NRF54LM20 - NRF_MPC Alignment Assertion When Building With TFM And CONFIG_DEBUG
Issue
When building the Blinky example for the NRF54LM20A with TFM and CONFIG_DEBUG=y the MCU will assert on boot.
When booting an assert is triggered in workspace/modules/hal/nordic/nrfx/hal/nrf_mpc.h
NRF_STATIC_INLINE void nrf_mpc_override_endaddr_set(NRF_MPC_Type * p_reg,
                                                    uint8_t        index,
                                                    uint32_t       address)
    NRFX_ASSERT(index < NRF_MPC_OVERRIDE_COUNT);
    NRFX_ASSERT((address & 0xFFFUL) == 0);
    p_reg->OVERRIDE[index].ENDADDR = address;
At some point the above function is called with the address 0x2007FC00 and triggers the assert.
The address 0x2007FC00 can be found in build/partitions.yml for both sram_nonsecure and sram_primary partitions.
Steps to Recreate
Added CONFIG_DEBUG=y to prj.conf, build (west build -b nrf54lm20dk/nrf54lm20a/cpuapp/ns --pristine)
Debugging
I did try to override partitions.yml with pm_static_nrf54lm20dk_nrf54lm20a_cpuapp.yml by manually shrinking  sram_nonsecure and sram_primary to meet the alignment requirements.
This did not fully work, TFM got a little more into the boot preocess before asserting on some other issues. pm has a tendency to do its own thing even if you try override it with pm_static so I stopped there.
Checking things just now, the non-debug build also should have alignment issues but NRFX_ASSERT is disabled in non-debug builds. I think that is a bit of an issue, I don't know the function of the MPC, but I would assume it is important for security. I think the policy on the asserts in nrf_mpc need to be reevaluated.
Comnents
The docs for CONFIG_DEBUG say this:
Build a kernel suitable for debugging. Right now, this option only disables optimization, ...
There is no mention that it will also disable some runtime assets nor can I find any Kconfig options to keep NRFX_ASSERT in the build.
Questions
Where does pm get the base values for partion layout?
How else can NDEBUG be enabled?
Environment
Linux
SDK 3.2.1
Toolchain 3.2.0
Thank you
