We are unable to connect the nRF54L15 DK Debug Out port to our external nRF54L15 pre-production board. Error: code: 1, description: Generic, message: Batch task protection-get failed, Device error: Setting the debug port SELECT register failed
We have the Nordic nRF54L15-DK PCA10156 0.9.3 2025.19
We use nRF Connect for Desktop v5.2.1 and Programmer v4.7.2 and connect by USB to our ASI_nRF54L_DK1 001057739416.
Windows OS: Windows 11 Pro v 25H2 build 26200.7623
PC Hardware: Intel Core i7-8700 3.2GHz  16GB RAM  64-bit OS, x64 processor
The Programmer Logs the following initialization:
14:19:58.371
Initialising the bundled nrfutil device
14:19:59.280
Using the bundled core version for nrfutil device: 8.1.1
14:19:59.307
Using nrfutil device version: 2.15.7
14:19:59.308
Using nrf-device-lib version: 0.22.5
14:19:59.308
Using nrf-probe version: 0.51.0
14:19:59.308
Using SEGGER J-Link version: JLink_V8.76
14:19:59.325
Getting serial port options from the persistent store for AH02X0KT.pc-nrfconnect-programmer
14:19:59.326
Device connected with the serial number AH02X0KT
14:21:06.589
Getting serial port options from the persistent store for 001057739416.pc-nrfconnect-programmer
14:21:06.589
Device connected with the serial number 001057739416
14:21:06.613
The setup works fine for programming the DK's BLE chip.
We are following the instructions from the nRF54L15_DK_HW__USER_Guide_v0.9.1.pdf for programming an external board, but always get this error:
12:33:34.446 Failed "reading readback protection status for application core". Error: code: 1, description: Generic, message: Batch task protection-get failed, Device error: Setting the debug port SELECT register failed while powering up sys and debug regions (Unknown error in the J-Link DLL (error code =-1)). This might indicate that the debug port is unavailable. Double-check device power supply and SWD lines, and ensure that SWD is not disabled
12:33:58.273
These are our Connections from P19 DEBUG_OUT to our external board:
  • Power Supply 2.5V to SWDO_VTG and to our board's BLE VDD.
  • GND to Ground
  • SWDO_SWDIO to SWDIO
  • SWDO_SELECT to Ground
  • SWDO_SWDCLK to SWDCLK
  • SWD0_SW0  Not Used
  • SWDO_RESET  Not Used
Is the RESET connection required now? Because on nRF52 devices, Reset would break the programming. What must we do to enable the SWD? What J-LINK Settings should we use on the Programmer GUI?
  • Nope. This would only work if nrfjprog would support the NRF54 family!
    C:\Users\stevewald>nrfjprog -f NRF54 -c 1000 --readcode --log
    ERROR: Argument provided has a wrong value. Memory access not aligned, value
    ERROR: outside of range or similar.
    C:\Users\stevewald>nrfjprog -f UNKNOWN -c 1000 --readcode --log
    ERROR: [ nRFXX] - Family identification failed.
    ERROR: nrfjprog could not identify the target device. This may be due to an
    ERROR: invalid family argument, a problem with your device, or nrfjprog may
    ERROR: not yet support your device.
    ERROR: Please check the family argument passed, or upgrade nrfjprog to a more
    ERROR: recent version.
    C:\Users\stevewald>nrfjprog --version
    nrfjprog version: 10.15.2 external
    JLinkARM.dll version: 8.42
    We looked at the SWD signals with a scope. The signals are not 'weak', but do meet voltage levels. However they are both under-damped (I/O - blue), and over-damped (CLK - green). No wonder the cable needs to be so short. The drivers need to be re-engineered.
  • The nrfutil device command knows --swd-clock-frequency option that has the same function.
  • Ok. You have a method for piping the nRF Connect Programmer commands through nrfutil?
  • You can try with nrfutil as well with the flag that Jörg mentioned. As a quick check, with my version of nrfjprog it was able to program the SoC (nRF54L15) and I checked the functionality afterward and it was fine (without --verify flag as it failed for me as well).
  • I updated my command-line-tools to 10.24.2 but still only have JLinkArm.dll version 8.42, and no support for the 54L in nrfprog. It won't even start running a command without throwing the undefined family error.
    My customer looked at the waveforms above and exclaimed "There is no reason for those signals to be loaded like that!" I agree. Don't they come from the DEBUGGER chip (nRF5340)? Why can't the GPIO on that part be programmed to a decent sized load???
