bootloader_app_start vs NVIC_SystemReset();
Hi, i want to jump from my app to the bootloader, i used the function
void bootloader_app_start(void)
    vMBt_eStopAdv_Exe() ;// Stoping the BLE ADV
    sd_power_gpregret_clr(POWER_GPREGRET_GPREGRET_Msk);
sd_power_gpregret_set(BOOTLOADER_DFU_START);
sd_softdevice_disable();
interrupts_disable();
sd_softdevice_vector_table_base_set(NRF_UICR->BOOTLOADERADDR);
bootloader_util_app_start(NRF_UICR->BOOTLOADERADDR);
and it's OK , but when i use NVIC_SystemReset(); instead of bootloader_util_app_start it dosen't work and the bootloader dosen't start. although i added in the script of the bootloader to enter the bootloader program if GPREGRET=BOOTLOADERADDR or GPREGRET=0x00 ( case of a reset is handled )
this the modfication in the bootloader code :
if (dfu_start || (!bootloader_app_is_valid(DFU_BANK_0_REGION_START)) ||NRF_POWER->GPREGRET == 0x00)... this the condition part to enter dfu_mode , i just added the case where GPREGRET=0x00
Remarks:
1- the initialisation of the softdevice is always done in the case of a reset because we have :
-static bool dfu_start = false;
  • bool app_reset = (NRF_POWER->GPREGRET == BOOTLOADER_DFU_START);
  • ble_stack_init(!app_reset );
2- no button check is included , i commented that part as follow
//dfu_start |= ((nrf_gpio_pin_read(BOOTLOADER_BUTTON_PIN) == 0) ? true: false);
Questions :
  1. Why it dosen't work with the nvic reset ?
  2. can you explain to me the process of jump ..i have a small idea about assembly code but i don't know what are the registers used there when jumping...(thread mode .. )
  3. If i want to use Nvic_Reset() what should i do ? ( i don't care about the bonding service !! )
  4. This function ( __asm static void bootloader_util_reset(uint32_t start_addr) , used for the jump) is really confusing me !! in fact it's invoking a parameter that it never uses ..any explanation please
  • Hi Hung Bui,
    Ok, understood. But i hope you didn't miss understand my post. if you read my question, you will see that i said "and it's OK , but when i use NVIC_SystemReset(); instead of bootloader_util_app_start it dosen't work and the bootloader dosen't start " . That means ,before the soft reset i have set GPREGRET to BOOTLOADER_DFU_START . This the code i use for the soft reset : ( i don't use NVIC_SystemReset() only) :
    sd_softdevice_vector_table_base_set(NRF_UICR->BOOTLOADERADDR); //bootloader_util_app_start(NRF_UICR->BOOTLOADERADDR);
    NVIC_SystemReset();
  • Hi Hung Bui,
    Ok, i find the problem, and thanks for your help. It was my misunderstanding of the impact of a soft reset. In fact i thought it changes the GPREGRET register to 0x00 as the hard reset do. Now, i commented the code before the soft reset ,as follow :
    // sd_power_gpregret_clr(POWER_GPREGRET_GPREGRET_Msk); // clear GPREGRET flag
    // sd_power_gpregret_set(BOOTLOADER_DFU_START); // set GPREGRET flag
    and it's working well.
    One more information for the reader, it works because in the bootloader code there is some where
    sd_power_gpregret_clr(POWER_GPREGRET_GPREGRET_Msk); just when the dfu starts, thats why app_reset will be false and the !app =true and then the softdevice re*-init.
  • @Toto: I also missed the part that you set sd_power_gpregret_set(BOOTLOADER_DFU_START) before soft reset, with assumption that you will set it to something else or leave it = 0. Glad that you fixed the issue.
  • Hello Toto, i was reading your post and just before I was reading this link text I have used only this code in my application: uint32_t err_code; err_code = sd_power_gpregret_set(10); APP_ERROR_CHECK(err_code);
    NVIC_SystemReset();
    I hope it helps...
