current time gets 0 after connectiong with bluetooth
hi, i am using ble_uart example to take time when data arrives and time when data being sent over bluetooth. when i prints the time without connecting to bluetooth. then the time gives a value. but after connecting with bluetooth it gives 0. i dont know what makes it 0.
below is my code:
/**@snippet [Handling the data received over UART] */
		uint8_t data[5];
    static uint8_t index,push = 0;
    uint32_t       err_code;
		static uint32_t previous_time,current_time,duration_time,waiting_time;
		waiting_time=450;
    switch (p_event->evt_type)
        case APP_UART_DATA_READY:
            index++;
						push++;
						if(index%3 == 0)
							count++;
							err_code = app_timer_cnt_get(&current_time);
							err_code = app_timer_cnt_diff_compute(current_time,previous_time,&duration_time);
							current_time = app_timer_ms(current_time);
							previous_time = app_timer_ms(previous_time);
							duration_time = app_timer_ms(duration_time);
							SEGGER_RTT_printf(0, "current:%d\tprevious:%d\tduration:%d\n",current_time,previous_time,duration_time);
							SEGGER_RTT_printf(0, "%x\t%x\t%x\n",data_array[0],data_array[1],data_array[2]);
									sendData(data_array,index);
									previous_time = current_time;
							index = 0;
							preCount=count;
what i am doing wrong here.
thanks!!
  • FormerMember
    0 FormerMember in reply to Mathias
    I see. I had forgotten what this thread was about.
    It should not be necessary to to use the app_timer module, what is necessary is to explicitly start RTC1. You should get the same result if you do the following:
    NRF_RTC1->TASKS_START = 1;
  • Unfortunately, that doesn't seem to be working. If I explicitly start RTC1 using NRF_RTC1->TASKS_START = 1, and don't run the empty, self defined timer anymore, I again get 0 on every request for the RTC1 Counter register's value.
  • FormerMember
    Is app_timer used somewhere in your application? I so, your timer and app_timer will share RTC1. In that case, could you try to use RTC2 instead for your timer?
  • App_timer is used in my application. And I'm using nRF51 so unfortunately, I can only use RTC1. But I don't need the timer I defined, I just need to get the value of the Counter register of RTC1 at any moment I want. And I don't understand why that gives me 0 when the SoftDevice and thus my application, is in a BLE connection, which is the same issue as the people above I believe.
    I "fixed" the register giving 0 by starting a self defined timer when in a connection, but I don't understand why I would need to do that? If app_timer is used, I presume that RTC1 is thus active and used and thus the Counter register should be giving me correct values without needing me to start a self defined timer, no?
  • FormerMember
    I just tested again reading the counter value, and it works fine to read NRF_RTC1-COUNTER, both when the device is advertising, and when in connected state (nRF51-DK, SDK 12.3.0, S132 v.2.0.1, ble_app_hrs)
    	case BSP_EVENT_KEY_0:
    						rtc_value = NRF_RTC1->COUNTER; //NRF_RTC1->CC[0];
    						NRF_LOG_INFO("RTC value: %d \n\r", rtc_value);
    Another option is to do the following:
    NRF_RTC1->CC[0] = NRF_RTC1->COUNTER;
    rtc_value = NRF_RTC1->CC[0];
