BLE Data Integrity Failures (Out-of-Order Segments)
We are experiencing critical data integrity issues on the BLE link of our gateway device. The problem occurs specifically when the device is operating as a BLE-to-Wi-Fi bridge and is under heavy load.
The scenario is a large file transfer (approx. 800KB) from a BLE node. When our gateway receives this data via GATT notifications (using an application-level SAR protocol), it simultaneously uploads it to a remote server via a Wi-Fi TCP connection. When both data streams (BLE-in and Wi-Fi-out) are active, the BLE link becomes unstable, logging numerous errors.
Upon debugging, we noticed that the GATT notification segments are in out of order at this point. For example, if we are expecting packets in sequence of (A1, A2, A3, A4), during error the sequence will be (A1, A2, A2, A4). one of the packet will repeat and seems to be replacing next packet.
Observed Behavior & Key Correlations
We have isolated three distinct sets of logs that, when correlated by their timestamps, show a clear pattern of failure.
1. Gateway Application Log :During the transfer, our gateway's application log records a high number of critical errors related to our SAR (Segmentation and Reassembly Protocol). The failures appear to start with packet corruption, which then breaks the segmentation logic:
  • sfp crc fail: This error occurs multiple times, indicating the gateway is receiving corrupted BLE packets.
  • Reassembly buffer overflow / out of order seg skipped: These logs indicate our SAR protocol is failing. We believe this is because the preceding packet corruption (sfp crc fail) creates a "hole" in the expected packet sequence. When the next valid packet arrives, the SAR logic sees it as "out of order," which breaks the reassembly process.
2. Node Log :Logs from the sending BLE node correlate directly with our gateway's internal errors.
  • SFP Nack Retry: This is logged on the Node almost immediately after our gateway logs a sfp crc fail.
  • SFP Timeout Retry: This occurs after the gateway's SAR protocol fails (e.g., after the out of order seg skipped log), suggesting our gateway received Continution Segment instead of Last segment.
3. Gateway Wi-Fi/TCP Log (Suspected Correlated Event):Logs from the gateway's internal TCP stack show that at the exact same time as the BLE CRC failures and SAR errors, the Wi-Fi radio is under maximum load.
  • tcp_window_full: The Wi-Fi send buffer is full, indicating a high-throughput transfer.
  • ca dup_ack: The TCP stack is busy handling packet loss and retransmissions on the Wi-Fi/Internet side.
  • RTT logs.txt
    06 2016/01/01 02:06:58.6 misc: RESET: 2016/01/01 02:06:58 BT Provisioned success
    007 2016/01/01 02:06:58.6 bt: off
    008 2016/01/01 02:06:58.6 mqtt: disconnected
    009 2016/01/01 02:06:58.7 bt: scan deferred
    010 2016/01/01 02:07:00.1 bt: scan
    011 2016/01/01 02:07:03.1 bo: Boot call
    012 2016/01/01 02:07:03.1 mqtt: bt_start
    013 2016/01/01 02:07:03.1 bt: adv deferred
    014 2016/01/01 02:07:10.1 bt: off
    015 2016/01/01 02:07:11.1 bt: advertise
    016 2016/01/01 02:07:11.1 bt: Proxy enabled already
    017 2016/01/01 02:07:11.1 bt2: Start proxy
    018 2016/01/01 02:07:11.1 bt2: Enable Mesh
    019 2016/01/01 02:07:11.1 bt2: Adv Tx Power 8
    020 2016/01/01 02:07:11.1 bt: adv iBeacon BB 59E
    021 2016/01/01 02:07:11.1 bt2: Adv repeat 314C
    022 2016/01/01 02:07:11.1 mqtt: bt_connect
    023 2016/01/01 02:07:11.6 bt: GAP conn handle 0
    024 2016/01/01 02:07:11.6 bt2: set_connect_flag 1
    025 2016/01/01 02:07:11.6 bt: GAP RSSI -66
    026 2016/01/01 02:07:11.6 bt2: set_connect_flag 3
    027 2016/01/01 02:07:12.3 bt: bspReadySet 1
    028 2016/01/01 02:07:12.3 bt2: set_connect_flag 7
    029 2016/01/01 02:07:12.3 mqtt: Connect
    030 2016/01/01 02:07:12.3 bt2: Tx L21 15,04,04,01,00,3C,35,39,35,33
    031 2016/01/01 02:07:12.3 bt2: Mesh disable supressed
    032 2016/01/01 02:07:12.3 bt: connected
    033 2016/01/01 02:07:13.1 bt: node id deferred
    034 2016/01/01 02:07:25.7 bt2: Rx L5 05,02,35,C7,2C
    035 2016/01/01 02:07:25.7 mqtt: GWINFO C72C 35
    036 2016/01/01 02:07:31.9 bt2: Rx L3 03,05,00
    037 2016/01/01 02:07:31.9 mqtt: CONNACK
    038 2016/01/01 02:07:31.9 mqtt: Register /wear/v2/data/595315500014389
    039 2016/01/01 02:07:31.9 bt2: Tx L35 23,0A,00,00,00,01,2F,77,65,61
    040 2016/01/01 02:07:32.1 bt2: Rx L7 07,0B,00,01,00,01,00
    041 2016/01/01 02:07:32.1 mqtt: REGACK 1
    042 2016/01/01 02:07:32.1 mqtt: Register /wear/v2/cs/595315500014389
    043 2016/01/01 02:07:32.1 bt2: Tx L33 21,0A,00,00,00,02,2F,77,65,61
    044 2016/01/01 02:07:32.2 bt2: Rx L7 07,0B,00,02,00,02,00
    045 2016/01/01 02:07:32.2 mqtt: REGACK 2
    046 2016/01/01 02:07:32.2 mqtt: Register /wear/v1/time/595315500014389
    047 2016/01/01 02:07:32.2 bt2: Tx L35 23,0A,00,00,00,03,2F,77,65,61
    048 2016/01/01 02:07:32.2 bt2: Rx L7 07,0B,00,03,00,03,00
    049 2016/01/01 02:07:32.2 mqtt: REGACK 3
    050 2016/01/01 02:07:32.2 mqtt: Register /wear/v2/fwu/595315500014389
    051 2016/01/01 02:07:32.2 bt2: Tx L34 22,0A,00,00,00,04,2F,77,65,61
    052 2016/01/01 02:07:32.3 bt2: Rx L7 07,0B,00,04,00,04,00
    053 2016/01/01 02:07:32.3 mqtt: REGACK 4
    054 2016/01/01 02:07:32.3 mqtt: Register /wear/v1/lwt/595315500014389
    055 2016/01/01 02:07:32.3 bt2: Tx L34 22,0A,00,00,00,05,2F,77,65,61
    056 2016/01/01 02:07:32.3 bt2: Rx L7 07,0B,00,05,00,05,00
    057 2016/01/01 02:07:32.3 mqtt: REGACK 5
    058 2016/01/01 02:07:32.3 mqtt: Register /wear/v1/stat/595315500014389
    059 2016/01/01 02:07:32.3 bt2: Tx L35 23,0A,00,00,00,06,2F,77,65,61
    060 2016/01/01 02:07:32.4 bt2: Rx L7 07,0B,00,06,00,06,00
    061 2016/01/01 02:07:32.4 mqtt: REGACK 6
    062 2016/01/01 02:07:32.4 mqtt: Register /wear/v1/sfp/595315500014389
    063 2016/01/01 02:07:32.4 bt2: Tx L34 22,0A,00,00,00,07,2F,77,65,61
    064 2016/01/01 02:07:32.5 bt2: Rx L7 07,0B,00,07,00,07,00
    065 2016/01/01 02:07:32.5 mqtt: REGACK 7
    066 2016/01/01 02:07:32.5 mqtt: Subscribe Q0 /mqcp/ppm/v2/data/595315500014389
    067 2016/01/01 02:07:32.5 bt2: Tx L38 26,12,00,00,08,2F,6D,71,63,70
    068 2016/01/01 02:07:32.9 bt2: Rx L8 08,13,00,00,08,00,08,00
    069 2016/01/01 02:07:32.9 mqtt: SUBACK 8
    070 2016/01/01 02:07:32.9 mqtt: Subscribe Q1 /mqcp/ppm/v2/cs/595315500014389
    071 2016/01/01 02:07:32.9 bt2: Tx L36 24,12,20,00,09,2F,6D,71,63,70
    072 2016/01/01 02:07:33.3 bt2: Rx L8 08,13,20,00,09,00,09,00
    073 2016/01/01 02:07:33.3 mqtt: SUBACK 9
    074 2016/01/01 02:07:33.3 mqtt: Subscribe Q0 /mqcp/ppm/v1/time/595315500014389
    075 2016/01/01 02:07:33.3 bt2: Tx L38 26,12,00,00,0A,2F,6D,71,63,70
    076 2016/01/01 02:07:33.7 bt2: Rx L8 08,13,00,00,0A,00,0A,00
    077 2016/01/01 02:07:33.7 mqtt: SUBACK 10
    078 2016/01/01 02:07:33.7 mqtt: Subscribe Q1 /mqcp/ppm/v2/fwu/595315500014389
    079 2016/01/01 02:07:33.7 bt2: Tx L37 25,12,20,00,0B,2F,6D,71,63,70
    080 2016/01/01 02:07:34.1 bt2: Rx L8 08,13,20,00,0B,00,0B,00
    081 2016/01/01 02:07:34.1 mqtt: SUBACK 11
    082 2016/01/01 02:07:34.1 mqtt: Subscribe Q0 /mqcp/ppm/v1/sfp/595315500014389
    083 2016/01/01 02:07:34.1 bt2: Tx L37 25,12,00,00,0C,2F,6D,71,63,70
    084 2016/01/01 02:07:34.5 bt2: Rx L8 08,13,00,00,0C,00,0C,00
    085 2016/01/01 02:07:34.5 mqtt: SUBACK 12
    086 2016/01/01 02:07:34.5 mqtt: ready
    087 2016/01/01 02:07:34.5 bo: Connected, rssi -66, mtu 236, gw addr 0xC72C
    088 2016/01/01 02:07:34.5 bo: Send Status
    089 2016/01/01 02:07:34.5 mqtt: Publish_send L24 Q1 T6
    090 2016/01/01 02:07:34.5 mqtt: Publish 01,56,85,DF,66,62,02,00,00,00
    091 2016/01/01 02:07:34.5 bt2: Tx L31 1F,0C,20,00,06,00,0D,01,56,85
    092 2016/01/01 02:07:34.5 mqtt: publishing
    093 2016/01/01 02:07:34.9 bt2: Rx L7 07,0D,00,06,00,0D,00
    094 2016/01/01 02:07:34.9 mqtt: PUBACK
    095 2016/01/01 02:07:34.9 mqtt: ready
    096 2016/01/01 02:07:34.9 bo: Uploading 3584 Events bytes
    097 2016/01/01 02:07:34.9 mqtt: Publish_send L68 Q0 T1
    098 2016/01/01 02:07:34.9 mqtt: Publish 00,36,06,79,27,B3,00,00,56,85
    099 2016/01/01 02:07:34.9 bt2: Tx L75 4B,0C,00,00,01,00,0E,00,36,06
    100 2016/01/01 02:07:34.9 mqtt: ready
    101 2016/01/01 02:07:39.3 bt: bspReadySet 0
    102 2016/01/01 02:07:39.3 bt2: Stop proxy
    103 2016/01/01 02:07:39.3 bt2: Disable Mesh
    104 2016/01/01 02:07:39.3 bt: off
    105 2016/01/01 02:07:39.3 mqtt: disconnected
    106 2016/01/01 02:07:39.3 core: GeneralError: 1974 Disconnect during Events
    107 2016/01/01 02:07:39.3 bo: call completed with failures
    108 2016/01/01 02:07:41.1 bt: node_id_advertise
    109 2016/01/01 02:07:41.1 bt2: Enable Proxy
    110 2016/01/01 02:07:41.1 bt2: Start proxy
    111 2016/01/01 02:07:41.1 bt2: Enable Mesh
    112 2016/01/01 02:07:41.1 bt2: Adv Tx Power 8
    113 2016/01/01 02:07:41.1 bt: adv iBeacon FE 7500059E
    114 2016/01/01 02:07:41.1 bt2: Adv repeat 314C
    115 2016/01/01 02:08:08.1 bt2: Stop proxy
    116 2016/01/01 02:08:08.1 bt2: Disable Mesh
    087 2025/11/03 05:47:16.44 misc:  1
    088 2025/11/03 05:47:16.44 misc: 85
    089 2025/11/03 05:47:16.44 misc: 85
    090 2025/11/03 05:47:16.44 misc: 3b
    091 2025/11/03 05:47:16.44 misc: 5e
    092 2025/11/03 05:47:16.44 misc: sfp Length<1001>
    093 2025/11/03 05:47:16.44 core: GeneralError: sfp crc fail
    094 2025/11/03 05:47:38.00 misc:  1
    095 2025/11/03 05:47:38.00 misc: e6
    096 2025/11/03 05:47:38.00 misc: e7
    097 2025/11/03 05:47:38.01 misc: 1f
    098 2025/11/03 05:47:38.01 misc: sfp Length<1015>
    099 2025/11/03 05:47:38.01 core: GeneralError: sfp crc fail
    100 2025/11/03 05:47:38.01 core: GeneralError: uid:1 MQTTSN MLen 1030 785
    101 2025/11/03 05:48:28.66 misc:  1
    102 2025/11/03 05:48:28.66 misc: 74
    103 2025/11/03 05:48:28.66 misc: 74
    104 2025/11/03 05:48:28.66 misc: 74
    105 2025/11/03 05:48:28.66 misc: f9
    106 2025/11/03 05:48:28.66 misc: sfp Length<1007>
    107 2025/11/03 05:48:28.66 core: GeneralError: sfp crc fail
    108 2025/11/03 05:48:37.98 misc: Unsubscribed handle <0x0012>
    109 2025/11/03 05:48:37.98 misc: BLE Disconnected <22>
  • Hi, Revanth and I work together in same team and I too reproduced this issue on my setup with nrf52840 DK sniffer capturing the BLE exchange. I've taken the liberty of sharing this wireshark capture here.outOfOrder.pcapng
    There are at least 5 instances where the first segment PDU arrived from wearable(nrf52840 based dev board running nordic BLE stack) consecutively without a continue or last segment in between. Please also see the attached snapshots
