Upgrading from NCSv3.0.0 to NCSv3.2.1, I2S issue
hello,
We have a project that uses sound for distance measurement.
When I upgraded from NCSv3.0.0 to NCSv3.2.1, I encountered a problem where the i2s function stopped working.
The following is the driver code for NCSv3.0.0.Can be used normally.
Main process:  i2s_init()--->Enable the register clock---->enable PA---->k_sleep(250)---->start_i2s()---->handle---->set_next_buf()--->handle---->set_next_buf() .... --->stop_i2s()
Since this sound is an ultrasonic wave, when played directly, there will be a "pop" sound. Therefore, I need to first turn on the i2s clock and reduce this "pop" sound.
#define I2S_DATA_BLOCK_WORDS 192
static void i2s_comp_handler(nrfx_i2s_buffers_t const *released_bufs, uint32_t status)
    if (!(status & NRFX_I2S_STATUS_NEXT_BUFFERS_NEEDED)) {
        // printk("i2s No buffer stop : %d\n", status);
        return;
    uint32_t *next_tx_buf = NULL;
    if (released_bufs->p_tx_buffer == m_buffer_tx[0]) {
        next_tx_buf = m_buffer_tx[0];
    } else if (released_bufs->p_tx_buffer == m_buffer_tx[1]) {
        next_tx_buf = m_buffer_tx[1];
    if(!released_bufs->p_tx_buffer) {
    current_buf += 1;
    //Put the data from bpsk_tata into m_buffer_tx[0] or m_buffer_tx[1]
    singleGetAudioDataToTxBuf(bpsk_tata, m_buffer_tx[0], m_buffer_tx[1], current_buf);
    const nrfx_i2s_buffers_t next_buffers = {
        .p_rx_buffer = NULL,
        .p_tx_buffer = next_tx_buf,
        .buffer_size = I2S_DATA_BLOCK_WORDS,
    (void)nrfx_i2s_next_buffers_set(&i2s_inst, &next_buffers);
void audio_i2s_init(void)
    int ret;
    ret = pinctrl_apply_state(PINCTRL_DT_DEV_CONFIG_GET(I2S_NL), PINCTRL_STATE_DEFAULT);
    if (ret != 0) {
        printk("Failed to apply pinctrl state: %d\n", ret);
        return;
    IRQ_CONNECT(DT_IRQN(I2S_NL), DT_IRQ(I2S_NL, priority), nrfx_isr, nrfx_i2s_20_irq_handler, 0);
    irq_enable(DT_IRQN(I2S_NL));
    ret = nrfx_i2s_init(&i2s_inst, &cfg, i2s_comp_handler);
    if (ret != 0) {
        printk("Failed to initialize I2S: %d\n", ret);
        return;
    printk("i2s initialize (%d)\r\n",ret);
void i2s_codec_thread(void)
    audio_i2s_init();
    for (;;) {
        k_sem_take(&i2s_sync_sem, K_FOREVER);
        NRF_I2S20->ENABLE = 1;       // First, turn on the clock stabilization PA
        NRF_I2S20->TASKS_START = 1;
        pf_gpio_write(GPIO_PA, 1);
        k_sleep(K_MSEC(250));
        current_buf += 1;
        const nrfx_i2s_buffers_t initial_buffers = {
            .p_tx_buffer = m_buffer_tx[0],
            .buffer_size = (I2S_DATA_BLOCK_WORDS)};
        // Send real data
        ret = nrfx_i2s_start(&i2s_inst, &initial_buffers, 0);
        if (ret != 0) {
            printk("Failed to start I2S: %d\n", ret);
        do
            __WFE();
            __SEV();
            __WFE();
        } while (current_buf < BLOCKS_TO_TRANSFER);
        nrfx_i2s_stop(&i2s_inst);
When upgrading to NCSv3.2.1,Performing this operation will cause the system to crash.
The cause of the system crash:call (void)nrfx_i2s_next_buffers_set(&i2s_inst, &next_buffers);
ASSERTION FAIL [p_cb->state == NRFX_DRV_STATE_POWERED_ON] @ WEST_TOPDIR/modules/hal/nordic/nrfx/drivers/src/nrfx_i2s.c:385
At this moment p_cb->state=1
I tried to stop manipulating the registers. Instead, I played a silent segment first and then switched to the actual data. This way, the system no longer crashed. However, this had an impact on the accuracy of my distance measurement.
I hope that the NCSv3.2.1 version can solve my problem.
Look forward to your reply!
Thanks
    I tried some other approaches, but the results were not as good as those of ncsv3.0.0. I wonder if any of you have better methods.
    I also came up with an idea: to separate the NCSv3.0.0 I2s driver file and place it on NCSv3.2.1. During the compilation process, specify the NCSv3.0.0 I2s driver file. Will this method work?
    Thanks
  • hi,
    I tried your method, and the code is as follows:
            return;
    if (!start_real_data) {
        // printk("i2s No start_real_data stop : %d\n", status);
        return;
        if (released_bufs->p_tx_buffer == m_buffer_tx[0]/*!(current_buf % 2)*/) {
            current_buf += 1;
            const nrfx_i2s_buffers_t next_buffers1 = {
                .buffer_size = I2S_DATA_BLOCK_WORDS};
            nrfx_i2s_next_buffers_set(&i2s_inst, &next_buffers1);
            // printk("i2s event handler 1 :%d %d %d %d\n",released_bufs->p_tx_buffer[0],m_buffer_tx[0][0], m_buffer_tx[0][1],m_buffer_tx[0][191]);
        } else if (released_bufs->p_tx_buffer == m_buffer_tx[1] /*(current_buf % 2)*/) {
            current_buf += 1;
            const nrfx_i2s_buffers_t next_buffers2 = {
                .p_tx_buffer = m_buffer_tx[1],
            nrfx_i2s_next_buffers_set(&i2s_inst, &next_buffers2);
            // printk("i2s event handler 2 :%d %d %d %d %d %d\n",released_bufs->p_tx_buffer[0],m_buffer_tx[1][0], m_buffer_tx[1][135],m_buffer_tx[1][136],m_buffer_tx[1][190],m_buffer_tx[1][191]);
            current_buf += 1;
            // printk("i2s event handler 0 :%d %d %d %d\n",released_bufs->p_tx_buffer[0],m_buffer_tx[1][0], m_buffer_tx[1][1],m_buffer_tx[1][191]);
    static uint32_t m_buffer_rx[2][96] = {0};
    void es8311Play()
        current_buf = 0;
        current_index = 0;
        buf_end_flag = 0;
        start_real_data = false;
        const nrfx_i2s_buffers_t initial_buffers_test = {
            .p_rx_buffer = m_buffer_rx[0],
            .p_tx_buffer = NULL,
            .buffer_size = 1};
        int ret = nrfx_i2s_start(&i2s_inst, &initial_buffers_test, 0);
        if (ret != 0) {
            printk("Failed to start I2S111111: %d\n", ret);
        pf_gpio_write(GPIO_PA_GPIO, 1);
        start_real_data = true;
        es8311_i2s_start();
        do
            __WFE();
            __SEV();
            __WFE();
    1.
    nrfx_i2s_start()
    p_tx_buffer = NULL,  and a "dummy" RX buffer,size = 1
    2. Turn on the PA
    3. delay 250ms
    4.
    5. nrfx_i2s_start() ,Start sending the actual data.
    After running for a period of time, a problem of system freeze was discovered.
    ASSERTION FAIL [p_buffers->p_rx buffer I= ((void *)0)] @WEST_TOPDIR/modules/hal/nor di c/nr fx/drivers/sro/nr fx_i2s. c:422
    Thanks
    The assertion happens because the driver remains in RX-only mode when start_real_data = true; is set, but then in i2s_comp_handler only TX buffer is set after if (!start_real_data) {} else {.
    To change the driver operating mode (RX-only to TX-only), you must first stop the I2S using nrfx_i2s_stop, wait for NRFX_I2S_STATUS_TRANSFER_STOPPED status, and restart the I2S in TX mode.
    Waiting for NRFX_I2S_STATUS_TRANSFER_STOPPED is missing in the existing code, hence a potential race condition.
    Additionally, I see "dummy" RX buffer is set only once - I think it must be set continuously during the 250ms wait period in i2s_comp_handler on each NRFX_I2S_STATUS_NEXT_BUFFERS_NEEDED. I might be wrong, but I think otherwise the clock is not generated during the whole 250ms time period.
    -Amanda H.
