is not set
# CONFIG_MPU_STACK_GUARD is not set
# CONFIG_MPU_DISABLE_BACKGROUND_MAP is not set
# CONFIG_CUSTOM_SECTION_ALIGN is not set
CONFIG_CUSTOM_SECTION_MIN_ALIGN_SIZE=32
CONFIG_HAS_SWO=y
# end of ARM Options
CONFIG_ARM=y
CONFIG_ARCH_IS_SET=y
# General Architecture Options
# CONFIG_SEMIHOST is not set
CONFIG_LITTLE_ENDIAN=y
# CONFIG_USERSPACE is not set
CONFIG_KOBJECT_DATA_AREA_RESERVE_EXTRA_PERCENT=100
CONFIG_KOBJECT_RODATA_AREA_EXTRA_BYTES=16
CONFIG_GEN_PRIV_STACKS=y
# CONFIG_STACK_GROWS_UP is not set
# CONFIG_FRAME_POINTER is not set
# Interrupt Configuration
CONFIG_ISR_TABLES_LOCAL_DECLARATION_SUPPORTED=y
# CONFIG_ISR_TABLES_LOCAL_DECLARATION is not set
CONFIG_IRQ_VECTOR_TABLE_JUMP_BY_ADDRESS=y
# CONFIG_IRQ_VECTOR_TABLE_JUMP_BY_CODE is not set
CONFIG_EXCEPTION_DEBUG=y
# CONFIG_SIMPLIFIED_EXCEPTION_CODES is not set
# end of Interrupt Configuration
# end of General Architecture Options
CONFIG_ARCH_HAS_TIMING_FUNCTIONS=y
CONFIG_ARCH_HAS_STACK_PROTECTION=y
CONFIG_ARCH_HAS_USERSPACE=y
CONFIG_ARCH_HAS_EXECUTABLE_PAGE_BIT=y
CONFIG_ARCH_HAS_RAMFUNC_SUPPORT=y
CONFIG_ARCH_HAS_NESTED_EXCEPTION_DETECTION=y
CONFIG_ARCH_SUPPORTS_COREDUMP=y
CONFIG_ARCH_SUPPORTS_COREDUMP_THREADS=y
CONFIG_ARCH_SUPPORTS_ARCH_HW_INIT=y
CONFIG_ARCH_SUPPORTS_ROM_START=y
CONFIG_ARCH_HAS_EXTRA_EXCEPTION_INFO=y
CONFIG_ARCH_HAS_THREAD_LOCAL_STORAGE=y
CONFIG_ARCH_HAS_SUSPEND_TO_RAM=y
CONFIG_ARCH_HAS_THREAD_ABORT=y
CONFIG_ARCH_HAS_CODE_DATA_RELOCATION=y
CONFIG_CPU_HAS_MPU=y
CONFIG_MPU=y
CONFIG_MPU_REQUIRES_NON_OVERLAPPING_REGIONS=y
CONFIG_MPU_GAP_FILLING=y
CONFIG_SRAM_REGION_PERMISSIONS=y
# DSP Options
# end of DSP Options
# Floating Point Options
# end of Floating Point Options
# Cache Options
# end of Cache Options
CONFIG_TOOLCHAIN_HAS_BUILTIN_FFS=y
CONFIG_ARCH_HAS_CUSTOM_SWAP_TO_MAIN=y
# General Kernel Options
CONFIG_MULTITHREADING=y
CONFIG_NUM_COOP_PRIORITIES=16
CONFIG_NUM_PREEMPT_PRIORITIES=15
CONFIG_MAIN_THREAD_PRIORITY=0
CONFIG_COOP_ENABLED=y
CONFIG_PREEMPT_ENABLED=y
CONFIG_PRIORITY_CEILING=-127
# CONFIG_SCHED_DEADLINE is not set
CONFIG_THREAD_STACK_INFO=y
# CONFIG_THREAD_CUSTOM_DATA is not set
# CONFIG_DYNAMIC_THREAD is not set
CONFIG_SCHED_DUMB=y
# CONFIG_SCHED_SCALABLE is not set
# CONFIG_SCHED_MULTIQ is not set
# CONFIG_WAITQ_SCALABLE is not set
CONFIG_WAITQ_DUMB=y
# Misc Kernel related options
CONFIG_LIBC_ERRNO=y
CONFIG_ERRNO=y
CONFIG_CURRENT_THREAD_USE_TLS=y
# end of Misc Kernel related options
# Kernel Debugging and Metrics
CONFIG_BOOT_DELAY=0
# CONFIG_BOOT_CLEAR_SCREEN is not set
# CONFIG_THREAD_MONITOR is not set
# CONFIG_THREAD_NAME is not set
# CONFIG_THREAD_RUNTIME_STATS is not set
# end of Kernel Debugging and Metrics
# CONFIG_OBJ_CORE is not set
# System Work Queue Options
# CONFIG_SYSTEM_WORKQUEUE_NO_YIELD is not set
# end of System Work Queue Options
# Barrier Operations
CONFIG_BARRIER_OPERATIONS_ARCH=y
# end of Barrier Operations
# Atomic Operations
CONFIG_ATOMIC_OPERATIONS_BUILTIN=y
# end of Atomic Operations
# Timer API Options
CONFIG_TIMESLICING=y
CONFIG_TIMESLICE_PRIORITY=0
# CONFIG_TIMESLICE_PER_THREAD is not set
# end of Timer API Options
# Other Kernel Object Options
CONFIG_POLL=y
# CONFIG_MEM_SLAB_TRACE_MAX_UTILIZATION is not set
CONFIG_NUM_MBOX_ASYNC_MSGS=10
# CONFIG_EVENTS is not set
# CONFIG_PIPES is not set
CONFIG_KERNEL_MEM_POOL=y
# CONFIG_HEAP_MEM_POOL_IGNORE_MIN is not set
# end of Other Kernel Object Options
CONFIG_SWAP_NONATOMIC=y
CONFIG_SYS_CLOCK_EXISTS=y
CONFIG_TIMEOUT_64BIT=y
CONFIG_SYS_CLOCK_MAX_TIMEOUT_DAYS=365
# Security Options
# CONFIG_STACK_CANARIES is not set
CONFIG_STACK_POINTER_RANDOM=0
# end of Security Options
# Memory Domains
CONFIG_ARCH_MEM_DOMAIN_SUPPORTS_ISOLATED_STACKS=y
CONFIG_MEM_DOMAIN_ISOLATED_STACKS=y
# end of Memory Domains
# SMP Options
CONFIG_MP_NUM_CPUS=1
# CONFIG_TICKET_SPINLOCKS is not set
# end of SMP Options
CONFIG_TOOLCHAIN_SUPPORTS_THREAD_LOCAL_STORAGE=y
CONFIG_THREAD_LOCAL_STORAGE=y
CONFIG_TOOLCHAIN_SUPPORTS_STATIC_INIT_GNU=y
# CONFIG_STATIC_INIT_GNU is not set
# CONFIG_BOOTARGS is not set
# end of General Kernel Options
# Device Options
# CONFIG_DEVICE_DEPS is not set
# CONFIG_DEVICE_MUTABLE is not set
# CONFIG_DEVICE_DT_METADATA is not set
# end of Device Options
# Initialization Priorities
CONFIG_KERNEL_INIT_PRIORITY_OBJECTS=30
CONFIG_KERNEL_INIT_PRIORITY_LIBC=35
CONFIG_KERNEL_INIT_PRIORITY_DEFAULT=40
CONFIG_KERNEL_INIT_PRIORITY_DEVICE=50
CONFIG_APPLICATION_INIT_PRIORITY=90
# end of Initialization Priorities
# Virtual Memory Support
# end of Virtual Memory Support
# SoC and Board Hooks
# CONFIG_SOC_PREP_HOOK is not set
# CONFIG_SOC_EARLY_INIT_HOOK is not set
# CONFIG_SOC_LATE_INIT_HOOK is not set
# CONFIG_BOARD_EARLY_INIT_HOOK is not set
# CONFIG_BOARD_LATE_INIT_HOOK is not set
# end of SoC and Board Hooks
# Device Drivers
# CONFIG_ADC is not set
# CONFIG_AUDIO is not set
# CONFIG_AUXDISPLAY is not set
# CONFIG_BBRAM is not set
# Bluetooth HCI Driver Options
CONFIG_BT_HCI_INIT_PRIORITY=50
# CONFIG_HCI_NXP_SET_CAL_DATA_ANNEX100 is not set
# CONFIG_FLASH is not set
CONFIG_BT_DRV_TX_STACK_SIZE=256
CONFIG_BT_DRV_RX_STACK_SIZE=256
# CONFIG_CAN is not set
# CONFIG_CHARGER is not set
CONFIG_CLOCK_CONTROL_NRF_FORCE_ALT=y
CONFIG_CLOCK_CONTROL_NRF=y
# CONFIG_CLOCK_CONTROL_NRF_K32SRC_RC is not set
CONFIG_CLOCK_CONTROL_NRF_K32SRC_XTAL=y
# CONFIG_CLOCK_CONTROL_NRF_K32SRC_SYNTH is not set
# CONFIG_CLOCK_CONTROL_NRF_K32SRC_500PPM is not set
# CONFIG_CLOCK_CONTROL_NRF_K32SRC_250PPM is not set
# CONFIG_CLOCK_CONTROL_NRF_K32SRC_150PPM is not set
# CONFIG_CLOCK_CONTROL_NRF_K32SRC_100PPM is not set
# CONFIG_CLOCK_CONTROL_NRF_K32SRC_75PPM is not set
CONFIG_CLOCK_CONTROL_NRF_K32SRC_50PPM=y
# CONFIG_CLOCK_CONTROL_NRF_K32SRC_30PPM is not set
# CONFIG_CLOCK_CONTROL_NRF_K32SRC_20PPM is not set
CONFIG_CLOCK_CONTROL_NRF_ACCURACY=50
# CONFIG_CLOCK_CONTROL_FIXED_RATE_CLOCK is not set
# CONFIG_COMPARATOR is not set
# CONFIG_COREDUMP_DEVICE is not set
# CONFIG_CRYPTO is not set
# CONFIG_DAC is not set
# CONFIG_DAI is not set
# CONFIG_DISK_DRIVERS is not set
# CONFIG_DISPLAY is not set
# CONFIG_DMA is not set
# CONFIG_DP_DRIVER is not set
# CONFIG_EDAC is not set
# CONFIG_EEPROM is not set
CONFIG_ENTROPY_GENERATOR=y
CONFIG_ENTROPY_NRF5_RNG=y
# CONFIG_ENTROPY_NRF5_BIAS_CORRECTION is not set
CONFIG_ENTROPY_NRF5_THR_POOL_SIZE=8
CONFIG_ENTROPY_NRF5_THR_THRESHOLD=4
CONFIG_ENTROPY_NRF5_ISR_POOL_SIZE=16
CONFIG_ENTROPY_NRF5_ISR_THRESHOLD=12
CONFIG_ENTROPY_HAS_DRIVER=y
# CONFIG_ESPI is not set
# Firmware drivers
# CONFIG_ARM_SCMI is not set
# end of Firmware drivers
# CONFIG_FPGA is not set
# CONFIG_FUEL_GAUGE is not set
# CONFIG_GNSS is not set
# CONFIG_GPIO_GET_DIRECTION is not set
# CONFIG_GPIO_GET_CONFIG is not set
# CONFIG_GPIO_HOGS is not set
# CONFIG_GPIO_ENABLE_DISABLE_INTERRUPT is not set
CONFIG_GPIO_NRFX=y
CONFIG_GPIO_NRFX_INTERRUPT=y
# CONFIG_HAPTICS is not set
# CONFIG_HWINFO is not set
# CONFIG_HWSPINLOCK is not set
# CONFIG_I2S is not set
# CONFIG_I3C is not set
# Interrupt controller drivers
CONFIG_INTC_INIT_PRIORITY=40
# end of Interrupt controller drivers
# CONFIG_IPM is not set
# CONFIG_KSCAN is not set
# CONFIG_LED is not set
# CONFIG_LED_STRIP is not set
# CONFIG_LORA is not set
CONFIG_MBOX=y
CONFIG_MBOX_NRFX_IPC=y
CONFIG_MBOX_INIT_PRIORITY=40
# CONFIG_MDIO is not set
# CONFIG_MIPI_DBI is not set
# Miscellaneous Drivers
# CONFIG_TIMEAWARE_GPIO is not set
# end of Miscellaneous Drivers
# CONFIG_MM_DRV is not set
# CONFIG_MSPI is not set
# CONFIG_PCIE is not set
# CONFIG_PCIE_ENDPOINT is not set
# CONFIG_PECI is not set
# CONFIG_PM_CPU_OPS is not set
# CONFIG_PS2 is not set
# CONFIG_PTP_CLOCK is not set
# CONFIG_PWM is not set
# CONFIG_RETAINED_MEM is not set
# CONFIG_RTC is not set
# CONFIG_SDHC is not set
# CONFIG_SMBUS is not set
# CONFIG_STEPPER is not set
# Timer drivers
# CONFIG_TIMER_READS_ITS_FREQUENCY_AT_RUNTIME is not set
# CONFIG_SYSTEM_CLOCK_SLOPPY_IDLE is not set
CONFIG_SYSTEM_CLOCK_INIT_PRIORITY=0
CONFIG_TICKLESS_CAPABLE=y
CONFIG_SYSTEM_TIMER_HAS_DISABLE_SUPPORT=y
CONFIG_NRF_RTC_TIMER_LOCK_ZERO_LATENCY_IRQS=y
# CONFIG_NRF_RTC_TIMER_TRIGGER_OVERFLOW is not set
# CONFIG_SYSTEM_CLOCK_NO_WAIT is not set
# CONFIG_SYSTEM_CLOCK_WAIT_FOR_AVAILABILITY is not set
CONFIG_SYSTEM_CLOCK_WAIT_FOR_STABILITY=y
# end of Timer drivers
# CONFIG_USB_BC12 is not set
# CONFIG_UDC_DRIVER is not set
# CONFIG_UHC_DRIVER is not set
# CONFIG_UVB is not set
# CONFIG_USB_DEVICE_DRIVER is not set
# CONFIG_USBC_TCPC_DRIVER is not set
# CONFIG_USBC_VBUS_DRIVER is not set
# CONFIG_USBC_PPC_DRIVER is not set
# CONFIG_VIDEO is not set
# CONFIG_VIRTUALIZATION is not set
# CONFIG_W1 is not set
# CONFIG_TEE is not set
# CONFIG_REQUIRES_FULL_LIBC is not set
# CONFIG_REQUIRES_FLOAT_PRINTF is not set
CONFIG_FULL_LIBC_SUPPORTED=y
CONFIG_MINIMAL_LIBC_SUPPORTED=y
CONFIG_NEWLIB_LIBC_SUPPORTED=y
CONFIG_PICOLIBC_SUPPORTED=y
# C Library
# CONFIG_MINIMAL_LIBC is not set
CONFIG_PICOLIBC=y
# CONFIG_NEWLIB_LIBC is not set
# CONFIG_EXTERNAL_LIBC is not set
CONFIG_HAS_NEWLIB_LIBC_NANO=y
CONFIG_COMMON_LIBC_ABORT=y
# CONFIG_COMMON_LIBC_ASCTIME_R is not set
# CONFIG_COMMON_LIBC_CTIME_R is not set
CONFIG_COMMON_LIBC_MALLOC=y
CONFIG_COMMON_LIBC_CALLOC=y
CONFIG_COMMON_LIBC_REALLOCARRAY=y
# CONFIG_COMMON_LIBC_REMOVE is not set
# CONFIG_PICOLIBC_USE_MODULE is not set
CONFIG_PICOLIBC_USE_TOOLCHAIN=y
# CONFIG_PICOLIBC_IO_FLOAT is not set
CONFIG_PICOLIBC_IO_LONG_LONG=y
CONFIG_NEED_LIBC_MEM_PARTITION=y
# end of C Library
# C++ Language Support
# CONFIG_CPP is not set
# end of C++ Language Support
# CONFIG_CRC is not set
# Additional libraries
# Hash Function Support
# CONFIG_SYS_HASH_FUNC32 is not set
# end of Hash Function Support
# Hashmap (Hash Table) Support
# CONFIG_SYS_HASH_MAP is not set
# end of Hashmap (Hash Table) Support
# Heap and Memory Allocation
# CONFIG_SYS_HEAP_STRESS is not set
# CONFIG_SYS_HEAP_INFO is not set
CONFIG_SYS_HEAP_ALLOC_LOOPS=3
# CONFIG_SYS_HEAP_RUNTIME_STATS is not set
# CONFIG_SYS_HEAP_LISTENER is not set
# CONFIG_SYS_HEAP_SMALL_ONLY is not set
# CONFIG_SYS_HEAP_BIG_ONLY is not set
CONFIG_SYS_HEAP_AUTO=y
# CONFIG_MULTI_HEAP is not set
# CONFIG_SHARED_MULTI_HEAP is not set
# end of Heap and Memory Allocation
# Memory Blocks
# CONFIG_SYS_MEM_BLOCKS is not set
# end of Memory Blocks
CONFIG_NET_BUF=y
# CONFIG_NET_BUF_LOG is not set
# CONFIG_NET_BUF_POOL_USAGE is not set
CONFIG_NET_BUF_ALIGNMENT=0
# OS Support Library
# CONFIG_FDTABLE is not set
CONFIG_ZVFS_OPEN_MAX=4
# CONFIG_PRINTK_SYNC is not set
# CONFIG_MPSC_PBUF is not set
# CONFIG_SPSC_PBUF is not set
CONFIG_CBPRINTF_COMPLETE=y
# CONFIG_CBPRINTF_NANO is not set
CONFIG_CBPRINTF_FULL_INTEGRAL=y
# CONFIG_CBPRINTF_REDUCED_INTEGRAL is not set
# CONFIG_CBPRINTF_FP_SUPPORT is not set
# CONFIG_CBPRINTF_FP_A_SUPPORT is not set
# CONFIG_CBPRINTF_LIBC_SUBSTS is not set
# CONFIG_CBPRINTF_PACKAGE_LONGDOUBLE is not set
# CONFIG_CBPRINTF_STATIC_PACKAGE_CHECK_ALIGNMENT is not set
CONFIG_CBPRINTF_CONVERT_CHECK_PTR=y
# CONFIG_ZVFS is not set
# end of OS Support Library
# POSIX API Support
# POSIX Options
# CONFIG_POSIX_API is not set
CONFIG_POSIX_AEP_CHOICE_NONE=y
# CONFIG_POSIX_AEP_CHOICE_BASE is not set
# CONFIG_POSIX_AEP_CHOICE_PSE51 is not set
# CONFIG_POSIX_AEP_CHOICE_PSE52 is not set
# CONFIG_POSIX_AEP_CHOICE_PSE53 is not set
# CONFIG_POSIX_ASYNCHRONOUS_IO is not set
# CONFIG_POSIX_BARRIERS is not set
# CONFIG_POSIX_C_LANG_SUPPORT_R is not set
# CONFIG_POSIX_C_LIB_EXT is not set
# POSIX device I/O
# CONFIG_POSIX_DEVICE_IO is not set
CONFIG_POSIX_OPEN_MAX=4
# end of POSIX device I/O
# CONFIG_POSIX_FD_MGMT is not set
# CONFIG_POSIX_FILE_SYSTEM is not set
# POSIX memory
CONFIG_POSIX_PAGE_SIZE=0x40
# CONFIG_POSIX_SHARED_MEMORY_OBJECTS is not set
# CONFIG_POSIX_MAPPED_FILES is not set
# CONFIG_POSIX_MEMORY_PROTECTION is not set
# end of POSIX memory
# CONFIG_POSIX_MESSAGE_PASSING is not set
# CONFIG_POSIX_SINGLE_PROCESS is not set
# CONFIG_POSIX_MULTI_PROCESS is not set
# CONFIG_POSIX_THREADS is not set
# CONFIG_POSIX_READER_WRITER_LOCKS is not set
# POSIX scheduler options
# CONFIG_POSIX_PRIORITY_SCHEDULING is not set
# end of POSIX scheduler options
# CONFIG_POSIX_SEMAPHORES is not set
# POSIX signals
# CONFIG_POSIX_REALTIME_SIGNALS is not set
# CONFIG_POSIX_SIGNALS is not set
# end of POSIX signals
# CONFIG_POSIX_SPIN_LOCKS is not set
# POSIX synchronized I/O
# CONFIG_POSIX_FSYNC is not set
# CONFIG_POSIX_SYNCHRONIZED_IO is not set
# end of POSIX synchronized I/O
# CONFIG_POSIX_TIMERS is not set
# X/Open system interfaces
# CONFIG_XOPEN_STREAMS is not set
# CONFIG_XSI_SYSTEM_LOGGING is not set
# CONFIG_XSI_THREADS_EXT is not set
# end of X/Open system interfaces
# Miscellaneous POSIX-related options
# CONFIG_EVENTFD is not set
# end of Miscellaneous POSIX-related options
# Deprecated POSIX options
CONFIG_EVENTFD_MAX=0
# CONFIG_FNMATCH is not set
CONFIG_MAX_PTHREAD_COUNT=0
CONFIG_MAX_PTHREAD_KEY_COUNT=0
CONFIG_MAX_TIMER_COUNT=0
CONFIG_MSG_COUNT_MAX=0
# CONFIG_POSIX_CLOCK is not set
# CONFIG_POSIX_FS is not set
CONFIG_POSIX_LIMITS_RTSIG_MAX=0
CONFIG_POSIX_MAX_FDS=4
CONFIG_POSIX_MAX_OPEN_FILES=4
# CONFIG_POSIX_MQUEUE is not set
# CONFIG_POSIX_PUTMSG is not set
# CONFIG_POSIX_SIGNAL is not set
# CONFIG_POSIX_SYSCONF is not set
# CONFIG_POSIX_UNAME is not set
# CONFIG_PTHREAD is not set
# CONFIG_PTHREAD_BARRIER is not set
# CONFIG_PTHREAD_COND is not set
# CONFIG_PTHREAD_IPC is not set
# CONFIG_PTHREAD_KEY is not set
# CONFIG_PTHREAD_MUTEX is not set
# CONFIG_PTHREAD_RWLOCK is not set
# CONFIG_PTHREAD_SPINLOCK is not set
# CONFIG_TIMER is not set
CONFIG_TIMER_DELAYTIMER_MAX=0
CONFIG_SEM_NAMELEN_MAX=0
CONFIG_SEM_VALUE_MAX=0
# end of Deprecated POSIX options
CONFIG_TC_PROVIDES_POSIX_C_LANG_SUPPORT_R=y
# end of POSIX Options
# POSIX Shell Utilities
# end of POSIX Shell Utilities
# end of POSIX API Support
# CONFIG_OPENAMP_RSC_TABLE is not set
# CONFIG_SMF is not set
CONFIG_LIBGCC_RTLIB=y
# Utility Library
# CONFIG_JSON_LIBRARY is not set
# CONFIG_RING_BUFFER is not set
CONFIG_NOTIFY=y
# CONFIG_BASE64 is not set
CONFIG_ONOFF=y
# CONFIG_WINSTREAM is not set
# CONFIG_UTF8 is not set
# end of Utility Library
# end of Additional libraries
# Subsystems and OS Services
# CONFIG_BINDESC is not set
CONFIG_BT=y
CONFIG_BT_HCI=y
# CONFIG_BT_CUSTOM is not set
CONFIG_BT_HCI_RAW=y
# CONFIG_BT_HCI_RAW_H4 is not set
# CONFIG_BT_HCI_RAW_CMD_EXT is not set
CONFIG_BT_CONN_TX=y
# CONFIG_BT_SCA_UPDATE is not set
# CONFIG_BT_TRANSMIT_POWER_CONTROL is not set
# CONFIG_BT_PATH_LOSS_MONITORING is not set
# CONFIG_BT_SUBRATING is not set
# CONFIG_BT_ISO_PERIPHERAL is not set
# CONFIG_BT_ISO_CENTRAL is not set
# CONFIG_BT_ISO_BROADCASTER is not set
# CONFIG_BT_ISO_SYNC_RECEIVER is not set
# Bluetooth buffer configuration
# end of Bluetooth buffer configuration
# Bluetooth Host
# Bluetooth Classic Options
# end of Bluetooth Classic Options
# end of Bluetooth Host
CONFIG_BT_CTLR_ENTROPY_SUPPORT=y
CONFIG_BT_CTLR_CRYPTO_SUPPORT=y
CONFIG_BT_CTLR_LE_ENC_SUPPORT=y
CONFIG_BT_CTLR_EXT_REJ_IND_SUPPORT=y
CONFIG_BT_CTLR_DATA_LEN_UPDATE_SUPPORT=y
CONFIG_BT_CTLR_PRIVACY_SUPPORT=y
CONFIG_BT_CTLR_EXT_SCAN_FP_SUPPORT=y
CONFIG_BT_CTLR_PHY_UPDATE_SUPPORT=y
CONFIG_BT_CTLR_PHY_2M_SUPPORT=y
CONFIG_BT_CTLR_PHY_CODED_SUPPORT=y
CONFIG_BT_CTLR_ADV_EXT_SUPPORT=y
CONFIG_BT_CTLR_ADV_PERIODIC_SUPPORT=y
CONFIG_BT_CTLR_ADV_PERIODIC_RSP_SUPPORT=y
CONFIG_BT_CTLR_SYNC_PERIODIC_SUPPORT=y
CONFIG_BT_CTLR_SYNC_PERIODIC_RSP_SUPPORT=y
CONFIG_BT_CTLR_SYNC_TRANSFER_SENDER_SUPPORT=y
CONFIG_BT_CTLR_SYNC_TRANSFER_RECEIVER_SUPPORT=y
CONFIG_BT_CTLR_ADV_ISO_SUPPORT=y
CONFIG_BT_CTLR_SYNC_ISO_SUPPORT=y
CONFIG_BT_CTLR_CENTRAL_ISO_SUPPORT=y
CONFIG_BT_CTLR_PERIPHERAL_ISO_SUPPORT=y
CONFIG_BT_CTLR_CHAN_SEL_2_SUPPORT=y
CONFIG_BT_CTLR_SCA_UPDATE_SUPPORT=y
CONFIG_BT_CTLR_CONN_RSSI_SUPPORT=y
CONFIG_BT_CTLR_ECDH_SUPPORT=y
CONFIG_BT_CTLR_LE_POWER_CONTROL_SUPPORT=y
CONFIG_BT_CTLR_LE_PATH_LOSS_MONITORING_SUPPORT=y
CONFIG_BT_CTLR_SUBRATING_SUPPORT=y
# CONFIG_BT_LL_SW_SPLIT is not set
# BLE Controller configuration
CONFIG_BT_CTLR_ENTROPY=y
CONFIG_BT_CTLR_CRYPTO=y
# CONFIG_BT_CTLR_TX_PWR_PLUS_3 is not set
# CONFIG_BT_CTLR_TX_PWR_PLUS_2 is not set
# CONFIG_BT_CTLR_TX_PWR_PLUS_1 is not set
CONFIG_BT_CTLR_TX_PWR_0=y
# CONFIG_BT_CTLR_TX_PWR_MINUS_1 is not set
# CONFIG_BT_CTLR_TX_PWR_MINUS_2 is not set
# CONFIG_BT_CTLR_TX_PWR_MINUS_3 is not set
# CONFIG_BT_CTLR_TX_PWR_MINUS_4 is not set
# CONFIG_BT_CTLR_TX_PWR_MINUS_5 is not set
# CONFIG_BT_CTLR_TX_PWR_MINUS_6 is not set
# CONFIG_BT_CTLR_TX_PWR_MINUS_7 is not set
# CONFIG_BT_CTLR_TX_PWR_MINUS_8 is not set
# CONFIG_BT_CTLR_TX_PWR_MINUS_12 is not set
# CONFIG_BT_CTLR_TX_PWR_MINUS_16 is not set
# CONFIG_BT_CTLR_TX_PWR_MINUS_20 is not set
# CONFIG_BT_CTLR_TX_PWR_MINUS_40 is not set
CONFIG_BT_CTLR_TX_PWR_DBM=0
CONFIG_BT_CTLR_TX_PWR_ANTENNA=0
CONFIG_BT_CTLR_TX_PWR_DYNAMIC_CONTROL=y
# BLE Controller features
CONFIG_BT_CTLR_LE_ENC=y
CONFIG_BT_CTLR_ECDH=y
CONFIG_BT_CTLR_EXT_REJ_IND=y
CONFIG_BT_CTLR_LE_PING=y
CONFIG_BT_CTLR_DATA_LENGTH=y
CONFIG_BT_CTLR_PHY=y
CONFIG_BT_CTLR_CONN_RSSI=y
# CONFIG_BT_CTLR_LE_POWER_CONTROL is not set
# CONFIG_BT_CTLR_LE_PATH_LOSS_MONITORING is not set
CONFIG_BT_CTLR_FILTER_ACCEPT_LIST=y
CONFIG_BT_CTLR_PRIVACY=y
CONFIG_BT_CTLR_RL_SIZE=8
CONFIG_BT_CTLR_EXT_SCAN_FP=y
CONFIG_BT_CTLR_PHY_2M=y
CONFIG_BT_CTLR_PHY_CODED=y
CONFIG_BT_CTLR_CHAN_SEL_2=y
CONFIG_BT_CTLR_ADV_EXT=y
CONFIG_BT_CTLR_ADV_SET=3
CONFIG_BT_CTLR_ADV_INTERVAL_MAX=0xFFFFFF
CONFIG_BT_CTLR_ADV_DATA_LEN_MAX=255
# CONFIG_BT_CTLR_ADV_PERIODIC is not set
# CONFIG_BT_CTLR_ADV_PERIODIC_RSP is not set
# CONFIG_BT_CTLR_SYNC_PERIODIC is not set
# CONFIG_BT_CTLR_SYNC_PERIODIC_RSP is not set
# CONFIG_BT_CTLR_SYNC_TRANSFER_SENDER is not set
# CONFIG_BT_CTLR_ADV_ISO is not set
# CONFIG_BT_CTLR_SYNC_ISO is not set
# CONFIG_BT_CTLR_SET_HOST_FEATURE is not set
# CONFIG_BT_CTLR_CENTRAL_ISO is not set
# CONFIG_BT_CTLR_PERIPHERAL_ISO is not set
# CONFIG_BT_CTLR_SUBRATING is not set
CONFIG_BT_CTLR_DF_CTE_TX_SUPPORT=y
# CONFIG_BT_CTLR_ASSERT_HANDLER is not set
# CONFIG_BT_EAD is not set
# Controller Area Network (CAN) bus subsystem
# end of Controller Area Network (CAN) bus subsystem
# CONFIG_CONSOLE_SUBSYS is not set
# CONFIG_DAP is not set
# System Monitoring Options
# CONFIG_THREAD_ANALYZER is not set
# end of System Monitoring Options
# Debugging Options
# CONFIG_DEBUG is not set
# CONFIG_STACK_USAGE is not set
# CONFIG_STACK_SENTINEL is not set
CONFIG_PRINTK=y
CONFIG_EARLY_CONSOLE=y
# CONFIG_FORCE_NO_ASSERT is not set
CONFIG_ASSERT_VERBOSE=y
# CONFIG_ASSERT_NO_FILE_INFO is not set
# CONFIG_ASSERT_NO_COND_INFO is not set
# CONFIG_ASSERT_NO_MSG_INFO is not set
# CONFIG_ASSERT_TEST is not set
# CONFIG_OVERRIDE_FRAME_POINTER_DEFAULT is not set
# CONFIG_DEBUG_INFO is not set
# CONFIG_DEBUG_THREAD_INFO is not set
# CONFIG_DEBUG_COREDUMP is not set
# CONFIG_SYMTAB is not set
# end of Debugging Options
# CONFIG_MIPI_STP_DECODER is not set
# CONFIG_CS_TRACE_DEFMT is not set
# CONFIG_DISK_ACCESS is not set
# CONFIG_DSP is not set
# CONFIG_EMUL is not set
# CONFIG_CHARACTER_FRAMEBUFFER is not set
# File Systems
# CONFIG_FILE_SYSTEM is not set
# CONFIG_ZMS is not set
# end of File Systems
# Inter Processor Communication
# CONFIG_RPMSG_SERVICE is not set
CONFIG_IPC_SERVICE=y
CONFIG_IPC_SERVICE_REG_BACKEND_PRIORITY=46
CONFIG_IPC_SERVICE_BACKEND_RPMSG=y
CONFIG_IPC_SERVICE_BACKEND_RPMSG_WQ_STACK_SIZE=1024
CONFIG_IPC_SERVICE_BACKEND_RPMSG_NUM_ENDPOINTS_PER_INSTANCE=2
CONFIG_IPC_SERVICE_RPMSG=y
CONFIG_IPC_SERVICE_STATIC_VRINGS=y
CONFIG_IPC_SERVICE_STATIC_VRINGS_MEM_ALIGNMENT=4
# CONFIG_IPC_SERVICE_ICMSG is not set
# CONFIG_IPC_SERVICE_ICMSG_ME is not set
# end of Inter Processor Communication
# CONFIG_JWT is not set
# CONFIG_LLEXT is not set
# Linkable loadable Extension Development Kit (EDK)
CONFIG_LLEXT_EDK_NAME="llext-edk"
# CONFIG_LLEXT_EDK_USERSPACE_ONLY is not set
# end of Linkable loadable Extension Development Kit (EDK)
# Logging
# CONFIG_LOG_OUTPUT is not set
# end of Logging
CONFIG_MEM_ATTR=y
# CONFIG_MEM_ATTR_HEAP is not set
# Device Management
# Host command handler subsystem
# CONFIG_EC_HOST_CMD is not set
# end of Host command handler subsystem
# CONFIG_OSDP is not set
# end of Device Management
# CONFIG_MODBUS is not set
# CONFIG_MODEM_MODULES is not set
# Networking
# CONFIG_NETWORKING is not set
# end of Networking
# Power Management
# CONFIG_PM_POLICY_LATENCY_STANDALONE is not set
# end of Power Management
# Portability
# end of Portability
# CONFIG_PROFILING is not set
# Random Number Generators
# CONFIG_TEST_RANDOM_GENERATOR is not set
CONFIG_TIMER_RANDOM_INITIAL_STATE=123456789
CONFIG_ENTROPY_DEVICE_RANDOM_GENERATOR=y
# CONFIG_XOSHIRO_RANDOM_GENERATOR is not set
CONFIG_CSPRNG_ENABLED=y
CONFIG_HARDWARE_DEVICE_CS_GENERATOR=y
# CONFIG_CTR_DRBG_CSPRNG_GENERATOR is not set
# end of Random Number Generators
# CONFIG_RTIO is not set
# SD
# CONFIG_MMC_STACK is not set
# CONFIG_SDMMC_STACK is not set
# CONFIG_SDIO_STACK is not set
# end of SD
# CONFIG_SETTINGS is not set
# Storage
# CONFIG_STREAM_FLASH is not set
# end of Storage
# CONFIG_TASK_WDT is not set
# Testing
# end of Testing
# Linker Options
# Linker Sections
# Compiler Options
CONFIG_STD_C99=y
CONFIG_SIZE_OPTIMIZATIONS=y
# CONFIG_DEBUG_OPTIMIZATIONS is not set
# Build Options
# Boot Options
# Compatibility
