gpio button interrupt is not triggering?
Hi all,
I am using pca10040 board. My requirement is when i press the button led should turn on after repress the button led should turn off.
For that i tried below code :
#include <stdbool.h>
#include <stdint.h>
#include "pca10040.h"
#include "bsp.h"
#include "nordic_common.h"
#include "nrf_gpio.h"
#include "nrf_drv_clock.h"
#include "sdk_errors.h"
#include "app_error.h"
#include "app_uart.h"
#include "app_fifo.h"
#include "app_button.h"
#include "app_timer.h"
#include "nrf_delay.h"
#include "nrf_error.h"
#define APP_TIMER_PRESCALER 0
#define  APP_TIMER_OP_QUEUE_SIZE 6
#define BUTTON_DETECTION_DELAY        APP_TIMER_TICKS(500u, APP_TIMER_PRESCALER)
#define MAX_TEST_DATA_BYTES     (15U)                /**< max number of test bytes to be used for tx and rx. */
#define UART_TX_BUF_SIZE 256                         /**< UART TX buffer size. */
#define UART_RX_BUF_SIZE 1                           /**< UART RX buffer size. */
void button_handler(uint8_t pin_no, uint8_t button_action)
    UNUSED_VARIABLE(puts("Enter \r\n"));
    nrf_gpio_pin_toggle(BSP_LED_1);
    if (button_action == APP_BUTTON_PUSH)
        switch (pin_no)
            case BSP_BUTTON_0:
                    UNUSED_VARIABLE(puts(" Buttons 0 \r\n"));
                    nrf_gpio_pin_toggle(BSP_LED_0);
void leds_init(void)
        UNUSED_VARIABLE(puts("LEDS Initialized \r\n"));
// Configure LED-pins as outputs
    nrf_gpio_cfg_output(BSP_LED_0);
    nrf_gpio_cfg_output(BSP_LED_1);
    nrf_gpio_cfg_output(BSP_LED_2);
    nrf_gpio_cfg_output(BSP_LED_3);
    nrf_gpio_pin_set(BSP_LED_0);
    nrf_gpio_pin_set(BSP_LED_1);
    nrf_gpio_pin_set(BSP_LED_2);
    nrf_gpio_pin_set(BSP_LED_3);
void uart_error_handle(app_uart_evt_t * p_event)
    if (p_event->evt_type == APP_UART_COMMUNICATION_ERROR)
    else if (p_event->evt_type == APP_UART_FIFO_ERROR)
void uart_init(void)
    ret_code_t err_code;
    const app_uart_comm_params_t comm_params =
        RX_PIN_NUMBER,
        TX_PIN_NUMBER,
        RTS_PIN_NUMBER,
        CTS_PIN_NUMBER,
        APP_UART_FLOW_CONTROL_ENABLED,
        false,
        UART_BAUDRATE_BAUDRATE_Baud38400
                       UART_RX_BUF_SIZE,
                       UART_TX_BUF_SIZE,
                       uart_error_handle,
                       APP_IRQ_PRIORITY_LOW,
                       err_code);
    UNUSED_VARIABLE(puts(" UART Initialized \r\n"));
        err_code = nrf_drv_clock_init();
        uart_init();
        leds_init();
        UNUSED_VARIABLE(puts(" Buttons Initialized \r\n"));
        app_button_cfg_t p_button[] = {{BUTTON_1, false, BUTTON_PULL, button_handler}};
        APP_TIMER_INIT(APP_TIMER_PRESCALER, APP_TIMER_OP_QUEUE_SIZE, NULL);
        // Initializing the buttons.
        err_code = app_button_init(p_button,1, BUTTON_DETECTION_DELAY);
        // Enabling the buttons.
        err_code = app_button_enable();
        while(1) {
            __WFE();
            __SEV();
            __WFE();
Buttons Initialization is done. But button handler is not calling. In my console i'm getting prints like this :
 UART Initialized
LEDS Initialized
 Buttons Initialized
After that its hanging there itself.
Why button handler is not called?
Im a newbie on this. Can anyone help me to fix this issue?
Thank you,
  • The gpiote interrupt priority is defined by GPIOTE_CONFIG_IRQ_PRIORITY in nrf_drv_config.h.
  • yeah thats fine. How many interrupts we can able to generate and setting priorities using gpio?
  • App_button uses PORT event which is only limited to number of pins, so you can technically have buttons on all pins if you want. You have to change GPIOTE_CONFIG_NUM_OF_LOW_POWER_EVENTS in nrf_drv_config.h to be high enough though. You can use two priority level when using SoftDevice: APP_PRIORITY_LOW and APP_PRIORITY_HIGH. If not using SoftDevice you have 4 interrupt levels. Did this answer your question?
  • Hi Ole Bauck, Thank you for your responses. Whatever you above mentioned thats fine. I'm using GPIOTE, with that we can able to set upto 8 interrupts only right? if wrong means please correct me. Actually i need more than 8 interrupts, I dont know how to use remaining pins a interrupt pins and how to set priorities about those pins.
    Can you guide me on this please?
    Thanks Again.. :)
  • Just answered similar question here. With PORT event you can have interrupt on all pins, with IN event you can only have on 8 pins.
1 2 3
