Partition Manager: nRF54L15 OTP Memory Region Size Mismatch
Board: nRF54L15DK
NCS: v3.1.1
When I build an application for the nRF54L15 processor, the "otp" memory region in the auto generated "partitions.yml" file has a size of 0x4FC:
otp:
  address: 0xffd500
  end_address: 0xffd9fc
  region: otp
The real size of the OTP section is 0x500 (320 4-byte registers) "nrf54l15_types.h":
/* UICR_OTP: One time programmable memory */
  #define UICR_OTP_MaxCount (320UL)                  /*!< Max size of OTP[320] array.                                          */
  #define UICR_OTP_MaxIndex (319UL)                  /*!< Max index of OTP[320] array.                                         */
  #define UICR_OTP_MinIndex (0UL)                    /*!< Min index of OTP[320] array.                                         */
I tracked this autogenerated memory region to the "ncs/v3.1.1/nrf/cmake/sysbuild/partition_manager.cmake" file on lines 526 to 532:
    if(DEFINED ${image_name}_CONFIG_SOC_NRF54L15_CPUAPP
      OR DEFINED ${image_name}_CONFIG_SOC_NRF54L05_CPUAPP
      OR DEFINED ${image_name}_CONFIG_SOC_NRF54L10_CPUAPP
      set(otp_start_addr "0xffd500")
      set(otp_size 1276)  # 319 * 4
    endif()
Is the last of the OPT registers reserved for something?  Why is there a size discrepancy?
