[00:06:49.411,024] <inf> i2s_nrfx: I2S MCK frequency: 256000, actual PCM rate: 8000
what changes i made my code to get proper transmission
Best Regards
Sharon
Thanks for sharing the details and prj.conf. With retry pacing in place and CONFIG_I2S_NRFX_TX_BLOCK_COUNT=8, the earlier -EAGAIN TX queue behavior should now be handled correctly on the application side.
Regarding MCK: the nRF I2S peripheral does support generating MCK at 256x LRCK as shown here in master mode using the appropriate I2S ratio configuration. The current log shows 32x LRCK simply because of the current I2S clock configuration, not due to a hardware limitation.
The remaining question is whether your codec strictly requires 256x LRCK or just recommends it. If it is required, the next step would be to adjust the I2S configuration (ratio and MCK frequency) to generate MCK for the selected sample rate and verify that this frequency is achievable and within the codec’s tolerance.
Best Regards,
Syed Maysum
i2s require 4mhz
i got same -eagen error
