I2C issue with update over the air
We are using a TMD2636 proximity sensor on our board, connected via I²C on pins P0.18 (SDA) and P0.30 (SCL). The same I²C bus also contains a TMP117 temperature sensor and another device.
Before enabling OTA updates, all sensors work correctly. However, after enabling:
CONFIG_NCS_SAMPLE_MCUMGR_BT_OTA_DFU=y
The proximity sensor (TMD2636) stops responding, while the TMP117 and the other sensor continue to operate normally on the same bus.
I checked the I²C pulses with a logic analyzer and confirmed that the TMD2636 no longer sends an ACK after OTA support is enabled.
These are two screenshots from Digital Analyzer, when I enable CONFIG_NCS_SAMPLE_MCUMGR_BT_OTA_DFU=y, as you see, the proximity sensor doesn't send ACK:
But when I disable the CONFIG_NCS_SAMPLE_MCUMGR_BT_OTA_DFU=n, the proximity sensor starts to send ack,
Could you please advise on what might cause this issue or how I can resolve it?
Alireza
