Combining DTM and dfu-next samples
I am trying to get the nrf/sampoles/bluetooth/direct_test_mode working together with the code from zephyr/samples/subsys/usb/dfu-next.
I have the DTM mode running correctly, but can't integrate the dfu mode to this sample.
I started with the dtm sample, added the dfu logic in to dfu.h/dfu.c and added dfu_init to the dtm main.c.
Unfortunately I've hit two stumble blocks:
- the remote_shell part of the multi image build seems to be somehow hardcoced to the samples directory - whatever I try the build system always searches for remote_shell in the nrf/samples/nrf5340/remote_shell directory. I would however like to alter the code "locally", not in the SDK folder. You can overwrite settings for remote_shell (see below), but I can't figure out how to overwrite source files (e.g. main.c) with custom code.
- When enabling DFU mode in the project sysbuild/remote_shell/prj.conf overwrite. There seems to be a logic problem: the direct_test_mode sample needs to be compiled for cpunet core (see readme of the sample). However, dfu mode needs to be enabled for the app core. alter the (SDK sample directory) code to be able to set the same code changes I'm hit with
errors like:
: error: 'PM_MCUBOOT_SECONDARY_ID' undeclared (first use in this function)
   65 | #define PM__mcuboot_secondary_ID PM_MCUBOOT_SECONDARY_ID
After investigating, I think the problem is that PM expects the app-core application to be the parent image, but in this configuration it is the child image and thus downstream settings get confused and  the image does not compile.
Could you please assist me in creating a DTM project, that is updatable via dfu mode?
Thank you very much,
simeg
  • Hi Edvin,
    Thank you again for looking in to this .
    YES, the project - as is -  builds successfully.
    This was however not the issue or the question I was trying to ask:
    the problem is how to get DTM and DFU working together.
    I am unclear how we can modify the DTM code to add USB-DFU functionality to it.
    Also, how we can get west to use local sources, e.g. while building I get a warning:
    57/242] Building C object CMakeFiles/app.dir/src/main.c.obj
    /home/user/ncs/v3.1.1/nrf/samples/nrf5340/remote_shell/src/main.c: In function 'main':
    /home/user/ncs/v3.1.1/nrf/samples/nrf5340/remote_shell/src/main.c:138:15: warning: implicit declaration of function 'dfu_init' [-Wimplicit-function-declaration]
      138 |         err = dfu_init();
    Here you see that nrf connect uses "main.c" from the "samples" directory, I would however like that this code would exist locally in our git repository and that west does use source code from other folders.
    After flashing the project it shows up in the "dfu-util" utility:
    user:~/workspace/nrf-bluetooth/direct_test_mode(user.dfu_and_dtm)$ sudo dfu-util -l
    dfu-util 0.11
    Copyright 2005-2009 Weston Schmidt, Harald Welte and OpenMoko Inc.
    Copyright 2010-2021 Tormod Volden and Stefan Schmidt
    This program is Free Software and has ABSOLUTELY NO WARRANTY
    Please report bugs to http://sourceforge.net/p/dfu-util/tickets/
    Found Runtime: [2fe3:0001] ver=0401, devnum=35, cfg=1, intf=2, path="3-7.4.5", alt=0, name="UNKNOWN", serial="8924B12F028AA082"
    However, the chip can not successfully be flashed:
    user:~/workspace/nrf-bluetooth/direct_test_mode(user.dfu_and_dtm)$ sudo dfu-util --alt 0 --download build/direct_test_mode/zephyr/zephyr.signed.bin
    dfu-util 0.11
    dfu-util: Warning: Invalid DFU suffix signature
    dfu-util: A valid DFU suffix will be required in a future dfu-util release
    Opening DFU capable USB device...
    Device ID 2fe3:0001
    Run-Time device DFU version 0110
    Claiming USB DFU (Run-Time) Interface...
    Setting Alternate Interface zero...
    Determining device status...
    DFU state(0) = appIDLE, status(0) = No error condition is present
    Device really in Run-Time Mode, send DFU detach request...
    Device will detach and reattach...
    Opening DFU USB Device...
    Claiming USB DFU Interface...
    Setting Alternate Interface #0 ...
    DFU state(2) = dfuIDLE, status(0) = No error condition is present
    DFU mode device DFU version 0110
    Device returned transfer size 512
    Copying data from PC to DFU device
    Download        [                         ]   0%            0 bytesdfu-util: Error during download (LIBUSB_ERROR_PIPE)
    It seems that the dfu functionality is not "present" once the device is detached.
    Could you please assist us in getting DTM working together with DFU mode?
    The challenge here is that the direct test mode is running on the network core. You probably already flashed the app core with the empty_app_core sample, which basically starts up the network core and shuts down.
    You may actually want to look into modifying this into the empty app core. But if you want to be able to DFU back and forth between direct test mode, then you need a DFU image that contains the empty app core and the direct test mode for the network core. So much like the BLE samples would automatically build the IPC radio sample for the network core on the nRF5340, you would need your empty_app_core sample to automatically include the direct test mode for the network core, and then add DFU to your empty_app_core.
    To add USB DFU to an application, you can reference this DevAcademy course. Note that it says that if you want USB DFU from the application, you should go straight to step 5.
    The solution to the exercise is found here:
    https://github.com/NordicDeveloperAcademy/ncs-inter/tree/main/l9/l9_e4_sol
    If I understand correctly, you want to maintain your application on github, and just make it point to the nRF Connect SDK for the rest of the files, right?
    That is possible. If you have nrfutil installed, you can use the command:
    nrfutil sdk-manager toolchain env --as-script --ncs-version v3.1.1
    Then copy the output into a file called e.g. ncs_v3_1_1.cmd
    Then add this line at the end:
    SET ZEPHYR_BASE=C:\nordic\SDKs\ncs\v3.1.1\zephyr
    (but with the path to your NCS's zephyr folder)
    Then add this script to path, and you can call "ncs_v3_1_1.cmd" from anywhere, and you can use it to build. You can also place application folder's outside the nRF Connect SDK and build it in VS Code.
    Edvin
  • Hi Edvin,
    I got a step further by trying a different approach:
    instead of starting from the DTM sample I took the Remote IPC shell as a starting point and grafted the direct test mode on to it.
    I named the resulting project "dtm_remote_shell".
    This approach allowed me to compile the project and get DFU (app-core only) mode together with DTM.
    However, for our scenario we will have to upgrade both app- and netcore together, and this led to the problem I am having now:
    if I enable NETCORE_APP_UPDATE and the related configs, b0n shows up in the images, but I get following error:
       * Running CMake for dtm_remote_shell *
    -- Application: /home/simeg/workspace/nrf-bluetooth/dtm_remote_shell
    -- CMake version: 3.21.0
    -- Found Python3: /home/simeg/ncs/toolchains/b2ecd2435d/usr/local/bin/python (found suitable version "3.12.4", minimum required is "3.10") found components: Interpreter
    -- Cache files will be written to: /home/simeg/.cache/zephyr
    -- Zephyr version: 4.1.99 (/home/simeg/ncs/v3.1.1/zephyr)
    -- Found west (found suitable version "1.4.0", minimum required is "0.14.0")
    -- Board: nrf5340dk, qualifiers: nrf5340/cpuapp
    -- Found host-tools: zephyr 0.17.0 (/home/simeg/ncs/toolchains/b2ecd2435d/opt/zephyr-sdk)
    -- Found toolchain: zephyr 0.17.0 (/home/simeg/ncs/toolchains/b2ecd2435d/opt/zephyr-sdk)
    -- Found Dtc: /home/simeg/ncs/toolchains/b2ecd2435d/usr/bin/dtc (found suitable version "1.5.0", minimum required is "1.4.6")
    -- Found BOARD.dts: /home/simeg/ncs/v3.1.1/zephyr/boards/nordic/nrf5340dk/nrf5340dk_nrf5340_cpuapp.dts
    -- Found devicetree overlay: /home/simeg/workspace/nrf-bluetooth/dtm_remote_shell/boards/nrf5340dk_nrf5340_cpuapp.overlay
    -- Generated zephyr.dts: /home/simeg/workspace/nrf-bluetooth/dtm_remote_shell/build_1/dtm_remote_shell/zephyr/zephyr.dts
    -- Generated pickled edt: /home/simeg/workspace/nrf-bluetooth/dtm_remote_shell/build_1/dtm_remote_shell/zephyr/edt.pickle
    -- Generated devicetree_generated.h: /home/simeg/workspace/nrf-bluetooth/dtm_remote_shell/build_1/dtm_remote_shell/zephyr/include/generated/zephyr/devicetree_generated.h
    warning: STDOUT_CONSOLE (defined at lib/libc/Kconfig:156) was assigned the value 'y' but got the
    value 'n'. Check these unsatisfied dependencies: CONSOLE_HAS_DRIVER (=n). See
    http://docs.zephyrproject.org/latest/kconfig.html#CONFIG_STDOUT_CONSOLE and/or look up
    STDOUT_CONSOLE in the menuconfig/guiconfig interface. The Application Development Primer, Setting
    Configuration Values, and Kconfig - Tips and Best Practices sections of the manual might be helpful
    too.
    warning: LOG_BACKEND_UART (defined at subsys/logging/backends/Kconfig.uart:4) was assigned the value
    'y' but got the value 'n'. Check these unsatisfied dependencies: UART_CONSOLE (=n). See
    http://docs.zephyrproject.org/latest/kconfig.html#CONFIG_LOG_BACKEND_UART and/or look up
    LOG_BACKEND_UART in the menuconfig/guiconfig interface. The Application Development Primer, Setting
    too.
    warning: The choice symbol USB_DRIVER_LOG_LEVEL_ERR (defined at
    subsys/logging/Kconfig.template.log_config:11) was selected (set =y), but no symbol ended up as the
    choice selection. See
    http://docs.zephyrproject.org/latest/kconfig.html#CONFIG_USB_DRIVER_LOG_LEVEL_ERR and/or look up
    USB_DRIVER_LOG_LEVEL_ERR in the menuconfig/guiconfig interface. The Application Development Primer,
    Setting Configuration Values, and Kconfig - Tips and Best Practices sections of the manual might be
    helpful too.
    warning: The choice symbol USB_DEVICE_LOG_LEVEL_ERR (defined at
    http://docs.zephyrproject.org/latest/kconfig.html#CONFIG_USB_DEVICE_LOG_LEVEL_ERR and/or look up
    USB_DEVICE_LOG_LEVEL_ERR in the menuconfig/guiconfig interface. The Application Development Primer,
    helpful too.
    warning: Experimental symbol UDC_DRIVER is enabled.
    warning: Experimental symbol USB_DEVICE_STACK_NEXT is enabled.
    Parsing /home/simeg/workspace/nrf-bluetooth/dtm_remote_shell/Kconfig
    Loaded configuration '/home/simeg/ncs/v3.1.1/zephyr/boards/nordic/nrf5340dk/nrf5340dk_nrf5340_cpuapp_defconfig'
    Merged configuration '/home/simeg/workspace/nrf-bluetooth/dtm_remote_shell/prj.conf'
    Merged configuration '/home/simeg/workspace/nrf-bluetooth/dtm_remote_shell/build_1/dtm_remote_shell/zephyr/.config.sysbuild'
    Configuration saved to '/home/simeg/workspace/nrf-bluetooth/dtm_remote_shell/build_1/dtm_remote_shell/zephyr/.config'
    Kconfig header saved to '/home/simeg/workspace/nrf-bluetooth/dtm_remote_shell/build_1/dtm_remote_shell/zephyr/include/generated/zephyr/autoconf.h'
    -- Found GnuLd: /home/simeg/ncs/toolchains/b2ecd2435d/opt/zephyr-sdk/arm-zephyr-eabi/arm-zephyr-eabi/bin/ld.bfd (found version "2.38")
    -- Found assembler: /home/simeg/ncs/toolchains/b2ecd2435d/opt/zephyr-sdk/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc
    -- libmetal version: 1.7.0 (/home/simeg/workspace/nrf-bluetooth/dtm_remote_shell)
    -- Build type:
    -- Host:    Linux/x86_64
    -- Target:  Generic/arm
    -- Machine: arm
    -- Vendor: none
    -- Looking for include file stdatomic.h
    -- Looking for include file stdatomic.h - found
    -- open-amp version: 1.7.0 (/home/simeg/ncs/v3.1.1/modules/lib/open-amp/open-amp)
    -- Machine: arm
    -- C_FLAGS :  -Wall -Wextra
    -- Looking for include file fcntl.h
    -- Looking for include file fcntl.h - found
    -- Using ccache: /home/simeg/ncs/toolchains/b2ecd2435d/usr/bin/ccache
    -- Found gen_kobject_list: /home/simeg/ncs/v3.1.1/zephyr/scripts/build/gen_kobject_list.py
    CMake Warning at /home/simeg/ncs/v3.1.1/zephyr/CMakeLists.txt:1027 (message):
      No SOURCES given to Zephyr library: drivers__disk
      Excluding target from build.
    -- Including signing script: /home/simeg/ncs/v3.1.1/nrf/cmake/sysbuild/image_signing.cmake
    -- Configuring done
    -- Generating done
    -- Build files have been written to: /home/simeg/workspace/nrf-bluetooth/dtm_remote_shell/build_1/dtm_remote_shell
    CMake Warning at /home/simeg/ncs/v3.1.1/nrf/cmake/sysbuild/debug_keys.cmake:27 (message):
          --- WARNING: Using generated NSIB public/private key-pair. ---
          --- It should not be used for production.                  ---
          --- See SB_CONFIG_SECURE_BOOT_SIGNING_KEY_FILE             ---
      /home/simeg/ncs/v3.1.1/nrf/cmake/sysbuild/provision_hex.cmake:11 (include)
      /home/simeg/ncs/v3.1.1/nrf/sysbuild/CMakeLists.txt:55 (include)
      /home/simeg/ncs/v3.1.1/nrf/sysbuild/CMakeLists.txt:777 (include_provision_hex)
      cmake/modules/sysbuild_extensions.cmake:598 (nrf_POST_CMAKE)
      cmake/modules/sysbuild_extensions.cmake:598 (cmake_language)
      cmake/modules/sysbuild_images.cmake:46 (sysbuild_module_call)
      cmake/modules/sysbuild_default.cmake:21 (include)
      /home/simeg/ncs/v3.1.1/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:75 (include)
      /home/simeg/ncs/v3.1.1/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:92 (include_boilerplate)
      /home/simeg/ncs/v3.1.1/zephyr/share/sysbuild-package/cmake/SysbuildConfig.cmake:8 (include)
      template/CMakeLists.txt:10 (find_package)
    CMake Warning at /home/simeg/ncs/v3.1.1/nrf/cmake/sysbuild/partition_manager.cmake:119 (message):
            --- WARNING: Using a bootloader without pm_static.yml.            ---
            --- There are cases where a deployed product can consist of       ---
            --- multiple images, and only a subset of these images can be     ---
            --- upgraded through a firmware update mechanism. In such cases,  ---
            --- the upgradable images must have partitions that are static    ---
            --- and are matching the partition map used by the bootloader     ---
            --- programmed onto the device.                                   ---
      /home/simeg/ncs/v3.1.1/nrf/cmake/sysbuild/partition_manager.cmake:636 (partition_manager)
      /home/simeg/ncs/v3.1.1/nrf/sysbuild/CMakeLists.txt:825 (include)
      File "/home/simeg/ncs/v3.1.1/nrf/scripts/partition_manager.py", line 1054, in <module>
        main()
      File "/home/simeg/ncs/v3.1.1/nrf/scripts/partition_manager.py", line 1022, in main
        args, ranges_configuration = parse_args()
      File "/home/simeg/ncs/v3.1.1/nrf/scripts/partition_manager.py", line 928, in parse_args
        parser.add_argument(f'--{x}-size', required=True, type=lambda z: int(z, 0))
      File "/home/simeg/ncs/toolchains/b2ecd2435d/usr/local/lib/python3.12/argparse.py", line 1495, in add_argument
        return self._add_action(action)
      File "/home/simeg/ncs/toolchains/b2ecd2435d/usr/local/lib/python3.12/argparse.py", line 1877, in _add_action
        self._optionals._add_action(action)
      File "/home/simeg/ncs/toolchains/b2ecd2435d/usr/local/lib/python3.12/argparse.py", line 1697, in _add_action
        action = super(_ArgumentGroup, self)._add_action(action)
      File "/home/simeg/ncs/toolchains/b2ecd2435d/usr/local/lib/python3.12/argparse.py", line 1509, in _add_action
        self._check_conflict(action)
      File "/home/simeg/ncs/toolchains/b2ecd2435d/usr/local/lib/python3.12/argparse.py", line 1646, in _check_conflict
        conflict_handler(action, confl_optionals)
      File "/home/simeg/ncs/toolchains/b2ecd2435d/usr/local/lib/python3.12/argparse.py", line 1655, in _handle_conflict_error
        raise ArgumentError(action, message % conflict_string)
    argparse.ArgumentError: argument --sram_primary-size: conflicting option string: --sram_primary-size
    CMake Error at /home/simeg/ncs/v3.1.1/nrf/cmake/sysbuild/partition_manager.cmake:179 (message):
      Partition Manager failed, aborting.  Command:
      /home/simeg/ncs/toolchains/b2ecd2435d/usr/local/bin/python3.12;/home/simeg/ncs/v3.1.1/nrf/scripts/partition_manager.py;--input-files;/home/simeg/workspace/nrf-bluetooth/dtm_remote_shell/build_1/b0n/zephyr/include/generated/pm.yml;/home/simeg/workspace/nrf-bluetooth/dtm_remote_shell/build_1/b0n/modules/nrf/subsys/partition_manager/pm.yml.secure_boot_storage;/home/simeg/workspace/nrf-bluetooth/dtm_remote_shell/build_1/zephyr/include/generated/pm.yml;/home/simeg/workspace/nrf-bluetooth/dtm_remote_shell/build_1/b0n/zephyr/include/generated/pm.yml;/home/simeg/workspace/nrf-bluetooth/dtm_remote_shell/build_1/b0n/modules/nrf/subsys/partition_manager/pm.yml.secure_boot_storage;/home/simeg/workspace/nrf-bluetooth/dtm_remote_shell/build_1/zephyr/include/generated/pm.yml;--regions;sram_primary;flash_primary;sram_primary;flash_primary;--output-partitions;/home/simeg/workspace/nrf-bluetooth/dtm_remote_shell/build_1/partitions_CPUNET.yml;--output-regions;/home/simeg/workspace/nrf-bluetooth/dtm_remote_shell/build_1/regions_CPUNET.yml;--flash_primary-dynamic-partition;direct_test_mode;--sram_primary-size;0x10000;--sram_primary-base-address;0x21000000;--sram_primary-placement-strategy;complex;--sram_primary-dynamic-partition;sram_primary;--flash_primary-size;0x40000;--flash_primary-base-address;0x1000000;--flash_primary-placement-strategy;complex;--flash_primary-device;flash_controller;--flash_primary-default-driver-kconfig;CONFIG_SOC_FLASH_NRF;--sram_primary-size;0x10000;--sram_primary-base-address;0x21000000;--sram_primary-placement-strategy;complex;--sram_primary-dynamic-partition;sram_primary;--flash_primary-size;0x40000;--flash_primary-base-address;0x1000000;--flash_primary-placement-strategy;complex;--flash_primary-device;flash_controller;--flash_primary-default-driver-kconfig;CONFIG_SOC_FLASH_NRF
      /home/simeg/ncs/v3.1.1/nrf/cmake/sysbuild/partition_manager.cmake:639 (partition_manager)
    See also "/home/simeg/workspace/nrf-bluetooth/dtm_remote_shell/build_1/CMakeFiles/CMakeOutput.log".
    FATAL ERROR: command exited with status 1: /home/simeg/ncs/toolchains/b2ecd2435d/usr/local/bin/cmake -DWEST_PYTHON=/home/simeg/ncs/toolchains/b2ecd2435d/usr/local/bin/python3.12 -B/home/simeg/workspace/nrf-bluetooth/dtm_remote_shell/build_1 -GNinja -DBOARD=nrf5340dk/nrf5340/cpuapp -S/home/simeg/ncs/v3.1.1/zephyr/share/sysbuild -DAPP_DIR:PATH=/home/simeg/workspace/nrf-bluetooth/dtm_remote_shell
     *  The terminal process terminated with exit code: 1.
    When I look at the build directory and search for the different sram-primary definitions it seems to lign up and also the indicated CMake command (from the build output) does not acually show any discrepancies.
    I seem close to have this project building in the desired state - mind to look in to it once more?dtm_remote_shell.tar.gz
    Try adding a pm_static.yml to your project, and see if that helps.
    Edvin
