nRF Command Line Tools: nrfdfu.dll 32bit version problem when updating nRF9160 firmware
Dear support team,
we use the Nordic nrfdfu.dll (64bit) in our Win11 C#/.Net application for modem update which works fine.
When we switch our application to 32bit process and change to the Nordic nrfdfu.dll (32bit) the modem update functionality no longer works. The communication start between PC application and nRF9160 modem seems to fail and the application hangs until we stop it after some minutes.
Via DllImport we use the following methods of the nrfdfu.dll:
        [DllImport(nrfDfuDllName, EntryPoint = "NRFDFU_connect_to_mcuboot_target", CallingConvention = CallingConvention.Cdecl)]
        [DllImport(nrfDfuDllName, EntryPoint = "NRFDFU_connect_to_modemdfu_target", CallingConvention = CallingConvention.Cdecl)]
        [DllImport(nrfDfuDllName, EntryPoint = "NRFDFU_program_package", CallingConvention = CallingConvention.Cdecl, CharSet = CharSet.Ansi)]
        [DllImport(nrfDfuDllName, EntryPoint = "NRFDFU_close_connection", CallingConvention = CallingConvention.Cdecl)]
        [DllImport(nrfDfuDllName, EntryPoint = "NRFDFU_verify_package", CallingConvention = CallingConvention.Cdecl, CharSet = CharSet.Ansi)]
Do you have any idea what the reason could be?
Peter
  • Hi Aghijith,
    any news on this topic?
    Best regards
    Johannes
  • Hello Peter,
    Sorry for the delay occurring here.
    When running the 32-bit version of the application, can you confirm which SEGGER J-Link DLL is loaded? A 32-bit process must load JLinkARM.dll (32-bit), while a 64-bit process uses JLink_x64.dll
    The DFU API launches a worker executable (jlinkarm_nrf_worker_*.exe) to handle the J-Link communication. When the application runs as a 32-bit process, the 32-bit version of this worker executable would typically need to be available, possibly either in the same directory as the application or somewhere in the system PATH. If only the 64-bit worker executable is present, it might be possible that the API attempts to launch that instead, which could potentially lead to the communication failing or the process hanging. Could you check whether a 32-bit jlinkarm_nrf_worker_*.exe is present and being used when running the application in 32-bit mode?
    Kind Regards,
    Abhijith
  • Hallo Abhijith,
    I am NOT using Jlink in SW update, I am just connected via USB-C cable. We have created a wrapper that calls methods from your nrfdfu.dll. I case of 32 bit DLL usage I get the error below in line 286 (error code = -220 from method "NRFDFU_program_package". When operating in 64 bit mode line 282 is executed and work OK.
    // Start programming
    int returnCode = -1;
    if ( NordicNrfDfuWrapper.IsRunningInA64BitProcess () )
        returnCode = NRFDFU_program_package_x64 ( this.connectionHandle, filePath );
        returnCode = NRFDFU_program_package ( this.connectionHandle, filePath );
    Best regards
    Johannes
    I checked with the internal team regarding this issue, and we tried to reproduce it on our side, but it seems to be working for us. I am including the steps we followed to reproduce the issue and also attaching the generated logs
    The last available 32-bit version of the nRF Command Line Tools (v10.19.0 for “Windows x86 32”) was downloaded from here.
    From this package, the 32-bit DLLs, the 32-bit worker executable (jlinkarm_nrf_worker.exe), and the corresponding header files were copied into a separate test directory.
    A small C test application was then created to load nrfdfu.dll and call the MCUboot functions provided by the library. The application was compiled as a 32-bit executable using Visual Studio (MSVC 2019).
    The target hardware used for testing was an nRF9160 running the fmfu_smp_svr sample from the nRF Connect SDK. For this setup, the test directory contained only the 32-bit versions of the DLLs and the worker executable, ensuring that no 32-bit and 64-bit components were mixed during the test.
    Using this setup, the behavior where the application hangs could not be reproduced. The test application was able to proceed, and log messages indicated that firmware chunks at increasing offsets were uploaded successfully. The test was not run to completion, but the upload appeared to progress beyond the point where the failure reportedly occurs.
    As an additional diagnostic step, it may be useful to enable a log callback in the DFU API. If no log messages are returned at all, it could indicate that something fails when the DLL attempts to start the worker executable.The worker (jlinkarm_nrf_worker.exe) should normally be located in the same directory as the DLL, and it is expected that the 32-bit version is used when running a 32-bit application
    H:\nrf91_dfu>.\main.exe
    [DBG] ModemUARTDFU-\\.\COM44: Timeout set to 10000ms
    [INFO] ModemUARTDFU-\\.\COM44: Initialize new probe.
    [DBG] ModemUARTDFU-\\.\COM44: initialize
    [INFO] ModemUARTDFU-\\.\COM44: Successfully opened port: \\.\COM44@115200,flow_control:none,parity:none.
    [TRACE] ModemUARTDFU-\\.\COM44: TX pkt with header: op:0 flags:0 len:14, group:2, seq:0, id: 0, total size: 36
    [DBG] ModemUARTDFU-\\.\COM44: UART TX(39)
    [DBG] ModemUARTDFU-\\.\COM44: Waiting with timeout 400ms
    [DBG] ModemUARTDFU-\\.\COM44: UART RX(87): 0x06 09 41 44 73 42 41 41 41 78 41 41 49 41 41 4C 39 6B 62 6D 46 74 5A 57 64 7A 62 58 42 66 59 32 39 74 5A 6D 5A 70 5A 57 78 6B 63 37 39 70 5A 6E 4A 68 62 57 56 66 62 57 46 34 47 51 49 41 61 48 42 68 59 32 74 66 62 57 46 34 47 51 48 34 2F 2F 2B 45 6E 67 3D 3D 0A
    [DBG] ModemUARTDFU-\\.\COM44: Frame type after decode: START
    [DBG] ModemUARTDFU-\\.\COM44: Attempting to decode frames vector with 1 frames
    [ERR] ModemUARTDFU-\\.\COM44: Error caught in parse_stat_response: Key not found: 'rc'
    [DBG] ModemUARTDFU-\\.\COM44: Have image upload chunk size of 272 (1st packet) and 328 (proceeding)
    [DBG] ModemUARTDFU-\\.\COM44: Using MTU 500 and frame size 500.
    [INFO] ModemUARTDFU-\\.\COM44: {
        "duration": 471,
        "error_code": "Ok",
        "operation": "open_uart",
        "outcome": "success",
        "progress_percentage": 100
    [DBG] ModemUARTDFU-\\.\COM44: program_package
    [INFO] ModemUARTDFU-\\.\COM44: Check if provided file exists
    [INFO] ModemUARTDFU-\\.\COM44: Check if provided file can be read
    [DBG] ModemUARTDFU-\\.\COM44: program_files
    [DBG] ModemUARTDFU-\\.\COM44: confirm_image
    [INFO] ModemUARTDFU-\\.\COM44: {"amountOfSteps":4,"description":"Finding image components","duration":0,"message":"Detecting package components","operation":"confirm_image","progressPercentage":25,"step":1}
    [INFO] ModemUARTDFU-\\.\COM44: {"amountOfSteps":4,"description":"Finding image components","duration":0,"message":"Verifying that package is complete","operation":"confirm_image","progressPercentage":50,"step":2}
    [INFO] ModemUARTDFU-\\.\COM44: {"amountOfSteps":4,"description":"Finding image components","duration":0,"message":"Detecting bootloader version","operation":"confirm_image","progressPercentage":75,"step":3}
    [INFO] ModemUARTDFU-\\.\COM44: {"amountOfSteps":4,"description":"Finding image components","duration":0,"message":"Finished","operation":"confirm_image","progressPercentage":100,"result":"success","step":4}
    [INFO] ModemUARTDFU-\\.\COM44: {"amountOfSteps":5,"description":"Upload segments","duration":0,"message":"Prepare modem for upload","operation":"enter_programming_state","progressPercentage":20,"step":1}
    [INFO] ModemUARTDFU-\\.\COM44: {"amountOfSteps":5,"description":"Upload segments","duration":0,"message":"Upload bootloader","operation":"enter_programming_state","progressPercentage":40,"step":2}
    [DBG] ModemUARTDFU-\\.\COM44: program_bootloader
    [INFO] ModemUARTDFU-\\.\COM44: {"amountOfSteps":2,"description":"Starting modem boot loader","duration":0,"message":"72B3D7C.ipc_dfu.signed_1.1.0.ihex","operation":"enter_programming_state","progressPercentage":50,"step":1}
    [INFO] ModemUARTDFU-\\.\COM44: Extracting 13416 bytes from 72B3D7C.ipc_dfu.signed_1.1.0.ihex.
        "duration": 0,
        "message": "Calculating image size",
        "operation": "upload_image",
        "progress_percentage": 5
        "duration": 0,
        "message": "Uploading image to device",
    [DBG] ModemUARTDFU-\\.\COM44: Uploading chunk offset: 0, len: 272, out of total len 4752, target addr: 536870924
    [TRACE] ModemUARTDFU-\\.\COM44: TX pkt with header: op:2 flags:0 len:341, group:65, seq:1, id: 1, total size: 472
    [DBG] ModemUARTDFU-\\.\COM44: UART TX(475)
    [DBG] ModemUARTDFU-\\.\COM44: Waiting with timeout 2000ms
    [DBG] ModemUARTDFU-\\.\COM44: UART RX(39): 0x06 09 41 42 63 44 41 41 41 4E 41 45 45 42 41 62 39 69 63 6D 4D 41 59 32 39 6D 5A 68 6B 42 45 50 2F 4E 63 77 3D 3D 0A
    [DBG] ModemUARTDFU-\\.\COM44: Chunk upload took 94ms. Current upload runtime is 0s
        "duration": 94,
        "progress_percentage": 15
    [DBG] ModemUARTDFU-\\.\COM44: Uploading chunk offset: 272, len: 328, out of total len 4752, target addr: 536871196
    [TRACE] ModemUARTDFU-\\.\COM44: TX pkt with header: op:2 flags:0 len:354, group:65, seq:2, id: 1, total size: 488
    [DBG] ModemUARTDFU-\\.\COM44: UART TX(491)
    [DBG] ModemUARTDFU-\\.\COM44: UART RX(39): 0x06 09 41 42 63 44 41 41 41 4E 41 45 45 43 41 62 39 69 63 6D 4D 41 59 32 39 6D 5A 68 6B 43 57 50 2F 7A 59 77 3D 3D 0A
    [DBG] ModemUARTDFU-\\.\COM44: Chunk upload took 91ms. Current upload runtime is 0s
        "duration": 186,
        "progress_percentage": 21
    [DBG] ModemUARTDFU-\\.\COM44: Uploading chunk offset: 600, len: 328, out of total len 4752, target addr: 536871524
    [TRACE] ModemUARTDFU-\\.\COM44: TX pkt with header: op:2 flags:0 len:354, group:65, seq:3, id: 1, total size: 488
    [DBG] ModemUARTDFU-\\.\COM44: UART RX(39): 0x06 09 41 42 63 44 41 41 41 4E 41 45 45 44 41 62 39 69 63 6D 4D 41 59 32 39 6D 5A 68 6B 44 6F 50 2F 77 78 77 3D 3D 0A
        "duration": 281,
        "progress_percentage": 27
    [DBG] ModemUARTDFU-\\.\COM44: Uploading chunk offset: 928, len: 328, out of total len 4752, target addr: 536871852
    [TRACE] ModemUARTDFU-\\.\COM44: TX pkt with header: op:2 flags:0 len:354, group:65, seq:4, id: 1, total size: 488
    [DBG] ModemUARTDFU-\\.\COM44: UART RX(39): 0x06 09 41 42 63 44 41 41 41 4E 41 45 45 45 41 62 39 69 63 6D 4D 41 59 32 39 6D 5A 68 6B 45 36 50 2B 4A 70 51 3D 3D 0A
    [DBG] ModemUARTDFU-\\.\COM44: Chunk upload took 92ms. Current upload runtime is 0s
        "duration": 374,
        "progress_percentage": 33
    [DBG] ModemUARTDFU-\\.\COM44: Uploading chunk offset: 1256, len: 328, out of total len 4752, target addr: 536872180
    [TRACE] ModemUARTDFU-\\.\COM44: TX pkt with header: op:2 flags:0 len:354, group:65, seq:5, id: 1, total size: 488
    [DBG] ModemUARTDFU-\\.\COM44: UART RX(39): 0x06 09 41 42 63 44 41 41 41 4E 41 45 45 46 41 62 39 69 63 6D 4D 41 59 32 39 6D 5A 68 6B 47 4D 50 2F 56 74 77 3D 3D 0A
        "duration": 466,
        "progress_percentage": 40
    [DBG] ModemUARTDFU-\\.\COM44: Uploading chunk offset: 1584, len: 328, out of total len 4752, target addr: 536872508
    [TRACE] ModemUARTDFU-\\.\COM44: TX pkt with header: op:2 flags:0 len:354, group:65, seq:6, id: 1, total size: 488
    [DBG] ModemUARTDFU-\\.\COM44: UART RX(39): 0x06 09 41 42 63 44 41 41 41 4E 41 45 45 47 41 62 39 69 63 6D 4D 41 59 32 39 6D 5A 68 6B 48 65 50 2B 46 78 77 3D 3D 0A
        "duration": 558,
        "progress_percentage": 46
    [DBG] ModemUARTDFU-\\.\COM44: Uploading chunk offset: 1912, len: 328, out of total len 4752, target addr: 536872836
    [TRACE] ModemUARTDFU-\\.\COM44: TX pkt with header: op:2 flags:0 len:354, group:65, seq:7, id: 1, total size: 488
    [DBG] ModemUARTDFU-\\.\COM44: UART RX(39): 0x06 09 41 42 63 44 41 41 41 4E 41 45 45 48 41 62 39 69 63 6D 4D 41 59 32 39 6D 5A 68 6B 49 77 50 2B 51 72 67 3D 3D 0A
    [DBG] ModemUARTDFU-\\.\COM44: Chunk upload took 93ms. Current upload runtime is 0s
        "duration": 653,
        "progress_percentage": 52
    [DBG] ModemUARTDFU-\\.\COM44: Uploading chunk offset: 2240, len: 328, out of total len 4752, target addr: 536873164
    [TRACE] ModemUARTDFU-\\.\COM44: TX pkt with header: op:2 flags:0 len:354, group:65, seq:8, id: 1, total size: 488
    [DBG] ModemUARTDFU-\\.\COM44: UART RX(39): 0x06 09 41 42 63 44 41 41 41 4E 41 45 45 49 41 62 39 69 63 6D 4D 41 59 32 39 6D 5A 68 6B 4B 43 50 38 2B 34 51 3D 3D 0A
        "duration": 748,
        "progress_percentage": 58
    [DBG] ModemUARTDFU-\\.\COM44: Uploading chunk offset: 2568, len: 328, out of total len 4752, target addr: 536873492
    [TRACE] ModemUARTDFU-\\.\COM44: TX pkt with header: op:2 flags:0 len:354, group:65, seq:9, id: 1, total size: 488
    [DBG] ModemUARTDFU-\\.\COM44: UART RX(39): 0x06 09 41 42 63 44 41 41 41 4E 41 45 45 4A 41 62 39 69 63 6D 4D 41 59 32 39 6D 5A 68 6B 4C 55 50 38 67 4F 77 3D 3D 0A
        "duration": 841,
        "progress_percentage": 64
    [DBG] ModemUARTDFU-\\.\COM44: Uploading chunk offset: 2896, len: 328, out of total len 4752, target addr: 536873820
    [TRACE] ModemUARTDFU-\\.\COM44: TX pkt with header: op:2 flags:0 len:354, group:65, seq:10, id: 1, total size: 488
    [DBG] ModemUARTDFU-\\.\COM44: UART RX(39): 0x06 09 41 42 63 44 41 41 41 4E 41 45 45 4B 41 62 39 69 63 6D 4D 41 59 32 39 6D 5A 68 6B 4D 6D 50 2F 5A 63 77 3D 3D 0A
        "duration": 934,
        "progress_percentage": 71
    [DBG] ModemUARTDFU-\\.\COM44: Uploading chunk offset: 3224, len: 328, out of total len 4752, target addr: 536874148
    [TRACE] ModemUARTDFU-\\.\COM44: TX pkt with header: op:2 flags:0 len:354, group:65, seq:11, id: 1, total size: 488
    [DBG] ModemUARTDFU-\\.\COM44: UART RX(39): 0x06 09 41 42 63 44 41 41 41 4E 41 45 45 4C 41 62 39 69 63 6D 4D 41 59 32 39 6D 5A 68 6B 4E 34 50 2F 42 54 77 3D 3D 0A
    [DBG] ModemUARTDFU-\\.\COM44: Chunk upload took 93ms. Current upload runtime is 1s
        "duration": 1028,
        "progress_percentage": 77
    [DBG] ModemUARTDFU-\\.\COM44: Uploading chunk offset: 3552, len: 328, out of total len 4752, target addr: 536874476
    [TRACE] ModemUARTDFU-\\.\COM44: TX pkt with header: op:2 flags:0 len:354, group:65, seq:12, id: 1, total size: 488
    [DBG] ModemUARTDFU-\\.\COM44: UART RX(39): 0x06 09 41 42 63 44 41 41 41 4E 41 45 45 4D 41 62 39 69 63 6D 4D 41 59 32 39 6D 5A 68 6B 50 4B 50 39 49 52 51 3D 3D 0A
    [DBG] ModemUARTDFU-\\.\COM44: Chunk upload took 92ms. Current upload runtime is 1s
        "duration": 1121,
        "progress_percentage": 83
    [DBG] ModemUARTDFU-\\.\COM44: Uploading chunk offset: 3880, len: 328, out of total len 4752, target addr: 536874804
    [TRACE] ModemUARTDFU-\\.\COM44: TX pkt with header: op:2 flags:0 len:354, group:65, seq:13, id: 1, total size: 488
    [DBG] ModemUARTDFU-\\.\COM44: UART RX(39): 0x06 09 41 42 63 44 41 41 41 4E 41 45 45 4E 41 62 39 69 63 6D 4D 41 59 32 39 6D 5A 68 6B 51 63 50 38 4F 2F 51 3D 3D 0A
        "duration": 1214,
        "progress_percentage": 89
    [DBG] ModemUARTDFU-\\.\COM44: Uploading chunk offset: 4208, len: 328, out of total len 4752, target addr: 536875132
    [TRACE] ModemUARTDFU-\\.\COM44: TX pkt with header: op:2 flags:0 len:354, group:65, seq:14, id: 1, total size: 488
    [DBG] ModemUARTDFU-\\.\COM44: UART RX(39): 0x06 09 41 42 63 44 41 41 41 4E 41 45 45 4F 41 62 39 69 63 6D 4D 41 59 32 39 6D 5A 68 6B 52 75 50 39 46 46 51 3D 3D 0A
        "duration": 1308,
        "progress_percentage": 95
    [DBG] ModemUARTDFU-\\.\COM44: Uploading chunk offset: 4536, len: 216, out of total len 4752, target addr: 536875460
    [TRACE] ModemUARTDFU-\\.\COM44: TX pkt with header: op:2 flags:0 len:241, group:65, seq:15, id: 1, total size: 340
    [DBG] ModemUARTDFU-\\.\COM44: UART TX(343)
    [DBG] ModemUARTDFU-\\.\COM44: UART RX(39): 0x06 09 41 42 63 44 41 41 41 4E 41 45 45 50 41 62 39 69 63 6D 4D 41 59 32 39 6D 5A 68 6B 53 6B 50 38 39 39 67 3D 3D 0A
    [DBG] ModemUARTDFU-\\.\COM44: Chunk upload took 125ms. Current upload runtime is 1s
        "duration": 1434,
    [INFO] ModemUARTDFU-\\.\COM44: {"amountOfSteps":2,"description":"Starting modem boot loader","duration":1437,"message":"Finished","operation":"enter_programming_state","progressPercentage":100,"result":"success","step":2}
    [INFO] ModemUARTDFU-\\.\COM44: {"amountOfSteps":5,"description":"Upload segments","duration":1437,"message":"Modem ready for upload","operation":"enter_programming_state","progressPercentage":60,"step":3}
    [INFO] ModemUARTDFU-\\.\COM44: {"amountOfSteps":5,"description":"Upload segments","duration":0,"message":"segment 1 of 2","operation":"upload_image","progressPercentage":80,"step":4}
    [INFO] ModemUARTDFU-\\.\COM44: Extracting 6436 bytes from firmware.update.image.segments.0.hex.
        "duration": 0,
        "duration": 0,
    [DBG] ModemUARTDFU-\\.\COM44: Uploading chunk offset: 0, len: 272, out of total len 2328, target addr: 1499471872
    [TRACE] ModemUARTDFU-\\.\COM44: TX pkt with header: op:2 flags:0 len:341, group:65, seq:16, id: 1, total size: 472
    [DBG] ModemUARTDFU-\\.\COM44: UART RX(39): 0x06 09 41 42 63 44 41 41 41 4E 41 45 45 51 41 62 39 69 63 6D 4D 41 59 32 39 6D 5A 68 6B 42 45 50 38 74 42 51 3D 3D 0A
    [DBG] ModemUARTDFU-\\.\COM44: Chunk upload took 85ms. Current upload runtime is 0s
        "duration": 86,
        "progress_percentage": 20
    [DBG] ModemUARTDFU-\\.\COM44: Uploading chunk offset: 272, len: 328, out of total len 2328, target addr: 1499472144
    [TRACE] ModemUARTDFU-\\.\COM44: TX pkt with header: op:2 flags:0 len:354, group:65, seq:17, id: 1, total size: 488
    [DBG] ModemUARTDFU-\\.\COM44: UART RX(39): 0x06 09 41 42 63 44 41 41 41 4E 41 45 45 52 41 62 39 69 63 6D 4D 41 59 32 39 6D 5A 68 6B 43 57 50 39 65 7A 41 3D 3D 0A
        "duration": 181,
    [DBG] ModemUARTDFU-\\.\COM44: Uploading chunk offset: 600, len: 328, out of total len 2328, target addr: 1499472472
    [TRACE] ModemUARTDFU-\\.\COM44: TX pkt with header: op:2 flags:0 len:354, group:65, seq:18, id: 1, total size: 488
    [DBG] ModemUARTDFU-\\.\COM44: UART RX(39): 0x06 09 41 42 63 44 41 41 41 4E 41 45 45 53 41 62 39 69 63 6D 4D 41 59 32 39 6D 5A 68 6B 44 6F 50 38 51 73 51 3D 3D 0A
        "duration": 274,
        "progress_percentage": 45
    [DBG] ModemUARTDFU-\\.\COM44: Uploading chunk offset: 928, len: 328, out of total len 2328, target addr: 1499472800
    [TRACE] ModemUARTDFU-\\.\COM44: TX pkt with header: op:2 flags:0 len:354, group:65, seq:19, id: 1, total size: 488
    [DBG] ModemUARTDFU-\\.\COM44: UART RX(39): 0x06 09 41 42 63 44 41 41 41 4E 41 45 45 54 41 62 39 69 63 6D 4D 41 59 32 39 6D 5A 68 6B 45 36 50 2B 2F 75 41 3D 3D 0A
    [DBG] ModemUARTDFU-\\.\COM44: Chunk upload took 95ms. Current upload runtime is 0s
        "duration": 370,
    [DBG] ModemUARTDFU-\\.\COM44: Uploading chunk offset: 1256, len: 328, out of total len 2328, target addr: 1499473128
    [TRACE] ModemUARTDFU-\\.\COM44: TX pkt with header: op:2 flags:0 len:354, group:65, seq:20, id: 1, total size: 488
    [DBG] ModemUARTDFU-\\.\COM44: UART RX(39): 0x06 09 41 42 63 44 41 41 41 4E 41 45 45 55 41 62 39 69 63 6D 4D 41 59 32 39 6D 5A 68 6B 47 4D 50 38 31 77 51 3D 3D 0A
        "duration": 462,
    [DBG] ModemUARTDFU-\\.\COM44: Uploading chunk offset: 1584, len: 328, out of total len 2328, target addr: 1499473456
    [TRACE] ModemUARTDFU-\\.\COM44: TX pkt with header: op:2 flags:0 len:354, group:65, seq:21, id: 1, total size: 488
    [DBG] ModemUARTDFU-\\.\COM44: UART RX(39): 0x06 09 41 42 63 44 41 41 41 4E 41 45 45 56 41 62 39 69 63 6D 4D 41 59 32 39 6D 5A 68 6B 48 65 50 38 6F 61 41 3D 3D 0A
        "duration": 557,
    [DBG] ModemUARTDFU-\\.\COM44: Uploading chunk offset: 1912, len: 328, out of total len 2328, target addr: 1499473784
    [TRACE] ModemUARTDFU-\\.\COM44: TX pkt with header: op:2 flags:0 len:354, group:65, seq:22, id: 1, total size: 488
    [DBG] ModemUARTDFU-\\.\COM44: UART RX(39): 0x06 09 41 42 63 44 41 41 41 4E 41 45 45 57 41 62 39 69 63 6D 4D 41 59 32 39 6D 5A 68 6B 49 77 50 39 77 32 41 3D 3D 0A
        "duration": 650,
        "progress_percentage": 96
    [DBG] ModemUARTDFU-\\.\COM44: Uploading chunk offset: 2240, len: 88, out of total len 2328, target addr: 1499474112
    [TRACE] ModemUARTDFU-\\.\COM44: TX pkt with header: op:2 flags:0 len:113, group:65, seq:23, id: 1, total size: 168
    [DBG] ModemUARTDFU-\\.\COM44: UART TX(171)
    [DBG] ModemUARTDFU-\\.\COM44: UART RX(39): 0x06 09 41 42 63 44 41 41 41 4E 41 45 45 58 41 62 39 69 63 6D 4D 41 59 32 39 6D 5A 68 6B 4A 47 50 39 31 6D 67 3D 3D 0A
    [DBG] ModemUARTDFU-\\.\COM44: Chunk upload took 61ms. Current upload runtime is 0s
        "duration": 713,
    [INFO] ModemUARTDFU-\\.\COM44: {"amountOfSteps":5,"description":"Upload segments","duration":719,"message":"segment 2 of 2","operation":"upload_image","progressPercentage":100,"result":"success","step":5}
    [INFO] ModemUARTDFU-\\.\COM44: Extracting 5564940 bytes from firmware.update.image.segments.1.hex.
        "duration": 0,
        "duration": 0,
    [DBG] ModemUARTDFU-\\.\COM44: Uploading chunk offset: 0, len: 272, out of total len 2023424, target addr: 24576
    [TRACE] ModemUARTDFU-\\.\COM44: TX pkt with header: op:2 flags:0 len:341, group:65, seq:24, id: 1, total size: 472
    [DBG] ModemUARTDFU-\\.\COM44: UART RX(39): 0x06 09 41 42 63 44 41 41 41 4E 41 45 45 59 41 62 39 69 63 6D 4D 41 59 32 39 6D 5A 68 6B 42 45 50 38 4B 51 41 3D 3D 0A
    [DBG] ModemUARTDFU-\\.\COM44: Chunk upload took 87ms. Current upload runtime is 0s
    [DBG] ModemUARTDFU-\\.\COM44: Uploading chunk offset: 272, len: 328, out of total len 2023424, target addr: 24848
    [TRACE] ModemUARTDFU-\\.\COM44: TX pkt with header: op:2 flags:0 len:352, group:65, seq:25, id: 1, total size: 488
    [DBG] ModemUARTDFU-\\.\COM44: UART RX(39): 0x06 09 41 42 63 44 41 41 41 4E 41 45 45 5A 41 62 39 69 63 6D 4D 41 59 32 39 6D 5A 68 6B 43 57 50 39 35 69 51 3D 3D 0A
    [DBG] ModemUARTDFU-\\.\COM44: Uploading chunk offset: 600, len: 328, out of total len 2023424, target addr: 25176
    [TRACE] ModemUARTDFU-\\.\COM44: TX pkt with header: op:2 flags:0 len:352, group:65, seq:26, id: 1, total size: 488
    [DBG] ModemUARTDFU-\\.\COM44: UART RX(39): 0x06 09 41 42 63 44 41 41 41 4E 41 45 45 61 41 62 39 69 63 6D 4D 41 59 32 39 6D 5A 68 6B 44 6F 50 38 33 39 41 3D 3D 0A
    [DBG] ModemUARTDFU-\\.\COM44: Uploading chunk offset: 928, len: 328, out of total len 2023424, target addr: 25504
    [TRACE] ModemUARTDFU-\\.\COM44: TX pkt with header: op:2 flags:0 len:352, group:65, seq:27, id: 1, total size: 488
    [DBG] ModemUARTDFU-\\.\COM44: UART RX(39): 0x06 09 41 42 63 44 41 41 41 4E 41 45 45 62 41 62 39 69 63 6D 4D 41 59 32 39 6D 5A 68 6B 45 36 50 2B 59 2F 51 3D 3D 0A
    [DBG] ModemUARTDFU-\\.\COM44: Uploading chunk offset: 1256, len: 328, out of total len 2023424, target addr: 25832
    [TRACE] ModemUARTDFU-\\.\COM44: TX pkt with header: op:2 flags:0 len:352, group:65, seq:28, id: 1, total size: 488
    [DBG] ModemUARTDFU-\\.\COM44: UART RX(39): 0x06 09 41 42 63 44 41 41 41 4E 41 45 45 63 41 62 39 69 63 6D 4D 41 59 32 39 6D 5A 68 6B 47 4D 50 38 53 68 41 3D 3D 0A
    [DBG] ModemUARTDFU-\\.\COM44: Uploading chunk offset: 1584, len: 328, out of total len 2023424, target addr: 26160
    [TRACE] ModemUARTDFU-\\.\COM44: TX pkt with header: op:2 flags:0 len:352, group:65, seq:29, id: 1, total size: 488
    [DBG] ModemUARTDFU-\\.\COM44: UART RX(39): 0x06 09 41 42 63 44 41 41 41 4E 41 45 45 64 41 62 39 69 63 6D 4D 41 59 32 39 6D 5A 68 6B 48 65 50 38 50 4C 51 3D 3D 0A
    [DBG] ModemUARTDFU-\\.\COM44: Uploading chunk offset: 1912, len: 328, out of total len 2023424, target addr: 26488
    [TRACE] ModemUARTDFU-\\.\COM44: TX pkt with header: op:2 flags:0 len:352, group:65, seq:30, id: 1, total size: 488
    [DBG] ModemUARTDFU-\\.\COM44: UART RX(39): 0x06 09 41 42 63 44 41 41 41 4E 41 45 45 65 41 62 39 69 63 6D 4D 41 59 32 39 6D 5A 68 6B 49 77 50 39 58 6E 51 3D 3D 0A
    [DBG] ModemUARTDFU-\\.\COM44: Uploading chunk offset: 2240, len: 328, out of total len 2023424, target addr: 26816
    [TRACE] ModemUARTDFU-\\.\COM44: TX pkt with header: op:2 flags:0 len:352, group:65, seq:31, id: 1, total size: 488
    [DBG] ModemUARTDFU-\\.\COM44: UART RX(39): 0x06 09 41 42 63 44 41 41 41 4E 41 45 45 66 41 62 39 69 63 6D 4D 41 59 32 39 6D 5A 68 6B 4B 43 50 38 49 2F 41 3D 3D 0A
    [DBG] ModemUARTDFU-\\.\COM44: Uploading chunk offset: 2568, len: 328, out of total len 2023424, target addr: 27144
    [TRACE] ModemUARTDFU-\\.\COM44: TX pkt with header: op:2 flags:0 len:352, group:65, seq:32, id: 1, total size: 488
    [DBG] ModemUARTDFU-\\.\COM44: UART RX(39): 0x06 09 41 42 63 44 41 41 41 4E 41 45 45 67 41 62 39 69 63 6D 4D 41 59 32 39 6D 5A 68 6B 4C 55 50 38 30 6C 67 3D 3D 0A
    [DBG] ModemUARTDFU-\\.\COM44: Uploading chunk offset: 2896, len: 328, out of total len 2023424, target addr: 27472
    [TRACE] ModemUARTDFU-\\.\COM44: TX pkt with header: op:2 flags:0 len:352, group:65, seq:33, id: 1, total size: 488
    [DBG] ModemUARTDFU-\\.\COM44: UART RX(39): 0x06 09 41 42 63 44 41 41 41 4E 41 45 45 68 41 62 39 69 63 6D 4D 41 59 32 39 6D 5A 68 6B 4D 6D 50 2B 41 42 77 3D 3D 0A
    [DBG] ModemUARTDFU-\\.\COM44: Uploading chunk offset: 3224, len: 328, out of total len 2023424, target addr: 27800
    [TRACE] ModemUARTDFU-\\.\COM44: TX pkt with header: op:2 flags:0 len:352, group:65, seq:34, id: 1, total size: 488
    [DBG] ModemUARTDFU-\\.\COM44: UART RX(39): 0x06 09 41 42 63 44 41 41 41 4E 41 45 45 69 41 62 39 69 63 6D 4D 41 59 32 39 6D 5A 68 6B 4E 34 50 2F 56 34 67 3D 3D 0A
    [DBG] ModemUARTDFU-\\.\COM44: Uploading chunk offset: 3552, len: 328, out of total len 2023424, target addr: 28128
    [TRACE] ModemUARTDFU-\\.\COM44: TX pkt with header: op:2 flags:0 len:352, group:65, seq:35, id: 1, total size: 488
    [DBG] ModemUARTDFU-\\.\COM44: UART RX(39): 0x06 09 41 42 63 44 41 41 41 4E 41 45 45 6A 41 62 39 69 63 6D 4D 41 59 32 39 6D 5A 68 6B 50 4B 50 2B 4B 67 77 3D 3D 0A
    [DBG] ModemUARTDFU-\\.\COM44: Uploading chunk offset: 3880, len: 328, out of total len 2023424, target addr: 28456
    [TRACE] ModemUARTDFU-\\.\COM44: TX pkt with header: op:2 flags:0 len:352, group:65, seq:36, id: 1, total size: 488
    [DBG] ModemUARTDFU-\\.\COM44: UART RX(39): 0x06 09 41 42 63 44 41 41 41 4E 41 45 45 6B 41 62 39 69 63 6D 4D 41 59 32 39 6D 5A 68 6B 51 63 50 38 61 55 41 3D 3D 0A
    [DBG] ModemUARTDFU-\\.\COM44: Chunk upload took 91ms. Current upload runtime is 1s
    [DBG] ModemUARTDFU-\\.\COM44: Uploading chunk offset: 4208, len: 328, out of total len 2023424, target addr: 28784
    [TRACE] ModemUARTDFU-\\.\COM44: TX pkt with header: op:2 flags:0 len:352, group:65, seq:37, id: 1, total size: 488
    (Here I did CTRL+C)
    Kind Regards,
    Abhijith
  • Hi Abhijith,
    today I created another standolone small console application with a minimized pcb modem update functionality. in the applications binary folder I copied nrfdfu.dll from your suggestion above, and also a nrfdfu_x64.dll. I got the same results, nrfdfu_x64.dll is running fine, if I compiled the console application in x64 mode. If I compile the console application in x86 mode (32 bit) your nrfdfu.dll is not executed successful, I got the below listed log messages in the console:
    Progress: 0%
    Progress: 0%
    Progress: 0%
    Progress: 0%
    Progress: 0%
    [*** LOG ERROR #0001 ***] [2026-03-12 13:20:10] [ModemUARTDFU-COM18] {device or resource busy: device or resource busy}
    Progress: 0%
    Progress: 0%
    Progress: 0%
    Progress: 0%
    Progress: 0%
    Progress: 0%
    [*** LOG ERROR #0011 ***] [2026-03-12 13:20:24] [ModemUARTDFU-COM18] {device or resource busy: device or resource busy}
    Progress: 0%
    Progress: 0%
    [*** LOG ERROR #0034 ***] [2026-03-12 13:20:26] [ModemUARTDFU-COM18] {device or resource busy: device or resource busy}
    Progress: 0%
    Progress: 0%
    [*** LOG ERROR #0038 ***] [2026-03-12 13:20:28] [ModemUARTDFU-COM18] {device or resource busy: device or resource busy}
    Progress: 0%
    Progress: 0%
    [*** LOG ERROR #0042 ***] [2026-03-12 13:20:30] [ModemUARTDFU-COM18] {device or resource busy: device or resource busy}
    Progress: 0%
    Progress: 0%
    [*** LOG ERROR #0046 ***] [2026-03-12 13:20:32] [ModemUARTDFU-COM18] {device or resource busy: device or resource busy}
    Progress: 0%
    Progress: 0%
    [*** LOG ERROR #0050 ***] [2026-03-12 13:20:34] [ModemUARTDFU-COM18] {device or resource busy: device or resource busy}
    Progress: 0%
    Progress: 0%
    [*** LOG ERROR #0054 ***] [2026-03-12 13:20:36] [ModemUARTDFU-COM18] {device or resource busy: device or resource busy}
    Progress: 0%
    Progress: 0%
    [*** LOG ERROR #0058 ***] [2026-03-12 13:20:39] [ModemUARTDFU-COM18] {device or resource busy: device or resource busy}
    Progress: 0%
    Progress: 0%
    [*** LOG ERROR #0062 ***] [2026-03-12 13:20:41] [ModemUARTDFU-COM18] {device or resource busy: device or resource busy}
    Progress: 0%
    Progress: 0%
    [*** LOG ERROR #0066 ***] [2026-03-12 13:20:43] [ModemUARTDFU-COM18] {device or resource busy: device or resource busy}
    Progress: 0%
    Progress: 0%
    [*** LOG ERROR #0070 ***] [2026-03-12 13:20:45] [ModemUARTDFU-COM18] {device or resource busy: device or resource busy}
    Progress: 0%
    Progress: 0%
    [*** LOG ERROR #0074 ***] [2026-03-12 13:20:47] [ModemUARTDFU-COM18] {device or resource busy: device or resource busy}
    Progress: 0%
    Progress: 0%
    [*** LOG ERROR #0078 ***] [2026-03-12 13:20:49] [ModemUARTDFU-COM18] {device or resource busy: device or resource busy}
    Progress: 0%
    Progress: 0%
    [*** LOG ERROR #0082 ***] [2026-03-12 13:20:51] [ModemUARTDFU-COM18] {device or resource busy: device or resource busy}
    Progress: 0%
    Progress: 0%
    [*** LOG ERROR #0086 ***] [2026-03-12 13:20:53] [ModemUARTDFU-COM18] {device or resource busy: device or resource busy}
    Progress: 0%
    [*** LOG ERROR #0090 ***] [2026-03-12 13:20:54] [ModemUARTDFU-COM18] {device or resource busy: device or resource busy}
    Thanks in advance and best regards
    Johannes
