nRF5 SDK 17.1.0 Secure DFU Bootloader and MCUboot as second stage bootloader
 Can MCUboot be used as a second stage bootloader (an application from the Secure DFU Bootloader over Serial Link standpoint) to be DFU'ed to existing devices which now are updateable w/ BL + SD + APP ?
Regards.
  • Hi Vidar,
     I've made the changes this is the output:|
    [00:00:07.315,429] <inf> btn: NRF_POWER->GPREGRET: 0xb1
    Also, after device has been restarted I've run the nrfutil command:
    nrfutil device read --address 0x4000051C --direct
    with output:
    0x4000051C: 000000B1                              |....|
    So this makes me thing the register was set correctly, but there is no effect from it?
    Kind regards.
    Thanks for confirming. Not sure why the bootloader is not entering DFU mode on startup then. Do you see if the nRF5 SDK bootloader is being entered on startup?
  • Hi Vidar,
     In the end the nrf5sdk secure bootloader and fw app works only if I disable BLE (including jump from app to bootloader and the other way around).
     The issue is now related to BLE. I get something like:
    ASSERTION FAIL [0] @ WEST_TOPDIR/nrf/subsys/mpsl/init/mpsl_init.c:301
    MPSL ASSERT: 112, 1577
    [00:00:04.102,203] <err> os: ***** HARD FAULT *****
    [00:00:04.102,233] <err> os: Fault escalation (see below)
    [00:00:04.102,233] <err> os: ARCH_EXCEPT with reason 4
    [00:00:04.102,264] <err> os: r0/a1: 0x00000004 r1/a2: 0x0000012d r2/a3: 0x0000000e
    [00:00:04.102,264] <err> os: r3/a4: 0x00000004 r12/ip: 0x00000010 r14/lr: 0x00038a8f
    [00:00:04.102,294] <err> os: xpsr: 0x21000018
    [00:00:04.102,294] <err> os: s[ 0]: 0x20016f60 s[ 1]: 0x00018c3d s[ 2]: 0x00000070 s[ 3]: 0x00323131
    [00:00:04.102,325] <err> os: s[ 4]: 0x00000001 s[ 5]: 0x2000622b s[ 6]: 0x20006250 s[ 7]: 0x000183e9
    [00:00:04.102,355] <err> os: s[ 8]: 0x20016120 s[ 9]: 0x20016160 s[10]: 0x20016140 s[11]: 0x00048419
    [00:00:04.102,355] <err> os: s[12]: 0x20016f80 s[13]: 0xffffffed s[14]: 0x00000000 s[15]: 0x00000000
    [00:00:04.102,386] <err> os: fpscr: 0x00000000
    [00:00:04.102,386] <err> os: Faulting instruction address (r15/pc): 0x00043f1a
    [00:00:04.102,416] <err> os: >>> ZEPHYR FATAL ERROR 4: Kernel panic on CPU 0
    [00:00:04.102,447] <err> os: Fault during interrupt handling
    [00:00:04.102,478] <err> os: Current thread: 0x20008678 (BT CTLR ECDH)
    [00:00:05.077,697] <err> os: Halting system
    Best regards
    Thank you for sharing the log. It shows that an assert was raised inside the precompiled MPSL library. To allow me look up which assert it is, could you please let me know the exact nRF connect SDK version you are using?
  • Hi Vidar,
     I'm using NCS v2.9.3. I've found that the issue is similar if not the same as this one:
    * RE: Hang with nRF5 SDK 17.1.0 Bootloader and nRF Connect SDK 2.1.0 application
     Including these KConfig fields makes everything work normally.
     Thanks for the help.
    Best regards.
