Thingy:91X doesn't connect with nRF Cloud
I am currently trying to get hello nRF Cloud example running.
However, my Thingy:91X doesn't connect with the nRF Cloud.
According to the logs of the cellular monitor application, the device is not connecting to the mobile network.
I tried the two included SIM cards (conexa and onomondo) as well as third SIM card from soracom (plan01s).
The device won't get provisioned.
  • Thank you for your help.
    It still does not work.
    uart:~$ > at AT%XFACTORYRESET=1
    ERROR
    [00:01:36.267,425] <dbg> trigger: trigger_work_fn: Sending data sample trigger
    [00:01:36.267,822] <dbg> app: app_task: Trigger received
    [00:01:36.267,913] <dbg> battery: state_sampling_run: Data sample trigger received, getting battery data
    [00:01:36.268,005] <dbg> trigger: trigger_poll_work_fn: Sending shadow/fota poll trigger
    [00:01:36.268,493] <inf> nrf_cloud_fota_poll: Checking for FOTA job...
    [00:01:36.270,050] <dbg> environmental_module: state_sampling_run: Data sample trigger received, getting environmental data
    [00:01:36.270,141] <dbg> environmental_module: sample: temp: 24.359111; press: 102062.695312; humidity: 16.691154; iaq: 200; CO2: 1883.093750; VOC: 11.507160
    [00:01:36.270,355] <dbg> environmental_module: sample: Submitting payload
    [00:01:36.270,690] <dbg> location_module: location_task: Trigger received
    [00:01:36.270,721] <dbg> location_module: handle_trigger_chan: Data sample trigger received, getting location
    [00:01:36.270,751] <dbg> location_module: trigger_location_update: GNSS disabled
    [00:01:36.270,782] <dbg> location_module: trigger_location_update: location library initialized
    [00:01:36.270,874] <inf> location: Wi-Fi and cellular methods combined
    [00:01:36.271,148] <dbg> led: poll_running: poll_running
    [00:01:36.271,179] <dbg> led: led_not_set_running: led_not_set_running
    [00:01:36.271,209] <dbg> led: running_run: running_run
    [00:01:36.271,270] <dbg> trigger: trigger_callback: Received message on channel LOCATION_CHAN
    [00:01:36.271,301] <dbg> trigger: trigger_callback: Location search started
    [00:01:36.271,301] <dbg> trigger: trigger_callback: Running SMF
    [00:01:36.271,331] <dbg> trigger: frequent_poll_run: frequent_poll_run
    [00:01:36.271,362] <dbg> trigger: frequent_poll_run: Location search started, going into blocked state
    [00:01:36.271,362] <dbg> trigger: frequent_poll_exit: frequent_poll_exit
    [00:01:36.271,514] <dbg> led: led_pattern_update_work_fn: Setting LED effect: LED_LOCATION_SEARCHING
    [00:01:36.271,545] <dbg> app_led_pwm: led_pwm_set_effect: Power state: 0
    [00:01:36.271,667] <dbg> location_module: location_task: Trigger received
    [00:01:36.271,728] <dbg> location_module: location_task: Trigger received
    [00:01:36.271,850] <dbg> network: state_sampling_run: Data sample trigger received, getting network quality data
    [00:01:36.272,064] <dbg> app: app_task: Trigger received
    [00:01:36.272,094] <dbg> app: app_task: Poll trigger received
    [00:01:36.272,247] <dbg> app: shadow_get: Requesting device configuration from the device shadow
    [00:01:36.272,430] <dbg> transport: state_connected_ready_run: state_connected_ready_run
    [00:01:36.272,460] <dbg> transport: state_connected_ready_run: Payload
                                        9f bf 21 68 31 34 32 30  35 2f 30 2f 00 61 30 02 |..!h1420 5/0/.a0.
                                        fb 40 38 5b ee b2 d0 a2  44 22 1a 69 89 a5 f0 ff |.@8[.... D".i....
    [00:01:36.279,937] <dbg> battery: sample: State of charge: 100.000000
    [00:01:36.279,998] <dbg> battery: sample: The battery is charging
    [00:01:36.280,700] <inf> wifi_nrf_bus: SPIM spi@b000: freq = 8 MHz
    [00:01:36.280,731] <inf> wifi_nrf_bus: SPIM spi@b000: latency = 0
    [00:01:40.117,980] <inf> nrf_cloud_fota_poll: No pending FOTA job
    [00:01:40.490,051] <dbg> transport: state_running_run: state_running_run
    [00:01:40.490,173] <dbg> transport: state_connected_ready_run: state_connected_ready_run
    [00:01:40.490,203] <dbg> transport: state_connected_ready_run: Payload
                                        9f bf 21 68 31 34 32 30  32 2f 30 2f 00 61 30 02 |..!h1420 2/0/.a0.
                                        18 64 22 1a 69 89 a5 f0  ff bf 00 61 31 02 fb 40 |.d".i... ...a1..@
    [00:01:40.907,989] <dbg> app: shadow_get: No shadow delta changes available
    [00:01:40.908,081] <dbg> app: app_task: Trigger received
    [00:01:41.339,691] <dbg> transport: state_running_run: state_running_run
    [00:01:41.907,958] <dbg> location_module: location_event_handler: Got location: lat: 35.884443, lon: 139.503266, acc: 83.000000, method: 4
    [00:01:41.908,020] <dbg> led: poll_running: poll_running
    [00:01:41.908,050] <dbg> led: poll_entry: poll_entry
    [00:01:41.908,142] <dbg> trigger: trigger_callback: Received message on channel LOCATION_CHAN
    [00:01:41.908,172] <dbg> trigger: trigger_callback: Location search done
    [00:01:41.908,172] <dbg> trigger: trigger_callback: Running SMF
    [00:01:41.908,203] <dbg> trigger: blocked_run: blocked_run
    [00:01:41.908,233] <dbg> trigger: blocked_run: Going into frequent poll state
    [00:01:41.908,447] <dbg> trigger: frequent_poll_entry: frequent_poll_entry
    [00:01:41.908,294] <dbg> led: led_pattern_update_work_fn: Setting LED effect: LED_POLL_MODE
    [00:01:41.908,355] <dbg> app_led_pwm: led_pwm_set_effect: Power state: 0
    [00:01:41.908,447] <dbg> trigger: frequent_poll_entry: Location search done
    [00:02:11.908,599] <dbg> trigger: trigger_poll_work_fn: Sending shadow/fota poll trigger
    [00:02:11.909,149] <inf> nrf_cloud_fota_poll: Checking for FOTA job...
    [00:02:11.910,583] <dbg> app: app_task: Trigger received
    [00:02:11.910,614] <dbg> app: app_task: Poll trigger received
    [00:02:11.910,766] <dbg> app: shadow_get: Requesting device configuration from the device shadow
    [00:02:11.911,132] <dbg> location_module: location_task: Trigger received
    [00:02:11.911,193] <dbg> location_module: location_task: Trigger received
    [00:02:13.478,454] <inf> nrf_cloud_fota_poll: No pending FOTA job
    [00:02:13.829,193] <dbg> app: shadow_get: No shadow delta changes available
    [00:02:13.829,284] <dbg> app: app_task: Trigger received
    Anyway, it works now.
    Thank you very much for your support!
