Reset the channel sounding parameters after a disconnection
Hi, I am trying to sound two reflectors from a single initiator, and since the CS works on a one-to-one ACL system, I wanted to know how I can reset the CS-related stuff in the code. I did try this without reboot, the data becomes stagnant after a reconnection or when I connect 2 reflectors (not sound, but just connect)
The sample provided by Nordic does a soft reboot, so it works flawlessly. I am trying to take a different path of not connecting to both of my nodes at once and do a soft reboot every time I wanna switch the sounding, but I wanted to know if a manual reset was possible for the CS params and buffer, so that I can continue with sounding another device without doing a soft reboot.
  • Hey, I tried it out, and It doesnt work. Also, I don't think this is something related because I don't disconnect the reflector, but stay connected and do the procedure consecutively with another reflector.
    Is there a specific way to reset my local counters on the reflector ? Either via the initiator or on the reflector directly?
  • The reason why I ask for counter reset on the reflector is that I always have this ranging counter mismatch or empty step data when I start measurement to the device 0 (which gets connected first). I have some logs below.
    I even use 2 Config_IDs to differentiate between these devices
    There are supposed to be at least 19 samples of distance measurement data, since I read and print distance results once every 500ms and switch between devices once every 10 seconds. But, I see this error either from the ranging_data_cb() or from the bt_ras_rreq_rd_subevent_data_parse()
    I: Disabling the CS procedure
    I: counters reset, local:-1, dropped:-1
    W: Procedure 584 aborted, reason - 0x1
    I: CS procedures disabled.
    I: Enabling the CS procedure
    I: Sounding to device 0
    I: CS procedures enabled:
    - config ID: 0
    - antenna configuration index: 0
    - TX power: 0 dbm
    - subevent length: 28198 us
    - subevents per event: 1
    - subevent interval: 0
    - event interval: 2
    - procedure interval: 5
    - procedure count: 0
    - maximum procedure length: 1000
    I: Ranging data dropped as peer ranging counter doesn't match local ranging data counter. (peer: 691, local: 690)
    I: Ranging data dropped as peer ranging counter doesn't match local ranging data counter. (peer: 692, local: 691)
    I: Ranging data dropped as peer ranging counter doesn't match local ranging data counter. (peer: 693, local: 692)
    I: Ranging data dropped as peer ranging counter doesn't match local ranging data counter. (peer: 694, local: 693)
    I: Ranging data dropped as peer ranging counter doesn't match local ranging data counter. (peer: 695, local: 694)
    I: Ranging data dropped as peer ranging counter doesn't match local ranging data counter. (peer: 696, local: 695)
    I: Ranging data dropped as peer ranging counter doesn't match local ranging data counter. (peer: 697, local: 696)
    I: Ranging data dropped as peer ranging counter doesn't match local ranging data counter. (peer: 698, local: 697)
    I: Ranging data dropped as peer ranging counter doesn't match local ranging data counter. (peer: 699, local: 698)
    I: Ranging data dropped as peer ranging counter doesn't match local ranging data counter. (peer: 700, local: 699)
    I: Ranging data dropped as peer ranging counter doesn't match local ranging data counter. (peer: 701, local: 700)
    I: Ranging data dropped as peer ranging counter doesn't match local ranging data counter. (peer: 702, local: 701)
    I: Ranging data dropped as peer ranging counter doesn't match local ranging data counter. (peer: 703, local: 702)
    I: Ranging data dropped as peer ranging counter doesn't match local ranging data counter. (peer: 704, local: 703)
    I: Ranging data dropped as peer ranging counter doesn't match local ranging data counter. (peer: 705, local: 704)
    I: Ranging data dropped as peer ranging counter doesn't match local ranging data counter. (peer: 706, local: 705)
    I: Ranging data dropped as peer ranging counter doesn't match local ranging data counter. (peer: 707, local: 706)
    I: Ranging data dropped as peer ranging counter doesn't match local ranging data counter. (peer: 708, local: 707)
    I: Ranging data dropped as peer ranging counter doesn't match local ranging data counter. (peer: 709, local: 708)
    I: Ranging data dropped as peer ranging counter doesn't match local ranging data counter. (peer: 710, local: 709)
    I: Ranging data dropped as peer ranging counter doesn't match local ranging data counter. (peer: 711, local: 710)
    I: Ranging data dropped as peer ranging counter doesn't match local ranging data counter. (peer: 712, local: 711)
    I: Ranging data dropped as peer ranging counter doesn't match local ranging data counter. (peer: 713, local: 712)
    I: Ranging data dropped as peer ranging counter doesn't match local ranging data counter. (peer: 714, local: 713)
    I: Ranging data dropped as peer ranging counter doesn't match local ranging data counter. (peer: 715, local: 714)
    I: Ranging data dropped as peer ranging counter doesn't match local ranging data counter. (peer: 716, local: 715)
    I: Ranging data dropped as peer ranging counter doesn't match local ranging data counter. (peer: 717, local: 716)
    I: Ranging data dropped as peer ranging counter doesn't match local ranging data counter. (peer: 718, local: 717)
    I: Ranging data dropped as peer ranging counter doesn't match local ranging data counter. (peer: 719, local: 718)
    I: Ranging data dropped as peer ranging counter doesn't match local ranging data counter. (peer: 720, local: 719)
    I: Ranging data dropped as peer ranging counter doesn't match local ranging data counter. (peer: 721, local: 720)
    I: Ranging data dropped as peer ranging counter doesn't match local ranging data counter. (peer: 722, local: 721)
    I: Ranging data dropped as peer ranging counter doesn't match local ranging data counter. (peer: 723, local: 722)
    Data from Reflector 2
    I: Ranging data dropped as peer ranging counter doesn't match local ranging data counter. (peer: 724, local: 723)
    Data from Reflector 1
    I: Ranging data dropped as peer ranging counter doesn't match local ranging data counter. (peer: 725, local: 724)
    I: Ranging data dropped as peer ranging counter doesn't match local ranging data counter. (peer: 726, local: 725)
    I: Ranging data dropped as peer ranging counter doesn't match local ranging data counter. (peer: 727, local: 726)
    I: Ranging data dropped as peer ranging counter doesn't match local ranging data counter. (peer: 728, local: 727)
    I: Ranging data dropped as peer ranging counter doesn't match local ranging data counter. (peer: 729, local: 4294967295)
    I: Sounding to device 1
    - config ID: 1
    - TX power: 0 dbm
    - event interval: 2
    I: Dropped subevent results. Waiting for ranging data from peer.
    I: Ranging data dropped as peer ranging counter doesn't match local ranging data counter. (peer: 585, local: 728)
    I: 1.756596,3.513278,2.610804,2.604011
    I: 1.756596,3.427624,2.751654,2.049362
    I: 2.049362,3.427624,2.837012,2.049362
    I: 2.049362,3.427624,2.854575,2.049362
    I: 2.049362,3.451425,3.105397,2.049362
    I: 2.049362,3.534048,3.157910,2.049362
    I: 2.049362,3.534048,3.105397,2.049362
    I: 2.049362,3.546767,3.382754,2.049362
    I: 2.049362,3.424742,3.265795,2.049362
    I: 2.049362,3.424742,2.969308,2.049362
    I: 2.049362,3.360484,2.927473,2.049362
    I: 2.049362,3.360484,2.792185,2.342129
    I: 2.195745,3.360484,2.820416,2.342129
    W: Procedure 623 aborted, reason - 0x1
    - config ID: 0
    - TX power: 0 dbm
    - event interval: 2
    E: empty step data
    E: empty step data
    E: empty step data
    E: empty step data
    E: empty step data
    E: empty step data
    E: empty step data
    E: empty step data
    E: empty step data
    E: empty step data
    E: empty step data
    E: empty step data
    E: empty step data
    E: empty step data
    E: empty step data
    E: empty step data
    E: empty step data
    E: empty step data
    E: empty step data
    E: empty step data
    E: empty step data
    E: empty step data
    E: empty step data
    E: empty step data
    E: empty step data
    E: empty step data
    E: empty step data
    E: empty step data
    E: empty step data
    E: empty step data
    E: empty step data
    E: empty step data
    E: empty step data
    E: empty step data
    E: empty step data
    E: empty step data
    E: empty step data
    E: empty step data
    E: empty step data
    - config ID: 1
    - TX power: 0 dbm
    - event interval: 2
    I: 2.049362,3.392859,2.921039,2.049362
    I: 2.049362,3.392859,3.176355,2.049362
    Sorry for my previous reply. It was a bit off. It was originally intended for another ticket, and I thought it could be the same issue, as they were also trying to range between multiple reflectors/initiators (but alternating, by disconnecting from them).
    I tried to build your applications, but I couldn't. I got a build error. Can you please let me know what NCS version you are using, and what build command you are using. If you are using nRF Connect for VS Code, you can copy the build command by right clicking the build folder and select "Copy build command" in VS Code.
    And is my understanding correct:
    If I build your applications, flash the central_uart... to one nRF54L15 DK, and the reflector to two other nRF54L15 DKs, I should be able to see the issue that you are seeing?
    Edvin
  • Hi, Its okay,
    I have updated the code base now. I will share that with you.
    The build command I am using is
    west build --build-dir cs/central_uart --pristine --board nrf54l15dk/nrf54l15/cpuapp --sysbuild -- -DCONF_FILE="prj.conf" -DDEBUG_THREAD_INFO=On -DCONFIG_DEBUG_THREAD_INFO=y -Dcentral_uart_DEBUG_THREAD_INFO=On
    Yes, if you run the reflector and initiator with my code, you should be able to recreate the issue.
    Vinayaka KS
