Why 10 KB payload takes ~6 seconds, but 6 bytes takes ~1 second
 * Copyright (c) 2023 Lucas Dietrich <[email protected]>
#include "creds/creds.h"
#include "dhcp.h"
#include <errno.h>
#include <stdio.h>
#include <stdlib.h>
#include <zephyr/net/socket.h>
#include <zephyr/net/dns_resolve.h>
#include <zephyr/net/mqtt.h>
#include <zephyr/net/sntp.h>
#include <zephyr/net/tls_credentials.h>
#include <zephyr/random/random.h>
#include <zephyr/posix/time.h>
#include <zephyr/kernel.h>
#if defined(CONFIG_MBEDTLS_MEMORY_DEBUG)
#include <mbedtls/memory_buffer_alloc.h>
#include <modem/nrf_modem_lib.h>
#include <modem/lte_lc.h>
static K_SEM_DEFINE(lte_connected, 0, 1);
LOG_MODULE_REGISTER(aws, LOG_LEVEL_DBG);
// #define SNTP_SERVER "0.pool.ntp.org"
#define SNTP_SERVER "pool.ntp.org"
#define AWS_BROKER_PORT CONFIG_AWS_MQTT_PORT
#define MQTT_RX_BUFFER_SIZE 512u
#define MQTT_TX_BUFFER_SIZE 512u
#define APP_BUFFER_SIZE	 256u
#define MAX_RETRIES	    10u
#define BACKOFF_EXP_BASE_MS 1000u
#define BACKOFF_EXP_MAX_MS  60000u
#define BACKOFF_CONST_MS    5000u
static struct sockaddr_in aws_broker;
static uint8_t rx_buffer[MQTT_RX_BUFFER_SIZE];
static uint8_t tx_buffer[MQTT_TX_BUFFER_SIZE];
static uint8_t buffer[APP_BUFFER_SIZE]; /* Shared between published and received messages */
static struct mqtt_client client_ctx;
static const char mqtt_client_name[] = CONFIG_AWS_THING_NAME;
static bool do_publish;	  /* Trigger client to publish */
static bool do_subscribe; /* Trigger client to subscribe */
#if (CONFIG_AWS_MQTT_PORT == 443 && !defined(CONFIG_MQTT_LIB_WEBSOCKET))
static const char * const alpn_list[] = {"x-amzn-mqtt-ca"};
static const sec_tag_t sec_tls_tags[] = { 212 };
static int subscribe_topic(void)
	int ret;
	struct mqtt_topic topics[] = {{
		.topic = {.utf8 = CONFIG_AWS_SUBSCRIBE_TOPIC,
			  .size = strlen(CONFIG_AWS_SUBSCRIBE_TOPIC)},
		.qos = CONFIG_AWS_QOS,
	const struct mqtt_subscription_list sub_list = {
		.list = topics,
		.list_count = ARRAY_SIZE(topics),
		.message_id = 1u,
	LOG_INF("Subscribing to %hu topic(s)", sub_list.list_count);
	ret = mqtt_subscribe(&client_ctx, &sub_list);
	if (ret != 0) {
		LOG_ERR("Failed to subscribe to topics: %d", ret);
	return ret;
static int publish_message(const char *topic, size_t topic_len, uint8_t *payload,
			   size_t payload_len)
	static uint32_t message_id = 1u;
	int ret;
	struct mqtt_publish_param msg;
	msg.retain_flag = 0u;
	msg.message.topic.topic.utf8 = topic;
	msg.message.topic.topic.size = topic_len;
	msg.message.topic.qos = CONFIG_AWS_QOS;
	msg.message.payload.data = payload;
	msg.message.payload.len = payload_len;
	msg.message_id = message_id++;
 for (int i = 0; i < 3; i++)
	 ret = mqtt_publish(&client_ctx, &msg);
	if (ret != 0) {
		LOG_ERR("Failed to publish message: %d", ret);
	LOG_INF("PUBLISHED on topic \"%s\" [ id: %u qos: %u ], payload: %u B", topic,
		msg.message_id, msg.message.topic.qos, payload_len);
		k_msleep(100);
	return ret;
static ssize_t handle_published_message(const struct mqtt_publish_param *pub)
	int ret;
	size_t received = 0u;
	const size_t message_size = pub->message.payload.len;
	LOG_INF("RECEIVED on topic \"%s\" [ id: %u qos: %u ] payload: %u B",
		(const char *)pub->message.topic.topic.utf8, pub->message_id,
		pub->message.topic.qos, message_size);
	while (received < message_size) {
		size_t to_read = MIN(message_size - received, sizeof(buffer));
		ret = mqtt_read_publish_payload_blocking(&client_ctx, buffer, to_read);
		if (ret < 0) {
			return ret;
		} else if (ret == 0) {
		received += ret;
		LOG_HEXDUMP_DBG(buffer, ret, "Received payload:");
	/* Send ACK */
	switch (pub->message.topic.qos) {
	case MQTT_QOS_1_AT_LEAST_ONCE: {
		struct mqtt_puback_param puback;
		puback.message_id = pub->message_id;
		mqtt_publish_qos1_ack(&client_ctx, &puback);
	} break;
	case MQTT_QOS_2_EXACTLY_ONCE: /* unhandled (not supported by AWS) */
	case MQTT_QOS_0_AT_MOST_ONCE: /* nothing to do */
	return received;
const char *mqtt_evt_type_to_str(enum mqtt_evt_type type)
	static const char *const types[] = {
		"CONNACK", "DISCONNECT", "PUBLISH", "PUBACK",	"PUBREC",
		"PUBREL",  "PUBCOMP",	 "SUBACK",  "UNSUBACK", "PINGRESP",
	return (type < ARRAY_SIZE(types)) ? types[type] : "<unknown>";
static void mqtt_event_cb(struct mqtt_client *client, const struct mqtt_evt *evt)
	LOG_DBG("MQTT event: %s [%u] result: %d", mqtt_evt_type_to_str(evt->type), evt->type,
		evt->result);
	switch (evt->type) {
	case MQTT_EVT_CONNACK: {
		do_subscribe = true;
	} break;
	case MQTT_EVT_PUBLISH: {
		const struct mqtt_publish_param *pub = &evt->param.publish;
		handle_published_message(pub);
	} break;
	case MQTT_EVT_SUBACK: {
		do_publish = true;
	} break;
	case MQTT_EVT_PUBACK:
	case MQTT_EVT_DISCONNECT:
	case MQTT_EVT_PUBREC:
	case MQTT_EVT_PUBREL:
	case MQTT_EVT_PUBCOMP:
	case MQTT_EVT_PINGRESP:
	case MQTT_EVT_UNSUBACK:
static void aws_client_setup(void)
	mqtt_client_init(&client_ctx);
	client_ctx.broker = &aws_broker;
	client_ctx.evt_cb = mqtt_event_cb;
	client_ctx.client_id.utf8 = (uint8_t *)mqtt_client_name;
	client_ctx.client_id.size = sizeof(mqtt_client_name) - 1;
	client_ctx.password = NULL;
	client_ctx.user_name = NULL;
	client_ctx.keepalive = CONFIG_MQTT_KEEPALIVE;
	client_ctx.protocol_version = MQTT_VERSION_3_1_1;
	client_ctx.rx_buf = rx_buffer;
	client_ctx.rx_buf_size = sizeof(rx_buffer);
	client_ctx.tx_buf = tx_buffer;
	client_ctx.tx_buf_size = sizeof(tx_buffer);
	/* setup TLS */
	client_ctx.transport.type = MQTT_TRANSPORT_SECURE;
	struct mqtt_sec_config *const tls_config = &client_ctx.transport.tls.config;
	tls_config->peer_verify = TLS_PEER_VERIFY_REQUIRED;
	tls_config->cipher_list = NULL;
	tls_config->sec_tag_list = sec_tls_tags;
	tls_config->sec_tag_count = ARRAY_SIZE(sec_tls_tags);
	tls_config->hostname = CONFIG_AWS_ENDPOINT;
	tls_config->cert_nocopy = TLS_CERT_NOCOPY_NONE;
	tls_config->alpn_protocol_name_list = alpn_list;
	tls_config->alpn_protocol_name_count = ARRAY_SIZE(alpn_list);
struct backoff_context {
	uint16_t retries_count;
	uint16_t max_retries;
#if defined(CONFIG_AWS_EXPONENTIAL_BACKOFF)
	uint32_t attempt_max_backoff; /* ms */
	uint32_t max_backoff;	      /* ms */
static void backoff_context_init(struct backoff_context *bo)
	__ASSERT_NO_MSG(bo != NULL);
	bo->retries_count = 0u;
	bo->max_retries = MAX_RETRIES;
	bo->attempt_max_backoff = BACKOFF_EXP_BASE_MS;
	bo->max_backoff = BACKOFF_EXP_MAX_MS;
static void backoff_get_next(struct backoff_context *bo, uint32_t *next_backoff_ms)
	__ASSERT_NO_MSG(next_backoff_ms != NULL);
	if (bo->retries_count <= bo->max_retries) {
		*next_backoff_ms = sys_rand32_get() % (bo->attempt_max_backoff + 1u);
		/* Calculate max backoff for the next attempt (~ 2**attempt) */
		bo->attempt_max_backoff = MIN(bo->attempt_max_backoff * 2u, bo->max_backoff);
		bo->retries_count++;
#else
	*next_backoff_ms = BACKOFF_CONST_MS;
static int aws_client_try_connect(void)
	int ret;
	uint32_t backoff_ms;
	struct backoff_context bo;
	backoff_context_init(&bo);
	while (bo.retries_count <= bo.max_retries) {
		ret = mqtt_connect(&client_ctx);
		if (ret == 0) {
			goto exit;
		backoff_get_next(&bo, &backoff_ms);
		LOG_ERR("Failed to connect: %d backoff delay: %u ms", ret, backoff_ms);
		k_msleep(backoff_ms);
exit:
	return ret;
// static const char publish_payload[] = "aaaaaaaaaaaaaaaaaAAAAAaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaAAAAAaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaAAAAAaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaAAAAAaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaAAAAAaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaAAAAAaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaAAAAAaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaAAAAAaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaAAAAAaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaAAAAAaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaAAAAAaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaAAAAAaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaAAAAAaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaAAAAAaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaAAAAAaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaAAAAAaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaAAAAAaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaAAAAAaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaAAAAAaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaAAAAAaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaAAAAAaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaAAAAAaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaAAAAAaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaAAAAAaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaAAAAAaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaAAAAAaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaAAAAAaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaAAAAAaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaAAAAAaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaAAAAAaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaAAAAAaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaAAAAAaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaAAAAAaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaAAAAAaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaAAAAAaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaAAAAAaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaAAAAAaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaAAAAAaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaAAAAAaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaAAAAAaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaAAAAAaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaAAAAAaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaAAAAAaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaAAAAAaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaAAAAAaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaAAAAAaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaAAAAAaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaAAAAAaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaAAAAAaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaAAAAAaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaAAAAAaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaAAAAAaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaAAAAAaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaAAAAAaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaAAAAAaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaAAAAAaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaAAAAAaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaAAAAAaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaAAAAAaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaAAAAAaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaAAAAAaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaAAAAAaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaAAAAAaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaAAAAAaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaAAAAAaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaAAAAAaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaAAAAAaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaAAAAAaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaAAAAAaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaAAAAAaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaAAAAAaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaAAAAAaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaAAAAAaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaAAAAAaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaAAAAAaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaAAAAAaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaAAAAAaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaAAAAAaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaAAAAAaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaAAAAAaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaAAAAAaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaAAAAAaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaAAAAAaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaAAAAAaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaAAAAAaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaAAAAAaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaAAAAAaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaAAAAAaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaAAAAAaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaAAAAAaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaAAAAAaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaAAAAAaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaAAAAAaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaAAAAAaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaAAAAAaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaAAAAAaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaAAAAAaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaAAAAAaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaAAAAAaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaAAAAAaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaAAAAAaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaAAAAAaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaAAAAAaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaAAAAAaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaAAAAAaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaAAAAAaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaAAAAAaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaAAAAAaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaAAAAAaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaAAAAAaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaAAAAAaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaAAAAAaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaAAAAAaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaAAAAAaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaAAAAAaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaAAAAAaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaAAAAAaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaAAAAAaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaAAAAAaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaAAAAAaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaAAAAAaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaAAAAAaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaAAAAAaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaAAAAAaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaAAAAAaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaAAAAAaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaAAAAAaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaAAAAAaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaAAAAAaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaAAAAAaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaAAAAAaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaAAAAAaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaAAAAAaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaAAAAAaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaAAAAAaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaAAAAAaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaAAAAAaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaAAAAAaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaAAAAAaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaAAAAAaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaAAAAAaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaAAAAAaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaAAAAAaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaAAAAAaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaAAAAAaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaAAAAAaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaAAAAAaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaAAAAAaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaAAAAAaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa00000000000";
static const char publish_payload[] = "aaaaaa";
static int publish(void)
	// LOG_INF("%s", buffer);
	return publish_message(CONFIG_AWS_PUBLISH_TOPIC, strlen(CONFIG_AWS_PUBLISH_TOPIC), (uint8_t *)publish_payload,
			       strlen(publish_payload));
void aws_client_loop(void)
	int rc;
	int timeout;
	struct pollfd fds;
	static int64_t last_publish = 0;
	aws_client_setup();
	rc = aws_client_try_connect();
	if (rc != 0) {
		goto cleanup;
	fds.fd = client_ctx.transport.tcp.sock;
	fds.events = POLLIN;
	for (;;) {
		timeout = mqtt_keepalive_time_left(&client_ctx);
		rc = poll(&fds, 1u, timeout);
		if (rc >= 0) {
			if (fds.revents & POLLIN) {
				rc = mqtt_input(&client_ctx);
				if (rc != 0) {
					LOG_ERR("Failed to read MQTT input: %d", rc);
			if (fds.revents & (POLLHUP | POLLERR)) {
				LOG_ERR("Socket closed/error");
			rc = mqtt_live(&client_ctx);
			if ((rc != 0) && (rc != -EAGAIN)) {
				LOG_ERR("Failed to live MQTT: %d", rc);
		} else {
			LOG_ERR("poll failed: %d", rc);
		if (do_publish) {
			do_publish = false;
			publish();
			last_publish = k_uptime_get();
		if (do_subscribe) {
			do_subscribe = false;
			subscribe_topic();
		if (!do_publish && !do_subscribe) {
			int64_t now = k_uptime_get();
			if (now - last_publish >= 1000) {
				do_publish = true;
cleanup:
	mqtt_disconnect(&client_ctx);
	close(fds.fd);
	fds.fd = -1;
static int resolve_broker_addr(struct sockaddr_in *broker)
	int ret;
	struct addrinfo *ai = NULL;
	const struct addrinfo hints = {
		.ai_family = AF_INET,
		.ai_socktype = SOCK_STREAM,
		.ai_protocol = 0,
	char port_string[6] = {0};
	sprintf(port_string, "%d", AWS_BROKER_PORT);
	ret = getaddrinfo(CONFIG_AWS_ENDPOINT, port_string, &hints, &ai);
	if (ret == 0) {
		char addr_str[INET_ADDRSTRLEN];
		memcpy(broker, ai->ai_addr, MIN(ai->ai_addrlen, sizeof(struct sockaddr_storage)));
		inet_ntop(AF_INET, &broker->sin_addr, addr_str, sizeof(addr_str));
		LOG_INF("Resolved: %s:%u", addr_str, htons(broker->sin_port));
	} else {
		LOG_ERR("failed to resolve hostname err = %d (errno = %d)", ret, errno);
	freeaddrinfo(ai);
	return ret;
static void lte_handler(const struct lte_lc_evt *const evt)
    switch (evt->type)
    case LTE_LC_EVT_NW_REG_STATUS:
        if ((evt->nw_reg_status != LTE_LC_NW_REG_REGISTERED_HOME) &&
            (evt->nw_reg_status != LTE_LC_NW_REG_REGISTERED_ROAMING))
        LOG_INF("Network registration status: %s",
               evt->nw_reg_status == LTE_LC_NW_REG_REGISTERED_HOME ? "Connected - home network" : "Connected - roaming");
        k_sem_give(&lte_connected);
    case LTE_LC_EVT_RRC_UPDATE:
        LOG_INF("RRC mode: %s", evt->rrc_mode == LTE_LC_RRC_MODE_CONNECTED ? "Connected" : "Idle");
static int modem_configure(void)
    int err = nrf_modem_lib_init();
    if (err) {
        return err;
    err = lte_lc_connect_async(lte_handler);
    if (err) {
        return err;
    k_sem_take(&lte_connected, K_FOREVER);
    return 0;
	modem_configure();
#if defined(CONFIG_NET_DHCPV4)
	app_dhcpv4_startup();
	for (;;) {
		resolve_broker_addr(&aws_broker);
		aws_client_loop();
		size_t cur_used, cur_blocks, max_used, max_blocks;
		mbedtls_memory_buffer_alloc_cur_get(&cur_used, &cur_blocks);
		mbedtls_memory_buffer_alloc_max_get(&max_used, &max_blocks);
		LOG_INF("mbedTLS heap usage: MAX %u/%u (%u) CUR %u (%u)", max_used,
			CONFIG_MBEDTLS_HEAP_SIZE, max_blocks, cur_used, cur_blocks);
		k_sleep(K_SECONDS(1));
	return 0;
CONFIG_AWS_IOT_LOG_LEVEL_DBG=y
CONFIG_AWS_TEST_SUITE_DQP=n
CONFIG_MAIN_STACK_SIZE=8192
CONFIG_ENTROPY_GENERATOR=y
CONFIG_TEST_RANDOM_GENERATOR=y
CONFIG_INIT_STACKS=y
CONFIG_HW_STACK_PROTECTION=y
CONFIG_REQUIRES_FULL_LIBC=y
CONFIG_SNTP=y
CONFIG_JSON_LIBRARY=y
CONFIG_POSIX_API=y
# DNS
CONFIG_DNS_RESOLVER=y
CONFIG_DNS_RESOLVER_ADDITIONAL_BUF_CTR=2
CONFIG_DNS_RESOLVER_MAX_SERVERS=1
CONFIG_DNS_SERVER_IP_ADDRESSES=y
CONFIG_DNS_SERVER1="8.8.8.8"
CONFIG_NET_SOCKETS_DNS_TIMEOUT=5000
CONFIG_DNS_RESOLVER_LOG_LEVEL_DBG=n
# Generic networking options
CONFIG_NETWORKING=y
CONFIG_NET_UDP=y
CONFIG_NET_TCP=y
CONFIG_NET_IPV6=y
CONFIG_NET_IPV4=y
CONFIG_NET_SOCKETS=y
CONFIG_NET_SOCKETS_SOCKOPT_TLS=y
# Logging
CONFIG_LOG=y
# Network buffers
CONFIG_NET_PKT_RX_COUNT=32
CONFIG_NET_PKT_TX_COUNT=16
CONFIG_NET_BUF_RX_COUNT=64
CONFIG_NET_BUF_TX_COUNT=32
# MQTT
CONFIG_MQTT_LIB=y
CONFIG_MQTT_LIB_TLS=y
CONFIG_MQTT_KEEPALIVE=600
CONFIG_MQTT_LIB_TLS_USE_ALPN=y
# TLS
CONFIG_NRF_SECURITY=y
CONFIG_MBEDTLS_TLS_LIBRARY=y
CONFIG_MBEDTLS_LEGACY_CRYPTO_C=y
CONFIG_MBEDTLS_ENABLE_HEAP=y
CONFIG_MBEDTLS_HEAP_SIZE=10240
CONFIG_MBEDTLS_SSL_MAX_CONTENT_LEN=10240
CONFIG_MBEDTLS_PEM_CERTIFICATE_FORMAT=y
CONFIG_MBEDTLS_SERVER_NAME_INDICATION=y
CONFIG_MBEDTLS_AES_ROM_TABLES=y
CONFIG_MBEDTLS_TLS_VERSION_1_2=y
CONFIG_MBEDTLS_MEMORY_DEBUG=y
CONFIG_MBEDTLS_HAVE_TIME_DATE=y
CONFIG_MBEDTLS_SSL_ALPN=y
CONFIG_MBEDTLS_SSL_CLI_C=y
CONFIG_MBEDTLS_X509_CRT_PARSE_C=y
CONFIG_MBEDTLS_KEY_EXCHANGE_ECDHE_ECDSA_ENABLED=y
CONFIG_MBEDTLS_KEY_EXCHANGE_ECDH_ECDSA_ENABLED=y
CONFIG_MBEDTLS_KEY_EXCHANGE_PSK_ENABLED=y
CONFIG_MBEDTLS_KEY_EXCHANGE_ECDHE_PSK_ENABLED=y
CONFIG_MBEDTLS_SSL_SRV_C=y
CONFIG_MBEDTLS_KEY_EXCHANGE_RSA_ENABLED=y
CONFIG_HEAP_MEM_POOL_SIZE=8192
CONFIG_MBEDTLS_CIPHER=y
CONFIG_MBEDTLS_MD=y
# Required mbedTLS dependencies
CONFIG_MBEDTLS_PK_C=y
CONFIG_MBEDTLS_PK_PARSE_C=y
CONFIG_MBEDTLS_PK_WRITE_C=y
CONFIG_MBEDTLS_RSA_C=y
CONFIG_MBEDTLS_PKCS1_V15=y
CONFIG_MBEDTLS_ECP_C=y
CONFIG_MBEDTLS_ECDSA_C=y
CONFIG_MBEDTLS_ECDH_C=y
CONFIG_MBEDTLS_DHM_C=y
CONFIG_MBEDTLS_GCM_C=y
CONFIG_MBEDTLS_SHA256_C=y
CONFIG_MBEDTLS_X509_USE_C=y
CONFIG_MBEDTLS_SSL_CONTEXT_SERIALIZATION=y
CONFIG_MBEDTLS_SSL_PROTO_TLS1_2=y
CONFIG_CONSOLE=n #for wifi uart keep this n
CONFIG_USE_SEGGER_RTT=y
CONFIG_RTT_CONSOLE=y
CONFIG_LOG_BACKEND_RTT=y
CONFIG_LOG_BACKEND_UART=n
CONFIG_UART_CONSOLE=n
CONFIG_NRF_MODEM_LIB=y
CONFIG_LTE_LINK_CONTROL=y
# Let the modem handle sockets, DNS, and SNTP
CONFIG_NET_NATIVE=n
CONFIG_NET_SOCKETS_OFFLOAD=y
CONFIG_SNTP_LOG_LEVEL_DBG=y
in nrf 9151 and sdk 2.9.0
we use cellular with aws
but here when we publish 10KB payload it take 6 sec and 6 byte payload take 1 sec so what we need to change for fast transmission
log:
00> [00:01:14.933,380] <inf> aws: RRC mode: Connected
00> [00:01:24.036,407] <inf> aws: Network registration status: Connected - roaming
00> [00:01:24.459,625] <inf> aws: Resolved: 3.111.212.253:8883
00> [00:01:32.697,906] <dbg> aws: mqtt_event_cb: MQTT event: CONNACK [0] result: 0
00> [00:01:32.697,967] <inf> aws: Subscribing to 1 topic(s)
00> [00:01:33.297,943] <dbg> aws: mqtt_event_cb: MQTT event: SUBACK [7] result: 0
00> [00:01:39.516,448] <inf> aws: PUBLISHED on topic "zephyr_sample/data" [ id: 1 qos: 0 ], payload: 9319 B
00> [00:01:45.363,739] <inf> aws: PUBLISHED on topic "zephyr_sample/data" [ id: 1 qos: 0 ], payload: 9319 B
00> [00:01:52.676,635] <inf> aws: PUBLISHED on topic "zephyr_sample/data" [ id: 1 qos: 0 ], payload: 9319 B
00> [00:02:24.236,785] <inf> aws: RRC mode: Idle
so what will do for fast transmission of 10 KB payload
