LwM2M FOTA Download Stalls at 1–2% on nRF9160 over NB-IoT/LTE-M
I am using nRF9160 DK with nRF Connect SDK v2.9 and the LwM2M client sample (/samples/cellular/lwm2m_client/), converted from PSK to X.509 certificates.
The device connects successfully to my custom Leshan server on AWS, and works with Onomondo SIM cards. Security handshake with X.509 works fine after adjusting the server settings.
However, firmware update over-the-air (FOTA) fails:
  • The download starts and reports 1–2% progress.
  • After that, the download stalls and no more CoAP requests are observed on the server.
  • This happens even when testing with PSK against the demo LwM2M server.
  • Network connection seems stable, no obvious LTE disconnects, and device registration updates continue.
Also, on the server UI, I see it show me "Request Timeout."
[00:00:15.417,205] <inf> app_lwm2m_client: LwM2M is connected to server
[00:00:15.417,266] <inf> app_lwm2m_client: Obtained date-time from modem
[00:00:38.783,386] <inf> app_lwm2m_client: FOTA download started for instance 0
[00:00:38.784,667] <inf> lwm2m_firmware: Image type 1
[00:00:38.787,139] <inf> lwm2m_firmware: Application firmware download started.
[00:00:57.482,666] <inf> lwm2m_firmware: Downloaded 1%
[00:00:59.722,747] <inf> lwm2m_firmware: Downloaded 2%
[00:01:15.415,527] <dbg> app_lwm2m_client: rd_client_event: Registration update started
[00:01:15.810,852] <inf> net_lwm2m_rd_client: Update callback (code:2.4)
[00:01:15.810,882] <dbg> app_lwm2m_client: rd_client_event: Registration update complete
[00:01:15.810,974] <inf> net_lwm2m_rd_client: Update Done
CONFIG_LWM2M=y
CONFIG_LWM2M_COAP_BLOCK_SIZE=1024
CONFIG_LWM2M_COAP_MAX_MSG_SIZE=2048
CONFIG_LWM2M_CLIENT_UTILS=y
CONFIG_LWM2M_ENGINE_MAX_MESSAGES=15
CONFIG_LWM2M_ENGINE_MAX_PENDING=15
CONFIG_LWM2M_ENGINE_MAX_REPLIES=15
Questions:
  1. Is there a recommended configuration for LwM2M FOTA over NB-IoT/LTE-M for large firmware images?
  2. Should PSM/eDRX be disabled during FOTA, or is there a way to pause registration updates to avoid blocking the download?
  3. What are the recommended CoAP block sizes and engine parameters to reliably transfer large images?
  4. Are there known limitations when using Onomondo SIM + AWS Leshan for large firmware downloads?
Additional Info:
  • MCUboot v2.1.0
  • Zephyr OS v3.7.99
  • LTE-M/NB-IoT tested with Onomondo SIM
  • The problem is that my device cannot find the app_update.bin file, and I don’t know how to properly configure the connection to access it
    Looking at your logs, the issue is clear:
    downloader: Setting up TLS credentials, sec tag count 1
    downloader: Failed to connect, err -111
    You're using https:// in your firmware URI, but the modem can't establish TLS because no valid CA certificate is provisioned for that Leshan server. That's why it connects on TCP level (you can see it resolves the IP fine) but fails at the TLS handshake.
    You have two options:
    Option A (recommended, easiest, and most reliable over cellular)
    Switch to plain HTTP. Host the firmware on your server:
    bash
    cd ~/ota
    python3 -m http.server 8000
    Then in Leshan UI write to /5/0/1 (Package URI):
    http://<your-server-ip>:8000/zephyr.signed.bin
    Make sure port 8000 is open in your firewall/security group inbound rules.
    Option B — Keep HTTPS, provision the CA certificate
    bash
    openssl s_client -connect leshan.yourserver.com:443 </dev/null 2>/dev/null | openssl x509 -outform PEM > leshan_ca.pem
    Provision it into the modem at a security tag:
    modem_key_mgmt_write(1, MODEM_KEY_MGMT_CRED_TYPE_CA_CHAIN, cert, cert_len);
    And add to prj.conf:
    CONFIG_FOTA_DOWNLOAD_SEC_TAG=1
    Also regarding app_update.bin, atleast for me in newer NCS with sysbuild it's no longer generated. The equivalent file is build/app/zephyr/zephyr.signed.bin. It's the same MCUboot-signed OTA image, just renamed. Use it directly in your firmware URL.
    hope that ressolve your issue
    Just to clarify, app_update.bin is not missing. In newer NCS versions with sysbuild, it has been renamed to zephyr.signed.bin, found at build/<your_app_name>/zephyr/zephyr.signed.bin. That's the correct file to use in your firmware URL.
    However, the file name is not what's blocking the update. As mentioned in my previous reply, the download is failing due to the TLS certificate error (-111). The device can't connect to your HTTPS server because the server's CA certificate isn't provisioned in the modem.
    Could you try the steps I shared earlier, extracting the server certificate and provisioning it with CONFIG_LWM2M_CLIENT_UTILS_DOWNLOADER_SEC_TAG? or alternatively if you want a quicker way to test first then try switching to plain HTTP and host the firmware on server.
    Best Regards,
    Syed Maysum
  • Here is a summary of what i did :
    1. HTTP configuration (local server)
      I hosted the firmware using a local Python server:
    python -m http.server 8000
    The firmware URL used was:
    192.168.1.46:8000/zephyr.signed.bin
    However, the download fails with a connection error. After investigation, I believe this is because the device is connected over LTE, and therefore cannot access my local IP address (192.168.1.46).
    ,519] <inf> app_lwm2m_client: FOTA download started for instance 0
    [00:36:05.209,411] <inf> fota_download_util: Download url http://192.168.1.46:8000/zephyr.signed.bin
    [00:36:05.209,503] <inf> fota_download_util: Download Path zephyr.signed.bin host http://192.168.1.46:8000
    [00:36:05.213,226] <inf> downloader: Host lookup failed for hostname 192.168.1.46 on IPv6 (err -22), attempting IPv4
    [00:36:05.216,705] <inf> downloader: Connecting to 192.168.1.46
    [00:36:29.223,419] <err> downloader: Failed to connect, err -116
    [00:36:29.223,449] <err> fota_download: Downloader error event -116
    [00:36:29.223,480] <err> lwm2m_firmware: FOTA_DOWNLOAD_EVT_ERROR
    [00:36:29.223,480] <inf> lwm2m_firmware: FOTA download failed, target 0
    [00:36:29.231,842] <inf> app_lwm2m_client: FOTA failure 0 by status 4
    1. HTTPS configuration (with CA certificate)
      I extracted the CA certificate from the server and integrated it into the modem using:
    modem_key_mgmt_write()
    I also configured:
    CONFIG_LWM2M_CLIENT_UTILS_DOWNLOADER_SEC_TAG=1
    Despite this, the HTTPS download still fails.
    :03.343,597] <inf> app_lwm2m_client: FOTA download started for instance 0
    [00:04:03.344,299] <inf> fota_download_util: Download url https://leshan.egconnect.cloud/zephyr.signed.bin
    [00:04:03.344,360] <inf> fota_download_util: Download Path zephyr.signed.bin host https://leshan.egconnect.cloud
    [00:04:03.348,815] <inf> downloader: Host lookup failed for hostname leshan.egconnect.cloud on IPv6 (err -22), attempting IPv4
    [00:04:03.433,502] <inf> net_lwm2m_rd_client: Update callback (code:2.4)
    [00:04:03.433,563] <dbg> app_lwm2m_client: rd_client_event: Registration update complete
    [00:04:03.433,593] <inf> net_lwm2m_rd_client: Update Done
    [00:04:03.532,379] <inf> net_lwm2m_message_handling: Send done!
    [00:04:03.533,386] <inf> net_lwm2m_message_handling: Send done!
    [00:04:03.542,877] <inf> lwm2m_rai: Ongoing traffic, RAI disabled
    [00:04:04.537,719] <inf> downloader: Setting up TLS credentials, sec tag count 1
    [00:04:04.537,841] <inf> downloader: Connecting to 91.134.59.209
    [00:04:05.689,239] <err> downloader: Failed to connect, err -111
    [00:04:05.689,270] <err> fota_download: Downloader error event -111
    [00:04:05.689,300] <err> lwm2m_firmware: FOTA_DOWNLOAD_EVT_ERROR
    [00:04:05.689,300] <inf> lwm2m_firmware: FOTA download failed, target 0
    [00:04:05.691,406] <inf> app_lwm2m_client: FOTA failure 0 by status 4
    1. Root cause (suspected)
      It seems that the main issue is network accessibility:
    • The firmware is hosted on my local machine (192.168.x.x)
    • The device is connected via LTE
    • Therefore, it cannot reach the firmware server
    but doesn't work
    I also configured:
