MCUBoot not a compatible amount of sectors NRF54L15
Hi guys,
I'm trying to do FOTA updates on my board and I was able so far to download the image but not able to apply it.
I've followed the academy FOTA over WiFi example but during bootup I see the following warning message:
[0:0:0.8,150] <wrn> mcuboot: Cannot upgrade: not a compatible amount of sectors
[0:0:0.8,156] <dbg> mcuboot: slot0 sectors: 180, slot1 sectors: 163, usable slot0 sectors: 179
What could be the issue here? On the partition manager I see both mcu_primary and mcu_secondary with the same size.
Please check my pm_static.yml:
EMPTY_0:
  address: 0xd800
  end_address: 0xe000
  placement:
    after:
    - mcuboot
  region: flash_primary
EMPTY_1:
  address: 0x176000
  end_address: 0x177000
  placement:
    after:
    - mcuboot_secondary
app:
  address: 0xe800
  end_address: 0xc2000
bootconf:
  address: 0xffd080
  end_address: 0xffd084
  region: bootconf
mcuboot:
  address: 0x0
  end_address: 0xd800
  placement:
    align:
      end: 0x1000
    before:
    - mcuboot_primary
mcuboot_pad:
  address: 0xe000
  end_address: 0xe800
  placement:
    align:
      start: 0x1000
    before:
    - mcuboot_primary_app
mcuboot_primary:
  address: 0xe000
  orig_span: &id001
  - mcuboot_pad
  - app
  sharers: 0x1
  span: *id001
mcuboot_primary_app:
  address: 0xe800
  orig_span: &id002
  - app
  span: *id002
mcuboot_secondary:
  address: 0xc2000
  end_address: 0x176000
  placement:
    after:
    - mcuboot_primary
    align:
      start: 0x1000
  share_size:
  - mcuboot_primary
otp:
  address: 0xffd500
  end_address: 0xffd9fc
  region: otp
sram_primary:
  address: 0x20000000
  end_address: 0x20040000
  region: sram_primary
zms_storage:
  address: 0x177000
  end_address: 0x17d000
  placement:
    after:
    - app
    align:
      start: 0x1000
    before:
    - end
Also my sysbuild.conf:
SB_CONFIG_BOOTLOADER_MCUBOOT=y
SB_CONFIG_PARTITION_MANAGER=y
Any ideias? I'm trying to have a stable version with FOTA so that I can move to the production pilot.
Fernando Fontes
  • Ok, I think I've fixed somehow.
    I will add here my app.overlay for future reference:
    &cpuapp_rram { //! Remove the amount of Flash reserved for the cpuflpr
        reg = < 0x0 DT_SIZE_K(1524) >;
    &cpuapp_sram { //! Without this the only 188Kb of RAM is available
    	reg = <0x20000000 DT_SIZE_K(256)>;
    	ranges = <0x0 0x20000000 DT_SIZE_K(256)>;
    &wdt31 {
    	status = "okay";
    Also the prj.conf for the mcuboot:
    # Copyright (c) 2024 Nordic Semiconductor ASA
    # NCS boot banner
    CONFIG_NCS_APPLICATION_BOOT_BANNER_STRING="MCUboot"
    # Disable UART Console and enable the RTT console
    CONFIG_LOG=y
    CONFIG_LOG_DEFAULT_LEVEL=0
    CONFIG_LOG_OVERRIDE_LEVEL=0
    CONFIG_LOG_MAX_LEVEL=4
    CONFIG_CONSOLE=y
    CONFIG_UART_CONSOLE=n
    CONFIG_RTT_CONSOLE=y
    CONFIG_LOG_BACKEND_RTT=y
    CONFIG_LOG_BACKEND_UART=n
    CONFIG_USE_SEGGER_RTT=y
    CONFIG_LOG_MODE_MINIMAL=n
    CONFIG_MCUBOOT_LOG_LEVEL_DBG=y
    CONFIG_MULTITHREADING=y
    CONFIG_SIZE_OPTIMIZATIONS=y
    CONFIG_HW_STACK_PROTECTION=y
    CONFIG_MAIN_STACK_SIZE=10240
    CONFIG_BOOT_BOOTSTRAP=n
    CONFIG_BOOT_VERSION_CMP_USE_BUILD_NUMBER=y
    CONFIG_FLASH=y
    CONFIG_FPROTECT=y
    CONFIG_PM_EXTERNAL_FLASH_MCUBOOT_SECONDARY=n
    CONFIG_SYS_CLOCK_EXISTS=y
    CONFIG_CLOCK_CONTROL=y
    CONFIG_NRF_GRTC_TIMER=y
    CONFIG_NRF_GRTC_START_SYSCOUNTER=y
    # Reduce memory consumption
    CONFIG_BOOT_BANNER=n
    CONFIG_NCS_BOOT_BANNER=n
    CONFIG_PRINTK=n
    # Use minimal C library instead of the Picolib
    # CONFIG_MINIMAL_LIBC=y
    CONFIG_PICOLIBC=y
    # Activate Link Time Optimization (LTO)
    CONFIG_LTO=y
    CONFIG_ISR_TABLES_LOCAL_DECLARATION=y
    # Improve debugging experience by disabling reset on fatal error
    CONFIG_RESET_ON_FATAL_ERROR=n
    # Disable GPIO, SPI and SPI NOR
    CONFIG_GPIO=n
    CONFIG_SPI=n
    CONFIG_SPI_NOR=n
    # Currently, without tickless kernel, the SYSCOUNTER value after the software
    # reset is not set properly and due to that the first system interrupt is not called
    # in the proper time - the SYSCOUNTER value is set to the value from before
    # reset + 1. Hence, the reboot time increases more and more.
    # To avoid it enable tickles kernel for mcuboot.
    CONFIG_TICKLESS_KERNEL=y
    CONFIG_PM=n
    CONFIG_BOOT_SWAP_SAVE_ENCTLV=n
    CONFIG_BOOT_ENCRYPT_IMAGE=n
    CONFIG_BOOT_UPGRADE_ONLY=n
    # Update MCUboot configuration
    CONFIG_MCUBOOT_INDICATION_LED=n
    CONFIG_BOOT_MAX_IMG_SECTORS=512
    CONFIG_PM_PARTITION_SIZE_MCUBOOT=0xF000
    Small portion of the logs for the mcuboot during the swap:
    [00:01:24.016,455] <inf> dfu_target_mcuboot: MCUBoot image-0 upgrade scheduled. Reset device to apply
    [00:01:24.016,671] <inf> ota_handler: FOTA_DOWNLOAD_EVT_FINISHED
    [00:01:24.016,812] <inf> ota_handler: Application FOTA done, rebooting
    [00:01:24.022,531] <inf> mcuboot: Starting bootloader
    [00:01:24.022,549] <dbg> mcuboot: context_boot_go: context_boot_go
    [00:01:24.022,646] <dbg> mcuboot: boot_slots_compatible: Non-optimal sector distribution, slot0 has 179 usable sectors (180 assigned) but slot1 has 180 assigned
    [00:01:24.022,687] <inf> mcuboot: Primary image: magic=unset, swap_type=0x1, copy_done=0x3, image_ok=0x3
    [00:01:24.022,707] <inf> mcuboot: Secondary image: magic=good, swap_type=0x2, copy_done=0x3, image_ok=0x3
    [00:01:24.022,710] <inf> mcuboot: Boot source: none
    [00:01:24.022,748] <inf> mcuboot: Image index: 0, Swap type: test
    [00:01:24.022,754] <dbg> mcuboot: boot_validate_slot: boot_validate_slot: slot 1, expected_swap_type 2
    [00:01:24.022,761] <dbg> mcuboot: bootutil_img_validate: bootutil_img_validate: flash area 0xb0c4
    [00:01:24.022,765] <dbg> mcuboot: bootutil_img_hash: bootutil_img_hash
    [00:01:24.087,497] <dbg> mcuboot: bootutil_tlv_iter_next: bootutil_tlv_iter_next: searching for 65535 (65535 is any) starting at 391192 ending at 391260
    --- 9 messages dropped ---
    [00:01:24.087,504] <dbg> mcuboot: bootutil_tlv_iter_next: bootutil_tlv_iter_next: TLV 36 found at 391196 (size 64)
    [00:01:24.087,510] <dbg> mcuboot: bootutil_img_validate: bootutil_img_validate: EXPECTED_SIG_TLV == 36
    [00:01:24.087,519] <dbg> mcuboot: bootutil_verify_sig: bootutil_verify_sig: ED25519 key_id 0
    [00:01:24.087,524] <dbg> mcuboot: bootutil_verify: bootutil_verify: ED25519 key_id 0
    [00:01:24.087,536] <dbg> ed25519_psa: ED25519_verify: ED25519_verify: PSA implementation
    [00:01:24.088,996] <dbg> mcuboot: bootutil_tlv_iter_next: bootutil_tlv_iter_next: searching for 65535 (65535 is any) starting at 391260 ending at 391260
    [00:01:24.089,002] <dbg> mcuboot: bootutil_tlv_iter_next: bootutil_tlv_iter_next: TLV 65535 not found
    [00:01:24.089,012] <inf> mcuboot: Starting swap using move algorithm.
    [00:01:24.089,024] <dbg> mcuboot: swap_scramble_trailer_sectors: swap_scramble_trailer_sectors: fa_id=2
    [00:01:24.089,029] <dbg> mcuboot: boot_trailer_scramble_offset: boot_trailer_scramble_offset: flash_area 0xb094, alignment 16
    [00:01:24.089,035] <dbg> mcuboot: boot_trailer_scramble_offset: boot_trailer_scramble_offset: final alignment 16, offset 712624
    [00:01:24.089,040] <dbg> mcuboot: boot_scramble_region: boot_scramble_region: 0xb094 712624 24656 1
    [00:01:24.089,045] <dbg> mcuboot: boot_scramble_region: boot_scramble_region: device without erase, overwriting
    [00:01:24.089,052] <dbg> mcuboot: boot_scramble_region: boot_scramble_region: start offset 737264, end offset 712624
    [00:01:24.107,318] <dbg> mcuboot: swap_status_init: initializing status; fa_id=2
    [00:01:24.107,333] <dbg> mcuboot: boot_write_swap_info: writing swap_info; fa_id=2 off=0xb3fc0 (0xc2fc0), swap_type=0x2 image_num=0x0
    [00:01:24.107,339] <dbg> mcuboot: boot_write_trailer: boot_write_trailer: for 0xb094 at 737216, size = 1
    [00:01:24.107,409] <dbg> mcuboot: boot_write_swap_size: writing swap_size; fa_id=2 off=0xb3fb0 (0xc2fb0)
    [00:01:24.107,416] <dbg> mcuboot: boot_write_trailer: boot_write_trailer: for 0xb094 at 737200, size = 4
    [00:01:24.107,484] <dbg> mcuboot: boot_write_magic: boot_write_magic: fa_id=2 off=0xb3ff0 (0xc2ff0)
    [00:01:24.107,577] <dbg> mcuboot: swap_scramble_trailer_sectors: swap_scramble_trailer_sectors: fa_id=5
    [00:01:24.107,583] <dbg> mcuboot: boot_trailer_scramble_offset: boot_trailer_scramble_offset: flash_area 0xb0c4, alignment 16
    [00:01:24.107,590] <dbg> mcuboot: boot_trailer_scramble_offset: boot_trailer_scramble_offset: final alignment 16, offset 712624
    [00:01:24.107,597] <dbg> mcuboot: boot_scramble_region: boot_scramble_region: 0xb0c4 712624 24656 1
    [00:01:24.107,603] <dbg> mcuboot: boot_scramble_region: boot_scramble_region: device without erase, overwriting
    [00:01:24.107,611] <dbg> mcuboot: boot_scramble_region: boot_scramble_region: start offset 737264, end offset 712624
    [00:01:24.129,072] <dbg> mcuboot: boot_erase_region: boot_erase_region: flash_area 0xb094, offset 393216, size 4096, backwards == 0
    [00:01:24.129,077] <dbg> mcuboot: boot_erase_region: boot_erase_region: device without erase
    [00:01:24.144,308] <dbg> mcuboot: boot_write_status: writing swap status; fa_id=2 off=0xadfb0 (0xbcfb0)
    [00:01:24.144,374] <dbg> mcuboot: boot_erase_region: boot_erase_region: flash_area 0xb094, offset 389120, size 4096, backwards == 0
    [00:01:24.144,379] <dbg> mcuboot: boot_erase_region: boot_erase_region: device without erase
    [00:01:24.163,642] <dbg> mcuboot: boot_write_status: writing swap status; fa_id=2 off=0xadfc0 (0xbcfc0)
    [00:01:24.163,717] <dbg> mcuboot: boot_erase_region: boot_erase_region: flash_area 0xb094, offset 385024, size 4096, backwards == 0
    [00:01:24.163,722] <dbg> mcuboot: boot_erase_region: boot_erase_region: device without erase
    [00:01:24.169,739] <dbg> mcuboot: boot_write_status: writing swap status; fa_id=2 off=0xadfd0 (0xbcfd0)
    [00:01:24.169,804] <dbg> mcuboot: boot_erase_region: boot_erase_region: flash_area 0xb094, offset 380928, size 4096, backwards == 0
    [00:01:24.169,808] <dbg> mcuboot: boot_erase_region: boot_erase_region: device without erase
    [00:01:24.179,209] <dbg> mcuboot: boot_write_status: writing swap status; fa_id=2 off=0xadfe0 (0xbcfe0)
    [00:01:24.179,304] <dbg> mcuboot: boot_erase_region: boot_erase_region: flash_area 0xb094, offset 376832, size 4096, backwards == 0
    [00:01:24.179,309] <dbg> mcuboot: boot_erase_region: boot_erase_region: device without erase
    Ok this really get's me happy! I've been struggling with FOTA for days. Apparently, MBEDTLS stoles 70% of the RAM for NRF54L15. Adding the Download while having the TLS for AWS MQTT is not possible, there is not enough RAM for both TLS contexts.
    Only a few questions left though. The app that I'm uploading to AWS is: zephyr/zephyr.signed.bin, and I guess this is being signed with the default cert file. What does CONFIG_BOOT_ENCRYPT_IMAGE=n means then? Isn't the image already encrypted? Or signed is different then encrypted?
    What are the requirements for the CONFIG_BOOT_VERSION_CMP_USE_BUILD_NUMBER? I want to prevent downgrades images of being applied.
    Fernando Fontes
  • Hi Fernando,
    I am glad to hear that this is now running!
    Yes. mbedtls will use a whole lot of RAM for maintaining the TLS connection, and there are configurations and overlays present here that should give a starting point:
    https://github.com/nrfconnect/sdk-nrf/tree/main/samples/net/https_client/boards
    The image is signed by default, but not encrypted. This is a bit of a wider topic, which you can read more about here:
    https://docs.nordicsemi.com/bundle/ncs-latest/page/nrf/app_dev/device_guides/nrf54l/ecies_x25519.html
    You must define the version in the application, as described here:
    https://docs.nordicsemi.com/bundle/ncs-3.0.2/page/nrf/app_dev/bootloaders_dfu/mcuboot_nsib/bootloader_downgrade_protection.html
    Håkon
