Migration to sysbuild results in failure to boot
I'm attempting to migration from using MCUBOOT as a child image to sysbuild using SDK 2.8.0.
Everything boots fine when building using a child image, but when switching to sysbuild I initially get a warning that BOOT_MAX_IMG_SECTORS is too small, followed by an error from MUCBOOT that the image is invalid.
If I increase BOOT_MAX_IMG_SECTORS to 512, the bootloader appears to not even start.  I never get as far as seeing the message "Starting bootloader".
As far as I can tell, the configurations are virtually identical, I've just moved the configurations into the 'sysbuild' folder.
Here is a copy of build_sysbuild/zephyr/.config
SB_CONFIG_BOARD="nrf52840dk"
SB_CONFIG_BOARD_REVISION=""
SB_CONFIG_BOARD_NRF52840DK=y
SB_CONFIG_BOARD_NRF52840DK_NRF52840=y
SB_CONFIG_BOARD_QUALIFIERS="nrf52840"
SB_CONFIG_SOC="nrf52840"
SB_CONFIG_SOC_SERIES="nrf52"
SB_CONFIG_SOC_FAMILY="nordic_nrf"
SB_CONFIG_SOC_FAMILY_NORDIC_NRF=y
SB_CONFIG_SOC_SERIES_NRF52X=y
SB_CONFIG_SOC_NRF52840=y
SB_CONFIG_SOC_NRF52840_QIAA=y
# Sysbuild image configuration
# Modules
# Available modules.
# nrf (C:/ncs/v2.8.0/nrf)
SB_CONFIG_PARTITION_MANAGER=y
SB_CONFIG_PM_MCUBOOT_PAD=0x200
SB_CONFIG_PM_EXTERNAL_FLASH_MCUBOOT_SECONDARY=y
# SB_CONFIG_PM_OVERRIDE_EXTERNAL_DRIVER_CHECK is not set
SB_CONFIG_BUILD_OUTPUT_BIN=y
SB_CONFIG_BUILD_OUTPUT_HEX=y
SB_CONFIG_APPCORE_REMOTE_BOARD_TARGET_CPUCLUSTER="cpuapp"
SB_CONFIG_APPCORE_REMOTE_DOMAIN="CPUAPP"
# Secure Bootloader
# SB_CONFIG_SECURE_BOOT_APPCORE is not set
# end of Secure Bootloader
# MCUboot configuration
SB_CONFIG_MCUBOOT_MAX_UPDATEABLE_IMAGES=4
SB_CONFIG_MCUBOOT_APPLICATION_IMAGE_NUMBER=0
SB_CONFIG_MCUBOOT_NETWORK_CORE_IMAGE_NUMBER=-1
SB_CONFIG_MCUBOOT_WIFI_PATCHES_IMAGE_NUMBER=-1
SB_CONFIG_MCUBOOT_QSPI_XIP_IMAGE_NUMBER=-1
SB_CONFIG_MCUBOOT_MCUBOOT_IMAGE_NUMBER=-1
SB_CONFIG_MCUBOOT_MIN_UPDATEABLE_IMAGES=1
SB_CONFIG_MCUBOOT_MIN_ADDITIONAL_UPDATEABLE_IMAGES=0
SB_CONFIG_MCUBOOT_UPDATEABLE_IMAGES=1
SB_CONFIG_MCUBOOT_ADDITIONAL_UPDATEABLE_IMAGES=0
SB_CONFIG_MCUBOOT_APP_SYNC_UPDATEABLE_IMAGES=y
# end of MCUboot configuration
SB_CONFIG_DFU_MULTI_IMAGE_PACKAGE_BUILD=y
SB_CONFIG_DFU_MULTI_IMAGE_PACKAGE_APP=y
SB_CONFIG_SUPPORT_QSPI_XIP=y
# SB_CONFIG_BT_FAST_PAIR is not set
SB_CONFIG_DFU_ZIP=y
SB_CONFIG_DFU_ZIP_APP=y
# SB_CONFIG_DFU_ZIP_BLUETOOTH_MESH_METADATA is not set
SB_CONFIG_MATTER=y
# SB_CONFIG_MATTER_FACTORY_DATA_GENERATE is not set
SB_CONFIG_MATTER_OTA=y
SB_CONFIG_MATTER_OTA_IMAGE_FILE_NAME="matter.ota"
SB_CONFIG_SUIT_BASE_MANIFEST_VARIANT="matter/v1"
# Wi-Fi
# SB_CONFIG_WIFI_NRF70 is not set
# end of Wi-Fi
# SUIT
# SB_CONFIG_SUIT_ENVELOPE is not set
# SB_CONFIG_SUIT_BUILD_RECOVERY is not set
# SB_CONFIG_SUIT_BUILD_FLASH_COMPANION is not set
# end of SUIT
# SDP
# SB_CONFIG_SDP is not set
# end of SDP
# SB_CONFIG_APPROTECT_USE_UICR is not set
# SB_CONFIG_APPROTECT_LOCK is not set
SB_CONFIG_APPROTECT_NO_SYSBUILD=y
SB_CONFIG_ZEPHYR_NRF_MODULE=y
# end of nrf (C:/ncs/v2.8.0/nrf)
SB_CONFIG_ZEPHYR_MCUBOOT_MODULE=y
SB_CONFIG_ZEPHYR_MBEDTLS_MODULE=y
SB_CONFIG_ZEPHYR_OBERON_PSA_CRYPTO_MODULE=y
SB_CONFIG_ZEPHYR_TRUSTED_FIRMWARE_M_MODULE=y
SB_CONFIG_ZEPHYR_PSA_ARCH_TESTS_MODULE=y
SB_CONFIG_ZEPHYR_SOC_HWMV1_MODULE=y
SB_CONFIG_ZEPHYR_CJSON_MODULE=y
SB_CONFIG_ZEPHYR_AZURE_SDK_FOR_C_MODULE=y
SB_CONFIG_ZEPHYR_CIRRUS_LOGIC_MODULE=y
SB_CONFIG_ZEPHYR_OPENTHREAD_MODULE=y
SB_CONFIG_ZEPHYR_SUIT_GENERATOR_MODULE=y
SB_CONFIG_ZEPHYR_SUIT_PROCESSOR_MODULE=y
SB_CONFIG_ZEPHYR_MEMFAULT_FIRMWARE_SDK_MODULE=y
SB_CONFIG_ZEPHYR_COREMARK_MODULE=y
SB_CONFIG_ZEPHYR_CANOPENNODE_MODULE=y
SB_CONFIG_ZEPHYR_CHRE_MODULE=y
SB_CONFIG_ZEPHYR_LZ4_MODULE=y
SB_CONFIG_ZEPHYR_NANOPB_MODULE=y
SB_CONFIG_ZEPHYR_TF_M_TESTS_MODULE=y
SB_CONFIG_ZEPHYR_ZSCILIB_MODULE=y
SB_CONFIG_ZEPHYR_CMSIS_MODULE=y
SB_CONFIG_ZEPHYR_CMSIS_DSP_MODULE=y
SB_CONFIG_ZEPHYR_CMSIS_NN_MODULE=y
SB_CONFIG_ZEPHYR_FATFS_MODULE=y
SB_CONFIG_ZEPHYR_HAL_NORDIC_MODULE=y
SB_CONFIG_ZEPHYR_HAL_ST_MODULE=y
SB_CONFIG_ZEPHYR_HAL_WURTHELEKTRONIK_MODULE=y
SB_CONFIG_ZEPHYR_HOSTAP_MODULE=y
SB_CONFIG_ZEPHYR_LIBMETAL_MODULE=y
SB_CONFIG_ZEPHYR_LIBLC3_MODULE=y
SB_CONFIG_ZEPHYR_LITTLEFS_MODULE=y
SB_CONFIG_ZEPHYR_LORAMAC_NODE_MODULE=y
SB_CONFIG_ZEPHYR_LVGL_MODULE=y
SB_CONFIG_ZEPHYR_MIPI_SYS_T_MODULE=y
SB_CONFIG_ZEPHYR_NRF_HW_MODELS_MODULE=y
SB_CONFIG_ZEPHYR_OPEN_AMP_MODULE=y
SB_CONFIG_ZEPHYR_PICOLIBC_MODULE=y
SB_CONFIG_ZEPHYR_SEGGER_MODULE=y
SB_CONFIG_ZEPHYR_TINYCRYPT_MODULE=y
SB_CONFIG_ZEPHYR_UOSCORE_UEDHOC_MODULE=y
SB_CONFIG_ZEPHYR_ZCBOR_MODULE=y
SB_CONFIG_ZEPHYR_NRFXLIB_MODULE=y
SB_CONFIG_ZEPHYR_CONNECTEDHOMEIP_MODULE=y
# Unavailable modules, please install those via the project manifest.
# end of Modules
# SB_CONFIG_WARN_EXPERIMENTAL is not set
SB_CONFIG_WARN_DEPRECATED=y
SB_CONFIG_SUPPORT_BOOTLOADER=y
SB_CONFIG_SUPPORT_BOOTLOADER_MCUBOOT_ZEPHYR=y
# SB_CONFIG_BOOTLOADER_NONE is not set
SB_CONFIG_BOOTLOADER_MCUBOOT=y
# SB_CONFIG_MCUBOOT_MODE_SINGLE_APP is not set
# SB_CONFIG_MCUBOOT_MODE_SWAP_WITHOUT_SCRATCH is not set
SB_CONFIG_MCUBOOT_MODE_SWAP_SCRATCH=y
# SB_CONFIG_MCUBOOT_MODE_OVERWRITE_ONLY is not set
# SB_CONFIG_MCUBOOT_MODE_DIRECT_XIP is not set
# SB_CONFIG_MCUBOOT_MODE_DIRECT_XIP_WITH_REVERT is not set
# SB_CONFIG_MCUBOOT_MODE_RAM_LOAD is not set
# SB_CONFIG_MCUBOOT_MODE_FIRMWARE_UPDATER is not set
SB_CONFIG_SIGNATURE_TYPE="RSA"
# SB_CONFIG_BOOT_SIGNATURE_TYPE_NONE is not set
SB_CONFIG_BOOT_SIGNATURE_TYPE_RSA=y
# SB_CONFIG_BOOT_SIGNATURE_TYPE_ECDSA_P256 is not set
# SB_CONFIG_BOOT_SIGNATURE_TYPE_ED25519 is not set
SB_CONFIG_BOOT_SIGNATURE_KEY_FILE="C:/ncs/v2.8.0/bootloader/mcuboot/root-rsa-2048.pem"
# SB_CONFIG_BOOT_ENCRYPTION is not set
# Build options
# SB_CONFIG_COMPILER_WARNINGS_AS_ERRORS is not set
# end of Build options
Please let me know if there's anything else I can provide.
Chris
