Weird I2C behavior - only P1.4 + P1.5 combination works
Hey folks, I've tried bunch of things but can't make TWIM work properly on nrf54l15-DK outside of that pair of pins.
Basically the issue is that it only works correctly if I use P1.4 and P1.5. If I change 4 to 11 - no luck. If I change 5 to 7 or 10, same. As soon as I change it back everything works perfectly.
Here is the overlay
&i2c20 {
    status = "okay";
    pinctrl-0 = <&i2c20_default>;
    // pinctrl-1 = <&i2c20_sleep>;
    pinctrl-names = "default";
    clock-frequency = <I2C_BITRATE_STANDARD>;
    pcf8574: pcf857x@20 {
        compatible = "nxp,pcf857x";
        status = "okay";
        reg = <0x20>;
        gpio-controller;
        #gpio-cells = <2>;
        ngpios = <8>;
i2c20_default: i2c20_default {
        group1 {
            psels = <NRF_PSEL(TWIM_SCL, 1, 11)>,
                    <NRF_PSEL(TWIM_SDA, 1, 5)>;
In conf file I do have
CONFIG_I2C=y
and that's it. Do I need to do some NRF specific flags for TWIM to work on other pins? I did hear there could be some issues with them.
Maybe pull ups enabled only on certain pins by default or DK v0.9.3 is wired in some weird way?
Any hints will be appreciated!
  • Pins that I've had a success with were stated in the title of the ticket tho. But indeed I could've duplicated them in the post as well. To be sure - they were 1.4 and 1.5.
    Here is the final dts file with pins as I want them to work at the end - as far as I could tell there are no conflicts? But in this configuration I2C on pins 10 and 11 does not work
    /dts-v1/;
    /* node '/' defined in zephyr/dts/vendor/nordic/nrf_common.dtsi:24 */
    	#address-cells = < 0x1 >;                              /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:19 */
    	#size-cells = < 0x1 >;                                 /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:20 */
    	compatible = "nordic,nrf54l15dk_nrf54l15-cpuapp";      /* in zephyr/boards/nordic/nrf54l15dk/nrf54l15dk_nrf54l15_cpuapp.dts:13 */
    	model = "Nordic nRF54L15 DK nRF54L15 Application MCU"; /* in zephyr/boards/nordic/nrf54l15dk/nrf54l15dk_nrf54l15_cpuapp.dts:14 */
    	/* node '/pin-controller' defined in zephyr/dts/vendor/nordic/nrf_common.dtsi:25 */
    	pinctrl: pin-controller {
    		compatible = "nordic,nrf-pinctrl"; /* in zephyr/dts/vendor/nordic/nrf_common.dtsi:30 */
    		/* node '/pin-controller/uart20_default' defined in zephyr/boards/nordic/nrf54l15dk/nrf54l15dk_nrf54l_05_10_15-pinctrl.dtsi:7 */
    		uart20_default: uart20_default {
    			phandle = < 0x9 >; /* in zephyr/boards/nordic/nrf54l15dk/nrf54l15dk_common.dtsi:92 */
    			/* node '/pin-controller/uart20_default/group1' defined in zephyr/boards/nordic/nrf54l15dk/nrf54l15dk_nrf54l_05_10_15-pinctrl.dtsi:8 */
    			group1 {
    				psels = < 0x24 >,
    				        < 0x2000026 >; /* in zephyr/boards/nordic/nrf54l15dk/nrf54l15dk_nrf54l_05_10_15-pinctrl.dtsi:9 */
    			/* node '/pin-controller/uart20_default/group2' defined in zephyr/boards/nordic/nrf54l15dk/nrf54l15dk_nrf54l_05_10_15-pinctrl.dtsi:13 */
    			group2 {
    				psels = < 0x1000025 >,
    				        < 0x3000027 >; /* in zephyr/boards/nordic/nrf54l15dk/nrf54l15dk_nrf54l_05_10_15-pinctrl.dtsi:14 */
    				bias-pull-up;          /* in zephyr/boards/nordic/nrf54l15dk/nrf54l15dk_nrf54l_05_10_15-pinctrl.dtsi:16 */
    		/* node '/pin-controller/uart20_sleep' defined in zephyr/boards/nordic/nrf54l15dk/nrf54l15dk_nrf54l_05_10_15-pinctrl.dtsi:20 */
    		uart20_sleep: uart20_sleep {
    			phandle = < 0xa >; /* in zephyr/boards/nordic/nrf54l15dk/nrf54l15dk_common.dtsi:93 */
    			/* node '/pin-controller/uart20_sleep/group1' defined in zephyr/boards/nordic/nrf54l15dk/nrf54l15dk_nrf54l_05_10_15-pinctrl.dtsi:21 */
    			group1 {
    				psels = < 0x24 >,
    				        < 0x1000025 >,
    				        < 0x2000026 >,
    				        < 0x3000027 >; /* in zephyr/boards/nordic/nrf54l15dk/nrf54l15dk_nrf54l_05_10_15-pinctrl.dtsi:22 */
    				low-power-enable;      /* in zephyr/boards/nordic/nrf54l15dk/nrf54l15dk_nrf54l_05_10_15-pinctrl.dtsi:26 */
    		/* node '/pin-controller/uart30_default' defined in zephyr/boards/nordic/nrf54l15dk/nrf54l15dk_nrf54l_05_10_15-pinctrl.dtsi:30 */
    		uart30_default: uart30_default {
    			phandle = < 0x13 >; /* in zephyr/boards/nordic/nrf54l15dk/nrf54l15dk_common.dtsi:99 */
    			/* node '/pin-controller/uart30_default/group1' defined in zephyr/boards/nordic/nrf54l15dk/nrf54l15dk_nrf54l_05_10_15-pinctrl.dtsi:31 */
    			group1 {
    				psels = < 0x0 >,
    				        < 0x2000002 >; /* in zephyr/boards/nordic/nrf54l15dk/nrf54l15dk_nrf54l_05_10_15-pinctrl.dtsi:32 */
    			/* node '/pin-controller/uart30_default/group2' defined in zephyr/boards/nordic/nrf54l15dk/nrf54l15dk_nrf54l_05_10_15-pinctrl.dtsi:36 */
    			group2 {
    				psels = < 0x1000001 >,
    				        < 0x3000003 >; /* in zephyr/boards/nordic/nrf54l15dk/nrf54l15dk_nrf54l_05_10_15-pinctrl.dtsi:37 */
    				bias-pull-up;          /* in zephyr/boards/nordic/nrf54l15dk/nrf54l15dk_nrf54l_05_10_15-pinctrl.dtsi:39 */
    		/* node '/pin-controller/uart30_sleep' defined in zephyr/boards/nordic/nrf54l15dk/nrf54l15dk_nrf54l_05_10_15-pinctrl.dtsi:43 */
    		uart30_sleep: uart30_sleep {
    			phandle = < 0x14 >; /* in zephyr/boards/nordic/nrf54l15dk/nrf54l15dk_common.dtsi:100 */
    			/* node '/pin-controller/uart30_sleep/group1' defined in zephyr/boards/nordic/nrf54l15dk/nrf54l15dk_nrf54l_05_10_15-pinctrl.dtsi:44 */
    			group1 {
    				psels = < 0x0 >,
    				        < 0x1000001 >,
    				        < 0x2000002 >,
    				        < 0x3000003 >; /* in zephyr/boards/nordic/nrf54l15dk/nrf54l15dk_nrf54l_05_10_15-pinctrl.dtsi:45 */
    				low-power-enable;      /* in zephyr/boards/nordic/nrf54l15dk/nrf54l15dk_nrf54l_05_10_15-pinctrl.dtsi:49 */
    		/* node '/pin-controller/spi00_default' defined in zephyr/boards/nordic/nrf54l15dk/nrf54l15dk_nrf54l_05_10_15-pinctrl.dtsi:53 */
    		spi00_default: spi00_default {
    			phandle = < 0x4 >; /* in ../../Projects/personal/mp3/nrf/build/nrf/zephyr/boards/nrf54l15dk_nrf54l10_cpuapp.overlay:52 */
    			/* node '/pin-controller/spi00_default/group1' defined in zephyr/boards/nordic/nrf54l15dk/nrf54l15dk_nrf54l_05_10_15-pinctrl.dtsi:54 */
    			group1 {
    				psels = < 0x6000044 >; /* in ../../Projects/personal/mp3/nrf/build/nrf/zephyr/boards/nrf54l15dk_nrf54l10_cpuapp.overlay:122 */
    			/* node '/pin-controller/spi00_default/group2' defined in ../../Projects/personal/mp3/nrf/build/nrf/zephyr/boards/nrf54l15dk_nrf54l10_cpuapp.overlay:125 */
    			group2 {
    				psels = < 0x4000046 >,
    				        < 0x5000042 >;       /* in ../../Projects/personal/mp3/nrf/build/nrf/zephyr/boards/nrf54l15dk_nrf54l10_cpuapp.overlay:126 */
    				nordic,drive-mode = < 0x8 >; /* in ../../Projects/personal/mp3/nrf/build/nrf/zephyr/boards/nrf54l15dk_nrf54l10_cpuapp.overlay:128 */
    		/* node '/pin-controller/spi00_sleep' defined in zephyr/boards/nordic/nrf54l15dk/nrf54l15dk_nrf54l_05_10_15-pinctrl.dtsi:61 */
    		spi00_sleep: spi00_sleep {
    			phandle = < 0x5 >; /* in ../../Projects/personal/mp3/nrf/build/nrf/zephyr/boards/nrf54l15dk_nrf54l10_cpuapp.overlay:53 */
    			/* node '/pin-controller/spi00_sleep/group1' defined in zephyr/boards/nordic/nrf54l15dk/nrf54l15dk_nrf54l_05_10_15-pinctrl.dtsi:62 */
    			group1 {
    				        < 0x5000042 >,
    				        < 0x6000044 >; /* in ../../Projects/personal/mp3/nrf/build/nrf/zephyr/boards/nrf54l15dk_nrf54l10_cpuapp.overlay:134 */
    				low-power-enable;      /* in ../../Projects/personal/mp3/nrf/build/nrf/zephyr/boards/nrf54l15dk_nrf54l10_cpuapp.overlay:137 */
    		/* node '/pin-controller/pwm20_default' defined in zephyr/boards/nordic/nrf54l15dk/nrf54l15dk_nrf54l_05_10_15-pinctrl.dtsi:70 */
    		pwm20_default: pwm20_default {
    			phandle = < 0xd >; /* in zephyr/boards/nordic/nrf54l15dk/nrf54l15dk_common.dtsi:106 */
    			/* node '/pin-controller/pwm20_default/group1' defined in zephyr/boards/nordic/nrf54l15dk/nrf54l15dk_nrf54l_05_10_15-pinctrl.dtsi:71 */
    			group1 {
    				psels = < 0x1600002a >; /* in zephyr/boards/nordic/nrf54l15dk/nrf54l15dk_nrf54l_05_10_15-pinctrl.dtsi:72 */
    		/* node '/pin-controller/pwm20_sleep' defined in zephyr/boards/nordic/nrf54l15dk/nrf54l15dk_nrf54l_05_10_15-pinctrl.dtsi:76 */
    		pwm20_sleep: pwm20_sleep {
    			phandle = < 0xe >; /* in zephyr/boards/nordic/nrf54l15dk/nrf54l15dk_common.dtsi:107 */
    			/* node '/pin-controller/pwm20_sleep/group1' defined in zephyr/boards/nordic/nrf54l15dk/nrf54l15dk_nrf54l_05_10_15-pinctrl.dtsi:77 */
    			group1 {
    				psels = < 0x1600002a >; /* in zephyr/boards/nordic/nrf54l15dk/nrf54l15dk_nrf54l_05_10_15-pinctrl.dtsi:78 */
    				low-power-enable;       /* in zephyr/boards/nordic/nrf54l15dk/nrf54l15dk_nrf54l_05_10_15-pinctrl.dtsi:79 */
    		/* node '/pin-controller/i2c20_default' defined in ../../Projects/personal/mp3/nrf/build/nrf/zephyr/boards/nrf54l15dk_nrf54l10_cpuapp.overlay:113 */
    			phandle = < 0x7 >; /* in ../../Projects/personal/mp3/nrf/build/nrf/zephyr/boards/nrf54l15dk_nrf54l10_cpuapp.overlay:97 */
    			/* node '/pin-controller/i2c20_default/group1' defined in ../../Projects/personal/mp3/nrf/build/nrf/zephyr/boards/nrf54l15dk_nrf54l10_cpuapp.overlay:114 */
    			group1 {
    				psels = < 0xb00002b >,
    				        < 0xc00002a >; /* in ../../Projects/personal/mp3/nrf/build/nrf/zephyr/boards/nrf54l15dk_nrf54l10_cpuapp.overlay:115 */
    		/* node '/pin-controller/spi21_default' defined in ../../Projects/personal/mp3/nrf/build/nrf/zephyr/boards/nrf54l15dk_nrf54l10_cpuapp.overlay:141 */
    		spi21_default: spi21_default {
    			phandle = < 0xb >; /* in ../../Projects/personal/mp3/nrf/build/nrf/zephyr/boards/nrf54l15dk_nrf54l10_cpuapp.overlay:71 */
    			/* node '/pin-controller/spi21_default/group1' defined in ../../Projects/personal/mp3/nrf/build/nrf/zephyr/boards/nrf54l15dk_nrf54l10_cpuapp.overlay:142 */
    			group1 {
    				psels = < 0x400002c >,
    				        < 0x500002d >; /* in ../../Projects/personal/mp3/nrf/build/nrf/zephyr/boards/nrf54l15dk_nrf54l10_cpuapp.overlay:143 */
    		/* node '/pin-controller/spi21_sleep' defined in ../../Projects/personal/mp3/nrf/build/nrf/zephyr/boards/nrf54l15dk_nrf54l10_cpuapp.overlay:147 */
    		spi21_sleep: spi21_sleep {
    			phandle = < 0xc >; /* in ../../Projects/personal/mp3/nrf/build/nrf/zephyr/boards/nrf54l15dk_nrf54l10_cpuapp.overlay:72 */
    			/* node '/pin-controller/spi21_sleep/group1' defined in ../../Projects/personal/mp3/nrf/build/nrf/zephyr/boards/nrf54l15dk_nrf54l10_cpuapp.overlay:148 */
    			group1 {
    				        < 0x500002d >; /* in ../../Projects/personal/mp3/nrf/build/nrf/zephyr/boards/nrf54l15dk_nrf54l10_cpuapp.overlay:149 */
    				low-power-enable;      /* in ../../Projects/personal/mp3/nrf/build/nrf/zephyr/boards/nrf54l15dk_nrf54l10_cpuapp.overlay:151 */
    		/* node '/pin-controller/i2s20_default_alt' defined in ../../Projects/personal/mp3/nrf/build/nrf/zephyr/boards/nrf54l15dk_nrf54l10_cpuapp.overlay:155 */
    		i2s20_default_alt: i2s20_default_alt {
    			phandle = < 0x10 >; /* in ../../Projects/personal/mp3/nrf/build/nrf/zephyr/boards/nrf54l15dk_nrf54l10_cpuapp.overlay:90 */
    			/* node '/pin-controller/i2s20_default_alt/group1' defined in ../../Projects/personal/mp3/nrf/build/nrf/zephyr/boards/nrf54l15dk_nrf54l10_cpuapp.overlay:156 */
    			group1 {
    				psels = < 0xd000024 >,
    				        < 0x12000025 >,
    				        < 0xf000026 >,
    				        < 0x11000027 >,
    				        < 0x13000028 >; /* in ../../Projects/personal/mp3/nrf/build/nrf/zephyr/boards/nrf54l15dk_nrf54l10_cpuapp.overlay:157 */
    	/* node '/entropy_bt_hci' defined in zephyr/dts/vendor/nordic/nrf_common.dtsi:33 */
    	rng_hci: entropy_bt_hci {
    		compatible = "zephyr,bt-hci-entropy"; /* in zephyr/dts/vendor/nordic/nrf_common.dtsi:34 */
    		status = "okay";                      /* in zephyr/dts/vendor/nordic/nrf_common.dtsi:35 */
    	/* node '/cpus' defined in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:22 */
    	cpus {
    		#address-cells = < 0x1 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:23 */
    		#size-cells = < 0x0 >;    /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:24 */
    		/* node '/cpus/cpu@0' defined in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:26 */
    		cpuapp: cpu: cpu@0 {
    			compatible = "arm,cortex-m33f"; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:27 */
    			reg = < 0x0 >;                  /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:28 */
    			device_type = "cpu";            /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:29 */
    			clocks = < &hfpll >;            /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:30 */
    			#address-cells = < 0x1 >;       /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:31 */
    			#size-cells = < 0x1 >;          /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:32 */
    			/* node '/cpus/cpu@0/itm@e0000000' defined in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:34 */
    			itm: itm@e0000000 {
    				compatible = "arm,armv8m-itm";     /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:35 */
    				reg = < 0xe0000000 0x1000 >;       /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:36 */
    				swo-ref-frequency = < 0x7a12000 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:37 */
    	/* node '/clocks' defined in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:51 */
    	clocks {
    		/* node '/clocks/pclk' defined in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:52 */
    		pclk: pclk {
    			compatible = "fixed-clock";     /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:53 */
    			#clock-cells = < 0x0 >;         /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:54 */
    			clock-frequency = < 0xf42400 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:55 */
    			phandle = < 0x12 >;             /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:579 */
    		/* node '/clocks/lfxo' defined in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:58 */
    		lfxo: lfxo {
    			compatible = "nordic,nrf54l-lfxo";        /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:59 */
    			#clock-cells = < 0x0 >;                   /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:60 */
    			clock-frequency = < 0x8000 >;             /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:61 */
    			load-capacitors = "internal";             /* in zephyr/boards/nordic/nrf54l15dk/nrf54l_05_10_15_cpuapp_common.dtsi:35 */
    			load-capacitance-femtofarad = < 0x4268 >; /* in zephyr/boards/nordic/nrf54l15dk/nrf54l_05_10_15_cpuapp_common.dtsi:36 */
    			phandle = < 0x11 >;                       /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:579 */
    		/* node '/clocks/hfxo' defined in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:64 */
    		hfxo: hfxo {
    			compatible = "nordic,nrf54l-hfxo";        /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:65 */
    			#clock-cells = < 0x0 >;                   /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:66 */
    			clock-frequency = < 0x1e84800 >;          /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:67 */
    			startup-time-us = < 0x356 >;              /* in zephyr/boards/nordic/nrf54l15dk/nrf54l15dk_common.dtsi:112 */
    			load-capacitors = "internal";             /* in zephyr/boards/nordic/nrf54l15dk/nrf54l_05_10_15_cpuapp_common.dtsi:40 */
    			load-capacitance-femtofarad = < 0x3a98 >; /* in zephyr/boards/nordic/nrf54l15dk/nrf54l_05_10_15_cpuapp_common.dtsi:41 */
    			phandle = < 0x6 >;                        /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:226 */
    		/* node '/clocks/hfpll' defined in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:71 */
    		hfpll: hfpll {
    			compatible = "fixed-clock";      /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:72 */
    			#clock-cells = < 0x0 >;          /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:73 */
    			clock-frequency = < 0x7a12000 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:74 */
    			phandle = < 0x1 >;               /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:30 */
    	/* node '/soc' defined in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:78 */
    	soc {
    		#address-cells = < 0x1 >;            /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:79 */
    		#size-cells = < 0x1 >;               /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:80 */
    		compatible = "simple-bus";           /* in zephyr/dts/arm/nordic/nrf54l_05_10_15_cpuapp.dtsi:23 */
    		interrupt-parent = < &cpuapp_nvic >; /* in zephyr/dts/arm/nordic/nrf54l_05_10_15_cpuapp.dtsi:24 */
    		ranges;                              /* in zephyr/dts/arm/nordic/nrf54l_05_10_15_cpuapp.dtsi:25 */
    		/* node '/soc/uicr@ffd000' defined in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:85 */
    		uicr: uicr@ffd000 {
    			compatible = "nordic,nrf-uicr"; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:86 */
    			reg = < 0xffd000 0x1000 >;      /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:87 */
    			nfct-pins-as-gpios;             /* in ../../Projects/personal/mp3/nrf/build/nrf/zephyr/boards/nrf54l15dk_nrf54l10_cpuapp.overlay:2 */
    		/* node '/soc/ficr@ffc000' defined in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:90 */
    		ficr: ficr@ffc000 {
    			compatible = "nordic,nrf-ficr"; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:91 */
    			reg = < 0xffc000 0x1000 >;      /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:92 */
    			#nordic,ficr-cells = < 0x1 >;   /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:93 */
    		/* node '/soc/memory@20000000' defined in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:96 */
    		cpuapp_sram: memory@20000000 {
    			compatible = "mmio-sram";            /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:97 */
    			#address-cells = < 0x1 >;            /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:98 */
    			#size-cells = < 0x1 >;               /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:99 */
    			reg = < 0x20000000 0x2f000 >;        /* in zephyr/dts/vendor/nordic/nrf54l15.dtsi:10 */
    			ranges = < 0x0 0x20000000 0x2f000 >; /* in zephyr/dts/vendor/nordic/nrf54l15.dtsi:11 */
    			status = "okay";                     /* in zephyr/boards/nordic/nrf54l15dk/nrf54l_05_10_15_cpuapp_common.dtsi:31 */
    		/* node '/soc/peripheral@50000000' defined in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:108 */
    		global_peripherals: peripheral@50000000 {
    			#address-cells = < 0x1 >;               /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:109 */
    			#size-cells = < 0x1 >;                  /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:110 */
    			ranges = < 0x0 0x50000000 0x10000000 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:111 */
    			/* node '/soc/peripheral@50000000/dppic@42000' defined in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:114 */
    			dppic00: dppic@42000 {
    				compatible = "nordic,nrf-dppic"; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:115 */
    				reg = < 0x42000 0x808 >;         /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:116 */
    				status = "okay";                 /* in zephyr/dts/arm/nordic/nrf54l_05_10_15_cpuapp.dtsi:95 */
    			/* node '/soc/peripheral@50000000/ppib@43000' defined in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:120 */
    			ppib00: ppib@43000 {
    				compatible = "nordic,nrf-ppib"; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:121 */
    				reg = < 0x43000 0x1000 >;       /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:122 */
    				status = "okay";                /* in zephyr/dts/arm/nordic/nrf54l_05_10_15_cpuapp.dtsi:111 */
    			/* node '/soc/peripheral@50000000/ppib@44000' defined in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:126 */
    			ppib01: ppib@44000 {
    				compatible = "nordic,nrf-ppib"; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:127 */
    				reg = < 0x44000 0x1000 >;       /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:128 */
    				status = "okay";                /* in zephyr/dts/arm/nordic/nrf54l_05_10_15_cpuapp.dtsi:115 */
    			/* node '/soc/peripheral@50000000/spi@4a000' defined in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:132 */
    			spi00: spi@4a000 {
    				compatible = "nordic,nrf-spim"; /* in ../../Projects/personal/mp3/nrf/build/nrf/zephyr/boards/nrf54l15dk_nrf54l10_cpuapp.overlay:51 */
    				#address-cells = < 0x1 >;       /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:140 */
    				#size-cells = < 0x0 >;          /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:141 */
    				reg = < 0x4a000 0x1000 >;       /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:142 */
    				interrupts = < 0x4a 0x1 >;      /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:143 */
    				max-frequency = < 0x1e84800 >;  /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:144 */
    				easydma-maxcnt-bits = < 0x10 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:145 */
    				rx-delay-supported;             /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:146 */
    				rx-delay = < 0x1 >;             /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:147 */
    				status = "okay";                /* in ../../Projects/personal/mp3/nrf/build/nrf/zephyr/boards/nrf54l15dk_nrf54l10_cpuapp.overlay:50 */
    				cs-gpios = < &gpio2 0x5 0x1 >;  /* in ../../Projects/personal/mp3/nrf/build/nrf/zephyr/boards/nrf54l15dk_nrf54l10_cpuapp.overlay:55 */
    				pinctrl-0 = < &spi00_default >; /* in ../../Projects/personal/mp3/nrf/build/nrf/zephyr/boards/nrf54l15dk_nrf54l10_cpuapp.overlay:52 */
    				pinctrl-1 = < &spi00_sleep >;   /* in ../../Projects/personal/mp3/nrf/build/nrf/zephyr/boards/nrf54l15dk_nrf54l10_cpuapp.overlay:53 */
    				pinctrl-names = "default",
    				                "sleep";        /* in ../../Projects/personal/mp3/nrf/build/nrf/zephyr/boards/nrf54l15dk_nrf54l10_cpuapp.overlay:54 */
    				/* node '/soc/peripheral@50000000/spi@4a000/sdhc@0' defined in ../../Projects/personal/mp3/nrf/build/nrf/zephyr/boards/nrf54l15dk_nrf54l10_cpuapp.overlay:56 */
    				sdhc0: sdhc@0 {
    					compatible = "zephyr,sdhc-spi-slot"; /* in ../../Projects/personal/mp3/nrf/build/nrf/zephyr/boards/nrf54l15dk_nrf54l10_cpuapp.overlay:57 */
    					reg = < 0x0 >;                       /* in ../../Projects/personal/mp3/nrf/build/nrf/zephyr/boards/nrf54l15dk_nrf54l10_cpuapp.overlay:58 */
    					status = "okay";                     /* in ../../Projects/personal/mp3/nrf/build/nrf/zephyr/boards/nrf54l15dk_nrf54l10_cpuapp.overlay:59 */
    					spi-max-frequency = < 0x7a1200 >;    /* in ../../Projects/personal/mp3/nrf/build/nrf/zephyr/boards/nrf54l15dk_nrf54l10_cpuapp.overlay:65 */
    					/* node '/soc/peripheral@50000000/spi@4a000/sdhc@0/mmc' defined in ../../Projects/personal/mp3/nrf/build/nrf/zephyr/boards/nrf54l15dk_nrf54l10_cpuapp.overlay:60 */
    					mmc {
    						compatible = "zephyr,sdmmc-disk"; /* in ../../Projects/personal/mp3/nrf/build/nrf/zephyr/boards/nrf54l15dk_nrf54l10_cpuapp.overlay:61 */
    						disk-name = "SD";                 /* in ../../Projects/personal/mp3/nrf/build/nrf/zephyr/boards/nrf54l15dk_nrf54l10_cpuapp.overlay:62 */
    						status = "okay";                  /* in ../../Projects/personal/mp3/nrf/build/nrf/zephyr/boards/nrf54l15dk_nrf54l10_cpuapp.overlay:63 */
    			/* node '/soc/peripheral@50000000/uart@4a000' defined in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:151 */
    			uart00: uart@4a000 {
    				compatible = "nordic,nrf-uarte"; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:152 */
    				reg = < 0x4a000 0x1000 >;        /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:153 */
    				interrupts = < 0x4a 0x1 >;       /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:154 */
    				clocks = < &hfpll >;             /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:155 */
    				status = "disabled";             /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:156 */
    				endtx-stoptx-supported;          /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:157 */
    				frame-timeout-supported;         /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:158 */
    			/* node '/soc/peripheral@50000000/vpr@4c000' defined in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:161 */
    			cpuflpr_vpr: vpr@4c000 {
    				compatible = "nordic,nrf-vpr-coprocessor"; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:162 */
    				reg = < 0x4c000 0x1000 >;                  /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:163 */
    				ranges = < 0x0 0x4c000 0x1000 >;           /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:164 */
    				#address-cells = < 0x1 >;                  /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:165 */
    				#size-cells = < 0x1 >;                     /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:166 */
    				status = "disabled";                       /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:167 */
    				enable-secure;                             /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:168 */
    				/* node '/soc/peripheral@50000000/vpr@4c000/mailbox@1' defined in zephyr/dts/arm/nordic/nrf54l_05_10_15_cpuapp.dtsi:44 */
    				cpuapp_vevif_rx: mailbox@1 {
    					compatible = "nordic,nrf-vevif-event-rx"; /* in zephyr/dts/arm/nordic/nrf54l_05_10_15_cpuapp.dtsi:45 */
    					reg = < 0x1 0x1000 >;                     /* in zephyr/dts/arm/nordic/nrf54l_05_10_15_cpuapp.dtsi:46 */
    					status = "disabled";                      /* in zephyr/dts/arm/nordic/nrf54l_05_10_15_cpuapp.dtsi:47 */
    					interrupts = < 0x4c 0x1 >;                /* in zephyr/dts/arm/nordic/nrf54l_05_10_15_cpuapp.dtsi:48 */
    					#mbox-cells = < 0x1 >;                    /* in zephyr/dts/arm/nordic/nrf54l_05_10_15_cpuapp.dtsi:49 */
    					nordic,events = < 0x1 >;                  /* in zephyr/dts/arm/nordic/nrf54l_05_10_15_cpuapp.dtsi:50 */
    					nordic,events-mask = < 0x100000 >;        /* in zephyr/dts/arm/nordic/nrf54l_05_10_15_cpuapp.dtsi:51 */
    				/* node '/soc/peripheral@50000000/vpr@4c000/mailbox@0' defined in zephyr/dts/arm/nordic/nrf54l_05_10_15_cpuapp.dtsi:54 */
    				cpuapp_vevif_tx: mailbox@0 {
    					compatible = "nordic,nrf-vevif-task-tx"; /* in zephyr/dts/arm/nordic/nrf54l_05_10_15_cpuapp.dtsi:55 */
    					reg = < 0x0 0x1000 >;                    /* in zephyr/dts/arm/nordic/nrf54l_05_10_15_cpuapp.dtsi:56 */
    					#mbox-cells = < 0x1 >;                   /* in zephyr/dts/arm/nordic/nrf54l_05_10_15_cpuapp.dtsi:57 */
    					nordic,tasks = < 0x7 >;                  /* in zephyr/dts/arm/nordic/nrf54l_05_10_15_cpuapp.dtsi:58 */
    					nordic,tasks-mask = < 0x7f0000 >;        /* in zephyr/dts/arm/nordic/nrf54l_05_10_15_cpuapp.dtsi:59 */
    					status = "disabled";                     /* in zephyr/dts/arm/nordic/nrf54l_05_10_15_cpuapp.dtsi:60 */
    			/* node '/soc/peripheral@50000000/gpio@50400' defined in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:180 */
    			gpio2: gpio@50400 {
    				compatible = "nordic,nrf-gpio"; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:181 */
    				gpio-controller;                /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:182 */
    				reg = < 0x50400 0x300 >;        /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:183 */
    				#gpio-cells = < 0x2 >;          /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:184 */
    				ngpios = < 0xb >;               /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:185 */
    				status = "okay";                /* in zephyr/boards/nordic/nrf54l15dk/nrf54l_05_10_15_cpuapp_common.dtsi:77 */
    				port = < 0x2 >;                 /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:187 */
    				phandle = < 0x3 >;              /* in ../../Projects/personal/mp3/nrf/build/nrf/zephyr/boards/nrf54l15dk_nrf54l10_cpuapp.overlay:55 */
    			/* node '/soc/peripheral@50000000/timer@55000' defined in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:190 */
    			timer00: timer@55000 {
    				compatible = "nordic,nrf-timer"; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:191 */
    				status = "disabled";             /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:192 */
    				reg = < 0x55000 0x1000 >;        /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:193 */
    				cc-num = < 0x6 >;                /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:194 */
    				max-bit-width = < 0x20 >;        /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:195 */
    				interrupts = < 0x55 0x1 >;       /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:196 */
    				clocks = < &hfpll >;             /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:197 */
    				prescaler = < 0x0 >;             /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:198 */
    			/* node '/soc/peripheral@50000000/dppic@82000' defined in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:201 */
    			dppic10: dppic@82000 {
    				compatible = "nordic,nrf-dppic"; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:202 */
    				reg = < 0x82000 0x808 >;         /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:203 */
    				status = "okay";                 /* in zephyr/dts/arm/nordic/nrf54l_05_10_15_cpuapp.dtsi:99 */
    			/* node '/soc/peripheral@50000000/ppib@83000' defined in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:207 */
    			ppib10: ppib@83000 {
    				compatible = "nordic,nrf-ppib"; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:208 */
    				reg = < 0x83000 0x1000 >;       /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:209 */
    				status = "okay";                /* in zephyr/dts/arm/nordic/nrf54l_05_10_15_cpuapp.dtsi:119 */
    			/* node '/soc/peripheral@50000000/ppib@84000' defined in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:213 */
    			ppib11: ppib@84000 {
    				compatible = "nordic,nrf-ppib"; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:214 */
    				reg = < 0x84000 0x1000 >;       /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:215 */
    				status = "okay";                /* in zephyr/dts/arm/nordic/nrf54l_05_10_15_cpuapp.dtsi:123 */
    			/* node '/soc/peripheral@50000000/timer@85000' defined in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:219 */
    			timer10: timer@85000 {
    				compatible = "nordic,nrf-timer"; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:220 */
    				status = "disabled";             /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:221 */
    				reg = < 0x85000 0x1000 >;        /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:222 */
    				cc-num = < 0x8 >;                /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:223 */
    				max-bit-width = < 0x20 >;        /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:224 */
    				interrupts = < 0x85 0x1 >;       /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:225 */
    				clocks = < &hfxo >;              /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:226 */
    				prescaler = < 0x0 >;             /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:227 */
    			/* node '/soc/peripheral@50000000/egu@87000' defined in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:230 */
    			egu10: egu@87000 {
    				compatible = "nordic,nrf-egu"; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:231 */
    				reg = < 0x87000 0x1000 >;      /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:232 */
    				interrupts = < 0x87 0x1 >;     /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:233 */
    				status = "disabled";           /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:234 */
    			/* node '/soc/peripheral@50000000/radio@8a000' defined in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:237 */
    			radio: radio@8a000 {
    				compatible = "nordic,nrf-radio"; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:238 */
    				reg = < 0x8a000 0x1000 >;        /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:239 */
    				interrupts = < 0x8a 0x1 >;       /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:240 */
    				status = "okay";                 /* in zephyr/boards/nordic/nrf54l15dk/nrf54l_05_10_15_cpuapp_common.dtsi:89 */
    				dfe-supported;                   /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:242 */
    				ieee802154-supported;            /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:243 */
    				ble-2mbps-supported;             /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:244 */
    				ble-coded-phy-supported;         /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:245 */
    				cs-supported;                    /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:246 */
    				/* node '/soc/peripheral@50000000/radio@8a000/ieee802154' defined in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:248 */
    				ieee802154: ieee802154 {
    					compatible = "nordic,nrf-ieee802154"; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:249 */
    					status = "okay";                      /* in zephyr/boards/nordic/nrf54l15dk/nrf54l_05_10_15_cpuapp_common.dtsi:93 */
    				/* node '/soc/peripheral@50000000/radio@8a000/bt_hci_sdc' defined in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:253 */
    				bt_hci_sdc: bt_hci_sdc {
    					compatible = "nordic,bt-hci-sdc"; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:254 */
    					status = "okay";                  /* in zephyr/dts/arm/nordic/nrf54l_05_10_15_cpuapp.dtsi:40 */
    				/* node '/soc/peripheral@50000000/radio@8a000/bt_hci_controller' defined in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:258 */
    				bt_hci_controller: bt_hci_controller {
    					compatible = "zephyr,bt-hci-ll-sw-split"; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:259 */
    					status = "disabled";                      /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:260 */
    			/* node '/soc/peripheral@50000000/dppic@c2000' defined in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:264 */
    			dppic20: dppic@c2000 {
    				compatible = "nordic,nrf-dppic"; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:265 */
    				reg = < 0xc2000 0x808 >;         /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:266 */
    				status = "okay";                 /* in zephyr/dts/arm/nordic/nrf54l_05_10_15_cpuapp.dtsi:103 */
    			/* node '/soc/peripheral@50000000/ppib@c3000' defined in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:270 */
    			ppib20: ppib@c3000 {
    				compatible = "nordic,nrf-ppib"; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:271 */
    				reg = < 0xc3000 0x1000 >;       /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:272 */
    				status = "okay";                /* in zephyr/dts/arm/nordic/nrf54l_05_10_15_cpuapp.dtsi:127 */
    			/* node '/soc/peripheral@50000000/ppib@c4000' defined in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:276 */
    			ppib21: ppib@c4000 {
    				compatible = "nordic,nrf-ppib"; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:277 */
    				reg = < 0xc4000 0x1000 >;       /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:278 */
    				status = "okay";                /* in zephyr/dts/arm/nordic/nrf54l_05_10_15_cpuapp.dtsi:131 */
    			/* node '/soc/peripheral@50000000/ppib@c5000' defined in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:282 */
    			ppib22: ppib@c5000 {
    				compatible = "nordic,nrf-ppib"; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:283 */
    				reg = < 0xc5000 0x1000 >;       /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:284 */
    				status = "okay";                /* in zephyr/dts/arm/nordic/nrf54l_05_10_15_cpuapp.dtsi:135 */
    			/* node '/soc/peripheral@50000000/i2c@c6000' defined in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:288 */
    			i2c20: i2c@c6000 {
    				compatible = "nordic,nrf-twim"; /* in ../../Projects/personal/mp3/nrf/build/nrf/zephyr/boards/nrf54l15dk_nrf54l10_cpuapp.overlay:95 */
    				#address-cells = < 0x1 >;       /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:290 */
    				#size-cells = < 0x0 >;          /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:291 */
    				reg = < 0xc6000 0x1000 >;       /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:292 */
    				interrupts = < 0xc6 0x1 >;      /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:293 */
    				easydma-maxcnt-bits = < 0x10 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:294 */
    				status = "okay";                /* in ../../Projects/personal/mp3/nrf/build/nrf/zephyr/boards/nrf54l15dk_nrf54l10_cpuapp.overlay:96 */
    				zephyr,pm-device-runtime-auto;  /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:296 */
    				pinctrl-0 = < &i2c20_default >; /* in ../../Projects/personal/mp3/nrf/build/nrf/zephyr/boards/nrf54l15dk_nrf54l10_cpuapp.overlay:97 */
    				pinctrl-names = "default";      /* in ../../Projects/personal/mp3/nrf/build/nrf/zephyr/boards/nrf54l15dk_nrf54l10_cpuapp.overlay:99 */
    				clock-frequency = < 0x186a0 >;  /* in ../../Projects/personal/mp3/nrf/build/nrf/zephyr/boards/nrf54l15dk_nrf54l10_cpuapp.overlay:100 */
    				/* node '/soc/peripheral@50000000/i2c@c6000/pcf857x@20' defined in ../../Projects/personal/mp3/nrf/build/nrf/zephyr/boards/nrf54l15dk_nrf54l10_cpuapp.overlay:101 */
    					compatible = "nxp,pcf857x"; /* in ../../Projects/personal/mp3/nrf/build/nrf/zephyr/boards/nrf54l15dk_nrf54l10_cpuapp.overlay:102 */
    					status = "okay";            /* in ../../Projects/personal/mp3/nrf/build/nrf/zephyr/boards/nrf54l15dk_nrf54l10_cpuapp.overlay:103 */
    					reg = < 0x20 >;             /* in ../../Projects/personal/mp3/nrf/build/nrf/zephyr/boards/nrf54l15dk_nrf54l10_cpuapp.overlay:104 */
    					gpio-controller;            /* in ../../Projects/personal/mp3/nrf/build/nrf/zephyr/boards/nrf54l15dk_nrf54l10_cpuapp.overlay:105 */
    					#gpio-cells = < 0x2 >;      /* in ../../Projects/personal/mp3/nrf/build/nrf/zephyr/boards/nrf54l15dk_nrf54l10_cpuapp.overlay:106 */
    					ngpios = < 0x8 >;           /* in ../../Projects/personal/mp3/nrf/build/nrf/zephyr/boards/nrf54l15dk_nrf54l10_cpuapp.overlay:107 */
    			/* node '/soc/peripheral@50000000/spi@c6000' defined in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:299 */
    			spi20: spi@c6000 {
    				compatible = "nordic,nrf-spim"; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:306 */
    				#address-cells = < 0x1 >;       /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:307 */
    				#size-cells = < 0x0 >;          /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:308 */
    				reg = < 0xc6000 0x1000 >;       /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:309 */
    				interrupts = < 0xc6 0x1 >;      /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:310 */
    				max-frequency = < 0x7a1200 >;   /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:311 */
    				easydma-maxcnt-bits = < 0x10 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:312 */
    				rx-delay-supported;             /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:313 */
    				rx-delay = < 0x1 >;             /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:314 */
    				status = "disabled";            /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:315 */
    				default-gpio-port = < &gpio1 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:316 */
    				cross-domain-pins-supported;    /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:317 */
    			/* node '/soc/peripheral@50000000/uart@c6000' defined in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:320 */
    			uart20: uart@c6000 {
    				compatible = "nordic,nrf-uarte"; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:321 */
    				reg = < 0xc6000 0x1000 >;        /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:322 */
    				interrupts = < 0xc6 0x1 >;       /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:323 */
    				status = "disabled";             /* in ../../Projects/personal/mp3/nrf/build/nrf/zephyr/boards/nrf54l15dk_nrf54l10_cpuapp.overlay:10 */
    				endtx-stoptx-supported;          /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:325 */
    				frame-timeout-supported;         /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:326 */
    				default-gpio-port = < &gpio1 >;  /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:327 */
    				cross-domain-pins-supported;     /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:328 */
    				current-speed = < 0x1c200 >;     /* in zephyr/boards/nordic/nrf54l15dk/nrf54l15dk_common.dtsi:91 */
    				pinctrl-0 = < &uart20_default >; /* in zephyr/boards/nordic/nrf54l15dk/nrf54l15dk_common.dtsi:92 */
    				pinctrl-1 = < &uart20_sleep >;   /* in zephyr/boards/nordic/nrf54l15dk/nrf54l15dk_common.dtsi:93 */
    				                "sleep";         /* in zephyr/boards/nordic/nrf54l15dk/nrf54l15dk_common.dtsi:94 */
    			/* node '/soc/peripheral@50000000/i2c@c7000' defined in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:331 */
    			i2c21: i2c@c7000 {
    				compatible = "nordic,nrf-twim"; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:332 */
    				#address-cells = < 0x1 >;       /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:333 */
    				#size-cells = < 0x0 >;          /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:334 */
    				reg = < 0xc7000 0x1000 >;       /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:335 */
    				interrupts = < 0xc7 0x1 >;      /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:336 */
    				easydma-maxcnt-bits = < 0x10 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:337 */
    				status = "disabled";            /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:338 */
    				zephyr,pm-device-runtime-auto;  /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:339 */
    			/* node '/soc/peripheral@50000000/spi@c7000' defined in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:342 */
    			spi21: spi@c7000 {
    				compatible = "nordic,nrf-spim"; /* in ../../Projects/personal/mp3/nrf/build/nrf/zephyr/boards/nrf54l15dk_nrf54l10_cpuapp.overlay:70 */
    				#address-cells = < 0x1 >;       /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:350 */
    				#size-cells = < 0x0 >;          /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:351 */
    				reg = < 0xc7000 0x1000 >;       /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:352 */
    				interrupts = < 0xc7 0x1 >;      /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:353 */
    				max-frequency = < 0x7a1200 >;   /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:354 */
    				easydma-maxcnt-bits = < 0x10 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:355 */
    				rx-delay-supported;             /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:356 */
    				rx-delay = < 0x1 >;             /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:357 */
    				status = "okay";                /* in ../../Projects/personal/mp3/nrf/build/nrf/zephyr/boards/nrf54l15dk_nrf54l10_cpuapp.overlay:85 */
    				default-gpio-port = < &gpio1 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:359 */
    				cross-domain-pins-supported;    /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:360 */
    				pinctrl-0 = < &spi21_default >; /* in ../../Projects/personal/mp3/nrf/build/nrf/zephyr/boards/nrf54l15dk_nrf54l10_cpuapp.overlay:71 */
    				pinctrl-1 = < &spi21_sleep >;   /* in ../../Projects/personal/mp3/nrf/build/nrf/zephyr/boards/nrf54l15dk_nrf54l10_cpuapp.overlay:72 */
    				                "sleep";        /* in ../../Projects/personal/mp3/nrf/build/nrf/zephyr/boards/nrf54l15dk_nrf54l10_cpuapp.overlay:73 */
    				cs-gpios = < &gpio1 0xe 0x0 >;  /* in ../../Projects/personal/mp3/nrf/build/nrf/zephyr/boards/nrf54l15dk_nrf54l10_cpuapp.overlay:74 */
    				/* node '/soc/peripheral@50000000/spi@c7000/ls0xx@0' defined in ../../Projects/personal/mp3/nrf/build/nrf/zephyr/boards/nrf54l15dk_nrf54l10_cpuapp.overlay:75 */
    				sharp: ls0xx@0 {
    					compatible = "sharp,ls0xx";         /* in ../../Projects/personal/mp3/nrf/build/nrf/zephyr/boards/nrf54l15dk_nrf54l10_cpuapp.overlay:76 */
    					spi-max-frequency = < 0x1e8480 >;   /* in ../../Projects/personal/mp3/nrf/build/nrf/zephyr/boards/nrf54l15dk_nrf54l10_cpuapp.overlay:77 */
    					reg = < 0x0 >;                      /* in ../../Projects/personal/mp3/nrf/build/nrf/zephyr/boards/nrf54l15dk_nrf54l10_cpuapp.overlay:78 */
    					status = "okay";                    /* in ../../Projects/personal/mp3/nrf/build/nrf/zephyr/boards/nrf54l15dk_nrf54l10_cpuapp.overlay:79 */
    					width = < 0xa0 >;                   /* in ../../Projects/personal/mp3/nrf/build/nrf/zephyr/boards/nrf54l15dk_nrf54l10_cpuapp.overlay:80 */
    					height = < 0x44 >;                  /* in ../../Projects/personal/mp3/nrf/build/nrf/zephyr/boards/nrf54l15dk_nrf54l10_cpuapp.overlay:81 */
    					disp-en-gpios = < &gpio1 0x9 0x0 >; /* in ../../Projects/personal/mp3/nrf/build/nrf/zephyr/boards/nrf54l15dk_nrf54l10_cpuapp.overlay:82 */
    			/* node '/soc/peripheral@50000000/uart@c7000' defined in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:363 */
    			uart21: uart@c7000 {
    				compatible = "nordic,nrf-uarte"; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:364 */
    				reg = < 0xc7000 0x1000 >;        /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:365 */
    				interrupts = < 0xc7 0x1 >;       /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:366 */
    				status = "disabled";             /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:367 */
    				endtx-stoptx-supported;          /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:368 */
    				frame-timeout-supported;         /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:369 */
    				default-gpio-port = < &gpio1 >;  /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:370 */
    				cross-domain-pins-supported;     /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:371 */
    			/* node '/soc/peripheral@50000000/i2c@c8000' defined in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:374 */
    			i2c22: i2c@c8000 {
    				compatible = "nordic,nrf-twim"; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:375 */
    				#address-cells = < 0x1 >;       /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:376 */
    				#size-cells = < 0x0 >;          /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:377 */
    				reg = < 0xc8000 0x1000 >;       /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:378 */
    				interrupts = < 0xc8 0x1 >;      /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:379 */
    				easydma-maxcnt-bits = < 0x10 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:380 */
    				status = "disabled";            /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:381 */
    				zephyr,pm-device-runtime-auto;  /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:382 */
    			/* node '/soc/peripheral@50000000/spi@c8000' defined in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:385 */
    			spi22: wifi_spi: spi@c8000 {
    				compatible = "nordic,nrf-spim"; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:392 */
    				#address-cells = < 0x1 >;       /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:393 */
    				#size-cells = < 0x0 >;          /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:394 */
    				reg = < 0xc8000 0x1000 >;       /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:395 */
    				interrupts = < 0xc8 0x1 >;      /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:396 */
    				max-frequency = < 0x7a1200 >;   /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:397 */
    				easydma-maxcnt-bits = < 0x10 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:398 */
    				rx-delay-supported;             /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:399 */
    				rx-delay = < 0x1 >;             /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:400 */
    				status = "disabled";            /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:401 */
    			/* node '/soc/peripheral@50000000/uart@c8000' defined in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:404 */
    			uart22: uart@c8000 {
    				compatible = "nordic,nrf-uarte"; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:405 */
    				reg = < 0xc8000 0x1000 >;        /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:406 */
    				interrupts = < 0xc8 0x1 >;       /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:407 */
    				status = "disabled";             /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:408 */
    				endtx-stoptx-supported;          /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:409 */
    				frame-timeout-supported;         /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:410 */
    			/* node '/soc/peripheral@50000000/egu@c9000' defined in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:413 */
    			egu20: egu@c9000 {
    				compatible = "nordic,nrf-egu"; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:414 */
    				reg = < 0xc9000 0x1000 >;      /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:415 */
    				interrupts = < 0xc9 0x1 >;     /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:416 */
    				status = "disabled";           /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:417 */
    			/* node '/soc/peripheral@50000000/timer@ca000' defined in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:420 */
    			timer20: timer@ca000 {
    				compatible = "nordic,nrf-timer"; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:421 */
    				status = "disabled";             /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:422 */
    				reg = < 0xca000 0x1000 >;        /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:423 */
    				cc-num = < 0x6 >;                /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:424 */
    				max-bit-width = < 0x20 >;        /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:425 */
    				interrupts = < 0xca 0x1 >;       /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:426 */
    				prescaler = < 0x0 >;             /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:427 */
    			/* node '/soc/peripheral@50000000/timer@cb000' defined in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:430 */
    			timer21: timer@cb000 {
    				compatible = "nordic,nrf-timer"; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:431 */
    				status = "disabled";             /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:432 */
    				reg = < 0xcb000 0x1000 >;        /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:433 */
    				cc-num = < 0x6 >;                /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:434 */
    				max-bit-width = < 0x20 >;        /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:435 */
    				interrupts = < 0xcb 0x1 >;       /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:436 */
    				prescaler = < 0x0 >;             /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:437 */
    			/* node '/soc/peripheral@50000000/timer@cc000' defined in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:440 */
    			timer22: timer@cc000 {
    				compatible = "nordic,nrf-timer"; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:441 */
    				status = "disabled";             /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:442 */
    				reg = < 0xcc000 0x1000 >;        /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:443 */
    				cc-num = < 0x6 >;                /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:444 */
    				max-bit-width = < 0x20 >;        /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:445 */
    				interrupts = < 0xcc 0x1 >;       /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:446 */
    				prescaler = < 0x0 >;             /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:447 */
    			/* node '/soc/peripheral@50000000/timer@cd000' defined in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:450 */
    			timer23: timer@cd000 {
    				compatible = "nordic,nrf-timer"; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:451 */
    				status = "disabled";             /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:452 */
    				reg = < 0xcd000 0x1000 >;        /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:453 */
    				cc-num = < 0x6 >;                /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:454 */
    				max-bit-width = < 0x20 >;        /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:455 */
    				interrupts = < 0xcd 0x1 >;       /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:456 */
    				prescaler = < 0x0 >;             /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:457 */
    			/* node '/soc/peripheral@50000000/timer@ce000' defined in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:460 */
    			timer24: timer@ce000 {
    				compatible = "nordic,nrf-timer"; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:461 */
    				status = "disabled";             /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:462 */
    				reg = < 0xce000 0x1000 >;        /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:463 */
    				cc-num = < 0x6 >;                /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:464 */
    				max-bit-width = < 0x20 >;        /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:465 */
    				interrupts = < 0xce 0x1 >;       /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:466 */
    				prescaler = < 0x0 >;             /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:467 */
    			/* node '/soc/peripheral@50000000/pdm@d0000' defined in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:470 */
    			pdm20: pdm@d0000 {
    				compatible = "nordic,nrf-pdm"; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:471 */
    				status = "disabled";           /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:472 */
    				reg = < 0xd0000 0x1000 >;      /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:473 */
    				interrupts = < 0xd0 0x1 >;     /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:474 */
    			/* node '/soc/peripheral@50000000/pdm@d1000' defined in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:477 */
    			pdm21: pdm@d1000 {
    				compatible = "nordic,nrf-pdm"; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:478 */
    				status = "disabled";           /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:479 */
    				reg = < 0xd1000 0x1000 >;      /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:480 */
    				interrupts = < 0xd1 0x1 >;     /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:481 */
    			/* node '/soc/peripheral@50000000/pwm@d2000' defined in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:484 */
    			pwm20: pwm@d2000 {
    				compatible = "nordic,nrf-pwm";  /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:485 */
    				status = "disabled";            /* in ../../Projects/personal/mp3/nrf/build/nrf/zephyr/boards/nrf54l15dk_nrf54l10_cpuapp.overlay:40 */
    				reg = < 0xd2000 0x1000 >;       /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:487 */
    				interrupts = < 0xd2 0x1 >;      /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:488 */
    				#pwm-cells = < 0x3 >;           /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:489 */
    				idleout-supported;              /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:490 */
    				pinctrl-0 = < &pwm20_default >; /* in zephyr/boards/nordic/nrf54l15dk/nrf54l15dk_common.dtsi:106 */
    				pinctrl-1 = < &pwm20_sleep >;   /* in zephyr/boards/nordic/nrf54l15dk/nrf54l15dk_common.dtsi:107 */
    				                "sleep";        /* in zephyr/boards/nordic/nrf54l15dk/nrf54l15dk_common.dtsi:108 */
    				phandle = < 0x16 >;             /* in zephyr/boards/nordic/nrf54l15dk/nrf54l15dk_common.dtsi:44 */
    			/* node '/soc/peripheral@50000000/pwm@d3000' defined in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:493 */
    			pwm21: pwm@d3000 {
    				compatible = "nordic,nrf-pwm"; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:494 */
    				status = "disabled";           /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:495 */
    				reg = < 0xd3000 0x1000 >;      /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:496 */
    				interrupts = < 0xd3 0x1 >;     /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:497 */
    				#pwm-cells = < 0x3 >;          /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:498 */
    				idleout-supported;             /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:499 */
    			/* node '/soc/peripheral@50000000/pwm@d4000' defined in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:502 */
    			pwm22: pwm@d4000 {
    				compatible = "nordic,nrf-pwm"; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:503 */
    				status = "disabled";           /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:504 */
    				reg = < 0xd4000 0x1000 >;      /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:505 */
    				interrupts = < 0xd4 0x1 >;     /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:506 */
    				#pwm-cells = < 0x3 >;          /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:507 */
    				idleout-supported;             /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:508 */
    			/* node '/soc/peripheral@50000000/adc@d5000' defined in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:511 */
    			adc: adc@d5000 {
    				compatible = "nordic,nrf-saadc"; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:512 */
    				reg = < 0xd5000 0x1000 >;        /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:513 */
    				interrupts = < 0xd5 0x1 >;       /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:514 */
    				status = "okay";                 /* in zephyr/boards/nordic/nrf54l15dk/nrf54l_05_10_15_cpuapp_common.dtsi:141 */
    				#io-channel-cells = < 0x1 >;     /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:516 */
    				zephyr,pm-device-runtime-auto;   /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:517 */
    			/* node '/soc/peripheral@50000000/nfct@d6000' defined in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:520 */
    			nfct: nfct@d6000 {
    				compatible = "nordic,nrf-nfct"; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:521 */
    				reg = < 0xd6000 0x1000 >;       /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:522 */
    				interrupts = < 0xd6 0x1 >;      /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:523 */
    				status = "disabled";            /* in ../../Projects/personal/mp3/nrf/build/nrf/zephyr/boards/nrf54l15dk_nrf54l10_cpuapp.overlay:6 */
    			/* node '/soc/peripheral@50000000/temp@d7000' defined in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:527 */
    			temp: temp@d7000 {
    				compatible = "nordic,nrf-temp"; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:528 */
    				reg = < 0xd7000 0x1000 >;       /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:529 */
    				interrupts = < 0xd7 0x1 >;      /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:530 */
    				status = "okay";                /* in zephyr/boards/nordic/nrf54l15dk/nrf54l_05_10_15_cpuapp_common.dtsi:97 */
    			/* node '/soc/peripheral@50000000/gpio@d8200' defined in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:534 */
    			gpio1: gpio@d8200 {
    				compatible = "nordic,nrf-gpio";  /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:535 */
    				gpio-controller;                 /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:536 */
    				reg = < 0xd8200 0x300 >;         /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:537 */
    				#gpio-cells = < 0x2 >;           /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:538 */
    				ngpios = < 0x10 >;               /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:539 */
    				status = "okay";                 /* in zephyr/boards/nordic/nrf54l15dk/nrf54l_05_10_15_cpuapp_common.dtsi:73 */
    				port = < 0x1 >;                  /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:541 */
    				gpiote-instance = < &gpiote20 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:542 */
    				phandle = < 0x8 >;               /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:316 */
    			/* node '/soc/peripheral@50000000/gpiote@da000' defined in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:545 */
    			gpiote20: gpiote@da000 {
    				compatible = "nordic,nrf-gpiote"; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:546 */
    				reg = < 0xda000 0x1000 >;         /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:547 */
    				status = "okay";                  /* in zephyr/boards/nordic/nrf54l15dk/nrf54l_05_10_15_cpuapp_common.dtsi:81 */
    				instance = < 0x14 >;              /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:549 */
    				interrupts = < 0xdb 0x1 >;        /* in zephyr/dts/arm/nordic/nrf54l_05_10_15_cpuapp.dtsi:82 */
    				phandle = < 0xf >;                /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:542 */
    			/* node '/soc/peripheral@50000000/i2s@dd000' defined in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:552 */
    			i2s20: i2s@dd000 {
    				compatible = "nordic,nrf-i2s";      /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:553 */
    				#address-cells = < 0x1 >;           /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:554 */
    				#size-cells = < 0x0 >;              /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:555 */
    				reg = < 0xdd000 0x1000 >;           /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:556 */
    				interrupts = < 0xdd 0x1 >;          /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:557 */
    				status = "okay";                    /* in ../../Projects/personal/mp3/nrf/build/nrf/zephyr/boards/nrf54l15dk_nrf54l10_cpuapp.overlay:89 */
    				pinctrl-0 = < &i2s20_default_alt >; /* in ../../Projects/personal/mp3/nrf/build/nrf/zephyr/boards/nrf54l15dk_nrf54l10_cpuapp.overlay:90 */
    				pinctrl-names = "default";          /* in ../../Projects/personal/mp3/nrf/build/nrf/zephyr/boards/nrf54l15dk_nrf54l10_cpuapp.overlay:91 */
    			/* node '/soc/peripheral@50000000/qdec@e0000' defined in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:561 */
    			qdec20: qdec@e0000 {
    				compatible = "nordic,nrf-qdec"; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:562 */
    				reg = < 0xe0000 0x1000 >;       /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:563 */
    				interrupts = < 0xe0 0x1 >;      /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:564 */
    				status = "disabled";            /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:565 */
    			/* node '/soc/peripheral@50000000/qdec@e1000' defined in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:568 */
    			qdec21: qdec@e1000 {
    				compatible = "nordic,nrf-qdec"; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:569 */
    				reg = < 0xe1000 0x1000 >;       /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:570 */
    				interrupts = < 0xe1 0x1 >;      /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:571 */
    				status = "disabled";            /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:572 */
    			/* node '/soc/peripheral@50000000/grtc@e2000' defined in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:575 */
    			grtc: grtc@e2000 {
    				compatible = "nordic,nrf-grtc";                                       /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:576 */
    				reg = < 0xe2000 0x1000 >;                                             /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:577 */
    				cc-num = < 0xc >;                                                     /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:578 */
    				clocks = < &lfxo >,
    				         < &pclk >;                                                   /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:579 */
    				clock-names = "lfclock",
    				              "hfclock";                                              /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:580 */
    				status = "okay";                                                      /* in zephyr/boards/nordic/nrf54l15dk/nrf54l_05_10_15_cpuapp_common.dtsi:57 */
    				interrupts = < 0xe4 0x1 >,
    				             < 0xe5 0x1 >;                                            /* in zephyr/dts/arm/nordic/nrf54l_05_10_15_cpuapp.dtsi:73 */
    				owned-channels = < 0x0 0x1 0x2 0x3 0x4 0x5 0x6 0x7 0x8 0x9 0xa 0xb >; /* in zephyr/boards/nordic/nrf54l15dk/nrf54l_05_10_15_cpuapp_common.dtsi:54 */
    				child-owned-channels = < 0x3 0x4 0x7 0x8 0x9 0xa 0xb >;               /* in zephyr/boards/nordic/nrf54l15dk/nrf54l_05_10_15_cpuapp_common.dtsi:56 */
    			/* node '/soc/peripheral@50000000/dppic@102000' defined in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:584 */
    			dppic30: dppic@102000 {
    				compatible = "nordic,nrf-dppic"; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:585 */
    				reg = < 0x102000 0x808 >;        /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:586 */
    				status = "okay";                 /* in zephyr/dts/arm/nordic/nrf54l_05_10_15_cpuapp.dtsi:107 */
    			/* node '/soc/peripheral@50000000/ppib@103000' defined in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:590 */
    			ppib30: ppib@103000 {
    				compatible = "nordic,nrf-ppib"; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:591 */
    				reg = < 0x103000 0x1000 >;      /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:592 */
    				status = "okay";                /* in zephyr/dts/arm/nordic/nrf54l_05_10_15_cpuapp.dtsi:139 */
    			/* node '/soc/peripheral@50000000/i2c@104000' defined in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:596 */
    			i2c30: i2c@104000 {
    				compatible = "nordic,nrf-twim"; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:597 */
    				#address-cells = < 0x1 >;       /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:598 */
    				#size-cells = < 0x0 >;          /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:599 */
    				reg = < 0x104000 0x1000 >;      /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:600 */
    				interrupts = < 0x104 0x1 >;     /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:601 */
    				easydma-maxcnt-bits = < 0x10 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:602 */
    				status = "disabled";            /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:603 */
    				zephyr,pm-device-runtime-auto;  /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:604 */
    			/* node '/soc/peripheral@50000000/spi@104000' defined in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:607 */
    			spi30: spi@104000 {
    				compatible = "nordic,nrf-spim"; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:614 */
    				#address-cells = < 0x1 >;       /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:615 */
    				#size-cells = < 0x0 >;          /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:616 */
    				reg = < 0x104000 0x1000 >;      /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:617 */
    				interrupts = < 0x104 0x1 >;     /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:618 */
    				max-frequency = < 0x7a1200 >;   /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:619 */
    				easydma-maxcnt-bits = < 0x10 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:620 */
    				rx-delay-supported;             /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:621 */
    				rx-delay = < 0x1 >;             /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:622 */
    				status = "disabled";            /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:623 */
    			/* node '/soc/peripheral@50000000/uart@104000' defined in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:626 */
    			uart30: uart@104000 {
    				compatible = "nordic,nrf-uarte"; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:627 */
    				reg = < 0x104000 0x1000 >;       /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:628 */
    				interrupts = < 0x104 0x1 >;      /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:629 */
    				status = "disabled";             /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:630 */
    				endtx-stoptx-supported;          /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:631 */
    				frame-timeout-supported;         /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:632 */
    				current-speed = < 0x1c200 >;     /* in zephyr/boards/nordic/nrf54l15dk/nrf54l15dk_common.dtsi:98 */
    				pinctrl-0 = < &uart30_default >; /* in zephyr/boards/nordic/nrf54l15dk/nrf54l15dk_common.dtsi:99 */
    				pinctrl-1 = < &uart30_sleep >;   /* in zephyr/boards/nordic/nrf54l15dk/nrf54l15dk_common.dtsi:100 */
    				                "sleep";         /* in zephyr/boards/nordic/nrf54l15dk/nrf54l15dk_common.dtsi:101 */
    			/* node '/soc/peripheral@50000000/clock@10e000' defined in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:635 */
    			clock: clock@10e000 {
    				compatible = "nordic,nrf-clock"; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:636 */
    				reg = < 0x10e000 0x1000 >;       /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:637 */
    				interrupts = < 0x105 0x1 >;      /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:638 */
    				status = "okay";                 /* in zephyr/boards/nordic/nrf54l15dk/nrf54l_05_10_15_cpuapp_common.dtsi:101 */
    			/* node '/soc/peripheral@50000000/power@10e000' defined in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:642 */
    			power: power@10e000 {
    				compatible = "nordic,nrf-power";  /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:643 */
    				reg = < 0x10e000 0x1000 >;        /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:644 */
    				ranges = < 0x0 0x10e000 0x1000 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:645 */
    				interrupts = < 0x105 0x1 >;       /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:646 */
    				status = "disabled";              /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:647 */
    				#address-cells = < 0x1 >;         /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:648 */
    				#size-cells = < 0x1 >;            /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:649 */
    				/* node '/soc/peripheral@50000000/power@10e000/gpregret1@500' defined in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:651 */
    				gpregret1: gpregret1@500 {
    					#address-cells = < 0x1 >;           /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:652 */
    					#size-cells = < 0x1 >;              /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:653 */
    					compatible = "nordic,nrf-gpregret"; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:654 */
    					reg = < 0x500 0x1 >;                /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:655 */
    					status = "okay";                    /* in zephyr/boards/nordic/nrf54l15dk/nrf54l_05_10_15_cpuapp_common.dtsi:105 */
    					/* node '/soc/peripheral@50000000/power@10e000/gpregret1@500/boot_mode@0' defined in zephyr/boards/nordic/nrf54l15dk/nrf54l_05_10_15_cpuapp_common.dtsi:107 */
    					boot_mode0: boot_mode@0 {
    						compatible = "zephyr,retention"; /* in zephyr/boards/nordic/nrf54l15dk/nrf54l_05_10_15_cpuapp_common.dtsi:108 */
    						status = "okay";                 /* in zephyr/boards/nordic/nrf54l15dk/nrf54l_05_10_15_cpuapp_common.dtsi:109 */
    						reg = < 0x0 0x1 >;               /* in zephyr/boards/nordic/nrf54l15dk/nrf54l_05_10_15_cpuapp_common.dtsi:110 */
    				/* node '/soc/peripheral@50000000/power@10e000/gpregret2@504' defined in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:659 */
    				gpregret2: gpregret2@504 {
    					#address-cells = < 0x1 >;           /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:660 */
    					#size-cells = < 0x1 >;              /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:661 */
    					compatible = "nordic,nrf-gpregret"; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:662 */
    					reg = < 0x504 0x1 >;                /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:663 */
    					status = "disabled";                /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:664 */
    			/* node '/soc/peripheral@50000000/comparator@106000' defined in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:668 */
    			comp: comparator@106000 {
    				compatible = "nordic,nrf-comp"; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:673 */
    				reg = < 0x106000 0x1000 >;      /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:674 */
    				status = "disabled";            /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:675 */
    				interrupts = < 0x106 0x1 >;     /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:676 */
    			/* node '/soc/peripheral@50000000/watchdog@108000' defined in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:682 */
    			wdt30: watchdog@108000 {
    				compatible = "nordic,nrf-wdt"; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:683 */
    				reg = < 0x108000 0x620 >;      /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:684 */
    				interrupts = < 0x108 0x1 >;    /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:685 */
    				status = "disabled";           /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:686 */
    			/* node '/soc/peripheral@50000000/watchdog@109000' defined in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:690 */
    			wdt31: watchdog@109000 {
    				compatible = "nordic,nrf-wdt"; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:691 */
    				reg = < 0x109000 0x620 >;      /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:692 */
    				interrupts = < 0x109 0x1 >;    /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:693 */
    				status = "disabled";           /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:694 */
    			/* node '/soc/peripheral@50000000/gpio@10a000' defined in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:697 */
    			gpio0: gpio@10a000 {
    				compatible = "nordic,nrf-gpio";  /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:698 */
    				gpio-controller;                 /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:699 */
    				reg = < 0x10a000 0x300 >;        /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:700 */
    				#gpio-cells = < 0x2 >;           /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:701 */
    				ngpios = < 0x5 >;                /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:702 */
    				status = "okay";                 /* in zephyr/boards/nordic/nrf54l15dk/nrf54l_05_10_15_cpuapp_common.dtsi:69 */
    				port = < 0x0 >;                  /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:704 */
    				gpiote-instance = < &gpiote30 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:705 */
    				phandle = < 0x17 >;              /* in zephyr/boards/nordic/nrf54l15dk/nrf54l15dk_common.dtsi:70 */
    			/* node '/soc/peripheral@50000000/gpiote@10c000' defined in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:708 */
    			gpiote30: gpiote@10c000 {
    				compatible = "nordic,nrf-gpiote"; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:709 */
    				reg = < 0x10c000 0x1000 >;        /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:710 */
    				status = "okay";                  /* in zephyr/boards/nordic/nrf54l15dk/nrf54l_05_10_15_cpuapp_common.dtsi:85 */
    				instance = < 0x1e >;              /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:712 */
    				interrupts = < 0x10d 0x1 >;       /* in zephyr/dts/arm/nordic/nrf54l_05_10_15_cpuapp.dtsi:90 */
    				phandle = < 0x15 >;               /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:705 */
    			/* node '/soc/peripheral@50000000/regulator@120000' defined in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:715 */
    			regulators: regulator@120000 {
    				compatible = "nordic,nrf54l-regulators"; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:716 */
    				reg = < 0x120000 0x1000 >;               /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:717 */
    				status = "okay";                         /* in zephyr/boards/nordic/nrf54l15dk/nrf54l_05_10_15_cpuapp_common.dtsi:45 */
    				#address-cells = < 0x1 >;                /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:719 */
    				#size-cells = < 0x1 >;                   /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:720 */
    				/* node '/soc/peripheral@50000000/regulator@120000/regulator@120600' defined in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:722 */
    				vregmain: regulator@120600 {
    					compatible = "nordic,nrf5x-regulator"; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:723 */
    					reg = < 0x120600 0x1 >;                /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:724 */
    					status = "okay";                       /* in zephyr/boards/nordic/nrf54l15dk/nrf54l_05_10_15_cpuapp_common.dtsi:49 */
    					regulator-name = "VREGMAIN";           /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:726 */
    					regulator-initial-mode = < 0x1 >;      /* in zephyr/boards/nordic/nrf54l15dk/nrf54l_05_10_15_cpuapp_common.dtsi:50 */
    		/* node '/soc/rram-controller@5004b000' defined in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:732 */
    		rram_controller: rram-controller@5004b000 {
    			compatible = "nordic,rram-controller"; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:733 */
    			reg = < 0x5004b000 0x1000 >;           /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:734 */
    			#address-cells = < 0x1 >;              /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:735 */
    			#size-cells = < 0x1 >;                 /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:736 */
    			interrupts = < 0x4b 0x1 >;             /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:737 */
    			/* node '/soc/rram-controller@5004b000/rram@0' defined in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:739 */
    			cpuapp_rram: rram@0 {
    				compatible = "soc-nv-flash";   /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:740 */
    				erase-block-size = < 0x1000 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:741 */
    				write-block-size = < 0x10 >;   /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:742 */
    				reg = < 0x0 0x165000 >;        /* in zephyr/dts/vendor/nordic/nrf54l15.dtsi:28 */
    				/* node '/soc/rram-controller@5004b000/rram@0/partitions' defined in zephyr/dts/vendor/nordic/nrf54l15_partition.dtsi:8 */
    				partitions {
    					compatible = "fixed-partitions"; /* in zephyr/dts/vendor/nordic/nrf54l15_partition.dtsi:9 */
    					#address-cells = < 0x1 >;        /* in zephyr/dts/vendor/nordic/nrf54l15_partition.dtsi:10 */
    					#size-cells = < 0x1 >;           /* in zephyr/dts/vendor/nordic/nrf54l15_partition.dtsi:11 */
    					/* node '/soc/rram-controller@5004b000/rram@0/partitions/partition@0' defined in zephyr/dts/vendor/nordic/nrf54l15_partition.dtsi:13 */
    					boot_partition: partition@0 {
    						label = "mcuboot";     /* in zephyr/dts/vendor/nordic/nrf54l15_partition.dtsi:14 */
    						reg = < 0x0 0x10000 >; /* in zephyr/dts/vendor/nordic/nrf54l15_partition.dtsi:15 */
    					/* node '/soc/rram-controller@5004b000/rram@0/partitions/partition@10000' defined in zephyr/dts/vendor/nordic/nrf54l15_partition.dtsi:18 */
    					slot0_partition: partition@10000 {
    						label = "image-0";         /* in zephyr/dts/vendor/nordic/nrf54l15_partition.dtsi:19 */
    						reg = < 0x10000 0xa6000 >; /* in zephyr/dts/vendor/nordic/nrf54l15_partition.dtsi:20 */
    					/* node '/soc/rram-controller@5004b000/rram@0/partitions/partition@b6000' defined in zephyr/dts/vendor/nordic/nrf54l15_partition.dtsi:23 */
    					slot1_partition: partition@b6000 {
    						label = "image-1";         /* in zephyr/dts/vendor/nordic/nrf54l15_partition.dtsi:24 */
    						reg = < 0xb6000 0xa6000 >; /* in zephyr/dts/vendor/nordic/nrf54l15_partition.dtsi:25 */
    					/* node '/soc/rram-controller@5004b000/rram@0/partitions/partition@15c000' defined in zephyr/dts/vendor/nordic/nrf54l15_partition.dtsi:28 */
    					storage_partition: partition@15c000 {
    						label = "storage";         /* in zephyr/dts/vendor/nordic/nrf54l15_partition.dtsi:29 */
    						reg = < 0x15c000 0x9000 >; /* in zephyr/dts/vendor/nordic/nrf54l15_partition.dtsi:30 */
    		/* node '/soc/memory@50041000' defined in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:746 */
    		nrf_mpc: memory@50041000 {
    			compatible = "nordic,nrf-mpc";     /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:747 */
    			reg = < 0x50041000 0x1000 >;       /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:748 */
    			#address-cells = < 0x1 >;          /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:749 */
    			#size-cells = < 0x1 >;             /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:750 */
    			override-num = < 0x5 >;            /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:751 */
    			override-granularity = < 0x1000 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:752 */
    		/* node '/soc/cpuapp-ppb-bus' defined in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:755 */
    		cpuapp_ppb: cpuapp-ppb-bus {
    			#address-cells = < 0x1 >;  /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:756 */
    			#size-cells = < 0x1 >;     /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:757 */
    			compatible = "simple-bus"; /* in zephyr/dts/arm/nordic/nrf54l_05_10_15_cpuapp.dtsi:65 */
    			ranges;                    /* in zephyr/dts/arm/nordic/nrf54l_05_10_15_cpuapp.dtsi:66 */
    			/* node '/soc/cpuapp-ppb-bus/interrupt-controller@e000e100' defined in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:759 */
    			cpuapp_nvic: nvic: interrupt-controller@e000e100 {
    				#address-cells = < 0x1 >;            /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:760 */
    				compatible = "arm,v8m-nvic";         /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:761 */
    				reg = < 0xe000e100 0xc00 >;          /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:762 */
    				arm,num-irq-priority-bits = < 0x3 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:763 */
    				interrupt-controller;                /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:764 */
    				#interrupt-cells = < 0x2 >;          /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:765 */
    				phandle = < 0x2 >;                   /* in zephyr/dts/arm/nordic/nrf54l_05_10_15_cpuapp.dtsi:24 */
    			/* node '/soc/cpuapp-ppb-bus/timer@e000e010' defined in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:768 */
    			cpuapp_systick: systick: timer@e000e010 {
    				compatible = "arm,armv8m-systick"; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:769 */
    				reg = < 0xe000e010 0x10 >;         /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:770 */
    				status = "disabled";               /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:771 */
    	/* node '/chosen' defined in zephyr/dts/arm/nordic/nrf54l_05_10_15_cpuapp.dtsi:17 */
    	chosen {
    		zephyr,bt-hci = &bt_hci_sdc;                /* in zephyr/dts/arm/nordic/nrf54l_05_10_15_cpuapp.dtsi:18 */
    		zephyr,entropy = &psa_rng;                  /* in zephyr/dts/arm/nordic/nrf54l_05_10_15_cpuapp.dtsi:19 */
    		zephyr,console = &uart20;                   /* in zephyr/boards/nordic/nrf54l15dk/nrf54l_05_10_15_cpuapp_common.dtsi:13 */
    		zephyr,shell-uart = &uart20;                /* in zephyr/boards/nordic/nrf54l15dk/nrf54l_05_10_15_cpuapp_common.dtsi:14 */
    		zephyr,uart-mcumgr = &uart20;               /* in zephyr/boards/nordic/nrf54l15dk/nrf54l_05_10_15_cpuapp_common.dtsi:15 */
    		zephyr,bt-mon-uart = &uart20;               /* in zephyr/boards/nordic/nrf54l15dk/nrf54l_05_10_15_cpuapp_common.dtsi:16 */
    		zephyr,bt-c2h-uart = &uart20;               /* in zephyr/boards/nordic/nrf54l15dk/nrf54l_05_10_15_cpuapp_common.dtsi:17 */
    		zephyr,flash-controller = &rram_controller; /* in zephyr/boards/nordic/nrf54l15dk/nrf54l_05_10_15_cpuapp_common.dtsi:18 */
    		zephyr,flash = &cpuapp_rram;                /* in zephyr/boards/nordic/nrf54l15dk/nrf54l_05_10_15_cpuapp_common.dtsi:19 */
    		zephyr,ieee802154 = &ieee802154;            /* in zephyr/boards/nordic/nrf54l15dk/nrf54l_05_10_15_cpuapp_common.dtsi:20 */
    		zephyr,boot-mode = &boot_mode0;             /* in zephyr/boards/nordic/nrf54l15dk/nrf54l_05_10_15_cpuapp_common.dtsi:21 */
    		zephyr,code-partition = &slot0_partition;   /* in zephyr/boards/nordic/nrf54l15dk/nrf54l15dk_nrf54l15_cpuapp.dts:17 */
    		zephyr,sram = &cpuapp_sram;                 /* in zephyr/boards/nordic/nrf54l15dk/nrf54l15dk_nrf54l15_cpuapp.dts:18 */
    		zephyr,display = &sharp;                    /* in ../../Projects/personal/mp3/nrf/build/nrf/zephyr/boards/nrf54l15dk_nrf54l10_cpuapp.overlay:169 */
    	/* node '/rng' defined in zephyr/dts/arm/nordic/nrf54l_05_10_15_cpuapp.dtsi:28 */
    	rng: rng {
    		status = "okay";                          /* in zephyr/dts/arm/nordic/nrf54l_05_10_15_cpuapp.dtsi:29 */
    		compatible = "nordic,nrf-cracen-ctrdrbg"; /* in zephyr/dts/arm/nordic/nrf54l_05_10_15_cpuapp.dtsi:30 */
    	/* node '/psa-rng' defined in zephyr/dts/arm/nordic/nrf54l_05_10_15_cpuapp.dtsi:33 */
    	psa_rng: psa-rng {
    		compatible = "zephyr,psa-crypto-rng"; /* in zephyr/dts/arm/nordic/nrf54l_05_10_15_cpuapp.dtsi:34 */
    		status = "okay";                      /* in zephyr/dts/arm/nordic/nrf54l_05_10_15_cpuapp.dtsi:35 */
    	/* node '/leds' defined in zephyr/boards/nordic/nrf54l15dk/nrf54l15dk_common.dtsi:10 */
    	leds {
    		compatible = "gpio-leds"; /* in zephyr/boards/nordic/nrf54l15dk/nrf54l15dk_common.dtsi:11 */
    		/* node '/leds/led_0' defined in zephyr/boards/nordic/nrf54l15dk/nrf54l15dk_common.dtsi:13 */
    		led0: led_0 {
    			gpios = < &gpio2 0x9 0x0 >; /* in zephyr/boards/nordic/nrf54l15dk/nrf54l15dk_common.dtsi:14 */
    			label = "Green LED 0";      /* in zephyr/boards/nordic/nrf54l15dk/nrf54l15dk_common.dtsi:15 */
    			status = "disabled";        /* in ../../Projects/personal/mp3/nrf/build/nrf/zephyr/boards/nrf54l15dk_nrf54l10_cpuapp.overlay:27 */
    		/* node '/leds/led_1' defined in zephyr/boards/nordic/nrf54l15dk/nrf54l15dk_common.dtsi:18 */
    		led1: led_1 {
    			gpios = < &gpio1 0xa 0x0 >; /* in zephyr/boards/nordic/nrf54l15dk/nrf54l15dk_common.dtsi:19 */
    			label = "Green LED 1";      /* in zephyr/boards/nordic/nrf54l15dk/nrf54l15dk_common.dtsi:20 */
    			status = "disabled";        /* in ../../Projects/personal/mp3/nrf/build/nrf/zephyr/boards/nrf54l15dk_nrf54l10_cpuapp.overlay:30 */
    		/* node '/leds/led_2' defined in zephyr/boards/nordic/nrf54l15dk/nrf54l15dk_common.dtsi:23 */
    		led2: led_2 {
    			gpios = < &gpio2 0x7 0x0 >; /* in zephyr/boards/nordic/nrf54l15dk/nrf54l15dk_common.dtsi:24 */
    			label = "Green LED 2";      /* in zephyr/boards/nordic/nrf54l15dk/nrf54l15dk_common.dtsi:25 */
    			status = "disabled";        /* in ../../Projects/personal/mp3/nrf/build/nrf/zephyr/boards/nrf54l15dk_nrf54l10_cpuapp.overlay:33 */
    		/* node '/leds/led_3' defined in zephyr/boards/nordic/nrf54l15dk/nrf54l15dk_common.dtsi:28 */
    		led3: led_3 {
    			gpios = < &gpio1 0xe 0x0 >; /* in zephyr/boards/nordic/nrf54l15dk/nrf54l15dk_common.dtsi:29 */
    			label = "Green LED 3";      /* in zephyr/boards/nordic/nrf54l15dk/nrf54l15dk_common.dtsi:30 */
    			status = "disabled";        /* in ../../Projects/personal/mp3/nrf/build/nrf/zephyr/boards/nrf54l15dk_nrf54l10_cpuapp.overlay:36 */
    	/* node '/pwmleds' defined in zephyr/boards/nordic/nrf54l15dk/nrf54l15dk_common.dtsi:34 */
    	pwmleds {
    		compatible = "pwm-leds"; /* in zephyr/boards/nordic/nrf54l15dk/nrf54l15dk_common.dtsi:35 */
    		/* node '/pwmleds/pwm_led_1' defined in zephyr/boards/nordic/nrf54l15dk/nrf54l15dk_common.dtsi:43 */
    		pwm_led1: pwm_led_1 {
    			pwms = < &pwm20 0x0 0x1312d00 0x0 >; /* in zephyr/boards/nordic/nrf54l15dk/nrf54l15dk_common.dtsi:44 */
    	/* node '/buttons' defined in zephyr/boards/nordic/nrf54l15dk/nrf54l15dk_common.dtsi:48 */
    	buttons {
    		compatible = "gpio-keys"; /* in zephyr/boards/nordic/nrf54l15dk/nrf54l15dk_common.dtsi:49 */
    		/* node '/buttons/button_0' defined in zephyr/boards/nordic/nrf54l15dk/nrf54l15dk_common.dtsi:51 */
    		button0: button_0 {
    			gpios = < &gpio1 0xd 0x11 >; /* in zephyr/boards/nordic/nrf54l15dk/nrf54l15dk_common.dtsi:52 */
    			label = "Push button 0";     /* in zephyr/boards/nordic/nrf54l15dk/nrf54l15dk_common.dtsi:53 */
    			zephyr,code = < 0xb >;       /* in zephyr/boards/nordic/nrf54l15dk/nrf54l15dk_common.dtsi:54 */
    			status = "disabled";         /* in ../../Projects/personal/mp3/nrf/build/nrf/zephyr/boards/nrf54l15dk_nrf54l10_cpuapp.overlay:14 */
    		/* node '/buttons/button_1' defined in zephyr/boards/nordic/nrf54l15dk/nrf54l15dk_common.dtsi:57 */
    		button1: button_1 {
    			gpios = < &gpio1 0x9 0x11 >; /* in zephyr/boards/nordic/nrf54l15dk/nrf54l15dk_common.dtsi:58 */
    			label = "Push button 1";     /* in zephyr/boards/nordic/nrf54l15dk/nrf54l15dk_common.dtsi:59 */
    			zephyr,code = < 0x2 >;       /* in zephyr/boards/nordic/nrf54l15dk/nrf54l15dk_common.dtsi:60 */
    			status = "disabled";         /* in ../../Projects/personal/mp3/nrf/build/nrf/zephyr/boards/nrf54l15dk_nrf54l10_cpuapp.overlay:17 */
    		/* node '/buttons/button_2' defined in zephyr/boards/nordic/nrf54l15dk/nrf54l15dk_common.dtsi:63 */
    		button2: button_2 {
    			gpios = < &gpio1 0x8 0x11 >; /* in zephyr/boards/nordic/nrf54l15dk/nrf54l15dk_common.dtsi:64 */
    			label = "Push button 2";     /* in zephyr/boards/nordic/nrf54l15dk/nrf54l15dk_common.dtsi:65 */
    			zephyr,code = < 0x3 >;       /* in zephyr/boards/nordic/nrf54l15dk/nrf54l15dk_common.dtsi:66 */
    			status = "disabled";         /* in ../../Projects/personal/mp3/nrf/build/nrf/zephyr/boards/nrf54l15dk_nrf54l10_cpuapp.overlay:20 */
    		/* node '/buttons/button_3' defined in zephyr/boards/nordic/nrf54l15dk/nrf54l15dk_common.dtsi:69 */
    		button3: button_3 {
    			gpios = < &gpio0 0x4 0x11 >; /* in zephyr/boards/nordic/nrf54l15dk/nrf54l15dk_common.dtsi:70 */
    			label = "Push button 3";     /* in zephyr/boards/nordic/nrf54l15dk/nrf54l15dk_common.dtsi:71 */
    			zephyr,code = < 0x4 >;       /* in zephyr/boards/nordic/nrf54l15dk/nrf54l15dk_common.dtsi:72 */
    			status = "disabled";         /* in ../../Projects/personal/mp3/nrf/build/nrf/zephyr/boards/nrf54l15dk_nrf54l10_cpuapp.overlay:23 */
    	/* node '/aliases' defined in zephyr/boards/nordic/nrf54l15dk/nrf54l15dk_common.dtsi:76 */
    	aliases {
    		led0 = &led0;               /* in zephyr/boards/nordic/nrf54l15dk/nrf54l15dk_common.dtsi:77 */
    		led1 = &led1;               /* in zephyr/boards/nordic/nrf54l15dk/nrf54l15dk_common.dtsi:78 */
    		led2 = &led2;               /* in zephyr/boards/nordic/nrf54l15dk/nrf54l15dk_common.dtsi:79 */
    		led3 = &led3;               /* in zephyr/boards/nordic/nrf54l15dk/nrf54l15dk_common.dtsi:80 */
    		pwm-led0 = &pwm_led1;       /* in zephyr/boards/nordic/nrf54l15dk/nrf54l15dk_common.dtsi:81 */
    		sw0 = &button0;             /* in zephyr/boards/nordic/nrf54l15dk/nrf54l15dk_common.dtsi:82 */
    		sw1 = &button1;             /* in zephyr/boards/nordic/nrf54l15dk/nrf54l15dk_common.dtsi:83 */
    		sw2 = &button2;             /* in zephyr/boards/nordic/nrf54l15dk/nrf54l15dk_common.dtsi:84 */
    		sw3 = &button3;             /* in zephyr/boards/nordic/nrf54l15dk/nrf54l15dk_common.dtsi:85 */
    		watchdog0 = &wdt31;         /* in zephyr/boards/nordic/nrf54l15dk/nrf54l15dk_common.dtsi:86 */
    		mcuboot-button0 = &button0; /* in zephyr/boards/nordic/nrf54l15dk/nrf54l_05_10_15_cpuapp_common.dtsi:25 */
    		mcuboot-led0 = &led0;       /* in zephyr/boards/nordic/nrf54l15dk/nrf54l_05_10_15_cpuapp_common.dtsi:26 */
  • Hey  did you have a chance to check the dts file? Or maybe there are other ways to find if there is a conflict or other reason for this issue?
  • As was "hunched" in the post - issue is indeed pull-up setup. Seems like DK has pull-ups on pins 4 and 5 (or bias-pull-up is set on them in some obscure way).
    Setting internal pull ups explicitly for i2c pinctrl solved the problem.
     i2c20_default: i2c20_default {
            group1 {
                psels = <NRF_PSEL(TWIM_SCL, 1, 11)>,
                        <NRF_PSEL(TWIM_SDA, 1, 10)>;
                bias-pull-up;
    Thank you for sharing, and for your patience. I unfortunately didn't have time to check up in the DTS before late yesterday and I'd spent the morning testing TWI. You are right, the SDA and SCL requires either an external pull up resistor on the line or to have the bias-pull-up set in the dts.
    Andreas
  • No worries Ok hand Thanks for checking the post anyhow!
