Baseline Power Consumption Benchmarking on nrf52dk
Hello Nordic Forum,
I ran the Power Profiler Kit on an nRF52DK development board to establish a baseline power consumption.
The current firmware project is quite simple, and I have removed most of the GPIO, including UART, to minimize power consumption.
I have not enabled power management yet, as I am focusing on benchmarking the current power usage.
Currently, the kit reads about 23.25 mA while running in the main loop. Does this seem reasonable?
Would I expect to achieve a significant reduction in consumption if I enable Power Management, or would this only be beneficial when I add sensors that implement power management interfaces?
Thank you in advance for your knowledge and support.
while (1) {
k_sleep(K_FOREVER);
CONFIG_CPP=y
CONFIG_GPIO=y
CONFIG_I2C=y
CONFIG_I2C_NRFX=y
CONFIG_CBPRINTF_FP_SUPPORT=y
CONFIG_DEBUG=y
CONFIG_PRINTK=y
CONFIG_LOG=y
  • Ok, so the configuration of board, ppk and wiring seems correct.
    I still struggle to understand how with everything disabled in
    prj.conf and overlay file and a code that only flashes an led on and off on the nrf52dk (pin 20), i read a current of 160uA when led is off.
    Is there a sample that has everything turned off and power mode configured for the lowest possible consumption that I can use for reference?
    Thank you
    CONFIG_CPP=y
    CONFIG_GPIO=y
    CONFIG_SERIAL=n
    CONFIG_PM_DEVICE=y
    &uart0 {
    status = "disabled";
    &pwm0 {
    &bprot {
    &ccm {
    &ecb {
    &ficr {
    &gpiote {
    status = "okay";
    &egu0 {
    &power {
    &reg {
    &egu1 {
    &egu2 {
    &egu3 {
    &egu4 {
    &egu5 {
    &rng {
    &ppi {
    status = "okay";
    &nvic {
    &clock {
    status = "okay";
    &uicr {
    &mwu {
    &wdt {
  • If you try the "Hello World" sample it is sufficient to add CONFIG_SERIAL=n the project configuration (this is true for most samples). You can also try the pre-compiled hex I posted here /f/nordic-q-a/120743/ble-advertising-power-benchmark/532498.
    Do you measure more when it is on? The measurements should not be affected by the led states as they are supplied by USB bus.
  • Vidar, thank you for your reply.
    Indeed I get a higher current when the Led is on.
    Here is the trace with the pre-compiled hex:
    The shape is the same but the floor current is of around 194uA. Similar to what it was identified in the other blog as well.
    I am gonna try with a different dk and post the results here
  • Thanks for confirming. This suggests that something is wrong with the setup. Hopefully, you will get the expected results when you try it on a different DK.
  • I was hoping to provide some progresses as I had ordered two more nrf52dk from digikey.
    Unfortunately, I tested one and i got the same 200uA result.
    Could it be the ppk?
