[00:06:49.411,024] <inf> i2s_nrfx: I2S MCK frequency: 256000, actual PCM rate: 8000
To solve this efficiently, we need to validate one interface at a time. I’ve reviewed your code carefully and there are concrete I2C bugs that must be fixed before we continue with I2S.
Issue 1: Incorrect I2C transfer lengths (must be fixed)
In multiple places you request 2 bytes from the I2C driver but store them in 1-byte variables, which is invalid and can corrupt memory or cause the codec to NACK. Examples from your code:
codec_probe():
uint8_t read_back = 0; i2c_write_read_dt(&dev_i2c, ®0, 2, &read_back, 2);
read_eg():
uint8_t reg = 0xD4; uint8_t val = 0; i2c_write_read_dt(&dev_i2c, ®, 2, &val, 2);
Both are invalid and must be corrected everywhere in the code.
Issue 2: Wrong API used for register writes
You are using i2c_write_read_dt() for normal register writes (write-only operations). So for normal writes please try using i2c_write_dt(). Correct patterns (assuming 8-bit register + 8-bit data):
Register write:
uint8_t buf[2] = { reg, val };
ret = i2c_write_dt(&dev_i2c, buf, 2);
Register read:
ret = i2c_write_read_dt(&dev_i2c, ®, 1, &val, 1);
So before testing I2S again please disable I2S in the overlay (&i2s20 { status = "disabled"; };) or physically disconnect all I2S lines and first fix all I2C calls so that transfer lengths exactly match buffer sizes and i2c_write_dt() is used for write-only operations. Then read the same codec register 10,000 times in a loop (this test should complete with 0 occurrences of -EIO).
Once this I2C-only test is stable, we will move on to validating I2S in isolation. Thanks
I am try to create external clock for mclk
Hi
I see you’re experimenting with generating a 4 MHz MCLK now. Just to make sure we’re aligned: I don’t yet have confirmation that the original I2C issue is resolved. Before we move further with MCLK/I2S, could you please confirm:
Once that’s confirmed, we can continue with the MCLK/I2S part. Thanks
Syed Maysum
