undefined reference to `__device_dts_ord_88'
Trying to migrate from SDK v2.7.0 to v2.8.0 and suddenly getting the build error
Based on other forum posts, I was able to track down more information using the <build target>\<project>\zephyr\include\generated\zephyr\devicetree_generated.h file which lists:
 *   88  /soc/radio@40001000/bt_hci_sdc
Reading around it looks like I need to add something along the lines of
&bt_hci_sdc {
    status = "okay";
to the Device Tree, but I am struggling to figure out where, which file, and the exact syntax.  So far nothing I've cobbled together based on online searching has worked.  For completeness, my environment is:
  • Windows 11
  • VS Code w/ nRF Connect plugin
  • toolchain / SDK v2.8.0
  • custom PCB using an nRF52832 in the QFAA package
  • sysbuild
  • MCUBOOT
  • One significant difference between the samples and my application is the usage of mcuboot.  Don't know how/if that might change things, but figured it was worth bringing up.  I am using sysbuild, and everything built fine in SDK v2.7.0 using sysbuild, and the original board files.  It was the jump to SDK v2.8.0 that broke things.
  • Will_20241202 said:
    I'm not sure how to build using the West commands.
    See How to use nRF Connect terminal profile
    I enabled the mcuboot configs to build the peripheral sample for your custom board file, and I still cannot reproduce the issue.
    Ensure you are using the correct boot board root path to build your application in NCS v2.8.0.
  • Ensure you are using the correct boot root path to build your application in NCS v2.8.0.
    Can you give a little more detail on what this means?
    As an additional data point, I discovered that when trying to build with SDK v2.8.0, the "Extra CMake arguments" specified on the add/edit Build Configuration page are not being applied (they were in SDK v2.7.0 based on the build logs I kept).  Worse still, after I add them using that page and press the Generate button to create the Build Configuration for later building, if I edit the Build Configuration for that target they have all been removed!
    For reference, the arguments I was trying to include using this method were:
    -Dmcuboot_CONF_FILE=D:/Projects/<REDACTED>/repositories/<REDACTED>/sysbuild/mcuboot/prj.conf
    -Dmcuboot_EXTRA_CONF_FILE=C:/ncs/v2.8.0/nrf/subsys/partition_manager/partition_manager_enabled.conf
    -DCACHED_CONF_FILE=D:/Projects/<REDACTED>/repositories/<REDACTED>/prj.conf
    Again to be clear, these were fine using SDK/toolchain v2.7.0 and appeared in the build logs output by VS Code to its "terminal" window.  Looking at the failing build logs for SDK/toolchain v2.8.0 they are not even being passed as arguments.
  • Sorry, I mean the board path.
    I don't think you need those arguments. It uses sysbuild by default since NCS v2.8.0.
  • Where is the board path specified?  The only place I'm aware of is on the add/edit Build Configuration page there is a section for "Board target", and I chose the "generic_nrf52832_v2/nrf52832" option from the drop down menu.
    Looking through the failed build log I do see lines like
    -- Found BOARD.dts: D:/Projects/<redacted>/repositories/<redacted>/boards/Generic/generic_nrf52832_v2/generic_nrf52832_v2.dts
    Loaded configuration 'D:/Projects/<redacted>/repositories/<redacted>/boards/Generic/generic_nrf52832_v2/generic_nrf52832_v2_defconfig'
    which agrees with where I think it should be looking.
