nrf9151 NTN Sockets
Hi all,
I'm testing Skylo NTN on nRF9151 SMA DK with the latest pre-commercial/alpha NTN modem firmware (downloaded mid-December 2025).
Registration works fine, and uplink NIDD send succeeds (#XSEND with WAITACK, #XSENDNTF confirm).
However, receiving downlink NIDD is impossible:
- #XSOCKET=1,3,0 succeeds (#XSOCKET: <id>,3,0 OK)
- #XSOCKET? confirms socket open
- #XRECV=<any timeout> (even 5s or 300s) immediately returns ERROR
I tried:
- RAI (#XSOCKETOPT=<id>,61,3) — ERROR (not supported?)
- Disabling PSM/eDRX (CPSMS=0, CEDRXS=0)
- Polling #XRECV multiple times quickly
- Events enabled (%MDMEV=2)
Is this expected behavior in the current alpha firmware?
Modem firmware version: 1.0.0-1.alpha nRF91
Using SLM Application ncs-serial-modem
Thanks for any guidance — excited for NTN but stuck on receive!
Logs:
> AT+CGMR
mfw_nrf9151-ntn_1.0.0-1.alpha
OK
> AT#XSEND=128,0,8192,"ECHO: Test msg"
#XSEND: 128,1,14
OK
%MDMEV: PRACH CE-LEVEL 0
+CSCON: 1,7,4
> AT#XRECV=5
ERROR
> AT#XRECV=5
ERROR
#XSENDNTF: 128,0,14
+CSCON: 0,7,4
> AT#XSOCKET=1,3,0
ERROR
> AT#XCLOSE=128
#XCLOSE: 128,0
OK
> AT#XSOCKET=1,3,0
#XSOCKET: 128,3,0
OK
#XSEND: 128,1,0
ERROR
#XSEND: 128,1,0
ERROR
#XSEND: 128,1,0
ERROR
> AT#XSEND=130,0,8192,"ECHO: Test msg"
#XSEND: 130,1,0
ERROR
> AT#XCLOSE=128
#XCLOSE: 128,0
OK
> AT#XSOCKET=0
ERROR
> AT#XSOCKET?
#XSOCKET: 129,3,0,3,0
#XSOCKET: 130,3,0,3,0
#XSOCKET: 131,3,0,3,0
OK
> AT#XCLOSE=129
#XCLOSE: 129,0
OK
> AT#XCLOSE=130
#XCLOSE: 130,0
OK
> AT#XCLOSE=131
#XCLOSE: 131,0
OK
> AT#XSOCKET?
OK
> AT#XSOCKET=1,3,0
#XSOCKET: 128,3,0
OK
> AT#XRECV=5
ERROR
> AT%CSCON=3
ERROR
> AT%MDMEV=2
OK
> AT#XSOCKET?
#XSOCKET: 128,3,0,3,0
OK
> AT#XSOCKETOPT=128,61,3
ERROR
ERROR
> AT#XSOCKET?
OK
> AT#XSOCKET=1,3,0
#XSOCKET: 129,3,0
OK
> #XSOCKETOPT=129,61,3
ERROR
> AT#XRECV=120
ERROR
> AT#XSOCKET=1,3,0
#XSOCKET: 130,3,0
OK
> AT#XRECV=120
ERROR
> AT#XRECV=120
ERROR
> AT#XRECV=120
ERROR
> AT#XRECV=120
ERROR
> AT#XRECV=120
ERROR
> AT#XRECV=120
ERROR
> AT#XRECV=120
ERROR
> AT#XSOCKET=130
ERROR
> AT#XSOCKET=129
ERROR
> AT#XCLOSE=129
#XCLOSE: 129,0
OK
> AT#XCLOSE=130
#XCLOSE: 130,0
OK
> AT#XSOCKET=1,3,0
#XSOCKET: 129,3,0
OK
> AT#XRECV=300
ERROR
> AT#XRECV=800
ERROR
> AT+CPSMS=0
OK
> AT+CEDRXS=0
OK
> AT#XSOCKET=1,3,0
#XSOCKET: 130,3,0
OK
> AT#XRECV=300
ERROR
  • Hi Simon D-M,
    I have follow monogoto website, but I think there are a few steps I have got confused
    1. After I program 2.0.2 with zip(after unzip full download from  Nordic,there is an zip I will call that A.zip2. I unzip the full dowanload and use A.zip for "Write" to flash SMA
    2. Look for hex(I was using subdir hex file) to do "Erase and Write", where the bootloader partion disapear(shuold I pick the img subdir hex instaed), apear the booloader portion disapear
    3. Then the board does not activate for AT command
    So are you able to provide me the steps include where should I use the hex and zip file from my download zip 2.0.2 and the alpha zip
    Below is 2.0.2 release note ,
    1. Should I use hex from"img_app_bl" for Erase and Write?
    These files were built with nRF Connect SDK version v3.1.0
    from sdk-nrf repository (github.com/.../sdk-nrf)
    Full commit SHA: 6c6e5b32496eb7203f4c52ae9b3575949eab522e
    Folder contents:
    img_app_bl/
      - Full application images including bootloader.
      - These files can be used with:
        - nRF Connect Programmer.
        - nRF Util CLI.
     img_dfu_zip/
      - These images contain only application and bootloader is not included.
      - Images are in binary format.
        - Over-the-air update, for example, through nRF Cloud, Azure or AWS.
    img_fota_dfu_hex/
      - Images are in HEX format.
      - These files can be used with nRF Connect Programmer (through USB bootloader only).
    img_fota_dfu_bin/
        - nRF Util CLI (through USB bootloader only)
    The following folders contain images configured for modem debugging:
      - img_app_bl/debug
      - img_fota_dfu_hex/debug
      - img_fota_dfu_bin/debug
    And 2.0.2 does not include NTN band
    *** mfw_nrf91x1_2.0.2
    The mfw_nrf91x1 is Cellular IoT and Positioning firmware for modem subsystem of nRF9131 LACA A0,
    nRF9151 LACA A0, and nRF9161 LACA A0 SiP modules. It supports 3GPP LTE release 14 LTE-M and NB-IoT
    standards, selected optional 3GPP LTE release 14 and 15 features, GPS L1C/A and QZSS L1C/A
    positioning.
    LTE-M operation is enabled on E-UTRA bands 1, 2, 3, 4, 5, 8, 12, 13, 18, 19, 20, 25, 26, 28, 66
    and 85.
    NB-IoT operation is enabled on E-UTRA bands 1, 2, 3, 4, 5, 8, 12, 13, 17, 19, 20, 25, 26, 28, 65, 66
    and 85.
    .............................Jan 1st  2026  ....................
    Hi Simon-D-M
    Finally I can complete 2.0.2 modem an Aplication to programm to the kit
    Modem versiom is 2.0.2, but some how not all commands work.
    My steps are
    1. Download 2.0.2
    2. Unzip it,
    3. Open Programmer
    4. Look unzip folder first seen zip file, and "Write"
    5. And then goto xx_bl folder, look for servic,.xxx.hex,this file include bootloader
    6. Add it and "Eraseand write",
    7.I can send at command, but mfm still 2.0.2
    My question is how can I make it 1.0.0.1 alpha, the zip file I dowanload does not contain hex works for fullfucion, or there is steps I am missing here
  • Hi yayalew
    How do you pragram the "alpha" modem firmware to the board?
    I have download the alpha zip  ut there is no saying how to apply.
    I unzip the alpha file , but do not see aany hex is good for "Write" or "Erase and Write"
    If you can kindly provive the donload link and steps to apply
    Simon
  • HI Simon-DM
    I decide to give up for now
    I will switch to other brand development kit
    Simon
  • > 1. After I program 2.0.2 with zip(after unzip full download from  Nordic,
    Just to give you some hints:
    "unzip full download"
    Nobody will fully understand, what you did. There are so many "downloads" around the nRF91, that even the "full" in the context of the modem firmware doesn't clear that up.
    If you want to use the nRF9151 A1 for NTN (and TN), you need
    mfw_nrf9151-ntn_1.0.0-1.alpha.zip
    and if you want to rollback to TN (only), you need
    mfw_nrf91x1_2.0.4.zip
    Now: never ever unzip these mfw downloads! Apply them with:
    nrfjprog --verify -r --program mfw_nrf9151-ntn_1.0.0-1.alpha.zip
    or
    nrfjprog --verify -r --program mfw_nrf91x1_2.0.4.zip
    I don't know, how often I did that in the last months (for sure more than 10x, and with several DKs), it was always successful. And never unzipped by me.
    Using the "Programmer App" of the "nRF Connect for PC" works similar:
    - Select your DK with "Select Device".
    - Add either the "mfw_nrf9151-ntn_1.0.0-1.alpha.zip" or the "mfw_nrf91x1_2.0.4.zip" with "Add file"
    The the "Programmer App" will show you the resulting functions, "erase & write" is disabled, "Write" is enabled, so select that. A new dialog "Modem DFU" is shows up, confirm "write" and then wait, it takes a minute or two.
    Also that was always successful, even if I use the "Programmer App" only in rare cases.
  • Hi Achim
    What I see was
    1. When I first power up the board(2.0.3 by default), there are two LEDs light up, one is power LED ,one is LED1. And I can run AT command from rfn connect tool serial command, to check modem version, etc
    2. After I did alpha.zip by  "write", the LED1 went off,and not able to execute at command anymore
    3. After redo v2.0.3 by quict start,
    4. and check at command v0.7 and 1.04
    the 0.7 AT%XSYSTEMMODE=0,0,0,0,1  : 5 parameters
    The 1.04 AT%XSYSTEMMODE=0,0,0,1 : only 4, if I put 5 , it will get error
    This is what I get in past a few days
    FYI, I have NTN sim card activated as well.
