adding Softdevice BLE (S140) with GPIO attached coprocessor to project without softdevice. hardfault calling existing code after Softdevice active
I am extending one of Qorvo's UWB platforms.. adding Softdevice BLE functions..  (which work ok) (this is on sdk 17_1_0)
the coprocessor uses a GPIO connected signaling mechanism,  using interrupts..
calling the existing code after BLE is active causes a hardfault..
this is running freetos,  we are in a freetos task.
I've debugged (using ozone) it to  attempting to setup the interrupt handler for the GPIO pins.
the existing code calls the nrfx libs
       return qgpio_pin_irq_configure(&qm33_irq, QGPIO_IRQ_DISABLED);  //according to the doc, a gpio interrupt disable shouldn't impact softdevice..
enum qerr qgpio_pin_irq_configure(const struct qgpio *qgpio_pin, uint32_t flags)
nrfx_err_t r;
enum qerr err;
struct qgpio_cb_data *cb_data;
nrfx_gpiote_in_config_t trigger_config;
uint32_t abs_pin = NRF_GPIO_PIN_MAP(qgpio_pin->port, qgpio_pin->pin_number);  // this sets abs_pin = 25
/* Init GPIOTE at least once. */
if (!nrfx_gpiote_is_init()) {   // this causes the hardfault.
   r = nrfx_gpiote_init();
   if (r)
   return QERR_EBUSY;
if (flags & QGPIO_IRQ_DISABLED) {
   nrfx_gpiote_in_event_disable(abs_pin);
   nrfx_gpiote_in_uninit(abs_pin);
   return QERR_SUCCESS;
hardfault window
The target stopped in HardFault exception state.
Reason: A fault with configurable priority has been escalated to a HardFault exception at 0x00000000.
I don't see any mechanism to cause hardfault on a GPIO pin  with SD active.
if SD is not active this code works as written
what am I missing
if I run this code BEFORE setup of softdevice, it works, but softdevice init fails.
  • I went thru all the code, found one place setting power state, only used for SPI, not SPIM, also not loaded in binary
    I put a stop of the code that fails,
    using the table link above
    R0 = 0x4002F000
    which says SPIM3
    if I run from there, another stop at the same place, like the interrupt is not cleared.
    if I disable the stop, I get a hard fault.
    so, added more debug info..  i save the spim object address and as the interrupts are redirected to a common interrupt handler I save the spim number all prior to the code causing the fault.
    the number is 3 (spim3)
    and the saved spim pointer is the same as above , in LSB format 00 F0 02 40
    anyhow.. still confused.. and in the latest fault it was saving the spim pointer address that faulted..
    interesting..   directly before the fault location is this in nrfx_spim.c
    #if NRFX_CHECK(NRFX_SPIM3_NRF52840_ANOMALY_198_WORKAROUND_ENABLED)
     if (p_spim == NRF_SPIM3)
     anomaly_198_disable();
    I commented it out.. and now no fault..  I can run my BLE operations..
    devzone.nordicsemi.com/.../enabling-workaround-for-anomaly-198-crashes-softdevice
    I
     have changed the define in sdk_config.h to 0 instead of 1
  • Hi Sam,
    You mentioned earlier "if I comment out the 198 anomaly test it hardfaults in the nrfx_spim, irq_handler,"
    Could you explain what has been changed ?
    My understanding now is that you have it working both BLE and SPIM3 ?
    Is there any option to use other SPIM instead of SPIM3 ? So that we can avoid errata 198. Please find this note in the SDK's release note (Known issue):
    - The workaround for Anomaly 198 for nRF52840 SPIM3 peripheral
    that has been implemented in nrfx_spim cannot be used with a SoftDevice.
    Flag NRFX_SPIM3_NRF52840_ANOMALY_198_WORKAROUND_ENABLED must be set to zero.
    The workaround based on a dedicated RAM block for SPIM3 must be used instead.
    If SPIM3 is a must, then you will have to use the solution to use dedicated RAM block for SPIM3.
    One my coworkers have made an example a few years back. I attached the project (SDK v17.1.0) and the instruction here:
    ble_app_beacon_spim.zip
    Look at the flash placement file:
    To see how this reserves one RAM block for the SPI, and then in main.c how it allocates the spim buffer to be within this block.
    Then you should use this buffer for your SPI when you initialize it. The softdevice will not touch the allocated ram block.
    Give it a go, and let me know how it works in your application. Please note that you can see where this RAM block ends up (this is dynamic). If the application grows too big, then it will go into ram block 8, and things may start to get messy with the callstack and so on. You should see this after compiling:
  • not my firmware, so I don't know..
    they have another package on this card that uses the same build model and mostly source, but with SoftDevice and the setting is off.
    #define NRFX_SPIM3_NRF52840_ANOMALY_198_WORKAROUND_ENABLED 0
    the spim_buffer (from your link map)  is not defined in either build, on the same 52840.
    so I don't know if that is a bug in their code or ...
    and its the old SDK 17
     oh, they use SD 113 (perf only), I use 140 (as I need central too)
  • Hi Sam,
    The sample I provided is the workaround for the issue that the default workaround for Anomaly 198 will cause a crash when using with softdevice. You need to define a dedicated RAM block for SPIM3 that doesn't overlap the RAM reserved by the softdevice.
    Can you try to implement the memory configuration similar to what showed in the example ?
  • I have asked Qorvo if they NEED spim3..
    waiting
