LTE Link Controller: RAI_UPDATE behaviour
I have a nRF9151 based device, modem firmware version v2.0.3, with `CONFIG_LTE_LC_RAI_MODULE=y`, registered on LTE-M.
Using `NRF_RAI_LAST` is working, but I am seeing odd behaviour of the `LTE_LC_EVT_RAI_UPDATE` event.
Each time the modem comes out of PSM, I receive an event reporting that neither AS-RAI nor CP-RAI are supported, followed a few milliseconds later by a second report saying AS-RAI is supported. For example, the following logs:
[00:01:00.044,281] <dbg> modem_monitor: lte_reg_handler: MODEM_SLEEP_EXIT
[00:01:00.044,281] <dbg> modem_monitor: lte_reg_handler:     Type: 1
[00:01:00.103,240] <dbg> modem_monitor: lte_reg_handler: MODEM_EVENT
[00:01:00.103,240] <dbg> modem_monitor: lte_reg_handler:    Event: 1
[00:01:00.512,634] <dbg> modem_monitor: lte_reg_handler: MODEM_EVENT
[00:01:00.512,634] <dbg> modem_monitor: lte_reg_handler:    Event: 6
[00:01:00.657,714] <wrn> modem_monitor: RAI_UPDATE
[00:01:00.657,745] <wrn> modem_monitor:     INFO: 147045644 505 1
[00:01:00.657,745] <wrn> modem_monitor:   AS-RAI: 0
[00:01:00.657,745] <wrn> modem_monitor:   CP-RAI: 0
[00:01:00.657,867] <dbg> modem_monitor: lte_reg_handler: RRC_UPDATE
[00:01:00.657,897] <dbg> modem_monitor: lte_reg_handler:    State: Active
[00:01:00.882,263] <wrn> modem_monitor: RAI_UPDATE
[00:01:00.882,293] <wrn> modem_monitor:     INFO: 147045644 505 1
[00:01:00.882,293] <wrn> modem_monitor:   AS-RAI: 1
[00:01:00.882,293] <wrn> modem_monitor:   CP-RAI: 0
[00:01:06.266,876] <dbg> modem_monitor: lte_reg_handler: RRC_UPDATE
[00:01:06.266,906] <dbg> modem_monitor: lte_reg_handler:    State: Idle
[00:01:22.291,900] <dbg> modem_monitor: lte_reg_handler: MODEM_SLEEP_ENTER
[00:01:22.291,931] <dbg> modem_monitor: lte_reg_handler:     Type: 1
[00:01:22.291,931] <dbg> modem_monitor: lte_reg_handler:      Dur: 46783975
This happens every time the modem comes out of PSM, not occasionally. Is this the expected behaviour?
It seems unlikely that the AS-RAI support is truly switching, seeing as the attached tower is never changing.
  • Hello again,
    I have an update for you:
    When modem wakes up from PSM, it selects a cell. When the cell has been selected, modem sends a RAI update with RAI not supported, because network communicates the support only in RRC connection establishment. At this point, modem does not know whether RAI is supported or not. When RRC connection has been established and RAI is supported, modem sends a new RAI update with RAI supported.
    The extra RAI update with RAI not supported is not very useful, but that’s how the modem currently behaves. The RAI update is intended to be used for information/debug purposes, so this should not affect application behavior anyway. The application should always set the RAI socket options, regardless of what the RAI update indicates. Modem then uses RAI if it is supported by the network.
    Michal
  • > When modem wakes up from PSM, it selects a cell. When the cell has been selected, modem sends a RAI update with RAI not supported, because network communicates the support only in RRC connection establishment.
    It seems odd that this behaviour occurs only for RAI, but no other information that could presumably change coming out of PSM. It seems like all other information is cached in the modem and only sent if it has actually changed, as indicated by the lack of other duplicate events notifying the cell tower, PSM parameters, etc.
    I agree that this has minimal impact on the functioning of an application. But as it currently stands, using it for information/debug purposes will return the wrong value if the application is caching the support status and a query happens to arrive at the wrong time.
  • Hi Jordan
    Michal is out of office, and it took some time to get to this after the holiday season, so sorry about the late reply here.
    I have now updated the internal ticket with your concerns and I agree with your points., We will get back to you when we hear from the devs on this.
    Simon
  • We got a reply rather fast from the developers today, so here it is:
    This is how the modem currently works, yes. In LTE-M during RRC connection establishment, the modem first sende the RAI notification with RAI disabled, and is followed by a second notification with RAI enabled.
    Note that we do not clear cached information here. The Network first tells us that RAI won't be used, and then very quickly after enable it. The network may remember device capabilities and then enable AS-RAI at the connection establishment. This is especially the case with NB-IOT as connection establishment is the only place NV-IoT enables AS-RAI.
    It might be possible to make a hacky solution with timers to hide these unnecessary reports, but we have decided against that as that could also introduce some other issues.
    Simon
  • Can I just ask for a bit of clarification around this. In addition to:
    ## PSM
    CONFIG_LTE_PSM_REQ=y
    CONFIG_LTE_LC_PSM_MODULE=y
    ## eDRX
    CONFIG_LTE_EDRX_REQ=y
    CONFIG_LTE_LC_EDRX_MODULE=y
    ## RAI
    CONFIG_LTE_RAI_REQ=y
    and adding the following code just after nrf_modem_lib_init() :
    lte_lc_psm_param_set("00111000", "00000110");       // 24 hours &12 seconds
    lte_lc_psm_req(true);
    lte_lc_ptw_set(LTE_LC_LTE_MODE_LTEM, "0000");       // 1.28 seconds
    lte_lc_edrx_param_set(LTE_LC_LTE_MODE_LTEM,"0000"); // 5.12 seconds
    lte_lc_edrx_req(true);
    rai_set();
    What else needs to be done to set up PSM, eDRX and RAI? When I try this code, I'm running into some issues. The lte event handler is telling me that the network is rejecting the PSM paramaters (with active  time = -1). And when I log the RAI stuff, it looks like this: MCC: 530, MNC: 5, AS RAI: false, CP RAI: false.
