multiple services issue
I'm running into something weird on SDK8.0 (I will be upgrading soon to SDK10, however it's a layered roll out so I can't update right now unless you tell me it's a bug in SDK8.0
I have two primary services. I register each and get two different handles. I then register a bunch of characteristic value attributes to each of the service handles and then discover on the central role only to find out that one service has no characteristics and the other has them all. Each service has an unique UUID, each service has a set of unique UUID characteristics and a couple in common. I see this happen on both a S130 central role and with the MCP so I trust that this is happening on the S110 side. Everything works, it's just that the service discovery is claiming zero assigned value handles to the first and all of them on the other. Reading and writing the value handles is just fine.
Any clue on why this can be happening? I can't post the code here due to client confidentially.
  • I always assumed it was for completeness and incase one day the implementation changes to allow you to put services in in any order and reorders them later (unlikely). I do think, since the handle is passed-in and it's known whether that is the last service or not, it ought to return an error if one adds to the 'wrong' service, that at least would make it clear that order does matter. As it is, yes, it's rather redundantly redundant.
