i2S is gave after 1 to 6 index transmission get error code 11 why this happen ??
 * Copyright 2023 NXP
#include <zephyr/kernel.h>
#include <zephyr/device.h>
#include <zephyr/drivers/i2s.h>
#include <stdio.h>
#include "codec_header.h"
#define SAMPLE_NO   64
#define CHANNELS    2
#define NUM_BLOCKS  4
/* BLOCK_SIZE in bytes */
#define BLOCK_SIZE (CHANNELS * SAMPLE_NO * sizeof(int16_t))
const struct device *dev_i2s = DEVICE_DT_GET(DT_NODELABEL(i2s20));
/* Stereo interleaved buffers */
static int16_t tx_block[NUM_BLOCKS][CHANNELS * SAMPLE_NO];
/* Sine wave table */
static const int16_t sine[SAMPLE_NO] = {
     3211,  6392,  9511, 12539, 15446, 18204, 20787, 23169,
    25329, 27244, 28897, 30272, 31356, 32137, 32609, 32767,
    32609, 32137, 31356, 30272, 28897, 27244, 25329, 23169,
    20787, 18204, 15446, 12539,  9511,  6392,  3211,     0,
    -3212, -6393, -9512,-12540,-15447,-18205,-20788,-23170,
   -25330,-27245,-28898,-30273,-31357,-32138,-32610,-32767,
   -32610,-32138,-31357,-30273,-28898,-27245,-25330,-23170,
   -20788,-18205,-15447,-12540, -9512, -6393, -3212,    -1
static void fill_buf(int16_t *buf, int shift)
    for (int i = 0; i < SAMPLE_NO; i++) {
        buf[2 * i]     = sine[i] >> shift;                 /* Left */
        buf[2 * i + 1] = sine[(i + SAMPLE_NO / 4) % SAMPLE_NO] >> shift; /* Right */
    struct i2s_config i2s_cfg;
    int ret;
    printk("=== System start ===\n");
   // POWER-UP DELAY
    k_msleep(300);
    // provide mclk clock
    //mclk_timer();
    // INIT I2C
    ret = i2c_init_codec();
    if (ret)
        printk("Codec I2C init failed (%d). STOP.\n", ret);
        while (1)
            k_sleep(K_FOREVER);
    printk("Codec I2C init OK\n");
    // CHECK I2S DEVICE
    if (!device_is_ready(dev_i2s)) {
        printk("I2S device not ready\n");
        return -ENODEV;
    // CONFIGURE I2S
    memset(&i2s_cfg, 0, sizeof(i2s_cfg));
    i2s_cfg.word_size = 16;
    i2s_cfg.channels = CHANNELS;
    i2s_cfg.format = I2S_FMT_DATA_FORMAT_I2S;
    i2s_cfg.frame_clk_freq = 8000;
    i2s_cfg.block_size = BLOCK_SIZE;
    i2s_cfg.timeout =1000;
    i2s_cfg.options = I2S_OPT_FRAME_CLK_MASTER | I2S_OPT_BIT_CLK_MASTER;
    ret = i2s_configure(dev_i2s, I2S_DIR_TX, &i2s_cfg);
    if (ret)
        printk("I2S configure failed (%d)\n", ret);
        return ret;
    printk("I2S configured.........\n");
    // PREPARE AUDIO BUFFERS
    for (int i = 0; i < NUM_BLOCKS; i++)
        fill_buf(tx_block[i], i % 3);
    // QUEUE BUFFERS BEFORE START
    ret = i2s_write(dev_i2s, tx_block[0], BLOCK_SIZE);
    ret |= i2s_write(dev_i2s, tx_block[1], BLOCK_SIZE);
    if (ret)
        printk("I2S write failed (%d)\n", ret);
        return ret;
    printk("Initial TX buffers queued\n");
    // NOW START I2S -lrck
    ret = i2s_trigger(dev_i2s, I2S_DIR_TX, I2S_TRIGGER_START);
    if (ret)
        printk("I2S start failed (%d)\n", ret);
        return ret;
    printk("I2S started successfully\n");
 // remaining buffer
    int idx = 2;
    while (1)
        ret = i2s_write(dev_i2s, tx_block[idx % NUM_BLOCKS], BLOCK_SIZE);
       // ret = i2s_write(dev_i2s, tx_block[idx % NUM_BLOCKS], BLOCK_SIZE);
        if (ret == 0)
            idx++;
            k_msleep(1);
        else if (ret == -EAGAIN)
            i2s_trigger(dev_i2s, I2S_DIR_TX, I2S_TRIGGER_DRAIN);
            k_msleep(2);
            printk("I2S write error (%d)\n", ret);
   printk("i2s_write.............");
    return 0;
 ovelay file
&pinctrl {
    i2c21_default: i2c22_default {
        group1 {
            psels =
                    <NRF_PSEL(TWIM_SCL, 1, 12)>,
                    <NRF_PSEL(TWIM_SDA, 1, 13)>;
                    bias-pull-up;
    i2c21_sleep: i2c22_sleep {
        group1 {
            psels = <NRF_PSEL(TWIM_SCL, 1,12)>,
                    low-power-enable;
    i2s20_default: i2s20_default {
        group1 {
            psels = <NRF_PSEL(I2S_SDIN, 1, 6)>, <NRF_PSEL(I2S_SCK_S, 1, 3)>;
    i2s20_sleep: i2s20_sleep {
        group1 {
                    <NRF_PSEL(I2S_SDOUT, 1, 5)>,
                    <NRF_PSEL(I2S_SCK_S, 1, 3)>,
                    <NRF_PSEL(I2S_MCK, 1, 4)>,
                    <NRF_PSEL(I2S_LRCK_M, 1, 14)>;
&i2c21 {
    status = "disabled";
    pinctrl-0 = <&i2c22_default>;
    pinctrl-1 = <&i2c22_sleep>;
    audiocodec: audiocodec@18 {
        compatible = "i2c-device";
        status = "okay";
        reg = < 0x18 >;
&i2s20 {
    status = "okay";
    pinctrl-0 = <&i2s20_default>;
    pinctrl-1 = <&i2s20_sleep>;
     custom_pins{
        compatible = "gpio-keys";
        codec_reset: codec-reset-node {
            gpios = <&gpio1 9 GPIO_ACTIVE_HIGH>;
            label = "Codec Reset Pin";
&i2c21 {
    status = "okay";
    button0: button_0 {
        button0_key: button0_key {
            gpios = <&gpio1 15 0>;
            label = "MCUBoot Button";
    leds {
        compatible = "gpio-leds";
        led0: led_0 {
            gpios = <&gpio1 0 GPIO_ACTIVE_HIGH>;
            label = "User LED 0";
&uart20 {
    status = "okay";
&uart20_default {
    group1 {
        psels = <NRF_PSEL(UART_TX, 1, 8)>, <NRF_PSEL(UART_RX, 1, 7)>;
/delete-node/ &{/pin-controller/i2c22_default/group2/};
&i2c22 {
/delete-node/ &button0;
/delete-node/ &{/pin-controller/i2s20_default/group5/};
/delete-node/ &{/pin-controller/i2s20_default/group2/};
/delete-node/ &{/pin-controller/i2s20_default/group4/};
/delete-node/ &{/pin-controller/i2s20_default/group3/};
 should i implement mclk clock seprate in code ??
OK
[00:06:49.411,024] <inf> i2s_nrfx: I2S MCK frequency: 256000, actual PCM rate: 8000
        .sck_pin      = _pin_sck,                                                         \
        .lrck_pin     = _pin_lrck,                                                        \
        .mck_pin      = _pin_mck,                                                         \
        .sdout_pin    = _pin_sdout,                                                       \
        .sdin_pin     = _pin_sdin,                                                        \
        .irq_priority = NRFX_I2S_DEFAULT_CONFIG_IRQ_PRIORITY,                             \
        .mode         = NRF_I2S_MODE_SLAVE,                                              \
        .format       = NRF_I2S_FORMAT_I2S,                                               \
        .alignment    = NRF_I2S_ALIGN_LEFT,                                               \
        .sample_width = NRF_I2S_SWIDTH_16BIT,                                             \
        .channels     = NRF_I2S_CHANNELS_LEFT,                                            \
        .mck_setup    = NRF_I2S_MCK_32MDIV8,                                              \
        .ratio        = NRF_I2S_RATIO_512X,                                                \
        NRFX_COND_CODE_1(NRF_I2S_HAS_CLKCONFIG,                                           \
                         (.clksrc = NRF_I2S_CLKSRC_PCLK32M,                               \
                          .enable_bypass = false,),                                       \
    Thanks for the updates. I think we may be mixing a few different topics, so just to make sure I understand you correctly and can help in the right direction, could we first align on one thing? Could you please confirm what you want the nRF54L15 to do for the I2S clocks:
    1. Option A:
      The nRF54L15 should generate the I2S clocks (BCLK, LRCK, and MCK), and the codec should use those clocks.
    2. Option B:
      The nRF54L15 should work as an I2S slave, and the clocks (BCLK/LRCK/MCK) are provided by an external source or the codec.
    These two setups are configured very differently, so confirming this first will help avoid confusion. Once this is clear, we can then look at: the I2S -11 (-EAGAIN) messages, and the I2C -5 (I/O error) issue separately if it still happens.
    Thanks for confirming, and we’ll take it step by step from there. Regards,
    Syed Maysum
    1. Option B:
      The nRF54L15 should work as an I2S slave, and the clocks (BCLK/LRCK/MCK) are provided by an external source or the codec.  this one
    Thanks for confirming the I2S slave setup. To summarize and move forward clearly:
    1. I2S slave mode and clocks
      Since the nRF54L15 is configured as an I2S slave, it does not control BCLK or LRCK. MCK must be provided by the external device (codec), or explicitly enabled internally only if the external master cannot provide it. So If your codec provides MCK, please remove all master clock settings (mck_setup, ratio, clksrc) from the nrfx_i2s configuration to avoid clock conflicts.
      // REMOVE these
      .mck_setup
      .ratio
      .clksrc
    2. Pin routing on nRF54L15
      On nRF54L15, the I2S peripheral and TWIM2x (I2C20, I2C21, I2C22) instances must be routed to Port P1 pins only. TWIM30 is the only I2C instance that can use Port P0. So remember Port P2 cannot be used for these serial peripherals as shown in this block diagram. Please double-check that all I2S and I2C pins are assigned to Port 1 pins (or Port 0 pin for TWIM30/I2C30). Using pins on other ports can lead to communication failures, including the -5 (EIO) behavior you are seeing.
    3. I2S -11 (-EAGAIN)
      This is expected behavior when the TX queue is temporarily full and can be handled by retrying, as you are already doing.
    Once external clocks are stable and pin routing is corrected, both I2C and I2S behavior should be consistent. Best Regards,
    Syed Maysum
