MCUboot external signing script - SIGNING_SCRIPT Variable Bug in nRF
Hi All,
I am currently working on an project with the nRF9151 using the nRF SDK v3.1.1 and MCUboot and I need to sign my application images using an external HSM.
I am using sysbuild and set -Dapplication_SIGNING_SCRIPT (my image is called application) as defined by https://docs.nordicsemi.com/bundle/ncs-3.1.1/page/zephyr/build/signing/index.html#extending_signing_externally.
My script was never called and after some testing I found out, that in "sysbuild/CMakeLists.txt" the variable is always overwritten to the default without checking if a custom signing script is selected. See CMakeLists.txt on Github. Is this the expected behavior or is there a workaround or different solution? I do not like to modify the nRF SDK directly.
If this is the problem it may also help to solve RE: Signing script not working as expected and RE: Application with MCUBoot and external signature.
Martin
