Zigbee end device bound to another device always issues broadcasts to resolve the short network address based on target's MAC
I tried searching public question on the matter and wasn't able to find anything reminiscent of the problem I have.
I'm developing a presence sensor using ZigBee protocol for communications. The device is an end device. Among other things it implements a client on/off cluster
for the purposes of direct binding and sending on/off commands directly to appliances (smart lights, smart sockets, etc.).
In principle it works and in a small testing network (2 devices: the said presence sensor and a smart socket) binding my presence sensor to a smart socket works without problems.
However when I tried for testing purposes adding the presence sensor to a much bigger zigbee network (90+ devices: 37 routers, 55 end devices) the results were highly mixed.
When bound to one of smart sockets, the binding seems to work, on/off commands are issued, received and executed in a timely manner with an acceptable minimal latency.
However in another case binding to a smart bulb although succeeds in terms of a binding operation, when it comes to an actual transmission of on/off commands the outcome is highly unreliable:
it works sometimes, much more often a really big delay happens.
I've used Wireshark to sniff the traffic that's happening and was able to conclude that said delays are there due to my presence sensor sending "ZigBee Device Profile: Network Address Request" broadcast requests always to determine a short network address of the target smart bulb. Smart bulb responses with own address as requested. However shortly after (say, when 'Off' command is sent after presence is no more detected), it sends again the same set of broadcast requests to figure out the network address it literally got just half a minute ago.
This suggests that for whatever reason it doesn't store the translation for MAC->address in the address table. The only "workaround" I have at the moment is to add my presence sensor device directly via the smart bulb I want to control, so that it's a direct parent node in the mesh. Then the commands are issued with a valid short address immediately without sending tons of broadcast requests.
I've tried "turning the knobs" like:
#define ZB_CONFIG_OVERALL_NETWORK_SIZE 100
#define ZB_CONFIG_HIGH_TRAFFIC
#define ZB_CONFIG_APPLICATION_COMPLEX
#include <zb_mem_config_common.h>
#undef ZB_CONFIG_IOBUF_POOL_SIZE
#define ZB_CONFIG_IOBUF_POOL_SIZE 128
#undef ZB_CONFIG_SCHEDULER_Q_SIZE
#define ZB_CONFIG_SCHEDULER_Q_SIZE 64
#undef ZB_CONFIG_APS_DUPS_TABLE_SIZE
#define ZB_CONFIG_APS_DUPS_TABLE_SIZE 64
#define ZB_CONFIG_NWK_DISC_TABLE_SIZE 32U
but this doesn't seem to help.
What am I missing? Is there some other setting I could tweak?
I'm using ZigBee R23 Add-on, 1.2.1
if that matters.
Thanks!
  • thanks for the suggestion
    I'm looking now at defines you've suggested and the thing is: I don't see where it would make an effect.
    If I don't provide these defines, then I don't 'see' the defines in my main.cpp (they don't come from any zigbee header file). And when I do provide the defines (I changed both to 64), there's no difference in the binary size, in the occupied RAM size.
    I've found the reference to these defines in:
    ncs-zigbee/lib/zboss/src/include/zb_aps_globals.h:110 (zb_aps_binding_table_t)
    however there it seems to be used only when ZB_CONFIGURABLE_MEM is NOT defined (which it is).
    I've tried changing the defines you've suggested nevertheless. (increased them both to 64).
    And the sensor was failing as before attempting to send a command.
    I've also tried undef'ing ZB_CONFIGURABLE_MEM and it did change the binary size (made it smaller. I guess because I've cranked up various numbers previously). But alas no improvement with sending the command to a bound device.
    However this was not all in vain. Here's a new piece of information I've collected.
    Apparently physical location of where the presence sensor was added to the zigbee network doesn't matter all that much for the issue in question. I mean it gets added to a different parent node, that I can see. However it fails sending commands to the bound smart bulb regardless of the physical location.
    At the same time added at a location close to the lamp (as I tried many times before without luck), and binding it to a smart socket (it physically is located at some distance over 1 hop in the network) - this worked like a charm without a single issue! No annoying meaningless broadcast with address requests.
    I've looked closer at a wireshark sniffed data and the following stands out to me:
    4002 39.916372904 0x1af6 Broadcast ZigBee ZDP 138 Network Address Request, Address: SiliconLabor_ff:fe:74:33:11
    this is an address request for that smart bulb. It's full MAC is 04:0d:84:ff:fe:74:33:11
    the MAC of the smart socket where I don't get any issue binding and sending commands is
    70:b3:d5:2b:60:09:d8:3d
    I have tried and bound the sensor to another smart socket with MAC ec:1b:bd:ff:fe:a2:0e:a3 and I'm getting exactly the same problem with it: endless meaningless broadcast requests for an address.
    I wonder if that 'ff:fe' part of the smart bulb's MAC (and the other smart socket's MAC) which looks suspiciously like a broadcasting short address has anything to do with my problems...
    Would it be possible to verify that in ZBOSS sources for you?
  • if you need me to test some specific case in this regard or sniff some specific communication with wireshark - just let me know.
    I also wonder, if you guys could reproduce the issue with "ff:fe" MACs?
    Sorry for the late reply. I have been ill and out of office for a few days (nothing serious. Just a fever/cold).
    Can you please upload the wireshark sniffer trace, so that I can forward it to our Zigbee team? If you could also specify a few of the relevant packet numbers, that would be helpful!
    Edvin
  • being sick sucks
    I hope you feel better now Slight smile
    I've attached a compressed archive file. There you'll find a wireshark sniffer trace file and desc.md file with all the descriptions and relevant packet numbers.
    Let me know if you need something else.
    Thanks!
    wireshark_sniffed.tar.gz
    Can you please try to capture a ZBOSS trace from your ZED node. Try to enable it by adding these Kconfigs to your prj.conf:
    CONFIG_ZBOSS_TRACE_MASK=0x80000051
    CONFIG_ZBOSS_TRACE_LOG_LEVEL_DBG=y
    And monitor the UART output. It will look like jibberish data, but save it to a file and upload it here. It needs to be decoded (since this trace is not open source).
    Edvin
