DTLS PSK Handshake Failure on nRF9151 DK
7762.wireshark_trace_clienthello_only_scsv.pcapng
Summary
We are trying to perform a DTLS 1.2 handshake using PSK (Pre-Shared Key)
from an **nRF9151 module running NCS v3.0.2, using modem-offloaded DTLS (IPPROTO_DTLS_1_2).
  • LTE connects successfully
  • PSK Identity + Key are provisioned to security tag 42
  • The socket is configured with `TLS_SEC_TAG_LIST` and `TLS_PEER_VERIFY_NONE`
  • DTLS handshake always fails with `errno = 111` (`ECONNREFUSED`)
  • Wireshark trace shows the modem sends a DTLS ClientHello containing only: that means no usable cipher suites get advertised.
Expected Behavior
The client should send a DTLS ClientHello advertising PSK cipher suites such as:
  • - `TLS_PSK_WITH_AES_128_CCM_8`
  • - `TLS_PSK_WITH_AES_128_CCM`
And the server should reply with ServerHello → PSK Key Exchange.
This works correctly using:
Heavy check mark OpenSSL-based client
Heavy check mark Go client (Pion/dtls)
Heavy multiplication x Fails only with the nRF91 modem-based DTLS client
Actual Behavior
  • Although PSK identity and key are provisioned correctly inside the modem, the ClientHello sent by the nRF9151 does not include any PSK cipher suite (e.g., TLS_PSK_WITH_AES_128_CCM_8). Instead, it offers only ECDHE-based certificate cipher suites followed by TLS_EMPTY_RENEGOTIATION_INFO_SCSV (0x00FF). As a result, the DTLS handshake fails with no shared cipher suite.
  • Server (Go or OpenSSL) rejects handshake
  • Client receives errno=111.
Files Included
| File | Description |
| `main.c` | Full C source used on nRF9151 |
| `prj.conf` | Project configuration |
| `wireshark_trace_clienthello_only_scsv.pcapng` | Modem trace export |
| `server_log.txt` | Output from Go/openssl servers (no shared cipher) |
Test with OpenSSL
> openssl s_server -dtls -accept 5684 -nocert -psk 73757065727365637265746b6579313233 -psk_identity device001 -cipher "PSK-AES128-CCM8:PSK-AES128-CCM:PSK-AES128-CBC-HA"
Returns:
Using default temp DH parameters
ACCEPT
ERROR
4057EA2E827B0000:error:0A0000C1:SSL routines:tls_post_process_client_hello:no shared cipher:../ssl/statem/statem_srvr.c:2220:
shutting down SSL
CONNECTION CLOSED
PSK Used
Identity: device001
Key: supersecretkey123
Confirmed stored under SEC_TAG=42.
Questions to Nordic
Why does modem DTLS not include PSK ciphers in ClientHello?
Is IPPROTO_DTLS_1_2 + TLS_SEC_TAG_LIST enough to enable PSK?
Do we need to explicitly set TLS_DTLS_VERSION, TLS_CIPHERSUITE_LIST, or something undocumented?
Is this a known issue in nRF9151 modem firmware v1.x?
Can you help me to get the DTLS handshake complete with success?
In the final product, the DTLS stuff must coexist with the LwM2M (which I already successfully tested 0m nRF9161 platform using Eclipse Leshan together with lwm2m client sample) one on nRF9151.
Thank you in advance for your support!
  • If I use your "GIMSServer", I still get a list with PSK cipher suites.
    #define ECONNREFUSED 111    /* Connection refused */
    tells, that the connection is refused. But there are many reasons for that. One maybe, that even if PSK cipher suites are proposed, the server doesn't support one of the proposed. Then the server may send an handshake alert instead of a Server_Hello. Or the identity/secret doesn't match. The the handshake may timeout or fail after the FINISH.
    (I would test to use a slightly shorter psk, your's has 17 bytes. Remove the last one.)
    Without current ip-capture, it stays unclear, where it fails.
  • I changed PSK removing the final "123". I also configured the GO DTLS server  to use TLS_PSK_WITH_AES_128_CCM_8. This changed the behavior...
    dtls_handshake_capture.pcapng
    No.	Time	Source	Destination	Protocol	Length	Info
    1	0.000000			AT	30	Sent AT Command: AT%XMODEMTRACE=1,2
    2	0.001068			AT	16	Rcvd AT Command: OK
    3	0.001587			AT	35	Sent AT Command: AT%XCOEX0=1,1,1565,1586
    4	0.001740			AT	16	Rcvd AT Command: OK
    5	0.002564			AT	34	Sent AT Command: AT%XSYSTEMMODE=1,0,0,0
    6	0.002808			AT	16	Rcvd AT Command: OK
    7	0.003479			AT	28	Sent AT Command: AT%FEACONF=0,3,1
    8	0.003510			AT	16	Rcvd AT Command: OK
    9	0.010163			AT	20	Sent AT Command: AT+CFUN?
    10	0.010224			AT	26	Rcvd AT Command: +CFUN: 0  OK
    11	0.010803			AT	21	Sent AT Command: AT+CFUN=1
    12	0.043213			AT	16	Rcvd AT Command: OK
    13	2.043671			AT	19	Sent AT Command: AT+CPIN
    14	2.043671			AT	32	Rcvd AT Command: +CPIN: SIM PIN  OK
    15	2.044190			AT	19	Sent AT Command: AT+CPIN
    16	2.075653			AT	16	Rcvd AT Command: OK
    17	2.538819			LTE RRC BCCH_BCH	28	MasterInformationBlock (SFN=18)
    18	2.542755			LTE RRC DL_SCH	117	SystemInformationBlockType1
    19	2.546784			LTE RRC DL_SCH	103	SystemInformation [ SIB2 ]
    20	2.550873			NAS-EPS	118	Attach request, PDN connectivity request
    21	2.553192			LTE RRC UL_CCCH	30	RRCConnectionRequest
    22	2.631012			LTE RRC DL_CCCH	74	RRCConnectionSetup
    23	2.632385			LTE RRC UL_DCCH/NAS-EPS	137	RRCConnectionSetupComplete, Attach request, PDN connectivity request
    24	2.742096			LTE RRC DL_DCCH/NAS-EPS	30	DLInformationTransfer, Identity request
    25	2.742188			NAS-EPS	19	Identity request
    26	2.742218			NAS-EPS	27	Identity response
    27	2.742371			LTE RRC UL_DCCH/NAS-EPS	44	ULInformationTransfer, Identity response
    28	2.814087			LTE RRC DL_DCCH/NAS-EPS	63	DLInformationTransfer, Authentication request
    29	2.814179			NAS-EPS	52	Authentication request
    30	2.873871			NAS-EPS	27	Authentication response
    31	2.874024			LTE RRC UL_DCCH/NAS-EPS	44	ULInformationTransfer, Authentication response
    32	2.971131			LTE RRC DL_DCCH/NAS-EPS	41	DLInformationTransfer, Security mode command
    33	2.971192			NAS-EPS	30	Security mode command
    34	2.973023			NAS-EPS	29	Security mode complete
    35	2.973175			LTE RRC UL_DCCH/NAS-EPS	46	ULInformationTransfer, Ciphered message
    36	3.554230			LTE RRC DL_DCCH	27	SecurityModeCommand
    37	3.555969			LTE RRC UL_DCCH	26	SecurityModeComplete
    38	3.603150			LTE RRC DL_DCCH	55	UECapabilityEnquiry
    39	3.605133			LTE RRC UL_DCCH	150	UECapabilityInformation
    40	3.715424			LTE RRC DL_DCCH/NAS-EPS	260	RRCConnectionReconfiguration, Ciphered message
    41	3.716919			LTE RRC UL_DCCH	26	RRCConnectionReconfigurationComplete
    42	3.717346			NAS-EPS	189	Ciphered message, Attach accept, Activate default EPS bearer context request (PDN type IPv4 only allowed)
    43	3.717987			NAS-EPS	23	Attach complete, Activate default EPS bearer context accept
    44	3.718201			LTE RRC UL_DCCH/NAS-EPS	40	ULInformationTransfer, Ciphered message, Deactivate EPS bearer context request (Unknown)
    45	3.774140			LTE RRC DL_DCCH/NAS-EPS	54	DLInformationTransfer, Ciphered message
    46	3.774262			NAS-EPS	43	Ciphered message, EMM information
    47	3.835266			LTE RRC DL_DCCH	37	RRCConnectionReconfiguration
    48	3.836029			LTE RRC UL_DCCH	26	RRCConnectionReconfigurationComplete
    49	5.076172			AT	19	Sent AT Command: AT+CPIN
    50	5.076203			AT	30	Rcvd AT Command: +CPIN: READY  OK
    51	5.076630			AT	21	Sent AT Command: AT+CFUN=4
    52	5.078217			NAS-EPS	31	Detach request (Combined EPS/IMSI detach / switch-off)
    53	5.078369			LTE RRC UL_DCCH/NAS-EPS	48	ULInformationTransfer, Ciphered message(DTAP) (TP) Update UE Location Information [Malformed Packet]
    54	5.300354			LTE RRC DL_DCCH	38	RRCConnectionRelease [cause=other]
    55	5.419403			AT	16	Rcvd AT Command: OK
    56	6.428681			AT	20	Sent AT Command: AT+CMEE?
    57	6.428711			AT	26	Rcvd AT Command: +CMEE: 0  OK
    58	6.435211			AT	21	Sent AT Command: AT+CMEE=1
    59	6.435242			AT	16	Rcvd AT Command: OK
    60	6.435974			AT	19	Sent AT Command: AT%CMNG
    61	7.161163			AT	16	Rcvd AT Command: OK
    62	7.161621			AT	21	Sent AT Command: AT+CMEE=0
    63	7.161652			AT	16	Rcvd AT Command: OK
    64	7.162110			AT	20	Sent AT Command: AT+CMEE?
    65	7.162140			AT	26	Rcvd AT Command: +CMEE: 0  OK
    66	7.162598			AT	21	Sent AT Command: AT+CMEE=1
    67	7.162628			AT	16	Rcvd AT Command: OK
    68	7.163147			AT	19	Sent AT Command: AT%CMNG
    69	7.236633			AT	16	Rcvd AT Command: OK
    70	7.237091			AT	21	Sent AT Command: AT+CMEE=0
    71	7.237122			AT	16	Rcvd AT Command: OK
    72	7.237518			AT	21	Sent AT Command: AT+CFUN=1
    73	7.270172			AT	16	Rcvd AT Command: OK
    74	9.270691			AT	19	Sent AT Command: AT+CPIN
    75	9.302124			AT	16	Rcvd AT Command: OK
    76	9.769104			LTE RRC BCCH_BCH	28	MasterInformationBlock (SFN=198)
    77	9.783020			LTE RRC DL_SCH	117	SystemInformationBlockType1
    78	9.783692			LTE RRC DL_SCH	103	SystemInformation [ SIB2 ]
    79	9.786499			NAS-EPS	118	Attach request, PDN connectivity request
    80	9.788605			LTE RRC UL_CCCH	30	RRCConnectionRequest
    81	9.826325			LTE RRC DL_CCCH	74	RRCConnectionSetup
    82	9.827698			LTE RRC UL_DCCH/NAS-EPS	137	RRCConnectionSetupComplete, Attach request, PDN connectivity request
    83	10.302674			AT	21	Sent AT Command: AT+CEREG?
    84	10.302826			AT	49	Rcvd AT Command: +CEREG: 0,2,"057D","01017406",7  OK
    85	10.303589			AT	20	Sent AT Command: AT+CFUN?
    86	10.303650			AT	26	Rcvd AT Command: +CFUN: 1  OK
    87	10.304260			AT	22	Sent AT Command: AT+CEREG=5
    88	10.304260			AT	16	Rcvd AT Command: OK
    89	10.304688			AT	22	Sent AT Command: AT+CSCON=1
    90	10.304718			AT	16	Rcvd AT Command: OK
    91	10.305206			AT	21	Sent AT Command: AT+CFUN=1
    92	10.305786			AT	16	Rcvd AT Command: OK
    93	10.381409			LTE RRC DL_DCCH	27	SecurityModeCommand
    94	10.383301			LTE RRC UL_DCCH	26	SecurityModeComplete
    95	10.488281			LTE RRC DL_DCCH	55	UECapabilityEnquiry
    96	10.490326			LTE RRC UL_DCCH	150	UECapabilityInformation
    97	10.594574			LTE RRC DL_DCCH/NAS-EPS	260	RRCConnectionReconfiguration, Ciphered message
    98	10.596344			LTE RRC UL_DCCH	26	RRCConnectionReconfigurationComplete
    99	10.596802			NAS-EPS	189	Ciphered message, Attach accept, Activate default EPS bearer context request (PDN type IPv4 only allowed)
    100	10.597809			NAS-EPS	23	Attach complete, Activate default EPS bearer context accept
    101	10.597992			LTE RRC UL_DCCH/NAS-EPS	40	ULInformationTransfer, Ciphered message
    102	10.645844			AT	67	Rcvd AT Command: +CEREG: 1,"057D","01017406",7,,,"00001111","00101101"
    103	10.647064	10.238.101.106	193.5.23.8	DNS	77	Standard query 0x17be A GIMSServer.mooo.com
    104	10.656433			LTE RRC DL_DCCH/NAS-EPS	54	DLInformationTransfer, Ciphered message
    105	10.656555			NAS-EPS	43	Ciphered message, EMM information
    106	10.724518			LTE RRC DL_DCCH	37	RRCConnectionReconfiguration
    107	10.725281			LTE RRC UL_DCCH	26	RRCConnectionReconfigurationComplete
    108	10.874237	193.5.23.8	10.238.101.106	DNS	93	Standard query response 0x17be A GIMSServer.mooo.com A 84.55.253.71
    109	10.880158	10.238.101.106	84.55.253.71	DTLSv1.2	176	Client Hello (SNI=GIMSServer.mooo.com)
    110	10.989227	84.55.253.71	10.238.101.106	DTLSv1.2	88	Hello Verify Request
    111	10.990021	10.238.101.106	84.55.253.71	DTLSv1.2	196	Client Hello (SNI=GIMSServer.mooo.com)
    112	11.090820	84.55.253.71	10.238.101.106	DTLSv1.2	171	Server Hello, Server Key Exchange, Server Hello Done
    113	11.097626	10.238.101.106	84.55.253.71	DTLSv1.2	143	Client Key Exchange, Change Cipher Spec, Encrypted Handshake Message
    114	12.199555	10.238.101.106	84.55.253.71	DTLSv1.2	143	Client Key Exchange, Change Cipher Spec, Encrypted Handshake Message
    115	13.225708	84.55.253.71	10.238.101.106	DTLSv1.2	171	Server Hello, Server Key Exchange, Server Hello Done
    116	13.226288	10.238.101.106	84.55.253.71	DTLSv1.2	143	Client Key Exchange, Change Cipher Spec, Encrypted Handshake Message
    117	15.138642	84.55.253.71	10.238.101.106	DTLSv1.2	171	Server Hello, Server Key Exchange, Server Hello Done
    118	15.139160	10.238.101.106	84.55.253.71	DTLSv1.2	143	Client Key Exchange, Change Cipher Spec, Encrypted Handshake Message
    119	17.090851	84.55.253.71	10.238.101.106	DTLSv1.2	171	Server Hello, Server Key Exchange, Server Hello Done
    120	17.091431	10.238.101.106	84.55.253.71	DTLSv1.2	143	Client Key Exchange, Change Cipher Spec, Encrypted Handshake Message
    121	19.192413	10.238.101.106	84.55.253.71	DTLSv1.2	143	Client Key Exchange, Change Cipher Spec, Encrypted Handshake Message
    122	19.302979	84.55.253.71	10.238.101.106	DTLSv1.2	171	Server Hello, Server Key Exchange, Server Hello Done
    123	19.303375	10.238.101.106	84.55.253.71	DTLSv1.2	143	Client Key Exchange, Change Cipher Spec, Encrypted Handshake Message
    124	21.217987	84.55.253.71	10.238.101.106	DTLSv1.2	171	Server Hello, Server Key Exchange, Server Hello Done
    125	21.218445	10.238.101.106	84.55.253.71	DTLSv1.2	143	Client Key Exchange, Change Cipher Spec, Encrypted Handshake Message
    126	23.143097	84.55.253.71	10.238.101.106	DTLSv1.2	171	Server Hello, Server Key Exchange, Server Hello Done
    127	23.143524	10.238.101.106	84.55.253.71	DTLSv1.2	143	Client Key Exchange, Change Cipher Spec, Encrypted Handshake Message
    128	25.086151	84.55.253.71	10.238.101.106	DTLSv1.2	171	Server Hello, Server Key Exchange, Server Hello Done
    129	25.086579	10.238.101.106	84.55.253.71	DTLSv1.2	143	Client Key Exchange, Change Cipher Spec, Encrypted Handshake Message
    130	27.298218	84.55.253.71	10.238.101.106	DTLSv1.2	171	Server Hello, Server Key Exchange, Server Hello Done
    131	27.298676	10.238.101.106	84.55.253.71	DTLSv1.2	143	Client Key Exchange, Change Cipher Spec, Encrypted Handshake Message
    132	29.217224	84.55.253.71	10.238.101.106	DTLSv1.2	171	Server Hello, Server Key Exchange, Server Hello Done
    133	29.217560	10.238.101.106	84.55.253.71	DTLSv1.2	143	Client Key Exchange, Change Cipher Spec, Encrypted Handshake Message
    134	31.137268	84.55.253.71	10.238.101.106	DTLSv1.2	171	Server Hello, Server Key Exchange, Server Hello Done
    135	31.137634	10.238.101.106	84.55.253.71	DTLSv1.2	143	Client Key Exchange, Change Cipher Spec, Encrypted Handshake Message
    136	33.088379	84.55.253.71	10.238.101.106	DTLSv1.2	171	Server Hello, Server Key Exchange, Server Hello Done
    137	33.088715	10.238.101.106	84.55.253.71	DTLSv1.2	143	Client Key Exchange, Change Cipher Spec, Encrypted Handshake Message
    138	35.334473	84.55.253.71	10.238.101.106	DTLSv1.2	171	Server Hello, Server Key Exchange, Server Hello Done
    139	35.334809	10.238.101.106	84.55.253.71	DTLSv1.2	143	Client Key Exchange, Change Cipher Spec, Encrypted Handshake Message
    140	37.217529	84.55.253.71	10.238.101.106	DTLSv1.2	171	Server Hello, Server Key Exchange, Server Hello Done
    141	37.217865	10.238.101.106	84.55.253.71	DTLSv1.2	143	Client Key Exchange, Change Cipher Spec, Encrypted Handshake Message
    142	39.136658	84.55.253.71	10.238.101.106	DTLSv1.2	171	Server Hello, Server Key Exchange, Server Hello Done
    143	39.137238	10.238.101.106	84.55.253.71	DTLSv1.2	143	Client Key Exchange, Change Cipher Spec, Encrypted Handshake Message
    144	43.238281	10.238.101.106	84.55.253.71	DTLSv1.2	143	Client Key Exchange, Change Cipher Spec, Encrypted Handshake Message
    145	51.339935	10.238.101.106	84.55.253.71	DTLSv1.2	143	Client Key Exchange, Change Cipher Spec, Encrypted Handshake Message
    146	67.441742	10.238.101.106	84.55.253.71	DTLSv1.2	143	Client Key Exchange, Change Cipher Spec, Encrypted Handshake Message
    See dtls_handshake_capture.pcapng wireshark capture (I hope this contains everything) and DTLS_DEbug.txt which shows the message sequence in Wireshark.
    As mentioned Lesson5_Exercise2 is connecting successfully to the public COAP server.
    Joel
  • I would check, if the go server really wants the psk in hex or how to pass it in as hex. Otherwise, just pass "secret" into go (plain) and "736563726574" to the modem (hex) and see what's happen.
  • mmm, I don't think the issue is the PSK. The handshake fails for both OpensSSL and the go server. To exclude entirely any issue related to the go server (I'll go back to it once I'm able to get a successful DTLS handshake) I switched to ssl_server2 demo server of mbed (build version: Mbed TLS 3.5.2). Since NRF is using mbed dtsl too, there shouldn't by any incompatibilities between client and sever.
    By running:./programs/ssl/ssl_server2 server_port=5685 dtls=1 psk=73757065727365637265746b6579 psk_identity=device001 force_ciphersuite=TLS-PSK-WITH-AES-128-CCM-8 debug_level=3
    I get the following handshake error:
      . Seeding the random number generator... ok
      . Loading the CA root certificate ... ok (0 skipped)
      . Loading the server cert. and key... ok (key types: RSA, EC)
      . Setting up the SSL/TLS structure...ssl_tls.c:0111: |3| Disable use of CID extension.
    ssl_msg.c:0291: |3| set_timer to 0 ms
     ok
      . Bind on udp://*:5685/ ... ok
      . Waiting for a remote connection ... ok
      . Performing the SSL/TLS handshake...ssl_tls.c:3919: |2| => handshake
    ssl_msg.c:2358: |2| => flush output
    ssl_msg.c:2367: |2| <= flush output
    ssl_tls12_server.c:4290: |2| server state: 0
    ssl_tls12_server.c:4290: |2| server state: 1
    ssl_tls12_server.c:0911: |2| => parse client hello
    ssl_msg.c:2160: |2| => fetch input
    ssl_msg.c:2206: |2| in_left: 0, nb_want: 5
    ssl_msg.c:2245: |3| f_recv_timeout: 0 ms
    ssl_msg.c:0323: |1| => mbedtls_ssl_check_record
    ssl_msg.c:0324: |3| dumping 'record buffer' (136 bytes)
    ssl_msg.c:0324: |3| 0000:  16 fe fd 00 00 00 00 00 00 00 00 00 7b 01 00 00  ............{...
    ssl_msg.c:0324: |3| 0010:  6f 00 00 00 00 00 00 00 6f fe fd 69 12 dd 81 96  o.......o..i....
    ssl_msg.c:0324: |3| 0020:  b8 ed a1 5d 89 18 8f d7 9b 16 93 3a 2e 0e df fa  ...].......:....
    ssl_msg.c:0324: |3| 0030:  f2 22 76 9f ea 51 f2 10 84 52 98 00 00 00 0a 00  ."v..Q...R......
    ssl_msg.c:0324: |3| 0040:  8d 00 ae 00 8c c0 a8 00 ff 01 00 00 3b 00 00 00  ............;...
    ssl_msg.c:0324: |3| 0050:  18 00 16 00 00 13 47 49 4d 53 53 65 72 76 65 72  ......GIMSServer
    ssl_msg.c:0324: |3| 0060:  2e 6d 6f 6f 6f 2e 63 6f 6d 00 0d 00 0e 00 0c 06  .mooo.com.......
    ssl_msg.c:0324: |3| 0070:  03 06 01 05 03 05 01 04 03 04 01 00 36 00 09 08  ............6...
    ssl_msg.c:0324: |3| 0080:  52 19 9a 7b 4d cb de 44                          R..{M..D
    ssl_msg.c:3869: |3| input record: msgtype = 22, version = [0x303], msglen = 123
    ssl_msg.c:0365: |1| <= mbedtls_ssl_check_record
    ssl_msg.c:2254: |2| ssl->f_recv(_timeout)() returned 136 (-0xffffff78)
    ssl_msg.c:2345: |2| <= fetch input
    ssl_tls12_server.c:0951: |3| client hello, message type: 22
    ssl_tls12_server.c:0959: |3| client hello, message len.: 123
    ssl_tls12_server.c:0962: |3| client hello, protocol version: [254:253]
    ssl_msg.c:2206: |2| in_left: 136, nb_want: 136
    ssl_msg.c:2214: |2| <= fetch input
    ssl_tls12_server.c:1052: |3| client hello v3, handshake type: 1
    ssl_tls12_server.c:1060: |3| client hello v3, handshake len.: 111
    ssl_tls12_server.c:1159: |3| dumping 'client hello, version' (2 bytes)
    ssl_tls12_server.c:1159: |3| 0000:  fe fd                                            ..
    ssl_tls12_server.c:1175: |3| dumping 'client hello, random bytes' (32 bytes)
    ssl_tls12_server.c:1175: |3| 0000:  69 12 dd 81 96 b8 ed a1 5d 89 18 8f d7 9b 16 93  i.......].......
    ssl_tls12_server.c:1175: |3| 0010:  3a 2e 0e df fa f2 22 76 9f ea 51 f2 10 84 52 98  :....."v..Q...R.
    ssl_tls12_server.c:1192: |3| dumping 'client hello, session id' (0 bytes)
    ssl_tls12_server.c:1215: |3| dumping 'client hello, cookie' (0 bytes)
    ssl_tls12_server.c:1227: |2| cookie verification failed
    ssl_tls12_server.c:1266: |3| dumping 'client hello, ciphersuitelist' (10 bytes)
    ssl_tls12_server.c:1266: |3| 0000:  00 8d 00 ae 00 8c c0 a8 00 ff                    ..........
    ssl_tls12_server.c:1288: |3| dumping 'client hello, compression' (1 bytes)
    ssl_tls12_server.c:1288: |3| 0000:  00                                               .
    ssl_tls12_server.c:1317: |3| dumping 'client hello extensions' (59 bytes)
    ssl_tls12_server.c:1317: |3| 0000:  00 00 00 18 00 16 00 00 13 47 49 4d 53 53 65 72  .........GIMSSer
    ssl_tls12_server.c:1317: |3| 0010:  76 65 72 2e 6d 6f 6f 6f 2e 63 6f 6d 00 0d 00 0e  ver.mooo.com....
    ssl_tls12_server.c:1317: |3| 0020:  00 0c 06 03 06 01 05 03 05 01 04 03 04 01 00 36  ...............6
    ssl_tls12_server.c:1317: |3| 0030:  00 09 08 52 19 9a 7b 4d cb de 44                 ...R..{M..D
    ssl_tls12_server.c:1340: |3| found ServerName extension
    ssl_tls.c:9366: |3| parse ServerName extension
    ssl_tls12_server.c:1363: |3| found signature_algorithms extension
    ssl_tls12_server.c:1423: |3| found CID extension
    ssl_tls12_server.c:0400: |3| Client sent CID extension, but CID disabled
    ssl_tls12_server.c:1531: |3| received TLS_EMPTY_RENEGOTIATION_INFO
    ssl_tls12_server.c:0810: |3| trying ciphersuite: 0xc0a8 (TLS-PSK-WITH-AES-128-CCM-8)
    ssl_tls12_server.c:1655: |2| selected ciphersuite: TLS-PSK-WITH-AES-128-CCM-8
    ssl_tls12_server.c:1678: |3| no hash algorithm for signature algorithm 0 - should not happen
    ssl_tls12_server.c:1683: |2| <= parse client hello
    ssl_tls12_server.c:4290: |2| server state: 2
    ssl_tls12_server.c:2170: |2| => write server hello
    ssl_tls12_server.c:2175: |2| client hello was not authenticated
    ssl_tls12_server.c:2176: |2| <= write server hello
    ssl_tls12_server.c:2049: |2| => write hello verify request
    ssl_tls12_server.c:2061: |3| dumping 'server version' (2 bytes)
    ssl_tls12_server.c:2061: |3| 0000:  fe fd                                            ..
    ssl_tls12_server.c:2082: |3| dumping 'cookie sent' (32 bytes)
    ssl_tls12_server.c:2082: |3| 0000:  69 12 dd 82 b9 71 3b a1 84 06 5e f0 98 5f 85 bf  i....q;...^.._..
    ssl_tls12_server.c:2082: |3| 0010:  c8 37 61 20 9d e9 ff 58 7e d8 15 9b cb ad 5f 53  .7a ...X~....._S
    ssl_msg.c:2788: |2| => write handshake message
    ssl_msg.c:2422: |2| => ssl_flight_append
    ssl_msg.c:2457: |2| <= ssl_flight_append
    ssl_msg.c:2909: |2| <= write handshake message
    ssl_msg.c:2539: |2| => mbedtls_ssl_flight_transmit
    ssl_msg.c:2542: |2| initialise flight transmission
    ssl_msg.c:2489: |3| skip swap epochs
    ssl_msg.c:2643: |3| dumping 'handshake header' (12 bytes)
    ssl_msg.c:2643: |3| 0000:  03 00 00 23 00 00 00 00 00 00 00 23              ...#.......#
    ssl_msg.c:2948: |2| => write record
    ssl_msg.c:3032: |3| output record: msgtype = 22, version = [254:253], msglen = 47
    ssl_msg.c:3072: |2| Still 16324 bytes available in current datagram
    ssl_msg.c:3085: |2| <= write record
    ssl_msg.c:2372: |2| message length: 60, out_left: 60
    ssl_msg.c:2379: |2| ssl->f_send() returned 60 (-0xffffffc4)
    ssl_msg.c:2406: |2| <= flush output
    ssl_msg.c:2684: |2| <= mbedtls_ssl_flight_transmit
    ssl_tls12_server.c:2103: |2| <= write hello verify request
    ssl_tls12_server.c:4290: |2| server state: 17
    ssl_tls.c:3930: |2| <= handshake
     hello verification requested
    ssl_msg.c:0324: |3| dumping 'record buffer' (168 bytes)
    ssl_msg.c:0324: |3| 0000:  16 fe fd 00 00 00 00 00 00 00 01 00 9b 01 00 00  ................
    ssl_msg.c:0324: |3| 0010:  8f 00 01 00 00 00 00 00 8f fe fd 69 12 dd 81 96  ...........i....
    ssl_msg.c:0324: |3| 0030:  f2 22 76 9f ea 51 f2 10 84 52 98 00 20 69 12 dd  ."v..Q...R.. i..
    ssl_msg.c:0324: |3| 0040:  82 b9 71 3b a1 84 06 5e f0 98 5f 85 bf c8 37 61  ..q;...^.._...7a
    ssl_msg.c:0324: |3| 0050:  20 9d e9 ff 58 7e d8 15 9b cb ad 5f 53 00 0a 00   ...X~....._S...
    ssl_msg.c:0324: |3| 0060:  8d 00 ae 00 8c c0 a8 00 ff 01 00 00 3b 00 00 00  ............;...
    ssl_msg.c:0324: |3| 0070:  18 00 16 00 00 13 47 49 4d 53 53 65 72 76 65 72  ......GIMSServer
    ssl_msg.c:0324: |3| 0080:  2e 6d 6f 6f 6f 2e 63 6f 6d 00 0d 00 0e 00 0c 06  .mooo.com.......
    ssl_msg.c:0324: |3| 0090:  03 06 01 05 03 05 01 04 03 04 01 00 36 00 09 08  ............6...
    ssl_msg.c:0324: |3| 00a0:  52 19 9a 7b 4d cb de 44                          R..{M..D
    ssl_msg.c:3869: |3| input record: msgtype = 22, version = [0x303], msglen = 155
    ssl_msg.c:2254: |2| ssl->f_recv(_timeout)() returned 168 (-0xffffff58)
    ssl_tls12_server.c:0959: |3| client hello, message len.: 155
    ssl_msg.c:2206: |2| in_left: 168, nb_want: 168
    ssl_tls12_server.c:1060: |3| client hello v3, handshake len.: 143
    ssl_tls12_server.c:1215: |3| dumping 'client hello, cookie' (32 bytes)
    ssl_tls12_server.c:1215: |3| 0000:  69 12 dd 82 b9 71 3b a1 84 06 5e f0 98 5f 85 bf  i....q;...^.._..
    ssl_tls12_server.c:1215: |3| 0010:  c8 37 61 20 9d e9 ff 58 7e d8 15 9b cb ad 5f 53  .7a ...X~....._S
    ssl_tls12_server.c:1230: |2| cookie verification passed
    ssl_tls12_server.c:2200: |3| server hello, chosen version: [254:253]
    ssl_tls12_server.c:2208: |3| server hello, current time: 1762844034
    ssl_tls12_server.c:2252: |3| dumping 'server hello, random bytes' (32 bytes)
    ssl_tls12_server.c:2252: |3| 0000:  69 12 dd 82 bf 92 35 b2 b4 bd ab 2e 69 06 a0 48  i.....5.....i..H
    ssl_tls12_server.c:2252: |3| 0010:  2a d0 47 d7 72 e4 f9 7c 93 f7 45 24 91 1c a9 bb  *.G.r..|..E$....
    ssl_tls12_server.c:2305: |3| server hello, session id len.: 32
    ssl_tls12_server.c:2306: |3| dumping 'server hello, session id' (32 bytes)
    ssl_tls12_server.c:2306: |3| 0000:  20 37 d6 6a db 86 1a 91 05 8e f3 91 92 28 19 ac   7.j.........(..
    ssl_tls12_server.c:2306: |3| 0010:  f4 b9 33 03 9e 8d 52 ec 1f a9 3e 4b f8 9c df 9d  ..3...R...>K....
    ssl_tls12_server.c:2307: |3| no session has been resumed
    ssl_tls12_server.c:2314: |3| server hello, chosen ciphersuite: TLS-PSK-WITH-AES-128-CCM-8
    ssl_tls12_server.c:2316: |3| server hello, compress alg.: 0x00
    ssl_tls12_server.c:1838: |3| server hello, secure renegotiation extension
    ssl_tls12_server.c:2381: |3| server hello, total extension length: 5
    ssl_tls12_server.c:2395: |2| <= write server hello
    ssl_tls12_server.c:4290: |2| server state: 3
    ssl_tls.c:6915: |2| => write certificate
    ssl_tls.c:6918: |2| <= skip write certificate
    ssl_tls12_server.c:4290: |2| server state: 4
    ssl_tls12_server.c:3223: |2| => write server key exchange
    ssl_tls12_server.c:3243: |2| <= skip write server key exchange
    ssl_tls12_server.c:4290: |2| server state: 5
    ssl_tls12_server.c:2432: |2| => write certificate request
    ssl_tls12_server.c:2445: |2| <= skip write certificate request
    ssl_tls12_server.c:4290: |2| server state: 6
    ssl_tls12_server.c:3314: |2| => write server hello done
    ssl_msg.c:0518: |3| update timeout value to 1000 millisecs
    ssl_msg.c:0291: |3| set_timer to 1000 ms
    ssl_msg.c:2643: |3| 0000:  02 00 00 4d 00 01 00 00 00 00 00 4d              ...M.......M
    ssl_msg.c:3032: |3| output record: msgtype = 22, version = [254:253], msglen = 89
    ssl_msg.c:3072: |2| Still 16282 bytes available in current datagram
    ssl_msg.c:2643: |3| 0000:  0e 00 00 00 00 02 00 00 00 00 00 00              ............
    ssl_msg.c:3032: |3| output record: msgtype = 22, version = [254:253], msglen = 12
    ssl_msg.c:3072: |2| Still 16257 bytes available in current datagram
    ssl_msg.c:2372: |2| message length: 25, out_left: 127
    ssl_msg.c:2379: |2| ssl->f_send() returned 127 (-0xffffff81)
    ssl_tls12_server.c:3341: |2| <= write server hello done
    ssl_tls12_server.c:4290: |2| server state: 7
    ssl_tls.c:7510: |2| => parse certificate
    ssl_tls.c:7514: |2| <= skip parse certificate
    ssl_tls12_server.c:4290: |2| server state: 8
    ssl_tls12_server.c:3639: |2| => parse client key exchange
    ssl_msg.c:4122: |2| => read record
    ssl_msg.c:4221: |2| => ssl_load_buffered_message
    ssl_msg.c:4289: |2| Next handshake message 2 not or only partially bufffered
    ssl_msg.c:4297: |2| <= ssl_load_buffered_message
    ssl_msg.c:2206: |2| in_left: 0, nb_want: 13
    ssl_msg.c:2245: |3| f_recv_timeout: 1000 ms
    ssl_msg.c:0324: |3| dumping 'record buffer' (103 bytes)
    ssl_msg.c:0324: |3| 0000:  16 fe fd 00 00 00 00 00 00 00 02 00 17 10 00 00  ................
    ssl_msg.c:0324: |3| 0010:  0b 00 02 00 00 00 00 00 0b 00 09 64 65 76 69 63  ...........devic
    ssl_msg.c:0324: |3| 0020:  65 30 30 31 14 fe fd 00 00 00 00 00 00 00 03 00  e001............
    ssl_msg.c:0324: |3| 0030:  01 01 16 fe fd 00 01 00 00 00 00 00 00 00 28 00  ..............(.
    ssl_msg.c:0324: |3| 0040:  01 00 00 00 00 00 00 05 9a 4a 52 25 26 c4 df 9f  .........JR%&...
    ssl_msg.c:0324: |3| 0050:  f9 f1 8e db 0e d3 17 c4 25 b4 23 fd 80 6c 1b ad  ........%.#..l..
    ssl_msg.c:0324: |3| 0060:  be d3 c1 20 60 f8 72                             ... `.r
    ssl_msg.c:3869: |3| input record: msgtype = 22, version = [0x303], msglen = 23
    ssl_msg.c:2254: |2| ssl->f_recv(_timeout)() returned 103 (-0xffffff99)
    ssl_msg.c:4864: |3| more than one record within datagram
    ssl_msg.c:3242: |3| handshake message: msglen = 23, type = 16, hslen = 23
    ssl_msg.c:4194: |2| <= read record
    ssl_tls.c:6529: |2| => derive keys
    ssl_tls.c:6512: |3| dumping 'premaster secret' (32 bytes)
    ssl_tls.c:6512: |3| 0000:  00 0e 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
    ssl_tls.c:6512: |3| 0010:  00 0e 73 75 70 65 72 73 65 63 72 65 74 6b 65 79  ..supersecretkey
    ssl_tls.c:8261: |3| ciphersuite = TLS-PSK-WITH-AES-128-CCM-8
    ssl_tls.c:8263: |3| dumping 'master secret' (48 bytes)
    ssl_tls.c:8263: |3| 0000:  0b ce c4 61 32 c1 20 11 77 92 bd 3c e0 9b a0 de  ...a2. .w..<....
    ssl_tls.c:8263: |3| 0010:  84 38 44 08 ee 85 16 a2 ea af 1a 88 4d 8b 79 84  .8D.........M.y.
    ssl_tls.c:8263: |3| 0020:  ce b2 dc d3 a2 35 99 0d 9f ce 2f de 76 76 12 0f  .....5..../.vv..
    ssl_tls.c:8385: |3| keylen: 16, minlen: 16, ivlen: 12, maclen: 0
    ssl_tls.c:6580: |2| <= derive keys
    ssl_tls12_server.c:4046: |2| <= parse client key exchange
    ssl_tls12_server.c:4290: |2| server state: 9
    ssl_tls12_server.c:4084: |2| => parse certificate verify
    ssl_tls12_server.c:4087: |2| <= skip parse certificate verify
    ssl_tls12_server.c:4290: |2| server state: 10
    ssl_msg.c:5146: |2| => parse change cipher spec
    ssl_msg.c:2195: |2| next record in same datagram, offset: 36
    ssl_msg.c:2206: |2| in_left: 67, nb_want: 13
    ssl_msg.c:3869: |3| input record: msgtype = 20, version = [0x303], msglen = 1
    ssl_msg.c:5167: |3| switching to new transform spec for inbound data
    ssl_msg.c:5194: |2| <= parse change cipher spec
    ssl_tls12_server.c:4290: |2| server state: 11
    ssl_tls.c:7968: |2| => parse finished
    ssl_tls.c:7688: |2| => calc finished tls
    ssl_tls.c:7715: |3| dumping 'calc finished result' (12 bytes)
    ssl_tls.c:7715: |3| 0000:  d0 ab 43 85 e8 fd 77 27 02 ed da 9b              ..C...w'....
    ssl_tls.c:7719: |2| <= calc finished
    ssl_msg.c:2195: |2| next record in same datagram, offset: 14
    ssl_msg.c:2206: |2| in_left: 53, nb_want: 13
    ssl_msg.c:3869: |3| input record: msgtype = 22, version = [0x303], msglen = 40
    ssl_msg.c:1514: |2| => decrypt buf
    ssl_msg.c:1650: |1| mbedtls_cipher_auth_decrypt_ext() returned -25344 (-0x6300)
    ssl_msg.c:3998: |1| ssl_decrypt_buf() returned -29056 (-0x7180)
    ssl_msg.c:5103: |2| => send alert message
    ssl_msg.c:5104: |3| send alert level=2 message=20
    ssl_msg.c:3032: |3| output record: msgtype = 21, version = [254:253], msglen = 2
    ssl_msg.c:2372: |2| message length: 15, out_left: 15
    ssl_msg.c:2379: |2| ssl->f_send() returned 15 (-0xfffffff1)
    ssl_msg.c:5115: |2| <= send alert message
    ssl_msg.c:4153: |1| ssl_get_next_record() returned -29056 (-0x7180)
    ssl_tls.c:7976: |1| mbedtls_ssl_read_record() returned -29056 (-0x7180)
     failed
      ! mbedtls_ssl_handshake returned -0x7180
    Last error was: -29056 - SSL - Verification of the message MAC failed
    Things seems to work till the end when I get the:
    error.
    Wireshark says:
    102	10.196838			LTE RRC BCCH_BCH	28	MasterInformationBlock (SFN=228)
    103	10.210754			LTE RRC DL_SCH	117	SystemInformationBlockType1
    104	10.266845			LTE RRC DL_SCH	103	SystemInformation [ SIB2 ]
    105	10.271911			NAS-EPS	118	Attach request, PDN connectivity request
    106	10.274200			LTE RRC UL_CCCH	30	RRCConnectionRequest
    107	10.313049			LTE RRC DL_CCCH	74	RRCConnectionSetup
    108	10.314422			LTE RRC UL_DCCH/NAS-EPS	137	RRCConnectionSetupComplete, Attach request, PDN connectivity request
    109	10.906128			LTE RRC DL_DCCH	27	SecurityModeCommand
    110	10.908020			LTE RRC UL_DCCH	26	SecurityModeComplete
    111	11.015106			LTE RRC DL_DCCH	55	UECapabilityEnquiry
    112	11.016967			LTE RRC UL_DCCH	150	UECapabilityInformation
    113	11.126342			LTE RRC DL_DCCH/NAS-EPS	260	RRCConnectionReconfiguration, Ciphered message
    114	11.128082			LTE RRC UL_DCCH	26	RRCConnectionReconfigurationComplete
    115	11.128540			NAS-EPS	189	Ciphered message, Attach accept, Activate default EPS bearer context request (PDN type IPv4 only allowed)
    116	11.129516			NAS-EPS	23	Attach complete, Activate default EPS bearer context accept
    117	11.129699			LTE RRC UL_DCCH/NAS-EPS	40	ULInformationTransfer, Ciphered message
    118	11.186157			LTE RRC DL_DCCH/NAS-EPS	54	DLInformationTransfer, Ciphered message
    119	11.186279			NAS-EPS	43	Ciphered message, EMM information
    120	11.246154			LTE RRC DL_DCCH	37	RRCConnectionReconfiguration
    121	11.246917			LTE RRC UL_DCCH	26	RRCConnectionReconfigurationComplete
    122	11.728393			AT	21	Sent AT Command: AT+CEREG?
    123	11.728576			AT	49	Rcvd AT Command: +CEREG: 0,1,"057D","01017406",7  OK
    124	11.729248	10.52.31.125	193.5.23.8	DNS	77	Standard query 0x2d90 A GIMSServer.mooo.com
    125	11.935974	193.5.23.8	10.52.31.125	DNS	93	Standard query response 0x2d90 A GIMSServer.mooo.com A 84.55.253.71
    126	11.941436	10.52.31.125	84.55.253.71	DTLS	176	Client Hello (SNI=GIMSServer.mooo.com)
    127	12.042328	84.55.253.71	10.52.31.125	DTLSv1.2	100	Hello Verify Request
    128	12.043243	10.52.31.125	84.55.253.71	DTLSv1.2	208	Client Hello (SNI=GIMSServer.mooo.com)
    129	12.167419	84.55.253.71	10.52.31.125	DTLSv1.2	167	Server Hello, Server Hello Done
    130	12.173523	10.52.31.125	84.55.253.71	DTLSv1.2	143	Client Key Exchange, Change Cipher Spec, Encrypted Handshake Message
    131	12.274414	84.55.253.71	10.52.31.125	DTLSv1.2	55	Alert (Level: Fatal, Description: Bad Record MAC)
    132	13.646393			LTE RRC DL_DCCH	38	RRCConnectionRelease [cause=other]
    133	13.750885			LTE RRC DL_SCH	117	SystemInformationBlockType1
    134	13.751526			LTE RRC DL_SCH	103	SystemInformation [ SIB2 ]
    2727.dtls_handshake_capture.pcapng
    As a  double check I also verified using gnutls. the result is the same handshake fails at the first encrypted message exchange. PSK in the modem is matching PSK used on the server.
    Joel
  • Strange.
    mbed_tls uses hex to pass in the secret to their demo-server, so that should work.
    But the MAC error in the Finish indicates, that somehow different psk are used. At least, that's one of the sources for MAC errors of the Finish, and in my experience as committer in Eclipse/Californium, it's the very most common one. Anyway, agreed, here the cause may be different.
    In general, I'm not aware of some interoperability issues in mbed_tls. In Eclipse/Californium I'm tracking that now for a couple of years. I use the ssl_server2, but I don't think, this makes a difference, If you like, provide your capture.
    But though you're using other one's implementation, I think, also others may be more helpful ;-).
    Edited: I had a short look at mbed_tls/programs/ssl/ssl_server, and now I have the feeling, that using ssl_server2 may make sense. But overall, that are questions to mbed_tls.
