ESL Tutorial - Unexplained byte in responses
I've been working through the Nordic Bluetooth ESL Tutorial and have the sample code up and running (using a nRF52833 DK as the tag and a nRF5340 DK as the access point).
I've been able to send commands and receive responses via the console, but I'm seeing an extra byte in the responses that I can't find described in any of the documentation.
For example,
> esl_c pawr update_pawr 0xA 0 pings the first 4 tags in group 0.
I only have one tag and I get the following response:
0x0434100300 where
0x04 = Tag 0, Length 4 bytes
0x34 = ???
0x10 = Basic state (the correct response to a ping)
0x0300 = 16-bit status field
> esl_c pawr update_pawr 0xF 0 reads sensor 0 data from the first 4 tags in group 0.
0x05342e007f08 where
0x05 = Tag 0, Length 5 bytes
0x34 = ???
0x2e = Sensor report, Length 2 bytes
0x7F08 = 16-bit sensor data
Where is the 0x34 coming from, and what does it signify?  It's in all of the responses.
Thanks
Scott
  • Hi Amanda,
    Thanks again for your help with all of these ESL questions.  I had disabled the unused peripherals as per the guide but the problem turned out to be an external sensor that was being initialised too soon after power-on. It's now working.
    I'm now trying to adjust the PaWR timing parameters but I don't seem to be able to adjust the Subevent Interval below 8 without causing the Central ESL app to stop working.  For example, the following works:
    CONFIG_ESL_PAWR_INTERVAL_MIN=1024
    CONFIG_ESL_PAWR_INTERVAL_MAX=1024
    CONFIG_ESL_CLIENT_MAX_GROUP=128
    CONFIG_ESL_SUBEVENT_INTERVAL=8
    CONFIG_ESL_RESPONSE_SLOT_DELAY=4
    CONFIG_ESL_RESPONSE_SLOT_SPACING=2
    CONFIG_ESL_NUM_RESPONSE_SLOTS=8
    CONFIG_ESL_CLIENT_MAX_RESPONSE_SLOT_BUFFER=8
    but this doesn't:
    CONFIG_ESL_PAWR_INTERVAL_MIN=768
    CONFIG_ESL_PAWR_INTERVAL_MAX=768
    CONFIG_ESL_SUBEVENT_INTERVAL=6
    I can't see anything obvious in the central_esl code but I thought that maybe CONFIG_ESL_SUBEVENT_INTERVAL was being divided by 8 somewhere which was causing values less than 8 to result in an error.  There are no clues in the log, because when the problem occurs, it also stops the VCP from working.
    Regards
    Scott
  • The latest issue is away from the original scope. Please create a new support case. Thanks.
