nRF Connect for VS Code settings failure and consequences
Hello, this ticket addresses three issues:
1. After installing nrfutil with subcommands device and toolchain-manager and sdk-manager, into %USERPROFILE%\.nrfutil, everything works fine when I set Nrf-connect › Nrfutil: Home in VS Code to that value. However, when I only install subcommands device and toolchain-manager, like the help information paragraph for that variable states, things do not work. So, this ticket I am opening to ask you to update the help information. I realize that sdk-manager is a newer command than toolchain-manager.
2. After setting the Nrf-connect › Nrfutil: Home variable, it is ignored when I attempt to flash a device. Instead, nRF Connect for VS Code insists on using the nrtutil in the toolchain.
3. As you are hopefully aware by now from various tickets that I and others have opened, C:\ncs\toolchains\66cdf9b75e\nrfutil\home\bin\nrfutil-device.exe has a bug and does not work if there are any CH340 or CP2102 devices on the USB bus. I was forced to replace that file in the toolchain with C:\Users\test\.nrfutil\bin\nrfutil-device.exe in order to flash my nRF9160DK when I have a CP2102 device on the USB bus.
The three issues are of course closely interrelated. Please let me know the schedule and plans for fixing these issues.
Burt Silverman
  • Be aware that when you open a toolchain the nrfutil home is inside the toolchain to use the nrfutil that is bundled with the toolchain. They will update relevant help text to clarify.
    Kenneth
  • Thank you, Kenneth, I will look forward to seeing what they change in upcoming releases.
    Burt
  • What does it mean in the Changelog for the most recent version when they say under Actions:
    • Updated the nrfutil device binary bundled with the extension to v2.15.6.
    In other words, under what conditions will one see 2.15.6 as opposed to whatever is bundled with the toolchain? Are they saying if you pick some old toolchain that does not have nrfutil bundled, then you would see 2.15.6 for nrfutil device? In any case, currently I can only see either the nrfutil device that is installed on my base Ubuntu Linux system or the nrfutil device bundled with the toolchain -- depending upon how I open the terminal. Forgive me if it sounds like I am repeating myself, but this is the first time I have looked at the Changelog.
    Burt
  • Hi Burt,
    To clarify, when the extension lists/installs/uninstalls SDKs and toolchains, also when generating an process environment for the combination of these, it uses a bundled sdk-manager binary. Bundled meaning bundled in the extension, not in the toolchain.
    Similarly when it enumerates connected devices, and for actions like erase/recover/reset, it uses the bundled device binary.
    Any other call that the user does in the terminal, or via any SDK script or west command (e.g. flash) will use nrfutil from the toolchain or PATH.
    Kenneth
  • Thanks for the good information, Kenneth. I reconfirmed that flash uses nrfutil from the toolchain or PATH by temporarily removing all of those instances of the device subcommand and seeing the flash failure. I will close the ticket. Also, I guess it is consistent with the fact that I could not change flash behavior by adjusting the Nrfutil:Home variable in the extension settings. It's complicated but I"m confident there are logical reasons for the designers to come up with what they did.
    Burt
