Migration from SDK 11 alpha to 11 final, advertising problem
This morning i did migration of my code from SDK 11 alpha 2 to 11 final on nRF52 and i have a big problem.
Nor bootloader or application do advertising. Am I alone ?
(i possibly not checked bootloader in 11 alpha but it worked with SDK 9 on nRF51)
What can I do as test ?
  • Do you mean that or do you mean does NRF_CLOCK_LF_SRC_RC need parameters? You say it works with SYNTH but not LF
    here's min
    static 	nrf_clock_lf_cfg_t CLOCK_CFG =
        .source = NRF_CLOCK_LF_SRC_RC
        .rc_ctiv = 4,      // Check temperature every 4 * 250ms
        .rc_temp_ctiv = 0, // Always calibrate
        .xtal_accuracy = 0
    that works fine for me under SD132v2 and SD130v2
  • static nrf_clock_lf_cfg_t CLOCK_CFG =
            .source = NRF_CLOCK_LF_SRC_SYNTH
            .xtal_accuracy = xx // what tu use here as xx
  • i have not set .xtal_accuracy = 0 in structure for RC, i will test
  • I usually use C++ and if you turn warnings up you get a useful warning about uninitialised struct members and I turned on the equivalent for C too, not that I remember what it is. It's a bit annoying sometimes but can be rather useful. I would think however that field is ignored totally in the RC case. I don't really understand where your problem likely lies, the bootloader isn't special, it's just another BLE service which runs out of a different piece of flash, if BLE works in general on that device with the S132 softdevice, there's no particular reason the bootloader wouldn't.
    You could try sticking a breakpoint in the softdevice fault handler, see if it's going there (as opposed to the usual error handler) although I'd think you'd notice.
  • Was a solution to this ever found? We're experiencing the same issue after upgrading to SDK11.
