I2C read failed reg 0x00 err -5
I am faced "I2C read failed reg 0x00 err -5" issue
&pinctrl {
	i2c22_default: i2c22_default {
		group1 {
			psels = <NRF_PSEL(TWIM_SCL, 2, 7)>,
					<NRF_PSEL(TWIM_SDA, 2, 6)>;
					bias-pull-up;
	i2c22_sleep: i2c22_sleep {
		group1 {
					low-power-enable;
	i2s20_default: i2s20_default {
		group1 {
			psels = <NRF_PSEL(I2S_SDOUT, 0, 0)>,
			        <NRF_PSEL(I2S_SDIN, 0, 1)>,
			        <NRF_PSEL(I2S_SCK_S, 0, 2)>,
			        <NRF_PSEL(I2S_MCK, 0, 3)>,
			        <NRF_PSEL(I2S_LRCK_M, 0, 4)>;
	i2s20_sleep: i2s20_sleep {
		group1 {
&i2c22 {
	status = "okay";
	pinctrl-0 = <&i2c22_default>;
	pinctrl-1 = <&i2c22_sleep>;
	audiocodec: audiocodec@18 {
		compatible = "i2c-device";
		status = "okay";
		reg = < 0x18 >;
&i2s20 {
	status = "okay";
	pinctrl-0 = <&i2s20_default>;
	pinctrl-1 = <&i2s20_sleep>;
}; this is my overlay
// read command
int read_eg(void)
    int ret;
    uint8_t reg = 0x00;
    uint8_t val = 0;
    ret = i2c_write_read_dt(&dev_i2c,
                            &reg, 1,
                            &val, 1);
    if (ret)
        printk("I2C read failed reg 0x%02x err %d\n", reg, ret);
        return ret;
   printk("Read reg 0x%02x = 0x%02x\n", reg, val);
    return 0;
int codec_hw_reset(void)
    int ret;
    ret=gpio_pin_set_dt(&codec_reset_pin, 1);
    k_msleep(20);
    /* HIGH → reset released */
    ret=gpio_pin_set_dt(&codec_reset_pin, 0);
    k_msleep(50);
    // return 0;
    // if(ret<3)
    //   printf("fail hw reset");
    return 0;
static int codec_i2c_config(void)
    if (!device_is_ready(dev_i2c.bus))
        printk("Error: I2C bus %s is not ready!\n", dev_i2c.bus->name);
        return -1;
    printk("I2C bus ready, addr=0x%02x\n", dev_i2c.addr); //dev_i2c.addr
    return 0;
static int codec_gpios_config(void)
    int ret;
    if (!gpio_is_ready_dt(&codec_reset_pin))
        printk("Error: Codec reset pin not ready\n");
        return -1;
    ret=gpio_pin_configure_dt(&codec_reset_pin,
                                GPIO_OUTPUT_ACTIVE |
                                GPIO_ACTIVE_LOW);
                                GPIO_ACTIVE_LOW);
    if (ret < 0)
        printk("Error %d: Failed to configure codec reset pin\n", ret);
        return -1;
    return 0;
int codec_init(void)
    int ret;
    ret = codec_gpios_config();
    if (ret != 0)
        return ret;
    ret = codec_i2c_config();
    if (ret != 0)
        return ret;
    ret = codec_hw_reset();
    if (ret != 0)
        return ret;
    k_msleep(50);
    read_eg();
    return 0;
} this is my code i get -5 error
  • hi ,
    when i am connect i2s ans i2c together is gettimg -5 i2c error . without i2s , i2c register read is proper ??
  • &pinctrl {
            group1 {
                psels =
                        <NRF_PSEL(TWIM_SCL, 1, 11)>,
                        <NRF_PSEL(TWIM_SDA, 1, 12)>;
            group1 {
                psels = <NRF_PSEL(TWIM_SCL, 1,11)>,
                        low-power-enable;
            group1 {
                psels = <NRF_PSEL(I2S_SDIN, 1, 4)>,
                        <NRF_PSEL(I2S_SDOUT, 1, 5)>,
                        <NRF_PSEL(I2S_SCK_S, 1, 6)>,
                        <NRF_PSEL(I2S_MCK, 1, 13)>,
                        <NRF_PSEL(I2S_LRCK_M, 1, 14)>;
            group1 {
    &i2c22 {
        status = "okay";
            status = "okay";
            reg = < 0x18 >;
    &i2s20 {
        status = "okay";
    &led0 {status = "disabled";};
         custom_pins{
            compatible = "gpio-keys";
            codec_reset: codec-reset-node {
                gpios = <&gpio1 9 GPIO_ACTIVE_HIGH>;
                label = "Codec Reset Pin";
    &i2c30 {
    /delete-node/ &{/pin-controller/i2c22_default/group2/};
    /delete-node/ &{/pin-controller/i2s20_default/group5/};
    /delete-node/ &{/pin-controller/i2s20_default/group2/};
    /delete-node/ &{/pin-controller/i2s20_default/group3/};
    /delete-node/ &{/pin-controller/i2s20_default/group4/};
    // &button0 {
    //  /delete-property/ gpios;
    Since the issue only appears when I2S is active, it may be related to marginal I2C signal integrity. Could you try enabling internal pull-ups on the I2C pins by adding bias-pull-up to the i2c22_default pinctrl node, and check if the behavior changes. You could trying adding this to the overlay:
        group1 {
            psels =
            bias-pull-up;
    Best Regards,
    Syed Maysum
  • i have another issue in my code , when i read i2s 1 to 5 index is properly transmitted after enter to index 6 leads to -11 error
