Best way to avoid recursion in Zephyr when enabling logging to backend with littlefs to flash memory
We are working on an nrf54l15dk board but want to log directly to the nrf flash memory (instead of the ext flash) - which we are doing successfully.
In Zephyr we have logging to backend enabled working so any call to LOG_ERR, LOG_INF ...etc gets directly stored in our flash memory (littlefs).
However, we want to avoid a situation where the low level flash code (whether this is the SPI or internal flash code) get's into a recursive loop if it tries to call a LOG function within the flash driver code itself.
Is this handled already by Zephyr (4.1.99) and nordic and what is the best way to work around this?
Obviously disabling FS logging (CONFIG_FS_LOG_LEVEL_OFF=y) will prevent this, but we would prefer seeing those in the shell terminal if possible.
Here is a snippet of the prj.conf that relates to what we are doing:
# Logging
CONFIG_LOG=y
CONFIG_LOG_CMDS=y
# Enable the FS log backend
CONFIG_LOG_MODE_DEFERRED=y
CONFIG_LOG_BACKEND_FS=y
CONFIG_LOG_BACKEND_FORMAT_TIMESTAMP=y
CONFIG_LOG_BACKEND_FS_AUTOSTART=y
CONFIG_LOG_BACKEND_FS_DIR="/lfs"
CONFIG_LOG_BACKEND_FS_FILE_SIZE=4096
# Increase log processing thread stack (try 4096 first, bump to 8192 if needed)
CONFIG_LOG_PROCESS_THREAD_STACK_SIZE=4096
# Disable nrf54 dk qspi flash chip so we can use the default nrf54 flash for littlefs
CONFIG_SPI_NOR=n
# littlefs flash support
CONFIG_FLASH=y
CONFIG_FLASH_MAP=y
CONFIG_FILE_SYSTEM=y
CONFIG_FILE_SYSTEM_LITTLEFS=y
  • jthmp said:
    We used the samples as a starting point, but since we are using backend logging there is no example I could find that is addressing our use case:
    Every time we use something like LOG_INF, or LOG_WRN it gets stored in a ext or internal flash memory. Looking at the zephyr code 'log_backend_fs.c' it seems like there is no contingency for detecting a persistent fs_write error.
    As in there not being a sample that handles the issues with flash writes for logging? I do not know of any that handles this exact problem myself, though it seems as if a few customers have run into a similar issue previously. I assume you are not for instance running into the same situation as this guy here, who had this issue because he wanted to initialize LWM2M_CARRIER at the same time? Either way it might be a good idea to have a look at that thread.
    If you see this often happen on a DK, could you get me something minimal that reproduces this?
    Elfving
