Enabling Provisioning
I'm attempting to enable provisioning using attestation tokens in my project.  As soon as I add the config;
CONFIG_NRF_PROVISIONING=y
The build starts failing with;
C:\Users\RANDAL~1.PHI\AppData\Local\Temp\ccKWl0nJ.s: Assembler messages:
C:\Users\RANDAL~1.PHI\AppData\Local\Temp\ccKWl0nJ.s:1406: Error: missing expression
I'm building for a custom board, that has the nrf9151 on it.  Using SDK 3.1.1
now when I build the nrf_cloud_multi_service sample, targeting the nrf9151dk it builds fine, which I think means that I have some sort of CONFIG conflict.
7271.prj.conf
  • Perhaps you can tell me what I'm doing wrong;
    nonsecure_storage:
    address: 0xE4000
    end_address: 0xfe000
    orig_span: &id001
    - nvs_storage
    - user_storage
    region: flash_primary
    span: *id001
    nvs_storage:
    address: 0xE4000
    end_address: 0xF1000
    inside:
    - nonsecure_storage
    placement:
    align:
    start: 0x1000
    before:
    - end
    user_storage:
    address: 0xF1000
    inside:
    - nonsecure_storage
    placement:
    align:
    start: 0x1000
    before:
    - end
    I changed my pm_static to this, but when I try to use user_storage in my program it appears to be placing the memory at 0x100000 and only 4K of memory at that.
    Thanks for sharing the updated layout. The partition split itself looks fine.
    If your data is ending up at 0x100000 with only 4 KB, that usually means the application is still writing to a default storage area, rather than the user_storage partition you defined. In other words, the partition exists, but the code isn’t actually using it yet.
    Have you tried doing a pristine rebuild and checked build/partitions.yml to confirm if the user_storage is present at 0xF1000 with size 0xD000?
    Best Regards,
    Syed Maysum
  • My bad, I was trying to create a nvs file system with more sectors than was available.  Instead of using
    FIXED_PARTITION_SIZE() to calculate, I was using a hardcoded value in my code Frowning2.
    So I appear to be all good now.
