System / BLE only starts after J-Link RTT is connected (custom board, no DCDC) – fixed in NCS v2.5.1, same issue again in v2.9.2
Hello,I am using a custom nRF52832-based board that has no DCDC circuitry (LDO only).What happened in NCS v2.5.1
  • After power-on, the system did not start (e.g. no BLE advertising).
  • The system only started after I connected J-Link RTT Viewer to the board.
  • I spent a lot of time adjusting configuration (DCDC, clocks, RTT/console, etc.) and eventually got it working so that the system starts correctly after power-on without the debugger connected.
What happened after upgrading to NCS v2.9.2
  • I upgraded to NCS v2.9.2 because v2.5.1 does not support ANT.
  • The same problem came back: the system does not start on power-on; it only starts after I connect J-Link RTT Viewer to the board.
  • I have tried to apply the same settings that fixed the issue in v2.5.1 (disabling DCDC in software, 32 kHz internal RC, disabling RTT / console, delays before BLE init, etc.), but the problem persists in v2.9.2.
Question
  • What changed between NCS v2.5.1 and v2.9.2 that could cause this “no start until RTT is connected” behavior again on a custom board without DCDC?
  • Is there any recommended configuration or workaround for NCS v2.9.2 so that the system (and BLE) starts reliably after power-on without requiring J-Link RTT to be connected?
Thank you for your help.
  • It is difficult to come up with a workaround when we don't now what the issue as. To debug this further, please read out the CPU registers from the device when it "hangs" using nrfjprog or nrfutil from the command line:
    nrfutil device cpu-registers-read
    nrfjprog --readregs
    This may help us figure out what state the chip/fw is in when it fails to perform BLE advertising.
    Have you tried replicating this issue on a Nordic development kit?
  • We ran nrfjprog --readregs while the device was in the non-advertising state (RTT Viewer not connected). The register dump is below.
    PS C:\ncs\v2.9.2\nrf\applications\ble_test> nrfjprog --readregs
    R0: 0x00000000
    R1: 0x00000000
    R2: 0x00000000
    R3: 0x00000000
    R4: 0x00000000
    R5: 0x00000000
    R6: 0x00000000
    R7: 0x00000000
    R8: 0x00000000
    R9: 0x00000000
    R10: 0x00000000
    R11: 0x00000000
    R12: 0x00000000
    SP: 0x20006100
    LR: 0xFFFFFFFF
    PC: 0x00002ADC
    xPSR: 0x01000000
    MSP: 0x20006100
    PSP: 0x00000000
    RAZ: 0x00000000
    CFBP: 0x00000000
    APSR: 0x00000000
    EPSR: 0x01000000
    IPSR: 0x00000000
  • The register readout is from early boot in the bootloader. Forgot to add that you should also build the bootloader and app with CONFIG_RESET_ON_FATAL_ERROR=n in case it is going in a boot loop.
  • PS C:\ncs\v2.9.2\nrf\applications\ble_test> nrfjprog --readregs
    R0: 0x00000000
    R1: 0x00000000
    R2: 0x00000000
    R3: 0x00000000
    R4: 0x00000000
    R5: 0x00000000
    R6: 0x00000000
    R7: 0x00000000
    R8: 0x00000000
    R9: 0x00000000
    R10: 0x00000000
    R11: 0x00000000
    R12: 0x00000000
    SP: 0x20006100
    LR: 0xFFFFFFFF
    PC: 0x00002ADC
    xPSR: 0x01000000
    MSP: 0x20006100
    PSP: 0x00000000
    RAZ: 0x00000000
    CFBP: 0x00000000
    APSR: 0x00000000
    EPSR: 0x01000000
    IPSR: 0x00000000
    We have set CONFIG_RESET_ON_FATAL_ERROR=n in both the bootloader and the app, rebuilt and reflashed, then read the CPU registers again with the device in the non-advertising state (RTT Viewer not connected). The register dump is above.One more question: could you provide (or point to) a minimal NCS v2.9.2 sample configured for LDO only (no DCDC), e.g. a BLE advertising app with sysbuild and MCUboot? Having such a baseline would help us compare our setup. We use a custom nRF52832 board without DCDC. Thank you.
  • Attached is a minimal sample you can build for nrf52dk/nrf52832. It includes a Kconfig fragment that selects the internal RC oscillator as the LF clock source and a Devictree overlay to select the LDO regulator. I also included the merged.hex file in this so you can also program that instead of building the project yourself (It's built on SDK v3.2.1).
    hello_world_ble_advertising.zip
