FRAME_INTVAL_UINT 10 // 毫秒 k_timer_init (& delay_timer ,delay_timer_handler ,NULL ); k_timer_start (& delay_timer ,K_MSEC ((uint32_t )FRAME_INTVAL_UINT ), K_MSEC ((uint32_t )FRAME_INTVAL_UINT ));
Do you have any application logs that demonstrate this issue?
Benjamin
In the main function, I use the k_timer_remaining_get function to query the next expiration time of the clock once every 1 second.
The log printing time is as follows:
Thanks, and do you see this remaining time decrease?
yes,The remaining time is decreasing, and it decreases by 1 second each time.
I’d like to forward this to someone who can provide a more detailed answer. Please confirm that I’ve understood your issue correctly.
You’re using a custom board with the nRF54L05. After the device has been running for about 12 hours and performs a sys_reboot(), the timer no longer fires as expected. When you call k_timer_remaining_get() after the issue occurs, it returns an abnormally large remaining time.
After this issue has occurred, can you fix it by power cycling or reflashing the firmware?
Also, have you been able to reproduce this issue on a DK (nrf54l15dk/nrf54l05)?
Benjamin
