nRF54L15 with nRF7002 custom board scan and shell problem
I am having trouble communicating between the nRF54L15 and the nRF7002 in a custom board.
I flashed the scan sample. I made a new overlay as below:
 * Copyright (c) 2024 Nordic Semiconductor ASA
#include <freq.h>
    chosen {
        zephyr,wifi = &wlan0;
    aliases {
        /delete-property/ led1;
        /delete-property/ led3;
        /delete-property/ sw0;
        /delete-property/ sw1;
    buttons {
        /delete-property/ button0;
        /delete-property/ button1;
    leds {
&pinctrl {
    spi1_default: spi1_default {
        group1 {
            psels = <NRF_PSEL(SPIM_SCK, 2, 6)>,
                <NRF_PSEL(SPIM_MISO, 2, 10)>,
                <NRF_PSEL(SPIM_MOSI, 2, 9)>;
    spi1_sleep: spi1_sleep {
        group1 {
            low-power-enable;
&spi1 {
    status = "okay";
    cs-gpios = < &gpio1 10 GPIO_ACTIVE_LOW >;
    pinctrl-0 = < &spi1_default >;
    pinctrl-1 = < &spi1_sleep >;
    nrf70: nrf7002@0 {
        compatible = "nordic,nrf7002-spi";
        status = "okay";
        reg = <0>;
        label = "nrf7002_wlan";
        spi-max-frequency = <DT_FREQ_M(1)>;
        iovdd-ctrl-gpios = <&gpio1 12 (GPIO_ACTIVE_HIGH | GPIO_PULL_DOWN)>;
        bucken-gpios = <&gpio1 11 (GPIO_ACTIVE_HIGH | GPIO_PULL_DOWN)>;
        host-irq-gpios = <&gpio1 14 GPIO_ACTIVE_HIGH>;
        /* Maximum TX power limits for 2.4 GHz */
        wifi-max-tx-pwr-2g-dsss = <21>;
        wifi-max-tx-pwr-2g-mcs0 = <16>;
        wifi-max-tx-pwr-2g-mcs7 = <16>;
        /* Maximum TX power limits for 5 GHz */
        wifi-max-tx-pwr-5g-low-mcs0 = <13>;
        wifi-max-tx-pwr-5g-low-mcs7 = <13>;
        wifi-max-tx-pwr-5g-mid-mcs0 = <13>;
        wifi-max-tx-pwr-5g-mid-mcs7 = <13>;
        wifi-max-tx-pwr-5g-high-mcs0 = <12>;
        wifi-max-tx-pwr-5g-high-mcs7 = <12>;
        wlan0: wlan0 {
            compatible = "nordic,wlan";
My prj.config is:
# Copyright (c) 2022 Nordic Semiconductor ASA
CONFIG_WIFI=y
CONFIG_WIFI_NRF70=y
CONFIG_NET_L2_WIFI_MGMT=y
# System settings
CONFIG_ASSERT=y
# Networking
CONFIG_NETWORKING=y
CONFIG_NET_BUF_RX_COUNT=1
CONFIG_NET_BUF_TX_COUNT=1
CONFIG_NET_L2_ETHERNET=y
CONFIG_NET_NATIVE=n
CONFIG_NET_OFFLOAD=y
CONFIG_INIT_STACKS=y
# Memories
CONFIG_MAIN_STACK_SIZE=5200
# Debugging
CONFIG_STACK_SENTINEL=y
CONFIG_DEBUG_COREDUMP=y
CONFIG_DEBUG_COREDUMP_BACKEND_LOGGING=y
CONFIG_DEBUG_COREDUMP_MEMORY_DUMP_MIN=y
# Logging
CONFIG_LOG=y
CONFIG_PRINTK=y
# If below config is enabled, printk logs are
# buffered. For unbuffered messages, disable this.
CONFIG_LOG_PRINTK=n
# printing of scan results puts pressure on queues in new locking
# design in net_mgmt. So, use a higher timeout for a crowded
# environment.
CONFIG_NET_MGMT_EVENT_QUEUE_TIMEOUT=5000
# Raw scan Options
CONFIG_WIFI_MGMT_RAW_SCAN_RESULTS=n
CONFIG_WIFI_MGMT_RAW_SCAN_RESULTS_ONLY=n
CONFIG_WIFI_SCAN_DWELL_TIME_ACTIVE=50
CONFIG_WIFI_SCAN_DWELL_TIME_PASSIVE=130
# --- RTT console output ---
CONFIG_USE_SEGGER_RTT=y
CONFIG_RTT_CONSOLE=y
# Pick ONE console:
CONFIG_UART_CONSOLE=n
CONFIG_SHELL_BACKEND_SERIAL=n
# If you want the shell over RTT:
CONFIG_SHELL=y
CONFIG_SHELL_BACKEND_RTT=y
CONFIG_SHELL_PROMPT_RTT="mosh:~$ "
# Make printk go to console immediately (optional but helpful)
CONFIG_LOG_PRINTK=y
the output of the RTT is below:
SEGGER J-Link V8.66 - Real time terminal output
SEGGER J-Link (unknown) V1.0, SN=1057703105
Process: JLink.exe
*** Booting nRF Connect SDK v3.2.1-d8887f6f32df ***
*** Using Zephyr OS v4.2.99-ec78104f1569 ***
mosh:~$
Starting nrf54l15dk with CPU frequency: 128 MHz
ASSERTION FAIL [iface] @ WEST_TOPDIR/zephyr/include/zephyr/net/net_if.h:775
[00:00:01.011,709] <err> os: r0/a1: 0x00000004 r1/a2: 0x00000307 r2/a3: 0x00000003
[00:00:01.011,716] <err> os: r3/a4: 0x00000004 r12/ip: 0x200052dc r14/lr: 0x00007f83
[00:00:01.011,722] <err> os: xpsr: 0x09000000
[00:00:01.011,726] <err> os: Faulting instruction address (r15/pc): 0x0001095c
[00:00:01.011,745] <err> os: >>> ZEPHYR FATAL ERROR 4: Kernel panic on CPU 0
[00:00:01.011,762] <err> os: Current thread: 0x20001450 (main)
[00:00:01.570,413] <err> coredump: #CD:BEGIN#
[00:00:01.749,789] <err> coredump: #CD:5a450200030005
  • Hi Håkon,
    I changed the SPI frequency to 2MHz but i got a set new errors:
    Process: JLink.exe
    nrf_wifi_if_zep_start_board dev=wlan0
    power: bucken=1 iovdd=1 io2=1 io3=1
    [00:00:00.097,704] <dbg> wifi_nrf_bus: rpu_gpio_config: GPIO configuration done...
    [00:00:00.100,075] <dbg> wifi_nrf_bus: rpu_pwron: Bucken = 1, IOVDD = 1
    [00:00:00.100,237] <inf> wifi_nrf_bus: SPIM spi@4a000: freq = 2 MHz
    [00:00:00.100,378] <inf> wifi_nrf_bus: SPIM spi@4a000: latency = 0
    [00:00:00.100,591] <dbg> wifi_nrf_bus: rpu_wrsr2: Written 0x1 to WRSR2
    [00:00:00.100,835] <dbg> wifi_nrf_bus: spim_read_reg: err: 0 -> 0 0 0 0 0 0
    [00:00:00.101,003] <dbg> wifi_nrf_bus: spim_wait_while_rpu_wake_write: RDSR2 = 0x0
    [00:00:00.102,334] <dbg> wifi_nrf_bus: spim_read_reg: err: 0 -> 0 0 0 0 0 0
    [00:00:00.102,505] <dbg> wifi_nrf_bus: spim_wait_while_rpu_wake_write: RDSR2 = 0x0
    [00:00:00.103,837] <dbg> wifi_nrf_bus: spim_read_reg: err: 0 -> 0 0 0 0 0 0
    [00:00:00.104,008] <dbg> wifi_nrf_bus: spim_wait_while_rpu_wake_write: RDSR2 = 0x0
    [00:00:00.105,339] <dbg> wifi_nrf_bus: spim_read_reg: err: 0 -> 0 0 0 0 0 0
    [00:00:00.105,509] <dbg> wifi_nrf_bus: spim_wait_while_rpu_wake_write: RDSR2 = 0x0
    [00:00:00.106,839] <dbg> wifi_nrf_bus: spim_read_reg: err: 0 -> 0 0 0 0 0 0
    [00:00:00.107,009] <dbg> wifi_nrf_bus: spim_wait_while_rpu_wake_write: RDSR2 = 0x0
    [00:00:00.108,338] <dbg> wifi_nrf_bus: spim_read_reg: err: 0 -> 0 0 0 0 0 0
    [00:00:00.108,508] <dbg> wifi_nrf_bus: spim_wait_while_rpu_wake_write: RDSR2 = 0x0
    [00:00:00.109,838] <dbg> wifi_nrf_bus: spim_read_reg: err: 0 -> 0 0 0 0 0 0
    [00:00:00.110,008] <dbg> wifi_nrf_bus: spim_wait_while_rpu_wake_write: RDSR2 = 0x0
    [00:00:00.111,339] <dbg> wifi_nrf_bus: spim_read_reg: err: 0 -> 0 0 0 0 0 0
    [00:00:00.111,510] <dbg> wifi_nrf_bus: spim_wait_while_rpu_wake_write: RDSR2 = 0x0
    [00:00:00.112,842] <dbg> wifi_nrf_bus: spim_read_reg: err: 0 -> 0 0 0 0 0 0
    [00:00:00.113,013] <dbg> wifi_nrf_bus: spim_wait_while_rpu_wake_write: RDSR2 = 0x0
    [00:00:00.114,344] <dbg> wifi_nrf_bus: spim_read_reg: err: 0 -> 0 0 0 0 0 0
    [00:00:00.114,515] <dbg> wifi_nrf_bus: spim_wait_while_rpu_wake_write: RDSR2 = 0x0
    [00:00:00.115,777] <err> wifi_nrf_bus: RPU wakeup write ACK failed even after 10ms
    [00:00:00.115,942] <err> wifi_nrf_bus: Error: RDSR2 failed
    [00:00:00.116,081] <err> wifi_nrf: zep_shim_bus_qspi_dev_add: RPU enable failed with error -1
    [00:00:00.116,285] <err> wifi_nrf: nrf_wifi_bus_qspi_dev_add: nrf_wifi_osal_bus_qspi_dev_add failed
    [00:00:00.121,495] <err> wifi_nrf: nrf_wifi_bal_dev_add: Bus dev_add failed
    [00:00:00.121,682] <err> wifi_nrf: nrf_wifi_sys_hal_dev_add: nrf_wifi_bal_dev_add failed
    [00:00:00.121,914] <err> wifi_nrf: nrf_wifi_sys_fmac_dev_add: nrf_wifi_sys_hal_dev_add failed
    [00:00:00.122,105] <err> wifi_nrf: nrf_wifi_fmac_dev_add_zep: nrf_wifi_fmac_dev_add failed
    [00:00:00.122,280] <err> wifi_nrf: nrf_wifi_if_start_zep: nrf_wifi_fmac_dev_add_zep failed
    nRF70 power keepalive: BUCKEN/IOVDD forced high
    [00:00:01.122,905] <err> wifi_nrf: nrf_wifi_if_stop_zep: rpu_ctx_zep is NULL
    [00:00:01.211,435] <inf> wifi_nrf_bus: SPIM spi@4a000: latency = 0
    [00:00:01.211,641] <dbg> wifi_nrf_bus: rpu_wrsr2: Written 0x1 to WRSR2
    [00:00:01.211,886] <dbg> wifi_nrf_bus: spim_read_reg: err: 0 -> 0 0 0 0 0 0
    [00:00:01.212,056] <dbg> wifi_nrf_bus: spim_wait_while_rpu_wake_write: RDSR2 = 0x0
    [00:00:01.213,381] <dbg> wifi_nrf_bus: spim_read_reg: err: 0 -> 0 0 0 0 0 0
    [00:00:01.213,551] <dbg> wifi_nrf_bus: spim_wait_while_rpu_wake_write: RDSR2 = 0x0
    [00:00:01.214,871] <dbg> wifi_nrf_bus: spim_read_reg: err: 0 -> 0 0 0 0 0 0
    [00:00:01.215,040] <dbg> wifi_nrf_bus: spim_wait_while_rpu_wake_write: RDSR2 = 0x0
    [00:00:01.216,360] <dbg> wifi_nrf_bus: spim_read_reg: err: 0 -> 0 0 0 0 0 0
    [00:00:01.216,529] <dbg> wifi_nrf_bus: spim_wait_while_rpu_wake_write: RDSR2 = 0x0
    [00:00:01.217,848] <dbg> wifi_nrf_bus: spim_read_reg: err: 0 -> 0 0 0 0 0 0
    [00:00:01.218,018] <dbg> wifi_nrf_bus: spim_wait_while_rpu_wake_write: RDSR2 = 0x0
    [00:00:01.219,339] <dbg> wifi_nrf_bus: spim_read_reg: err: 0 -> 0 0 0 0 0 0
    [00:00:01.219,509] <dbg> wifi_nrf_bus: spim_wait_while_rpu_wake_write: RDSR2 = 0x0
    [00:00:01.220,831] <dbg> wifi_nrf_bus: spim_read_reg: err: 0 -> 0 0 0 0 0 0
    [00:00:01.221,001] <dbg> wifi_nrf_bus: spim_wait_while_rpu_wake_write: RDSR2 = 0x0
    [00:00:01.222,322] <dbg> wifi_nrf_bus: spim_read_reg: err: 0 -> 0 0 0 0 0 0
    [00:00:01.222,492] <dbg> wifi_nrf_bus: spim_wait_while_rpu_wake_write: RDSR2 = 0x0
    [00:00:01.223,813] <dbg> wifi_nrf_bus: spim_read_reg: err: 0 -> 0 0 0 0 0 0
    [00:00:01.223,984] <dbg> wifi_nrf_bus: spim_wait_while_rpu_wake_write: RDSR2 = 0x0
    [00:00:01.225,306] <dbg> wifi_nrf_bus: spim_read_reg: err: 0 -> 0 0 0 0 0 0
    [00:00:01.225,475] <dbg> wifi_nrf_bus: spim_wait_while_rpu_wake_write: RD
    This log shows issues contacting the nRF7002:
    Q1: Have you tried to program the wifi/radio_test/multi_domain sample to the device, and issued the command in step 1 here?
    https://docs.nordicsemi.com/bundle/nan_043/page/APP/nan_043/otp_programming.html
    Q2: Have you tried to scope your pins to see if there is any of the signals that are misbehaving?
    Håkon
