Integration of MAX30001 with Ezurio nRF54L15U DK: Application Hangs after TF-M Boot & SPI/Jumper Configuration
  • Hi Nordic Support Team,
    I am currently working on integrating the MAX30001 ECG/Bio-impedance sensor with the Ezurio nRF54L15U DK (nRF54L series). I am using the nRF Connect SDK V3.1.1
    I have two main issues: the application seems to hang/stop outputting logs after TF-M initialization, and I need clarification on the hardware configuration for this specific third-party DK.
    1. The Issue (Boot Log): I have configured the SPI driver for the MAX30001. When I flash the board, I see the Trusted Firmware-M (TF-M) boot up, but I get no output from my main application. The logs stop here:
    Plaintext
    Pins have been configured as secure.
    GPIO port: 0x00000000
    Pin: 0x00000000
    Pin: 0x00000001
    Booting TF-M v2.1.2
    [Sec Thread] Secure image initializing!
    TF-M Float ABI: Hard
    Lazy stacking enabled
    [INF][PS] Encryption alg: 0x550020
    I suspect this is a TrustZone configuration issue where the SPI pins or the GPIOs used for the sensor (CS, INT) are defined as Secure and the Non-Secure application is faulting when trying to access them.
    2. Hardware Configuration Questions (Ezurio DK): Since this is the Ezurio nRF54L15U DK, the documentation is slightly different from the standard Nordic DKs.
    • SPI Pins: Could you confirm the recommended default SPI pins (MOSI, MISO, SCK) and Chip Select (CS) for this board overlay?
    • SPI Mode: For the MAX30001 on nRF54, should I be strictly using SPI Mode 0 (CPOL=0, CPHA=0)?
    • Jumper Configuration: The board has several jumpers (Jxx). To isolate the nRF54L15 for external SPI communication with the sensor, are there specific jumpers I need to remove to disconnect on-board peripherals that might share the same bus?
    • GPIO Security: Do I need to explicitly set the SPI pins to non-secure in the spm.conf or via Kconfig to allow the application to use them?
    My Current Setup:
    • Board: Ezurio nRF54L15U DK
    • Sensor: MAX30001 (MAX30001EVKIT or custom breakout)
    • Interface: SPI
    Any guidance on the correct Device Tree Overlay configuration for the pins and how to pass the execution past the TF-M stage would be helpful.
