AT%PERIODICSEARCHCONF=0,0,0,0,"1,20,600" - but with pretty low signals, I don't see more than one search
nRF9160, mfw 1.3.7, NCS 2.9.2
Case:
The modem first connects to LTE-M (Germany, band 3), pretty well.
Then the modem is moved into a building basement (band 8 or 20), with that the modem get's unregistered with the next sent message and starts one network search. That's not successful, maybe because of very low signals (-125 dBm and less), so also somehow OK. But then I don't detect any network search for 1h (instead of my configuration, which in my interpretation of the documentation should trigger new searchs after 10 minutes sleeps). After that hour, the device gives up and reboots ... and then after a couple of minutes (2-5) finds a network.
So, why does the modem not start the configured follow up network searches? Is there something as an optimization "no networks => no new search"?
(Unfortunately, I'm not able to provide modem-traces, at least that will be very, very complicated.)
  • No, there is not that kind of “no search” feature.
    If CFUN=0, CFUN=1 does not help either, it sounds like there is some kind of permanent prevention. Could it be Reset loop restriction? Have you subscribed %MDMEV?
  • > No, there is not that kind of “no search” feature.
    OK. Thanks for clarifying.
    No, not in my tests.
    It's unfortunately a custom board. There it's neither easy to get logs nor modem traces. I just kept some counters in "__noinit" to see, what was reported before the modem reboots.
    I guess, it will take some more tests to see, if reboot helps or just my tests (2 devices, about 20 tests in all) pretends, that it requires a reboot. We will see, even if that will take some time to come back with more experience.
