For the nRF54 series, how to write logs into ZMS just by changing prj.conf
I am porting a ncs project from nrf52832 into nrf54l15
If want to reuse existing Log functions of system of zephyr, like supported by NVS, is there any way to do it?
Nordic AI said nrf54l15 should use ZMS to protect flash, and need to manually implement zms_log_store() function to replace all places of zephyr LOG_INF() .Is it the latest truth?
Thanks & Best Regards
-Shawn
  • Thanks Andreas, here is my latest conclusion:)
    for logging API with nRF54L15, there are 3 scenarios:
    1. output to UART/serial.
       no problem at all. everybody is happy about that.
    2.output to local file, with existing prj.conf options
       mainstream market is happy about that, while Noridc strongly recommends another option
    3.output to ZMS file
       which is recommended by Nordic. But currently, only project with scenarios picky enough or with developers geeky enough, would choose this option.
    Please correct me if anything wrong
    -Shawn
  • Hi again Shawn
    I'll just reiterate the previous comment I made about this with one an addition: ZMS is developed and intended to be used to store data in RRAM and not as a logging backend to a file system. If you wish, you can use the FS logging backend instead, but that will introduce extra wear and tear on the RRAM due to this solution isn't using any ZMS implementation. The issue is with the implementation that has the appropriate algorithm to handle reading and writing to RRAM (which the nRF54L15 SoC uses).
    I've never said "we recommend you to a ZMS file". What we've said is that ZMS is better to use with RRAM, but there is no built in logging to file-system backend.
    Andreas
