iOS BLE cannot correctly read the model number.
After updating from SDK V2.1.3 OTA to SDK V2.9.0, iOS cannot correctly read data such as the model number, but Android can read it normally.
Turn off Bluetooth in the system, turn it back on, and it can be read normally after connecting.
  • Hi Leo,
    I see. Have you done any other changes? When I build the 2.1.3 project it fails to build during linking where it cannot find mcuboot_status_change() This is while using your custom board in the project folder(called nrf52840dk_nrf52840):
    [201/211] Linking C executable zephyr/zephyr_pre0.elf
    FAILED: zephyr/zephyr_pre0.elf zephyr/zephyr_pre0.map
    : && ccache /opt/nordic/ncs/toolchains/v2.1.3/opt/zephyr-sdk/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc   zephyr/CMakeFiles/zephyr_pre0.dir/misc/empty_file.c.obj -o zephyr/zephyr_pre0.elf  -fuse-ld=bfd  -Wl,-T  zephyr/linker_zephyr_pre0.cmd  -Wl,-Map=/Users/eith/Downloads/peripheral_ancs_client_2_1_3/build/mcuboot/zephyr/zephyr_pre0.map  -Wl,--whole-archive  app/libapp.a  zephyr/libzephyr.a  zephyr/arch/common/libarch__common.a  zephyr/arch/arch/arm/core/aarch32/libarch__arm__core__aarch32.a  zephyr/arch/arch/arm/core/aarch32/cortex_m/libarch__arm__core__aarch32__cortex_m.a  zephyr/arch/arch/arm/core/aarch32/mpu/libarch__arm__core__aarch32__mpu.a  zephyr/lib/libc/minimal/liblib__libc__minimal.a  zephyr/lib/posix/liblib__posix.a  zephyr/soc/arm/common/cortex_m/libsoc__arm__common__cortex_m.a  zephyr/soc/arm/nordic_nrf/nrf52/libsoc__arm__nordic_nrf__nrf52.a  zephyr/drivers/clock_control/libdrivers__clock_control.a  zephyr/drivers/console/libdrivers__console.a  zephyr/drivers/gpio/libdrivers__gpio.a  zephyr/drivers/flash/libdrivers__flash.a  zephyr/drivers/serial/libdrivers__serial.a  zephyr/drivers/timer/libdrivers__timer.a  zephyr/drivers/pinctrl/libdrivers__pinctrl.a  modules/nrf/lib/fatal_error/lib..__nrf__lib__fatal_error.a  modules/nrf/drivers/hw_cc310/lib..__nrf__drivers__hw_cc310.a  modules/mcuboot/boot/bootutil/zephyr/libmcuboot_util.a  modules/hal_nordic/nrfx/libmodules__hal_nordic__nrfx.a  modules/segger/libmodules__segger.a  -Wl,--no-whole-archive  zephyr/kernel/libkernel.a  zephyr/CMakeFiles/offsets.dir/./arch/arm/core/offsets/offsets.c.obj  -L"/opt/nordic/ncs/toolchains/v2.1.3/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/10.3.0/thumb/v7e-m+fp/hard"  -L/Users/eith/Downloads/peripheral_ancs_client_2_1_3/build/mcuboot/zephyr  -lgcc  zephyr/arch/common/libisr_tables.a  -no-pie  -mcpu=cortex-m4  -mthumb  -mabi=aapcs  -mfpu=fpv4-sp-d16  -mfp16-format=ieee  -Wl,--gc-sections  -Wl,--build-id=none  -Wl,--sort-common=descending  -Wl,--sort-section=alignment  -Wl,-u,_OffsetAbsSyms  -Wl,-u,_ConfigAbsSyms  -nostdlib  -static  -Wl,-X  -Wl,-N  -Wl,--orphan-handling=warn  /opt/nordic/ncs/v2.1.3/nrfxlib/crypto/nrf_cc310_platform/lib/cortex-m4/hard-float/no-interrupts/libnrf_cc310_platform_0.9.15.a  /opt/nordic/ncs/v2.1.3/nrfxlib/crypto/nrf_cc310_bl/lib/cortex-m4/hard-float/no-interrupts/libnrf_cc310_bl_0.9.12.a && cd /Users/eith/Downloads/peripheral_ancs_client_2_1_3/build/mcuboot/zephyr && /opt/nordic/ncs/toolchains/v2.1.3/Cellar/cmake/3.20.5/bin/cmake -E echo
    /opt/nordic/ncs/toolchains/v2.1.3/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/10.3.0/../../../../arm-zephyr-eabi/bin/ld.bfd: app/libapp.a(main.c.obj): in function `main':
    /opt/nordic/ncs/v2.1.3/bootloader/mcuboot/boot/zephyr/main.c:545: undefined reference to `mcuboot_status_change'
    /opt/nordic/ncs/toolchains/v2.1.3/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/10.3.0/../../../../arm-zephyr-eabi/bin/ld.bfd: /opt/nordic/ncs/v2.1.3/bootloader/mcuboot/boot/zephyr/main.c:622: undefined reference to `mcuboot_status_change'
    /opt/nordic/ncs/toolchains/v2.1.3/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/10.3.0/../../../../arm-zephyr-eabi/bin/ld.bfd: /opt/nordic/ncs/v2.1.3/bootloader/mcuboot/boot/zephyr/main.c:636: undefined reference to `mcuboot_status_change'
    /opt/nordic/ncs/toolchains/v2.1.3/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/10.3.0/../../../../arm-zephyr-eabi/bin/ld.bfd: /opt/nordic/ncs/v2.1.3/bootloader/mcuboot/boot/zephyr/main.c:667: undefined reference to `mcuboot_status_change'
    /opt/nordic/ncs/toolchains/v2.1.3/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/10.3.0/../../../../arm-zephyr-eabi/bin/ld.bfd: app/libapp.a(loader.c.obj): in function `context_boot_go':
    /opt/nordic/ncs/v2.1.3/bootloader/mcuboot/boot/bootutil/src/loader.c:2112: undefined reference to `mcuboot_status_change'
    collect2: error: ld returned 1 exit status
    [235/298] Building C object zephyr/kernel/CMakeFiles/kernel.dir/fatal.c.obj
    FAILED: modules/mcuboot/mcuboot_subimage-prefix/src/mcuboot_subimage-stamp/mcuboot_subimage-build mcuboot/zephyr/zephyr.hex mcuboot/zephyr/zephyr.elf
    cd /Users/eith/Downloads/peripheral_ancs_client_2_1_3/build/mcuboot && /opt/nordic/ncs/toolchains/v2.1.3/Cellar/cmake/3.20.5/bin/cmake --build . --
    [251/298] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v2.1.3/modules/hal/nordic/nrfx/drivers/src/nrfx_ppi.c.obj
    FATAL ERROR: command exited with status 1: /opt/nordic/ncs/toolchains/v2.1.3/bin/cmake --build /Users/eith/Downloads/peripheral_ancs_client_2_1_3/build
    Can you see if you have done any changes to the SDK? And perhaps download a fresh 2.1.3 and build with that? I would like to be able to build both your project without any changes so that I know I am testing the same as you.
  • Hi Einar,
    Can you see this file?
    boards\arm\nrf52840dk_nrf52840\mcuboot_hook.c
    Make sure you used custom nrf52840dk_nrf52840 board.
    I am able to test and I reproduce the issue. I have not been able to find the root cause or resolve it, but will look into this again after the holidays. I apologize for the delay.
    PS: That "custom" radio button only affect the list in nRF Connect for VS Code, the build command refers to the board by name. So using the same name for two boards can cause problems. I did remove the dk files from the SDK but still had build problems, so that is why I wonder if there are other changes. I did make the 2.1.3 project build by setting CONFIG_MCUBOOT_ACTION_HOOKS=n, as it is anyway an empty implementation. As I reproduce the issue now I will ignore i, but as a side noe, I strongly recommend naming your custom board differently as having multiple boards with the same name is not supported (if you migrate to SDK 3.0 or higher later you will need to migrate to hardware model 2, where you anyway need to rename the board).
  • Hi Einar,
    I'm glad to hear this news.
    This 'CONFIG_MCUBOOT_ACTION_HOOKS' can indeed be set to 'n'.
    As for the board names, I just used NRF52840DK here; the others are the actual names of our boards.
    BR,
    Leo Mo
