Best place for audio processing adjustments.
Hello all,
I am working on a project with 2 nrf5340 Audio DK's, and I have been working for a while now on getting myself familiar with the audio application, but I have a few questions. First of all I assumed it would be wise to develop on top of the provided audio application since writing the entire pairing and data transmission yourself would be near impossible, is this a correct assumption?
Secondly I have the walkie talkie demo running, and am now trying to encode and decode the data that I am sending over the line, for now I just want a simple xor operation to encrypt the data and decrypt it. Right now I am doing it before the codec encode in the audio_system.c and decrypting it after the decode, but I just get a horrible noise instead of the orginal audio. I tried a few other spots like inside the callback, but I saw another thread saying this was ill advised.
So my question is what would be the correct places to place the encrypt and decrypt of the data?
    Thank you for taking the time.
    So first I looked at what was coming in on the decode side, but there the audio frame is all zeroes.
    next I looked if the audio even arrived correctly at the other device, so after bleutooth transmission, which it does. In the file audio_datapath.c I see the audioframe having values before the sw_codec_decode, but the decoded data after the decode function is all zeroes, so somewhere in this function it goes wrong.
    In this function I saw that it depends on CONFIG_SW_CODEC_LC3 so I tried turning this on and placing some more print statements to see where the audio data is lost.
    In the file sw_codec_select.c there is this piece of code:
    case SW_CODEC_MONO: {
    			if (meta->bad_data && SW_CODEC_OVERRIDE_PLC) {
    				memset(decoded_data_mono[0], 0, PCM_NUM_BYTES_MONO);
    				decoded_data_size = PCM_NUM_BYTES_MONO;
    			} else {
    				ret = sw_codec_lc3_dec_run(
    					audio_frame->data, audio_frame->len, LC3_PCM_NUM_BYTES_MONO,
    					0, decoded_data_mono[0], (uint16_t *)&decoded_data_size,
    					meta->bad_data);
    				if (ret) {
    					return ret;
    And I see that the data in the audio frame before this function has values, but the decoded data after this function is all zeroes. So I followed the sw_codec_lc3_dec_run function to see where it goes wrong there.
    And finally I end up at this line in sw_codec_lc3.c:
    ret = LC3DecodeSessionData(dec_handle_ch[audio_ch], &LC3DecodeInput, &LC3DecodeOutput);
    The audio is fine before this function, but is all zeroes after this function. I placed this logging:
    if (frame_counter % 200 == 0)
    		LOG_INF("---- LC3 Decode #%d ----", frame_counter);
    		LOG_INF("Ch:%d, FrameLen:%d, PCMbuf:%d, bad_frame:%d",
    				audio_ch, lc3_data_size, pcm_data_buf_size, bad_frame);
    		LOG_HEXDUMP_INF(lc3_data, MIN(lc3_data_size, 16), "LC3 Input (first 16 bytes)");
    		LOG_INF("Decoded bytesWritten:%d, PLCCounter:%d",
    				LC3DecodeOutput.bytesWritten, LC3DecodeOutput.PLCCounter);
    		if (LC3DecodeOutput.bytesWritten > 0)
    			uint16_t *pcm16 = (uint16_t *)pcm_data;
    			size_t samples_to_print = MIN(8, LC3DecodeOutput.bytesWritten / sizeof(uint16_t));
    			printk("PCM samples (first %zu): ", samples_to_print);
    			for (size_t i = 0; i < samples_to_print; i++)
    				printk("%d ", pcm16[i]);
    			printk("\n");
    		LOG_INF("---------------------------");
    Which returns 0 bad_frames correct LC3 Input and no errors, but the PCM Samples printed are all zeroes.
    I don't know what this function does but is there a way to make it work, because I don't understand why it doesn't output anything when I encrypt my data even though I expect random noise, (which I want to hear)
    I hope this clears up my issue, please let me know if you need more information.
    Kind regards.
    I am sorry for the late reply. Is it correct that you pass data to LC3DecodeOutput(), meaning non-empty input frame, but the output frame is all zero non the less? You write that there are no errors, does that include from LC3DecodeOutput? What is the return value? If it returns 0 that means no error, and the output buffer should be a valid decoded frame containing raw PCM data.
    Also, is this on unmodified data, or do you see ths issue only when you have manipulatedc the input data (before it was encoded I assume)?
    So I pass valid data to LC3DecodeSessionData(), not LC3DecodeOutput(), and it returns 0, so it should be valid. This is modified data in the sense that I applied an XOR operation to the bytes after encoding. And indeed they are not empty, but still the output frames are zero.
    This problem only happens when I only encrypt the data (so after encoding). What I would expect is to hear noise (meaning in this case encrypted audio), but when I also apply the decryption it sounds normal again. I want to hear the noise to prove the audio is correctly being processed, but instead the audio gets set to 0 at the LC3DecodeSessionData().
  • Can you Is this data now encrypted before or after encoding? If you encrypt data before encoding I am not sure how the result will be, as the encoder is lossy and expects an audio signal. The encrypted signal is effectively white noise and impossible to compress in any measningfull way. It could perhaps also be that as there is no data erroc concelment will result in zero output (no noise)? If so, te return value will be 0 (LC3_RESULT_NO_ERROR) according to the API documentation for LC3DecodeSessionData.
  • No I am encrypting after encoding, and decrypting before decoding.
