NTN Support and Application Feasibility on nRF9151
Inquiry: NTN Support and Application Feasibility on nRF9151
I would like to seek clarification regarding Non-Terrestrial Network (NTN) support on the nRF9151.
There have been discussions and references suggesting NTN capability on the nRF9151, and I would like to better understand the current level of support and practical limitations.
Specifically, I am interested in the following:
1. Resource Availability
  • Which nRF Connect SDK versions include sample applications or support for NTN on nRF9151?
  • Are there example projects, reference code, or documentation demonstrating NTN connectivity in practice?
  • If official samples are not yet available, is there a roadmap or expected timeline for when they might be provided?
  • What type of antenna is required or recommended for NTN operation on the nRF9151?
2. Application Feasibility
We are currently using the nRF9151 with a Hologram eSIM in India, and our solution is working reliably:
  • connectivity
  • Cellular IoT stack
  • Data transmission to a CoAP server
Given this setup:
  • Is a similar application architecture feasible over NTN?
  • Can CoAP-based data transmission be supported over NTN in a comparable manner?
3. SDK Support and Examples
  • I could not find any nRF Connect SDK samples, documentation, or application notes specifically related to NTN on nRF9151
  • Are there any example applications, experimental features, or recommended references available?
  • If not, could you please advise on the current status and roadmap for NTN support on nRF9151?
Any guidance, documentation links, or clarification would be greatly appreciated.
Thank you for your support.
  • Benjamin,
    Thanks for confirming CoAP/custom payloads work over NTN.
    Achim mentioned adding NTN support using AT commands. Is there a library or code example for this, or is it a manual AT command configuration?
    And also we need a special eSIM/SIM for NTN, different from standard cellular NB-IoT?
    Appreciate the guidance.
    Priyesh
  • Achim mentioned adding NTN support using AT commands.
    That was referring to NCS 3.1.0. With NCS 3.2.0 that's included in the nrf/lib/lte_link_control.
    No, the nRF9151 supports switching between terrestrial and non-terrestrial radio access. You could use the same SIM card if that is what you are asking. However, you need a network operator that supports NTN.
    Benjamin
  • Thanks for the clarification on the SIM and network operator requirements.
    regards,
    Priyesh
  • I am working with an nRF9151 SMA DK using nRF Connect SDK v3.2.1 and testing NTN connectivity. When using the precompiled Eval HEX and issuing AT commands, the device is able to register on the NTN network, successfully ping external hosts, and establish UDP communication with a server. This indicates that basic NTN registration and IP connectivity are functioning as expected.
    However, while using AT commands, I was not able to construct a valid CoAP payload in hexadecimal format suitable for transmission over NTN. To address this, I switched to the CoAP client sample from the Nordic DevAcademy exercise and modified it to enable NTN, configure the required NTN settings, and provide device location using ntn_location_set() together with an NTN event handler.
    The modified CoAP application builds and flashes successfully, and there are no compile-time or obvious runtime errors. When running this application in LTE mode, the CoAP sample behaves as expected and is able to connect to the server and exchange data. When switching the same application to NTN mode, however, the device does not establish the connection.
    Given that raw UDP communication over NTN works via AT commands and the same CoAP sample works correctly over LTE, I would like to understand whether there are additional requirements or limitations when using CoAP over NTN on the nRF9151. Specifically, are there any required socket, CoAP, or modem configurations that differ between LTE and NTN, or any known constraints that would prevent the DevAcademy CoAP sample from working over NTN without further modification?
    is there anything that I should add in this code? I am using modem firmware from sma dk eval web page.
    code
     * Copyright (c) 2019 Nordic Semiconductor ASA
    #include <stdio.h>
    #include <ncs_version.h>
    #include <zephyr/kernel.h>
    #include <zephyr/net/socket.h>
    #include <modem/nrf_modem_lib.h>
    #include <modem/lte_lc.h>
    #include <zephyr/random/random.h>
    #include <zephyr/net/coap.h>
    #include <modem/ntn.h>
    #define SEND_REQ_THREAD_STACK_SIZE 1024
    #define SEND_REQ_THREA_PRIORITY 5
    /* Define the macros for the CoAP version and message length */
    #define APP_COAP_VERSION 1
    #define APP_COAP_MAX_MSG_LEN 1280
    K_SEM_DEFINE(con_sem, 0, 1);
    /* Declare the buffer coap_buf to receive the response. */
    static uint8_t coap_buf[APP_COAP_MAX_MSG_LEN];
    /* Define the CoAP message token next_token */
    static uint16_t next_token;
    static int sock;
    static struct sockaddr_storage server;
    static uint8_t test_counter = 0;
    K_SEM_DEFINE(lte_connected, 0, 1);
    LOG_MODULE_REGISTER(main, LOG_LEVEL_INF);
    /**@brief Resolves the configured hostname. */
    static int server_resolve(void)
            int err;
            struct addrinfo *result;
            struct addrinfo hints = {
                .ai_family = AF_INET,
                .ai_socktype = SOCK_DGRAM};
            char ipv4_addr[NET_IPV4_ADDR_LEN];
            err = getaddrinfo(CONFIG_COAP_SERVER_HOSTNAME, NULL, &hints, &result);
            if (err != 0)
                    LOG_ERR("ERROR: getaddrinfo failed %d\n", err);
                    return -EIO;
            if (result == NULL)
                    LOG_ERR("ERROR: Address not found\n");
                    return -ENOENT;
            /* IPv4 Address. */
            struct sockaddr_in *server4 = ((struct sockaddr_in *)&server);
            server4->sin_addr.s_addr =
                ((struct sockaddr_in *)result->ai_addr)->sin_addr.s_addr;
            server4->sin_family = AF_INET;
            server4->sin_port = htons(CONFIG_COAP_SERVER_PORT);
            inet_ntop(AF_INET, &server4->sin_addr.s_addr, ipv4_addr,
                      sizeof(ipv4_addr));
            LOG_INF("IPv4 Address found %s\n", ipv4_addr);
            /* Free the address. */
            freeaddrinfo(result);
            return 0;
    /**@brief Initialize the CoAP client */
    static int client_init(void)
            int err;
            sock = socket(AF_INET, SOCK_DGRAM, IPPROTO_UDP);
            if (sock < 0)
                    LOG_ERR("Failed to create CoAP socket: %d.\n", errno);
                    return -errno;
            err = connect(sock, (struct sockaddr *)&server,
                          sizeof(struct sockaddr_in));
            if (err < 0)
                    LOG_ERR("Connect failed : %d\n", errno);
                    return -errno;
            LOG_INF("Successfully connected to server");
            /* Generate a random token after the socket is connected */
            next_token = sys_rand32_get();
            k_sem_give(&con_sem);
            return 0;
    static void lte_handler(const struct lte_lc_evt *const evt)
            switch (evt->type)
            case LTE_LC_EVT_NW_REG_STATUS:
                    if ((evt->nw_reg_status != LTE_LC_NW_REG_REGISTERED_HOME) &&
                        (evt->nw_reg_status != LTE_LC_NW_REG_REGISTERED_ROAMING))
                    LOG_INF("Network registration status: %s",
                            evt->nw_reg_status == LTE_LC_NW_REG_REGISTERED_HOME ? "Connected - home network" : "Connected - roaming");
                    k_sem_give(&lte_connected);
            case LTE_LC_EVT_RRC_UPDATE:
                    LOG_INF("RRC mode: %s", evt->rrc_mode == LTE_LC_RRC_MODE_CONNECTED ? "Connected" : "Idle");
    static int modem_configure(void)
            int err;
            LOG_INF("Initializing modem library");
            err = nrf_modem_lib_init();
            if (err)
                    LOG_ERR("Failed to initialize the modem library, error: %d", err);
                    return err;
            lte_lc_system_mode_set(LTE_LC_SYSTEM_MODE_NTN_NBIOT, LTE_LC_SYSTEM_MODE_PREFER_AUTO);
            LOG_INF("Connecting to LTE network");
            err = lte_lc_connect_async(lte_handler);
            if (err)
                    LOG_ERR("Error in lte_lc_connect_async, error: %d", err);
                    return err;
            k_sem_take(&lte_connected, K_FOREVER);
            LOG_INF("Connected to LTE network");
            return 0;
    /**@brief Send CoAP POST request. */
    static int client_post_send(void)
            int err;
            struct coap_packet request;
            /* Initialize the CoAP packet and append the resource path */
            err = coap_packet_init(&request, coap_buf, sizeof(coap_buf),
                                   APP_COAP_VERSION, COAP_TYPE_CON,
                                   sizeof(next_token), (uint8_t *)&next_token,
                                   COAP_METHOD_POST, coap_next_id());
            if (err < 0)
                    LOG_ERR("Failed to create CoAP request, %d\n", err);
                    return err;
            err = coap_packet_append_option(&request, COAP_OPTION_URI_HOST,
                                            (uint8_t *)CONFIG_COAP_SERVER_HOSTNAME,
                                            strlen(CONFIG_COAP_SERVER_HOSTNAME));
            if (err < 0)
                    LOG_ERR("Failed to encode CoAP option, %d\n", err);
                    return err;
            err = coap_packet_append_option(&request, COAP_OPTION_URI_PATH,
                                            (uint8_t *)CONFIG_COAP_TX_RESOURCE,
                                            strlen(CONFIG_COAP_TX_RESOURCE));
            if (err < 0)
                    return err;
            /* Add payload marker */
            err = coap_packet_append_payload_marker(&request);
            if (err < 0)
                    LOG_ERR("Failed to append payload marker, %d\n", err);
                    return err;
            /* Format and append test_counter as payload */
            char payload[64];
            int len = snprintf(payload, sizeof(payload), "0000000000000000000000000000000");
            if (len < 0 || len >= sizeof(payload))
                    LOG_ERR("Failed to format counter payload");
                    return -EINVAL;
            err = coap_packet_append_payload(&request, (uint8_t *)payload, len);
            if (err < 0)
                    LOG_ERR("Failed to append payload, %d\n", err);
                    return err;
            err = send(sock, request.data, request.offset, 0);
            if (err < 0)
                    LOG_ERR("Failed to send CoAP request, %d\n", errno);
                    return -errno;
            LOG_INF("CoAP POST request sent: Token 0x%04x\n", next_token);
            return 0;
    /**@brief Handles responses from the remote CoAP server. */
    static int client_handle_response(uint8_t *buf, int received)
            struct coap_packet reply;
            uint8_t token[8];
            uint16_t token_len;
            const uint8_t *payload;
            uint16_t payload_len;
            uint8_t temp_buf[128];
            /* Parse the received CoAP packet */
            int err = coap_packet_parse(&reply, buf, received, NULL, 0);
            if (err < 0)
                    LOG_ERR("Malformed response received: %d\n", err);
                    return err;
            /* Confirm the token in the response matches the token sent */
            token_len = coap_header_get_token(&reply, token);
            if ((token_len != sizeof(next_token)) ||
                (memcmp(&next_token, token, sizeof(next_token)) != 0))
                    LOG_ERR("Invalid token received: 0x%02x%02x\n",
                            token[1], token[0]);
                    return 0;
            /* Retrieve the payload and confirm it's nonzero */
            payload = coap_packet_get_payload(&reply, &payload_len);
            if (payload_len > 0)
                    snprintf(temp_buf, MIN(payload_len + 1, sizeof(temp_buf)), "%s", payload);
                    strcpy(temp_buf, "EMPTY");
            /* Log the header code, token and payload of the response */
            LOG_INF("CoAP response: Code 0x%x, Token 0x%02x%02x, Payload: %s\n",
                    coap_header_get_code(&reply), token[1], token[0], (char *)temp_buf);
            return 0;
    /* Example location structure – exact type is defined by the NTN API
     * (not fully shown in the provided docs). Adjust to the real type.
    struct app_location
            double lat;
            double lon;
            float accuracy_m;
    /* Stub: get location from external GNSS or other source */
    static int app_get_location(struct app_location *loc)
            /* TODO: Implement real location acquisition */
            loc->lat = 36.331449;
            loc->lon = -119.292130;
            loc->accuracy_m = 200.0f;
            return 0;
    /* Convert app_location to NTN library location type and call ntn_location_set().
     * The docs state that validity time must be longer than the interval between updates.[[NTN usage](https://docs.nordicsemi.com/bundle/ncs-latest/page/nrf/libraries/modem/ntn.html#usage)]
    static int app_ntn_provide_location(uint32_t validity_time_s)
            struct app_location loc;
            int err = app_get_location(&loc);
            if (err)
                    LOG_ERR("Failed to get location: %d", err);
                    return err;
            err = ntn_location_set(loc.lat, loc.lon, 12, validity_time_s);
            if (err)
                    LOG_ERR("ntn_location_set failed: %d", err);
                    LOG_INF("NTN location updated, valid for %u s", validity_time_s);
            return err;
    /* NTN event handler – called when modem needs location updates.[[NTN usage](https://docs.nordicsemi.com/bundle/ncs-latest/page/nrf/libraries/modem/ntn.html#usage)] */
    static void app_ntn_event_handler(const struct ntn_evt *evt)
            switch (evt->type)
            case NTN_EVT_LOCATION_REQUEST:
                    LOG_INF("NTN location request");
                    /* Decide update interval based on max device speed, as suggested in docs.
                     * Example: 200 m accuracy, 120 km/h => update at least every 6 s.[[NTN usage](https://docs.nordicsemi.com/bundle/ncs-latest/page/nrf/libraries/modem/ntn.html#usage)]
                    app_ntn_provide_location(60000); /* validity_time_s >= update interval */
                    LOG_DBG("Unhandled NTN event type: %d", evt->type);
            int err;
            int received;
            /* Register NTN handler (safe even if you start in TN mode) */
            ntn_register_handler(app_ntn_event_handler);
            err = modem_configure();
            if (err)
                    LOG_ERR("Failed to configure the modem");
                    return 0;
            if (server_resolve() != 0)
                    LOG_INF("Failed to resolve server name");
                    return 0;
            if (client_init() != 0)
                    LOG_INF("Failed to initialize client");
                    return 0;
            while (1)
                    /* Receive response from the CoAP server */
                    received = recv(sock, coap_buf, sizeof(coap_buf), 0);
                    if (received < 0)
                            LOG_ERR("Socket error: %d, exit\n", errno);
                    else if (received == 0)
                            LOG_INF("Empty datagram\n");
                            continue;
                    err = client_handle_response(coap_buf, received);
                    if (err < 0)
                            LOG_ERR("Invalid response, exit\n");
            (void)close(sock);
            return 0;
    void send_req_thread(void *arg1, void *arg2, void *arg3)
            k_sem_take(&con_sem, K_FOREVER);
            while (1)
                    client_post_send();
                    k_sleep(K_SECONDS(10));
    K_THREAD_DEFINE(send_req, SEND_REQ_THREAD_STACK_SIZE, send_req_thread, NULL, NULL, NULL,
                    SEND_REQ_THREA_PRIORITY, 0, 0);
