nrfconnect sdk partial erase will cause USAGE_FAULT on k_sleep()
i'm using nRF52832 to construct an BTHomev2 sensor.
In development, we find the firmware seems to randomly fail in k_sleep(), but once we full earse the chip before flash in or use JFlash to flash in, it will never go into fault.
The fault shows stack smashed but we've confirmed the space remaining in stack is abundant, i guess the reason is incorrect erase procedure caused damaged zephyr kernel.
Following is code and configurations:
#include <zephyr/bluetooth/crypto.h>
#include <zephyr/bluetooth/gatt.h>
#include <zephyr/bluetooth/uuid.h>
#include <zephyr/drivers/sensor.h>
LOG_MODULE_REGISTER(main, LOG_LEVEL_INF);
#include "main.h"
#if !DT_HAS_COMPAT_STATUS_OKAY(sensirion_sht4x)
#error "No sensirion,sht4x compatible node found in the device tree"
static const struct device* sht40_device;
static int16_t  historical_temperature = 0;
static uint16_t historical_humidity    = 0;
static int16_t  perv_temperature       = 0;
static uint16_t perv_humidity          = 0;
#if CONFIG_BT_ID_MAX > 1
#error "This application supports only one Bluetooth identity"
static uint8_t encryption_nonce[16] = { 0 }; // actually 13 bytes
// static const uint8_t* const predefined_key       = 0x10001000 + 0x080; // UICR COUSTOM[15:0]
static const uint8_t predefined_key[16] = { 0x8b, 0xa5, 0x91, 0xa5, 0xef, 0x8f, 0xd5, 0x99,
                                            0x90, 0x31, 0x6d, 0x38, 0xe0, 0x4a, 0xe9, 0xed };
// #define ADV_PARAM BT_LE_ADV_PARAM(BT_LE_ADV_OPT_USE_IDENTITY | BT_LE_ADV_OPT_EXT_ADV, BT_GAP_ADV_SLOW_INT_MIN,
// BT_GAP_ADV_SLOW_INT_MAX, NULL)
#define ADV_PARAM BT_LE_ADV_PARAM(BT_LE_ADV_OPT_USE_IDENTITY, BT_ADV_MIN_INTERVAL, BT_ADV_MAX_INTERVAL, NULL)
static struct bthome_raw_data raw_data = { .battery_object_id     = BTHOMEV2_OBJID_BATTERY_U8_1,
                                           .battery_level         = 42,
                                           .temperature_object_id = BTHOMEV2_OBJID_TEMPERATURE_S16_0P01,
                                           .temperature           = 0000,
                                           .humidity_object_id    = BTHOMEV2_OBJID_HUMIDITY_U16_0P01,
                                           .humidity              = 0000 };
static struct bthome_payload advertising_payload = { .service_uuid     = { BT_UUID_16_ENCODE(BTHOMEV2_SERVICE_UUID) },
                                                     .device_info_byte = BTHOMEV2_DIB_ENCRYPTED | BTHOMEV2_DIB_VER,
                                                     .encrypted_data   = { 0 },
                                                     .counter          = 0x00000000,
                                                     .mic              = { 0 } };
static struct bt_data advertising_data[] = {
    BT_DATA_BYTES(BT_DATA_FLAGS, BT_LE_AD_GENERAL | BT_LE_AD_NO_BREDR),
    BT_DATA(BT_DATA_SVC_DATA16, &advertising_payload, sizeof(advertising_payload))
static struct bt_data scan_response_data[] = {
    BT_DATA(BT_DATA_NAME_COMPLETE, CONFIG_BT_DEVICE_NAME, sizeof(CONFIG_BT_DEVICE_NAME) - 1),
#include <nrfx_saadc.h>
#define SAADC_INPUT_PIN            NRFX_ANALOG_INTERNAL_VDD
#define BATTERY_SAMPLE_INTERVAL_MS 300000
static int16_t              battery_sample_voltage;
static nrfx_saadc_channel_t battery_sample_channel = NRFX_SAADC_DEFAULT_CHANNEL_SE(SAADC_INPUT_PIN, 0);
void battery_sample_timer_handler(struct k_timer* timer)
    nrfx_err_t err = nrfx_saadc_offset_calibrate(NULL);
    if (err != 0)
        LOG_ERR("nrfx_saadc_offset_calibrate error: %d", (int)err);
        return;
    err = nrfx_saadc_mode_trigger();
    if (err != 0)
        LOG_ERR("nrfx_saadc_mode_trigger error: %d", (int)err);
        return;
    int batt_volt          = ((600 * 6) * battery_sample_voltage) / ((1 << 12));
    raw_data.battery_level = (batt_volt > 3200) ? 100 : (batt_volt < 2500) ? 0 : (batt_volt - 2500) / 7;
    LOG_INF(
        "sampled battery voltage: %d mV, orignal data: %hd, level: %hhu%%",
        batt_volt,
        battery_sample_voltage,
        raw_data.battery_level);
K_TIMER_DEFINE(battery_sample_timer, battery_sample_timer_handler, NULL);
// Sensor
K_THREAD_STACK_DEFINE(sensor_thread_stack, 1024);
struct k_thread sensor_thread;
void sensor_handle(void* p1, void* p2, void* p3)
    LOG_INF("fetching saadc");
    nrfx_err_t err = nrfx_saadc_init(DT_IRQ(DT_NODELABEL(adc), priority));
    if (err != 0)
        return;
    battery_sample_channel.channel_config.gain = NRF_SAADC_GAIN1_6;
    err = nrfx_saadc_channels_config(&battery_sample_channel, 1);
    if (err != 0)
        LOG_ERR("nrfx_saadc_channels_config error: %d", (int)err);
        return;
    err = nrfx_saadc_simple_mode_set(BIT(0), NRF_SAADC_RESOLUTION_12BIT, NRF_SAADC_OVERSAMPLE_DISABLED, NULL);
    if (err != 0)
        LOG_ERR("nrfx_saadc_simple_mode_set error: %d", (int)err);
        return;
    err = nrfx_saadc_buffer_set(&battery_sample_voltage, 1);
    if (err != 0)
        LOG_ERR("nrfx_saadc_buffer_set error: %d", (int)err);
        return;
    k_timer_start(&battery_sample_timer, K_NO_WAIT, K_MSEC(BATTERY_SAMPLE_INTERVAL_MS));
    LOG_INF("fetching sht40");
    sht40_device = DEVICE_DT_GET_ANY(sensirion_sht4x);
    if (sht40_device == NULL)
        LOG_ERR("sht40 device not found");
        return;
        LOG_INF("sht40 device found: %s", sht40_device->name);
    if (!device_is_ready(sht40_device))
        LOG_ERR("sht40 %s is not ready", sht40_device->name);
        return;
        LOG_INF("sht40 %s device ready", sht40_device->name);
    while (1)
        // fetch temperature and humidity from SHT4X sensor
            LOG_ERR("SHT4X device pointer is NULL");
            continue;
        if (sensor_sample_fetch(sht40_device))
            LOG_ERR("fetch sample from SHT4X device failed ");
            continue;
        struct sensor_value sht40_t  = { 0 };
        struct sensor_value sht40_rh = { 0 };
        sensor_channel_get(sht40_device, SENSOR_CHAN_AMBIENT_TEMP, &sht40_t); // data zero initialized so failure is
        sensor_channel_get(sht40_device, SENSOR_CHAN_HUMIDITY, &sht40_rh);
        perv_temperature     = raw_data.temperature;
        perv_humidity        = raw_data.humidity;
        raw_data.temperature = (int16_t)(sht40_t.val1 * 100 + sht40_t.val2 / 10000);
        raw_data.humidity    = (uint16_t)(sht40_rh.val1 * 100 + sht40_rh.val2 / 10000);
        LOG_INF("sample fetched from SHT4X device: temp=%hd, humidity=%hu", raw_data.temperature, raw_data.humidity);
        k_sleep(K_MSEC(BT_TICK_TO_MSEC(BT_ADV_MIN_INTERVAL)));
// BT
static int encrypt_init()
    int result = bt_rand(&(advertising_payload.counter), sizeof(advertising_payload.counter));
    if (result)
        LOG_INF("counter initlization by bt_rand() filling failed: %d", result);
        return -1;
    bt_addr_le_t mac_addr[CONFIG_BT_ID_MAX];
    size_t       mac_count = CONFIG_BT_ID_MAX;
    bt_id_get(mac_addr, &mac_count);
    if (mac_count == 0)
        LOG_INF("nonce initlization by bt_id_get() failed: no MAC addresses found");
        return -1;
    for (size_t i = 0; i < mac_count; i++)
        char addr_str[BT_ADDR_LE_STR_LEN] = { 0 };
        bt_addr_le_to_str(&mac_addr[i], addr_str, sizeof(addr_str));
        LOG_INF("device MAC address %u: %s", (unsigned int)i, addr_str);
    encryption_nonce[5] = mac_addr[0].a.val[0];
    encryption_nonce[4] = mac_addr[0].a.val[1];
    encryption_nonce[3] = mac_addr[0].a.val[2];
    encryption_nonce[2] = mac_addr[0].a.val[3];
    encryption_nonce[1] = mac_addr[0].a.val[4];
    encryption_nonce[0] = mac_addr[0].a.val[5];
    memcpy(encryption_nonce + 6, advertising_payload.service_uuid, 2);
    memcpy(encryption_nonce + 8, &(advertising_payload.device_info_byte), 1);
    memcpy(encryption_nonce + 9, &(advertising_payload.counter), 4);
    LOG_INF("encryption initialization completed");
    return 0;
static int encrypt_payload(
    struct bthome_payload*        payload,
    const struct bthome_raw_data* raw_data,
    uint8_t*                      nonce,
    const uint8_t*                key)
    if (payload == NULL || raw_data == NULL || nonce == NULL || key == NULL)
        LOG_INF("encrypt_payload() invalid parameter");
        return -1;
    memcpy(nonce + 9, &(payload->counter), 4);
    uint8_t enc_data_buffer[sizeof(struct bthome_raw_data) + 4] = { 0 };
    // LOG_HEXDUMP_INF(raw_data, sizeof(struct bthome_raw_data), "raw_data to encrypt:");
    // LOG_HEXDUMP_INF(&(payload->counter), 4, "counter to encrypt:");
    // LOG_HEXDUMP_INF(nonce, 13, "nonce to encrypt:");
    // LOG_HEXDUMP_INF(key, 16, "key to encrypt:");
    int result =
        bt_ccm_encrypt(key, nonce, (uint8_t*)raw_data, sizeof(struct bthome_raw_data), NULL, 0, enc_data_buffer, 4);
    if (result)
        LOG_INF("bt_ccm_encrypt() failed: %d", result);
        return result;
    // LOG_HEXDUMP_INF(enc_data_buffer, sizeof(struct bthome_raw_data) + 4, "encrypted data + mic:");
    memcpy(&(payload->encrypted_data), enc_data_buffer, sizeof(struct bthome_raw_data));
    memcpy(&(payload->mic), enc_data_buffer + sizeof(struct bthome_raw_data), 4);
    // LOG_HEXDUMP_INF(&(payload->encrypted_data), sizeof(struct bthome_raw_data), "payload encrypted_data:");
    // LOG_HEXDUMP_INF(&(payload->counter), 4, "payload counter:");
    // LOG_HEXDUMP_INF(&(payload->mic), 4, "payload mic:");
    return result;
// static void bt_ready(int result)
//     if (result)
//         LOG_ERR("bluetooth init failed: %d", result);
//         return;
//     // bt_le_ext_adv_create(ADV_PARAM, NULL, &adv_set_ptr);
//     // if (result)
//     //     LOG_ERR("bluetooth extadvertising failed to create adv set: %d", result);
//     //     return;
//     // result = bt_le_ext_adv_set_data(adv_set_ptr, advertising_data, ARRAY_SIZE(advertising_data), NULL, 0);
//     // if (result)
//     //     LOG_ERR("bluetooth extadvertising failed to set data: %d, sizeof(advertising_payload):%d", result,
//     //     sizeof(advertising_payload)); return;
//     // result = bt_le_ext_adv_start(adv_set_ptr, BT_LE_EXT_ADV_START_DEFAULT);
//     // if (result)
//     //     LOG_ERR("bluetooth extadvertising failed to start: %d", result);
//     //     return;
//     // result = bt_le_adv_start(
//     //     ADV_PARAM, advertising_data, ARRAY_SIZE(advertising_data), scan_response_data,
//     //     ARRAY_SIZE(scan_response_data));
//     // if (result)
//     //     LOG_ERR(
//     //         "bluetooth adsr failed to set data: %d, sizeof(advertising_payload):%d",
//     //         result,
//     //     return;
//     // LOG_INF("bluetooth advertising started");
K_THREAD_STACK_DEFINE(bluetooth_thread_stack, 2048);
struct k_thread bluetooth_thread;
void bluetooth_handle(void* p1, void* p2, void* p3)
    LOG_INF("enabling bluetooth");
    int result = bt_enable(NULL);
    if (result)
        return;
        LOG_INF("bluetooth ready");
    result = encrypt_init();
    if (result)
        LOG_ERR("encryption initialization failed: %d", result);
        return;
    static size_t timeout_counter = 0;
    while (1)
        int should_immdately_adv = 0;
        if (abs(raw_data.temperature - historical_temperature) >= 30) // 0.3 degree C
            historical_temperature = raw_data.temperature;
            should_immdately_adv   = 1;
            LOG_INF("significant temperature change detected(peak): %hd", raw_data.temperature);
        if (abs(raw_data.temperature - perv_temperature) >= 20) // 0.2 degree C
            LOG_INF("significant temperature change detected(slope): %hd", raw_data.temperature);
        if (abs(raw_data.humidity - historical_humidity) >= 50) // 0.5% RH
            historical_humidity  = raw_data.humidity;
            LOG_INF("significant humidity change detected(peak): %hu", raw_data.humidity);
        if (abs(raw_data.humidity - perv_humidity) >= 25) // 0.25% RH
            LOG_INF("significant humidity change detected(slope): %hu", raw_data.humidity);
        if (should_immdately_adv)
            LOG_INF("immediate advertising triggered(rate of change)");
            int result = bt_le_adv_start(
                ADV_PARAM,
                advertising_data,
                scan_response_data,
            if (result)
                LOG_ERR(
                    result,
                continue;
            for (size_t i = 0; i < 30; i++)
                result = encrypt_payload(&advertising_payload, &raw_data, encryption_nonce, predefined_key);
                if (result)
                    LOG_ERR("payload encryption failed: %d", result);
                result = bt_le_adv_update_data(
                    advertising_data, ARRAY_SIZE(advertising_data), scan_response_data, ARRAY_SIZE(scan_response_data));
                if (result)
                    LOG_ERR("bluetooth adsr update failed to set data: %d", result);
                advertising_payload.counter++;
                LOG_INF("bluetooth advertising updated (%d/30)", i + 1);
            k_sleep(K_MSEC(BT_TICK_TO_MSEC(BT_ADV_MIN_INTERVAL * 2)));
            bt_le_adv_stop();
            LOG_INF("bluetooth advertising stopped");
            timeout_counter = timeout_counter + 1;
            if (timeout_counter > 99)
                LOG_INF("immediate advertising triggered(timeout)");
                    ADV_PARAM,
                    advertising_data,
                    scan_response_data,
                if (result)
                    LOG_ERR(
                        result,
                    continue;
                for (size_t i = 0; i < 10; i++)
                    if (result)
                        advertising_data,
                        scan_response_data,
                    if (result)
                    LOG_INF("bluetooth advertising updated (%d/10)", i + 1);
                bt_le_adv_stop();
    LOG_INF("Alan nRF52832SHT40 BTHomev2 Sensor");
    LOG_INF("creating sensor thread");
    k_tid_t sensor_tid = k_thread_create(
        &sensor_thread,
        K_THREAD_STACK_SIZEOF(sensor_thread_stack),
        sensor_handle,
        NULL,
        NULL,
        NULL,
        1,
        0,
        K_NO_WAIT);
    k_thread_name_set(sensor_tid, "sensor_measurement");
    k_thread_start(sensor_tid);
    LOG_INF("creating bluetooth thread");
    k_tid_t bluetooth_tid = k_thread_create(
        &bluetooth_thread,
        K_THREAD_STACK_SIZEOF(bluetooth_thread_stack),
        bluetooth_handle,
        NULL,
        NULL,
        NULL,
        0,
        0,
        K_NO_WAIT);
    k_thread_name_set(bluetooth_tid, "bluetooth_advertising");
    k_thread_start(bluetooth_tid);
    (void)sensor_tid;
    (void)bluetooth_tid;
    // result = encrypt_payload(&advertising_payload, &raw_data, encryption_nonce, predefined_key);
    // if (result)
    //     LOG_ERR("payload encryption failed: %d", result);
    //     return -1;
    // result = bt_le_adv_update_data(
    //     advertising_data, ARRAY_SIZE(advertising_data), scan_response_data, ARRAY_SIZE(scan_response_data));
    // if (result)
    //     LOG_ERR("bluetooth adsr update failed to set data: %d", result);
    //     return -1;
    // advertising_payload.counter++;
    //     for (;;)
    //         // determine if significant change occurred
    //         static adv_counter = 5;
    //     // encrypt and send adv
    //     k_sleep(K_MSEC(0x4000 * 3)); // in the bad environment, extend adv time to increase chance of reception
    // next:
    //     k_sleep(K_MSEC(0x3000));
    // while (1)
    //     k_sleep(K_MSEC(1000 * 1000));
    return 0;
# Copyright (c) 2022 Nordic Semiconductor ASA
CONFIG_BT=y
CONFIG_BT_PERIPHERAL=y
CONFIG_BT_DEVICE_NAME="Cattus BTHomeTempHumidity Sensorv1"
CONFIG_MAIN_STACK_SIZE=1024
CONFIG_BT_HOST_CCM=y
CONFIG_FLASH=y
CONFIG_SOC_FLASH_NRF=y
CONFIG_SOC_FLASH_NRF_UICR=y
CONFIG_SOC_FLASH_NRF_EMULATE_ONE_BYTE_WRITE_ACCESS=y
CONFIG_NRFX_SAADC=y
CONFIG_SHT4X=y
CONFIG_I2C=y
CONFIG_SENSOR=y
# to be removed to reduce power consumption when production
CONFIG_HW_STACK_PROTECTION=y
CONFIG_MPU_STACK_GUARD=y
CONFIG_THREAD_STACK_INFO=y
CONFIG_DEBUG=y
CONFIG_PRINTK=y
CONFIG_USE_SEGGER_RTT=y
CONFIG_LOG=y
CONFIG_LOG_BACKEND_RTT=y
CONFIG_LOG_MODE_IMMEDIATE=y
CONFIG_INIT_STACKS=y
CONFIG_ASSERT=y
CONFIG_SEGGER_RTT_BUFFER_SIZE_UP=8192
Fault report:
*** Booting nRF Connect SDK v3.2.1-d8887f6f32df ***
*** Using Zephyr OS v4.2.99-ec78104f1569 ***
[00:00:00.004,058] <inf> main: Alan nRF52832SHT40 BTHomev2 Sensor
[00:00:00.004,394] <inf> main: creating sensor thread
[00:00:00.004,821] <inf> main: creating bluetooth thread
[00:00:00.005,401] <inf> main: enabling bluetooth
[00:00:00.005,859] <inf> bt_sdc_hci_driver: SoftDevice Controller build revision:
                                            9b 8f ac c3 1d 42 ae 44  fa cd 1f c3 48 a0 b4 2f |.....B.D ....H../
                                            cf 29 ee 3d                                      |.).=
[00:00:00.007,59[00:00:00.010,681] <inf> bt_hci_core: HW Platform: Nordic Semiconductor (0x0002)
[00:00:00.011,077] <inf> bt_hci_core: HW Variant: nRF52x (0x0002)
[00:00:00.011,444] <inf> bt_hci_core: Firmware: Standard Bluetooth controller (0x00) Version 155.44175 Build 2923568579
[00:00:00.013,031] <inf> bt_hci_core: HCI transport: SDC
[00:00:00.013,366] <inf> bt_hci_core: Identity: D2:BB:30:5A:42:28 (random)
[00:00:00.013,793] <inf> bt_hci_core: HCI: version 6.2 (0x10) revision 0x1020, manufacturer 0x0059
[00:00:00.014,251] <inf> bt_hci_core: LMP: version 6.2 (0x10) subver 0x1020
[00:00:00.014,648] <inf> main: bluetooth ready
[00:00:00.014,984] <inf> main: device MAC address 0: D2:BB:30:5A:42:28 (random)
[00:00:00.015,411] <inf> main: encryption initialization completed
8] <inf> main: fetching saadc
[00:00:0[00:00:00.016,204] <inf> main: sampled battery voltage: 3205 mV, orignal data: 3647, level: 100%
0.015,991] <inf> main: fetching sht40
[00:00:00.016,876] <inf> main: sht40 device found: sht4x@44
[00:00:00.017,181] <inf> main: sht40 sht4x@44 device ready
[00:00:00.026,947] <inf> main: sample fetched from SHT4X device: temp=2269, humidity=1533
[00:00:01.000,000] <err> os: ***** USAGE FAULT *****
[00:00:01.000,305] <err> os:   Illegal load of EXC_RETURN into PC
[00:00:01.000,640] <err> os: r0/a1:  0x20004b94  r1/a2:  0x00000000  r2/a3:  0x00000000
[00:00:01.001,098] <err> os: r3/a4:  0x00000000 r12/ip:  0xaaaaaaaa r14/lr:  0x000202b5
[00:00:01.001,525] <err> os:  xpsr:  0x20004a00
[00:00:01.001,831] <err> os: Faulting instruction address (r15/pc): 0x00011760
[00:00:01.002,227] <err> os: >>> ZEPHYR FATAL ERROR 34: Unknown error on CPU 0
[00:00:01.002,624] <err> os: Current thread: 0x200042f8 (idle)
[00:00:01.002,960] <err> os: Halting system
The line of code last executed before fault is located in line 181, as well: k_sleep(K_MSEC(BT_TICK_TO_MSEC(BT_ADV_MIN_INTERVAL)));
