NRF5340 RTC0 can't got the interrupt.
    We are currently working on power optimization and want the device to wake up from the System ON state (PM_STATE_SUSPEND_TO_IDLE) using the RTC0 timer.
However, I found that when BLE is enabled, the RTC0 timer doesn’t seem to receive any interrupts back. Could you give me some suggestions?
Here is my sample code to use the counter API
struct counter_alarm_cfg alarm_cfg;
void rtc_callback(const struct device *dev, uint8_t chan_id, uint32_t ticks, void *user_data)
    ARG_UNUSED(dev);
    ARG_UNUSED(chan_id);
    ARG_UNUSED(ticks);
    ARG_UNUSED(user_data);
    usb_resume_devices();
    LOG_ERR("RTC wakeup event!\n");
    trans_deepsleep_to_standby();
    //deep_sleep_mode(false);
void setup_rtc_wakeup(void)
    int ret = 0;
    const struct device *rtc_dev = DEVICE_DT_GET(DT_NODELABEL(rtc0));
    if (!device_is_ready(rtc_dev)) {
        LOG_ERR("RTC device not ready\n");
        return;
    uint32_t now;
    counter_get_value(rtc_dev, &now);
    ret = counter_start(rtc_dev);
    if (ret == 0) {
        LOG_INF("counter_start ret =%d", ret);
    } else {
        LOG_ERR("counter_start setup err(%d)", ret);
    //k_sleep(K_MSEC(5));
    alarm_cfg.flags = 0;
    alarm_cfg.ticks = counter_us_to_ticks(rtc_dev, 2000000);
    alarm_cfg.callback = rtc_callback;
    alarm_cfg.user_data = &alarm_cfg;
    ret = counter_get_value(rtc_dev, &now);
    LOG_INF("RTC before sleep: %u us", counter_ticks_to_us(rtc_dev, now));
    ret = counter_set_channel_alarm(rtc_dev, 0, &alarm_cfg);
     if (ret == 0) {
        LOG_INF("counter_set_channel_alarm ret =%d", ret);
    } else {
        LOG_ERR("counter_set_channel_alarm setup err(%d)", ret);
    k_msleep(3000);
    printk("RTC value: %u us\n", counter_ticks_to_us(rtc_dev, now));
prj.conf
CONFIG_BT=y
CONFIG_BT_PERIPHERAL=y
CONFIG_COUNTER=y
CONFIG_COUNTER_LOG_LEVEL_INF=y
CONFIG_RTC=y
CONFIG_RTC_UPDATE=y
CONFIG_RTC_CALIBRATION=y
CONFIG_RTC_ALARM=y
Stanly
        Around 6.2mA. I follow the instruction to reduce the power consumption
    you can see the below code.
    1. set app core freq 128mHz to 64mhz.
    2. set the i2c bus, spi and i2s to suspend mode.
    3. set the BLE tx power to -20dbm.
    4. cut the unuse ram power.
    5. set the qspi external flash to suspend mode.
    here is my code:(doing a lot of thing for reducing the power consumption)
    if(suspend){
            cpu_freq_64mhz();
           // k_timer_start(&m_sleep_timer, K_SECONDS(5), K_SECONDS(0));
            ret = pm_device_action_run(i2c0_dev, PM_DEVICE_ACTION_SUSPEND);
            LOG_INF("I2C0 bus suspend -> %d\n", ret);
            ret = pm_device_action_run(i2c1_dev, PM_DEVICE_ACTION_SUSPEND);
            LOG_INF("I2C1 bus suspend -> %d\n", ret);
            ret = pm_device_action_run(i2c2_dev, PM_DEVICE_ACTION_SUSPEND);
            LOG_INF( "I2C2 bus suspend -> %d\n", ret);
            ret = pm_device_action_run(i2c3_dev, PM_DEVICE_ACTION_SUSPEND);
            LOG_INF( "I2C3 bus suspend -> %d\n", ret);
            //ret = pm_device_action_run(i2s_dev, PM_DEVICE_ACTION_SUSPEND);
            nrf_i2s_disable(NRF_I2S0);
            ret = pinctrl_apply_state(i2s_dev->config, PINCTRL_STATE_SLEEP);
            LOG_INF( "I2S bus suspend -> %d\n", ret);
            ret = pm_device_action_run(spi4_dev, PM_DEVICE_ACTION_SUSPEND);
            LOG_INF( "SPI4 bus suspend -> %d\n", ret);
            ret = bt_hci_get_conn_handle(get_bt_conn(), &conn_handle);
            set_tx_power(BT_HCI_VS_LL_HANDLE_TYPE_CONN, conn_handle, -20);
            power_down_unused_ram();
            ret = pm_device_action_run(qspi_dev, PM_DEVICE_ACTION_SUSPEND);
            LOG_INF("qspi flash suspend -> %d\n", ret);
    Stanly
  • Hi Stanly,
    You're doing several things which are not necessary. As a test to verify your setup, I suggest you try the "Hello world" sample with CONFIG_SERIAL set to "=n" and see if you are able to measure the expected System ON idle current then.
    Vidar
