Next buffers not supplied on time
Mian code -
 * Codec-style I2S SLAVE playback using k_mem_slab
 * nRF54Lx DK
#include <zephyr/kernel.h>
#include <zephyr/device.h>
#include <zephyr/drivers/i2s.h>
#include "codec/codec.h"
#define I2S_NODE DT_NODELABEL(i2s20)
//audio
#define SAMPLE_RATE_HZ     8000
#define SAMPLE_BIT_WIDTH   32
#define CHANNELS           2
#define SAMPLES_PER_BLOCK  160
//#define SAMPLES_PER_BLOCK  (SAMPLE_RATE_HZ / 10)    // 33ms blocks
#define BLOCK_SIZE         (SAMPLES_PER_BLOCK * CHANNELS * sizeof(int16_t))
#define NUM_BLOCKS         80
#define TIMEOUT_MS         2000
static const struct device *i2s_dev = DEVICE_DT_GET(I2S_NODE);
//  memory slab for I2S TX buffers
K_MEM_SLAB_DEFINE(i2s_tx_slab, BLOCK_SIZE, NUM_BLOCKS, 4);
//sine
// static int16_t sine_lut[] = {
//     3211, 6392, 9511, 12539, 15446, 18204, 20787, 23169,
//     25329, 27244, 28897, 30272, 31356, 32137, 32609, 32767,
//     -3212, -6393, -9512, -12540, -15447, -18205, -20788, -23170,
//     -25330, -27245, -28898, -30273, -31357, -32138, -32610, -32767};
    6392,  12539,  18204,  23169,  27244,  30272,  32137,  32767,  32137,
    30272, 27244, 23169, 18204, 12539, 6392, 0, -6393, -12540,
    -18205, -23170, -27245, -30273, -32138, -32767, -32138, -30273, -27245,
    -23170, -18205, -12540, -6393, -1};
// static int16_t sine_lut[8] = {
//      0,
//  23170,
//  32767,
//  23170,
//      0,
// -23170,
// -32768,
// -23170
// Fill block
static void fill_block(int16_t *buf)
    int lut_len = ARRAY_SIZE(sine_lut);
    for (int i = 0; i < SAMPLES_PER_BLOCK; i++)
        int16_t s = sine_lut[i % lut_len];
        buf[2 * i] = 25000;
        buf[2 * i + 1] = 25000;
    struct i2s_config cfg;
    int ret;
    printk("I2S playback (mem_slab)\n");
    // clocking and codec init
    ret = pwm_4mhz();
    if (ret < 0)
        printk("PWM init failed\n");
        return ret;
    for (int i = 0; i < 20; i++)
        ret = i2c_init_codec();
        if (ret == 0)
        k_msleep(5);
    if (ret < 0)
        printk("Codec init failed\n");
        return ret;
    k_msleep(10);
    // printk("BLOCK=%d  SAMPLES=%d\n", BLOCK_SIZE, SAMPLES_PER_BLOCK);
    if (!device_is_ready(i2s_dev))
        printk("I2S not ready\n");
        return -ENODEV;
    // I2S CONFIG
    cfg.word_size      = SAMPLE_BIT_WIDTH;
    cfg.channels       = CHANNELS;
    cfg.format         =I2S_FMT_DATA_FORMAT_I2S;;   //cfg.format = I2S_FMT_DATA_FORMAT_LEFT_JUSTIFIED;
    cfg.options        = I2S_OPT_FRAME_CLK_SLAVE |
                         I2S_OPT_BIT_CLK_SLAVE;
    cfg.frame_clk_freq = SAMPLE_RATE_HZ;
    cfg.block_size     = BLOCK_SIZE;
    cfg.timeout        = TIMEOUT_MS;
    cfg.mem_slab       = &i2s_tx_slab;
    ret = i2s_configure(i2s_dev, I2S_DIR_TX, &cfg);
    if (ret < 0)
        printk("I2S config failed\n");
        return ret;
    printk("Start streaming\n");
    //prefill
    for (int i = 0; i < 30; i++)
        void *block;
        k_mem_slab_alloc(&i2s_tx_slab, &block, K_FOREVER);
        fill_block((int16_t *)block);
        i2s_buf_write(i2s_dev, block, BLOCK_SIZE);
    ret = i2s_trigger(i2s_dev, I2S_DIR_TX, I2S_TRIGGER_START);
    if (ret < 0)
        printk("I2S trigger failed\n");
        return ret;
    while (1)
        void *block;
        ret = k_mem_slab_alloc(&i2s_tx_slab, &block, K_FOREVER);
        if (ret < 0)
           printk("Slab alloc failed\n");
           k_sleep(K_USEC(30));
           continue;
        ret = i2s_buf_write(i2s_dev, block, BLOCK_SIZE);
       // k_sleep(K_USEC(100));
        if (ret == -ENOMEM)
            /* Queue full — try again */
            k_mem_slab_free(&i2s_tx_slab, block);
            printk("free=%d\n", k_mem_slab_num_free_get(&i2s_tx_slab));
            continue;
        else if (ret < 0)
            printk("I2S error %d\n", ret);
            i2s_trigger(i2s_dev, I2S_DIR_TX, I2S_TRIGGER_DROP);
            k_sleep(K_MSEC(5));
            // i2s_trigger(i2s_dev, I2S_DIR_TX, I2S_TRIGGER_PREPARE);
            // k_sleep(K_MSEC(2));
            continue;
    printk("Exit\n");
    return 0;
Log:
SEGGER J-Link V9.10 - Real time terminal output
SEGGER J-Link EDU V11.0, SN=261002460
Process: JLink.exe
*** Booting nRF Connect SDK v3.2.1-d8887f6f32df ***
*** Using Zephyr OS v4.2.99-ec78104f1569 ***
PWM configured: period=250ns pulse=125ns
I2C bus ready, addr=0x18
Codec responded: reg0 = 0x01
Writing codec register table...
reg=0x01 val=0x01 err=0
reg=0x04 val=0x03 err=0
reg=0x05 val=0xD4 err=0
reg=0x06 val=0x20 err=0
reg=0x07 val=0x00 err=0
reg=0x08 val=0x00 err=0
reg=0x1B val=0x0C err=0
reg=0x0B val=0x84 err=0
reg=0x0C val=0x99 err=0
reg=0x0E val=0x80 err=0
reg=0x1D val=0x01 err=0
reg=0x1E val=0x84 err=0
reg=0x3F val=0xD4 err=0
reg=0x40 val=0x00 err=0
reg=0x41 val=0x00 err=0
reg=0x42 val=0xD0 err=0
reg=0x47 val=0x82 err=0
reg=0x48 val=0x82 err=0
reg=0x51 val=0x80 err=0
reg=0x52 val=0x00 err=0
reg=0x53 val=0x00 err=0
reg=0x1E val=0x00 err=0
reg=0x1F val=0xC0 err=0
reg=0x20 val=0xC6 err=0
reg=0x23 val=0xA8 err=0
reg=0x24 val=0x80 err=0
reg=0x25 val=0x80 err=0
reg=0x22 val=0x30 err=0
reg=0x2A val=0x3D err=0
reg=0x2B val=0x3D err=0
reg=0x2C val=0xC0 err=0
reg=0x26 val=0x80 err=0
reg=0x27 val=0x80 err=0
reg=0x2E val=0x00 err=0
reg=0x2F val=0x00 err=0
reg=0x30 val=0x00 err=0
reg=0x31 val=0x00 err=0
Codec init DONE.
I2C ready
Start streaming
[00:26:31.169,121] <dbg> i2s_nrfx: i2s_nrfx_write: Queued TX 0x200070d8
[00:26:31.169,370] <dbg> i2s_nrfx: i2s_nrfx_write: Queued TX 0x200075d8
[00:26:31.169,611] <dbg> i2s_nrfx: i2s_nrfx_write: Queued TX 0x20007ad8
[00:26:31.169,852] <dbg> i2s_nrfx: i2s_nrfx_write: Queued TX 0x20007fd8
[00:26:31.170,093] <dbg> i2s_nrfx: i2s_nrfx_write: Queued TX 0x200084d8
[00:26:31.170,332] <dbg> i2s_nrfx: i2s_nrfx_write: Queued TX 0x200089d8
[00:26:31.170,573] <dbg> i2s_nrfx: i2s_nrfx_write: Queued TX 0x20008ed8
[00:26:31.170,815] <dbg> i2s_nrfx: i2s_nrfx_write: Queued TX 0x200093d8
[00:26:31.171,052] <dbg> i2s_nrfx: i2s_nrfx_write: Queued TX 0x200098d8
[00:26:31.171,288] <dbg> i2s_nrfx: i2s_nrfx_write: Queued TX 0x20009dd8
[00:26:31.171,525] <dbg> i2s_nrfx: i2s_nrfx_write: Queued TX 0x2000a2d8
[00:26:31.171,762] <dbg> i2s_nrfx: i2s_nrfx_write: Queued TX 0x2000a7d8
[00:26:31.172,000] <dbg> i2s_nrfx: i2s_nrfx_write: Queued TX 0x2000acd8
[00:26:31.172,234] <dbg> i2s_nrfx: i2s_nrfx_write: Queued TX 0x2000b1d8
[00:26:31.172,471] <dbg> i2s_nrfx: i2s_nrfx_write: Queued TX 0x2000b6d8
[00:26:31.172,708] <dbg> i2s_nrfx: i2s_nrfx_write: Queued TX 0x2000bbd8
[00:26:31.172,946] <dbg> i2s_nrfx: i2s_nrfx_write: Queued TX 0x2000c0d8
[00:26:31.173,183] <dbg> i2s_nrfx: i2s_nrfx_write: Queued TX 0x2000c5d8
[00:26:31.178,428] <dbg> i2s_nrfx: i2s_nrfx_write: Queued TX 0x2000cad8
[00:26:31.178,670] <dbg> i2s_nrfx: i2s_nrfx_write: Queued TX 0x2000cfd8
[00:26:31.178,910] <dbg> i2s_nrfx: i2s_nrfx_write: Queued TX 0x2000d4d8
[00:26:31.179,147] <dbg> i2s_nrfx: i2s_nrfx_write: Queued TX 0x2000d9d8
[00:26:31.179,384] <dbg> i2s_nrfx: i2s_nrfx_write: Queued TX 0x2000ded8
[00:26:31.179,621] <dbg> i2s_nrfx: i2s_nrfx_write: Queued TX 0x2000e3d8
[00:26:31.179,859] <dbg> i2s_nrfx: i2s_nrfx_write: Queued TX 0x2000e8d8
[00:26:31.180,096] <dbg> i2s_nrfx: i2s_nrfx_write: Queued TX 0x2000edd8
[00:26:31.180,332] <dbg> i2s_nrfx: i2s_nrfx_write: Queued TX 0x2000f2d8
[00:26:31.180,569] <dbg> i2s_nrfx: i2s_nrfx_write: Queued TX 0x2000f7d8
[00:26:31.180,807] <dbg> i2s_nrfx: i2s_nrfx_write: Queued TX 0x2000fcd8
[00:26:31.181,044] <dbg> i2s_nrfx: i2s_nrfx_write: Queued TX 0x200101d8
[00:26:31.181,313] <dbg> i2s_nrfx: i2s_nrfx_write: Queued TX 0x200106d8
[00:26:31.181,565] <dbg> i2s_nrf[00:26:31.181,719] <dbg> i2s_nrfx: supply_next_buffers: Next buffers: 0x200075d8/(nil)
x: i2s_nrfx_write: Queued TX 0x20010bd8
[00:26:31.182,083] <dbg> i2s_nrfx: i2s_nrfx_write: Queued TX 0x200110d8
[00:26:31.182,318] <dbg> i2s_nrfx: i2s_nrfx_write: Queued TX 0x200115d8
[00:26:31.191,702] <dbg> i2s_nrfx: free_tx_buffer: Freed TX 0x200070d8
[00:26:31.191,944] <dbg> i2s_nrfx: supply_next_buffers: Next buffers: 0x20007ad8/(nil)
[00:26:31.192,189] <dbg> i2s_nrfx: i2s_nrfx_write: Queued TX 0x20011ad8
[00:26:31.201,702] <dbg> i2s_nrfx: free_tx_buffer: Freed TX 0x200075d8
[00:26:31.201,943] <dbg> i2s_nrfx: supply_next_buffers: Next buffers: 0x20007fd8/(nil)
[00:26:31.202,189] <dbg> i2s_nrfx: i2s_nrfx_write: Queued TX 0x20011d58
[00:26:31.211,702] <dbg> i2s_nrfx: free_tx_buffer: Freed TX 0x20007ad8
[00:26:31.211,944] <dbg> i2s_nrfx: supply_next_buffers: Next buffers: 0x200084d8/(nil)
[00:26:31.212,189] <dbg> i2s_nrfx: i2s_nrfx_write: Queued TX 0x20011fd8
[00:26:31.221,702] <dbg> i2s_nrfx: free_tx_buffer: Freed TX 0x20007fd8
[00:26:31.221,944] <dbg> i2s_nrfx: supply_next_buffers: Next buffers: 0x200089d8/(nil)
[00:26:31.222,190] <dbg> i2s_nrfx: i2s_nrfx_write: Queued TX 0x20012258
[00:26:31.231,702] <dbg> i2s_nrfx: free_tx_buffer: Freed TX 0x200084d8
[00:26:31.231,944] <dbg> i2s_nrfx: supply_next_buffers: Next buffers: 0x20008ed8/(nil)
[00:26:31.232,190] <dbg> i2s_nrfx: i2s_nrfx_write: Queued TX 0x200124d8
[00:26:31.241,702] <dbg> i2s_nrfx: free_tx_buffer: Freed TX 0x200089d8
[00:26:31.241,944] <dbg> i2s_nrfx: supply_next_buffers: Next buffers: 0x200093d8/(nil)
[00:26:31.242,189] <dbg> i2s_nrfx: i2s_nrfx_write: Queued TX 0x20012758
[00:26:31.251,702] <dbg> i2s_nrfx: free_tx_buffer: Freed TX 0x20008ed8
[00:26:31.251,944] <dbg> i2s_nrfx: supply_next_buffers: Next buffers: 0x200098d8/(nil)
[00:26:31.252,190] <dbg> i2s_nrfx: i2s_nrfx_write: Queued TX 0x200129d8
[00:26:31.261,703] <dbg> i2s_nrfx: free_tx_buffer: Freed TX 0x200093d8
[00:26:31.261,944] <dbg> i2s_nrfx: supply_next_buffers: Next buffers: 0x20009dd8/(nil)
[00:26:31.262,190] <dbg> i2s_nrfx: i2s_nrfx_write: Queued TX 0x20012c58
[00:26:31.271,703] <dbg> i2s_nrfx: free_tx_buffer: Freed TX 0x200098d8
[00:26:31.271,944] <dbg> i2s_nrfx: supply_next_buffers: Next buffers: 0x2000a2d8/(nil)
[00:26:31.272,190] <dbg> i2s_nrfx: i2s_nrfx_write: Queued TX 0x20012ed8
[00:26:31.281,703] <dbg> i2s_nrfx: free_tx_buffer: Freed TX 0x20009dd8
[00:26:31.281,944] <dbg> i2s_nrfx: supply_next_buffers: Next buffers: 0x2000a7d8/(nil)
[00:26:31.282,190] <dbg> i2s_nrfx: i2s_nrfx_write: Queued TX 0x20013158
[00:26:31.291,704] <dbg> i2s_nrfx: free_tx_buffer: Freed TX 0x2000a2d8
[00:26:31.291,945] <dbg> i2s_nrfx: supply_next_buffers: Next buffers: 0x2000acd8/(nil)
[00:26:31.292,191] <dbg> i2s_nrfx: i2s_nrfx_write: Queued TX 0x200133d8
[00:26:31.301,715] <dbg> i2s_nrfx: free_tx_buffer: Freed TX 0x2000a7d8
[00:26:31.301,939] <dbg> i2s_nrfx: supply_next_buffers: Next buffers: 0x2000b1d8/(nil)
[00:26:31.302,195] <dbg> i2s_nrfx: i2s_nrfx_write: Queued TX 0x2000a7d8
[00:26:31.311,715] <dbg> i2s_nrfx: free_tx_buffer: Freed TX 0x2000acd8
[00:26:31.311,939] <dbg> i2s_nrfx: supply_next_buffers: Next buffers: 0x2000b6d8/(nil)
[00:26:31.321,715] <dbg> i2s_nrfx: free_tx_buffer: Freed TX 0x2000b1d8
[00:26:31.321,939] <dbg> i2s_nrfx: supply_next_buffers: Next buffers: 0x2000bbd8/(nil)
[00:26:31.322,195] <dbg> i2s_nrfx: i2s_nrfx_write: Queued TX 0x2000b1d8
[00:26:31.331,715] <dbg> i2s_nrfx: free_tx_buffer: Freed TX 0x2000b6d8
[00:26:31.331,939] <dbg> i2s_nrfx: supply_next_buffers: Next buffers: 0x2000c0d8/(nil)
[00:26:31.341,715] <dbg> i2s_nrfx: free_tx_buffer: Freed TX 0x2000bbd8
[00:26:31.341,940] <dbg> i2s_nrfx: supply_next_buffers: Next buffers: 0x2000c5d8/(nil)
[00:26:31.342,194] <dbg> i2s_nrfx: i2s_nrfx_write: Queued TX 0x2000bbd8
[00:26:31.351,715] <dbg> i2s_nrfx: free_tx_buffer: Freed TX 0x2000c0d8
[00:26:31.351,939] <dbg> i2s_nrfx: supply_next_buffers: Next buffers: 0x2000cad8/(nil)
[00:26:31.361,715] <dbg> i2s_nrfx: free_tx_buffer: Freed TX 0x2000c5d8
[00:26:31.361,940] <dbg> i2s_nrfx: supply_next_buffers: Next buffers: 0x2000cfd8/(nil)
[00:26:31.362,196] <dbg> i2s_nrfx: i2s_nrfx_write: Queued TX 0x2000c5d8
[00:26:31.371,715] <dbg> i2s_nrfx: free_tx_buffer: Freed TX 0x2000cad8
[00:26:31.371,939] <dbg> i2s_nrfx: supply_next_buffers: Next buffers: 0x2000d4d8/(nil)
[00:26:31.381,715] <dbg> i2s_nrfx: free_tx_buffer: Freed TX 0x2000cfd8
[00:26:31.381,940] <dbg> i2s_nrfx: supply_next_buffers: Next buffers: 0x2000d9d8/(nil)
[00:26:31.382,196] <dbg> i2s_nrfx: i2s_nrfx_write: Queued TX 0x2000cfd8
[00:26:31.391,715] <dbg> i2s_nrfx: free_tx_buffer: Freed TX 0x2000d4d8
[00:26:31.391,938] <dbg> i2s_nrfx: supply_next_buffers: Next buffers: 0x2000ded8/(nil)
[00:26:31.401,719] <dbg> i2s_nrfx: free_tx_buffer: Freed TX 0x2000d9d8
[00:26:31.401,944] <dbg> i2s_nrfx: supply_next_buffers: Next buffers: 0x2000e3d8/(nil)
[00:26:31.402,200] <dbg> i2s_nrfx: i2s_nrfx_write: Queued TX 0x2000d9d8
[00:26:31.411,716] <dbg> i2s_nrfx: free_tx_buffer: Freed TX 0x2000ded8
[00:26:31.411,939] <dbg> i2s_nrfx: supply_next_buffers: Next buffers: 0x2000e8d8/(nil)
[00:26:31.421,715] <dbg> i2s_nrfx: free_tx_buffer: Freed TX 0x2000e3d8
[00:26:31.421,940] <dbg> i2s_nrfx: supply_next_buffers: Next buffers: 0x2000edd8/(nil)
[00:26:31.422,196] <dbg> i2s_nrfx: i2s_nrfx_write: Queued TX 0x2000e3d8
[00:26:31.431,718] <dbg> i2s_nrfx: free_tx_buffer: Freed TX 0x2000e8d8
[00:26:31.431,942] <dbg> i2s_nrfx: supply_next_buffers: Next buffers: 0x2000f2d8/(nil)
[00:26:31.441,715] <dbg> i2s_nrfx: free_tx_buffer: Freed TX 0x2000edd8
[00:26:31.441,938] <dbg> i2s_nrfx: supply_next_buffers: Next buffers: 0x2000f7d8/(nil)
[00:26:31.442,191] <dbg> i2s_nrfx: i2s_nrfx_write: Queued TX 0x2000edd8
[00:26:31.451,716] <dbg> i2s_nrfx: free_tx_buffer: Freed TX 0x2000f2d8
[00:26:31.451,939] <dbg> i2s_nrfx: supply_next_buffers: Next buffers: 0x2000fcd8/(nil)
[00:26:31.461,717] <dbg> i2s_nrfx: free_tx_buffer: Freed TX 0x2000f7d8
[00:26:31.461,941] <dbg> i2s_nrfx: supply_next_buffers: Next buffers: 0x200101d8/(nil)
[00:26:31.462,197] <dbg> i2s_nrfx: i2s_nrfx_write: Queued TX 0x2000f7d8
[00:26:31.471,716] <dbg> i2s_nrfx: free_tx_buffer: Freed TX 0x2000fcd8
[00:26:31.471,939] <dbg> i2s_nrfx: supply_next_buffers: Next buffers: 0x200106d8/(nil)
[00:26:31.481,716] <dbg> i2s_nrfx: free_tx_buffer: Freed TX 0x200101d8
[00:26:31.481,940] <dbg> i2s_nrfx: supply_next_buffers: Next buffers: 0x20010bd8/(nil)
[00:26:31.482,196] <dbg> i2s_nrfx: i2s_nrfx_write: Queued TX 0x200101d8
[00:26:31.491,716] <dbg> i2s_nrfx: free_tx_buffer: Freed TX 0x200106d8
[00:26:31.491,940] <dbg> i2s_nrfx: supply_next_buffers: Next buffers: 0x200110d8/(nil)
[00:26:31.501,716] <dbg> i2s_nrfx: free_tx_buffer: Freed TX 0x20010bd8
[00:26:31.501,941] <dbg> i2s_nrfx: supply_next_buffers: Next buffers: 0x200115d8/(nil)
[00:26:31.502,197] <dbg> i2s_nrfx: i2s_nrfx_write: Queued TX 0x20010bd8
[00:26:31.511,716] <dbg> i2s_nrfx: free_tx_buffer: Freed TX 0x200110d8
[00:26:31.511,940] <dbg> i2s_nrfx: supply_next_buffers: Next buffers: 0x20011ad8/(nil)
[00:26:31.521,716] <dbg> i2s_nrfx: free_tx_buffer: Freed TX 0x200115d8
[00:26:31.521,940] <dbg> i2s_nrfx: supply_next_buffers: Next buffers: 0x20011d58/(nil)
[00:26:31.522,197] <dbg> i2s_nrfx: i2s_nrfx_write: Queued TX 0x200115d8
[00:26:31.531,716] <dbg> i2s_nrfx: free_tx_buffer: Freed TX 0x20011ad8
[00:26:31.531,940] <dbg> i2s_nrfx: supply_next_buffers: Next buffers: 0x20011fd8/(nil)
[00:26:31.541,716] <dbg> i2s_nrfx: free_tx_buffer: Freed TX 0x20011d58
[00:26:31.541,940] <dbg> i2s_nrfx: supply_next_buffers: Next buffers: 0x20012258/(nil)
[00:26:31.542,197] <dbg> i2s_nrfx: i2s_nrfx_write: Queued TX 0x20011d58
[00:26:31.551,716] <dbg> i2s_nrfx: free_tx_buffer: Freed TX 0x20011fd8
[00:26:31.551,940] <dbg> i2s_nrfx: supply_next_buffers: Next buffers: 0x200124d8/(nil)
[00:26:31.561,716] <dbg> i2s_nrfx: free_tx_buffer: Freed TX 0x20012258
[00:26:31.561,940] <dbg> i2s_nrfx: supply_next_buffers: Next buffers: 0x20012758/(nil)
[00:26:31.562,196] <dbg> i2s_nrfx: i2s_nrfx_write: Queued TX 0x20012258
[00:26:31.571,716] <dbg> i2s_nrfx: free_tx_buffer: Freed TX 0x200124d8
[00:26:31.571,940] <dbg> i2s_nrfx: supply_next_buffers: Next buffers: 0x200129d8/(nil)
[00:26:31.581,716] <dbg> i2s_nrfx: free_tx_buffer: Freed TX 0x20012758
[00:26:31.581,941] <dbg> i2s_nrfx: supply_next_buffers: Next buffers: 0x20012c58/(nil)
[00:26:31.582,193] <dbg> i2s_nrfx: i2s_nrfx_write: Queued TX 0x20012758
[00:26:31.591,716] <dbg> i2s_nrfx: free_tx_buffer: Freed TX 0x200129d8
[00:26:31.591,940] <dbg> i2s_nrfx: supply_next_buffers: Next buffers: 0x20012ed8/(nil)
[00:26:31.601,716] <dbg> i2s_nrfx: free_tx_buffer: Freed TX 0x20012c58
[00:26:31.601,941] <dbg> i2s_nrfx: supply_next_buffers: Next buffers: 0x20013158/(nil)
[00:26:31.602,197] <dbg> i2s_nrfx: i2s_nrfx_write: Queued TX 0x20012c58
[00:26:31.611,717] <dbg> i2s_nrfx: free_tx_buffer: Freed TX 0x20012ed8
[00:26:31.611,940] <dbg> i2s_nrfx: supply_next_buffers: Next buffers: 0x200133d8/(nil)
[00:26:31.621,721] <dbg> i2s_nrfx: free_tx_buffer: Freed TX 0x20013158
[00:26:31.621,945] <dbg> i2s_nrfx: supply_next_buffers: Next buffers: 0x2000a7d8/(nil)
[00:26:31.622,201] <dbg> i2s_nrfx: i2s_nrfx_write: Queued TX 0x20013158
[00:26:31.631,717] <dbg> i2s_nrfx: free_tx_buffer: Freed TX 0x200133d8
[00:26:31.631,940] <dbg> i2s_nrfx: supply_next_buffers: Next buffers: 0x2000b1d8/(nil)
[00:26:31.641,716] <dbg> i2s_nrfx: free_tx_buffer: Freed TX 0x2000a7d8
[00:26:31.641,941] <dbg> i2s_nrfx: supply_next_buffers: Next buffers: 0x2000bbd8/(nil)
[00:26:31.642,197] <dbg> i2s_nrfx: i2s_nrfx_write: Queued TX 0x2000a7d8
[00:26:31.651,719] <dbg> i2s_nrfx: free_tx_buffer: Freed TX 0x2000b1d8
[00:26:31.651,943] <dbg> i2s_nrfx: supply_next_buffers: Next buffers: 0x2000c5d8/(nil)
[00:26:31.661,717] <dbg> i2s_nrfx: free_tx_buffer: Freed TX 0x2000bbd8
[00:26:31.661,941] <dbg> i2s_nrfx: supply_next_buffers: Next buffers: 0x2000cfd8/(nil)
[00:26:31.662,197] <dbg> i2s_nrfx: i2s_nrfx_write: Queued TX 0x2000bbd8
[00:26:31.671,717] <dbg> i2s_nrfx: free_tx_buffer: Freed TX 0x2000c5d8
[00:26:31.671,941] <dbg> i2s_nrfx: supply_next_buffers: Next buffers: 0x2000d9d8/(nil)
[00:26:31.681,718] <dbg> i2s_nrfx: free_tx_buffer: Freed TX 0x2000cfd8
[00:26:31.681,943] <dbg> i2s_nrfx: supply_next_buffers: Next buffers: 0x2000e3d8/(nil)
[00:26:31.682,199] <dbg> i2s_nrfx: i2s_nrfx_write: Queued TX 0x2000cfd8
[00:26:31.691,717] <dbg> i2s_nrfx: free_tx_buffer: Freed TX 0x2000d9d8
[00:26:31.691,940] <dbg> i2s_nrfx: supply_next_buffers: Next buffers: 0x2000edd8/(nil)
[00:26:31.701,717] <dbg> i2s_nrfx: free_tx_buffer: Freed TX 0x2000e3d8
[00:26:31.701,941] <dbg> i2s_nrfx: supply_next_buffers: Next buffers: 0x2000f7d8/(nil)
[00:26:31.702,197] <dbg> i2s_nrfx: i2s_nrfx_write: Queued TX 0x2000e3d8
[00:26:31.711,717] <dbg> i2s_nrfx: free_tx_buffer: Freed TX 0x2000edd8
[00:26:31.711,941] <dbg> i2s_nrfx: supply_next_buffers: Next buffers: 0x200101d8/(nil)
[00:26:31.721,717] <dbg> i2s_nrfx: free_tx_buffer: Freed TX 0x2000f7d8
[00:26:31.721,941] <dbg> i2s_nrfx: supply_next_buffers: Next buffers: 0x20010bd8/(nil)
[00:26:31.722,196] <dbg> i2s_nrfx: i2s_nrfx_write: Queued TX 0x2000f7d8
[00:26:31.731,717] <dbg> i2s_nrfx: free_tx_buffer: Freed TX 0x200101d8
[00:26:31.731,941] <dbg> i2s_nrfx: supply_next_buffers: Next buffers: 0x200115d8/(nil)
[00:26:31.741,717] <dbg> i2s_nrfx: free_tx_buffer: Freed TX 0x20010bd8
[00:26:31.741,942] <dbg> i2s_nrfx: supply_next_buffers: Next buffers: 0x20011d58/(nil)
[00:26:31.742,198] <dbg> i2s_nrfx: i2s_nrfx_write: Queued TX 0x20010bd8
[00:26:31.751,717] <dbg> i2s_nrfx: free_tx_buffer: Freed TX 0x200115d8
[00:26:31.751,941] <dbg> i2s_nrfx: supply_next_buffers: Next buffers: 0x20012258/(nil)
[00:26:31.761,717] <dbg> i2s_nrfx: free_tx_buffer: Freed TX 0x20011d58
[00:26:31.761,942] <dbg> i2s_nrfx: supply_next_buffers: Next buffers: 0x20012758/(nil)
[00:26:31.762,198] <dbg> i2s_nrfx: i2s_nrfx_write: Queued TX 0x20011d58
[00:26:31.771,717] <dbg> i2s_nrfx: free_tx_buffer: Freed TX 0x20012258
[00:26:31.771,938] <dbg> i2s_nrfx: supply_next_buffers: Next buffers: 0x20012c58/(nil)
[00:26:31.781,717] <dbg> i2s_nrfx: free_tx_buffer: Freed TX 0x20012758
[00:26:31.781,942] <dbg> i2s_nrfx: supply_next_buffers: Next buffers: 0x20013158/(nil)
[00:26:31.782,198] <dbg> i2s_nrfx: i2s_nrfx_write: Queued TX 0x20012758
[00:26:31.791,717] <dbg> i2s_nrfx: free_tx_buffer: Freed TX 0x20012c58
[00:26:31.791,941] <dbg> i2s_nrfx: supply_next_buffers: Next buffers: 0x2000a7d8/(nil)
[00:26:31.801,717] <dbg> i2s_nrfx: free_tx_buffer: Freed TX 0x20013158
[00:26:31.801,942] <dbg> i2s_nrfx: supply_next_buffers: Next buffers: 0x2000bbd8/(nil)
[00:26:31.802,198] <dbg> i2s_nrfx: i2s_nrfx_write: Queued TX 0x20013158
[00:26:31.811,718] <dbg> i2s_nrfx: free_tx_buffer: Freed TX 0x2000a7d8
[00:26:31.811,941] <dbg> i2s_nrfx: supply_next_buffers: Next buffers: 0x2000cfd8/(nil)
[00:26:31.821,717] <dbg> i2s_nrfx: free_tx_buffer: Freed TX 0x2000bbd8
[00:26:31.821,942] <dbg> i2s_nrfx: supply_next_buffers: Next buffers: 0x2000e3d8/(nil)
[00:26:31.822,198] <dbg> i2s_nrfx: i2s_nrfx_write: Queued TX 0x2000bbd8
[00:26:31.831,718] <dbg> i2s_nrfx: free_tx_buffer: Freed TX 0x2000cfd8
[00:26:31.831,942] <dbg> i2s_nrfx: supply_next_buffers: Next buffers: 0x2000f7d8/(nil)
[00:26:31.841,722] <dbg> i2s_nrfx: free_tx_buffer: Freed TX 0x2000e3d8
[00:26:31.841,946] <dbg> i2s_nrfx: supply_next_buffers: Next buffers: 0x20010bd8/(nil)
[00:26:31.842,203] <dbg> i2s_nrfx: i2s_nrfx_write: Queued TX 0x2000e3d8
[00:26:31.851,718] <dbg> i2s_nrfx: free_tx_buffer: Freed TX 0x2000f7d8
[00:26:31.851,941] <dbg> i2s_nrfx: supply_next_buffers: Next buffers: 0x20011d58/(nil)
[00:26:31.861,718] <dbg> i2s_nrfx: free_tx_buffer: Freed TX 0x20010bd8
[00:26:31.861,942] <dbg> i2s_nrfx: supply_next_buffers: Next buffers: 0x20012758/(nil)
[00:26:31.862,198] <dbg> i2s_nrfx: i2s_nrfx_write: Queued TX 0x20010bd8
[00:26:31.871,720] <dbg> i2s_nrfx: free_tx_buffer: Freed TX 0x20011d58
[00:26:31.871,944] <dbg> i2s_nrfx: supply_next_buffers: Next buffers: 0x20013158/(nil)
[00:26:31.881,718] <dbg> i2s_nrfx: free_tx_buffer: Freed TX 0x20012758
[00:26:31.881,942] <dbg> i2s_nrfx: supply_next_buffers: Next buffers: 0x2000bbd8/(nil)
[00:26:31.882,198] <dbg> i2s_nrfx: i2s_nrfx_write: Queued TX 0x20012758
[00:26:31.891,718] <dbg> i2s_nrfx: free_tx_buffer: Freed TX 0x20013158
[00:26:31.891,942] <dbg> i2s_nrfx: supply_next_buffers: Next buffers: 0x2000e3d8/(nil)
[00:26:31.901,720] <dbg> i2s_nrfx: free_tx_buffer: Freed TX 0x2000bbd8
[00:26:31.901,944] <dbg> i2s_nrfx: supply_next_buffers: Next buffers: 0x20010bd8/(nil)
[00:26:31.902,200] <dbg> i2s_nrfx: i2s_nrfx_write: Queued TX 0x2000bbd8
[00:26:31.911,718] <dbg> i2s_nrfx: free_tx_buffer: Freed TX 0x2000e3d8
[00:26:31.911,941] <dbg> i2s_nrfx: supply_next_buffers: Next buffers: 0x20012758/(nil)
[00:26:31.921,718] <dbg> i2s_nrfx: free_tx_buffer: Freed TX 0x20010bd8
[00:26:31.921,943] <dbg> i2s_nrfx: supply_next_buffers: Next buffers: 0x2000bbd8/(nil)
[00:26:31.922,199] <dbg> i2s_nrfx: i2s_nrfx_write: Queued TX 0x20010bd8
[00:26:31.931,718] <dbg> i2s_nrfx: free_tx_buffer: Freed TX 0x20012758
[00:26:31.931,942] <dbg> i2s_nrfx: supply_next_buffers: Next buffers: 0x20010bd8/(nil)
[00:26:31.941,718] <dbg> i2s_nrfx: free_tx_buffer: Freed TX 0x2000bbd8
[00:26:31.941,958] <dbg> i2s_nrfx: i2s_nrfx_write: Queued TX 0x2000bbd8
[00:26:31.942,173] <dbg> i2s_nrfx: i2s_nrfx_write: Next TX 0x2000bbd8
[00:26:31.942,382] <dbg> i2s_nrfx: supply_next_buffers: Next buffers: 0x2000bbd8/(nil)
[00:26:31.951,718] <dbg> i2s_nrfx: free_tx_buffer: Freed TX 0x20010bd8
[00:26:31.961,705] <err> i2s_nrfx: Next buffers not supplied on time
[00:26:31.961,931] <dbg> i2s_nrfx: free_tx_buffer: Freed TX 0x2000bbd8
[00:26:31.962,177] <err> i2s_nrfx: Cannot write in state: 4
I2S error -5
ASSERTION FAIL [p_cb->state != NRFX_DRV_STATE_UNINITIALIZED] @ WEST_TOPDIR/modules/hal/nordic/nrfx/drivers/src/nrfx_i2s.c:439
[00:26:31.962,647] <err> os: r0/a1: 0x00000004 r1/a2: 0x000001b7 r2/a3: 0x00000000
[00:26:31.962,889] <err> os: r3/a4: 0x00000004 r12/ip: 0x0000000a r14/lr: 0x00007f01
[00:26:31.963,123] <err> os: xpsr: 0x09000000
[00:26:31.963,303] <err> os: Faulting instruction address (r15/pc): 0x0000e364
[00:26:31.963,524] <err> os: >>> ZEPHYR FATAL ERROR 4: Kernel panic on CPU 0
[00:26:31.963,743] <err> os: Current thread: 0x20000a28 (main)
[00:26:31.963,947] <err> os: Halting system
no sine wave sound during this trasmission time ?..
I attached here reguster i Enabaled
 * Register declaration
const register_value REGISTER_DATA[] = {
//          # reg[0][0]   = 0x00   ; Select Page 0
{0,0x00},          // Select Page 0
/* Software reset */
{1,0x01},
/* ---------- PLL CONFIG (MCLK = 4 MHz → 8 kHz Fs) ---------- */
{4,0x03},          // PLL input = MCLK, CODEC_CLK = PLL
{5,0xD4},          // PLL power up, P=5, R=4   D4
{6,0x20},          // J=32
{7,0x00},          // D MSB
{8,0x00},          // D LSB
      // *** PLL LOCK WAIT (VERY IMPORTANT) ***
/* ---------- I2S DIGITAL ---------- */
{27,0x0C},         // I2S, 16bit, slave 0C
/* ---------- DAC CLOCK TREE ---------- */
{11,0x84},         // NDAC=4, power up
{12,0x99},         // MDAC=25, power up
{14,0x80},         // DOSR=128 → Fs = 8kHz
{29,0x01},         // DAC clock source  0x01
{30,0x84},         // BCLK divider  84
/* ---------- DAC POWER / UNMUTE ---------- */
{63,0xD4},         // Soft stepping  D4
{64,0x00},         // Left DAC unmute
{65,0x00},         // Right DAC unmute
{66,0xD0},         // DAC volume 00 dB
{71,0x82},    // beep
{72,0x82},
{81,0x80},
{82,0x00},
{83,0x00},
/* ===================== PAGE 1 ========================= */
{0,0x01},          // Select Page 1
/* ---------- Analog Power ---------- */
{30,0x00},         // Analog blocks power control
{31,0xC0},         // HPL + HPR unmute
{32,0xC6},         // Speaker drivers power up
/* ---------- DAC → Headphone ---------- */
{35,0xA8},         // Route DAC L/R → HP
{36,0x80},         // HP volume 0 dB
{37,0x80},         // HP volume 0 dB
/* ---------- Speaker ---------- */
{34,0x30},         // Speaker path enable
{42,0x3D},         // Speaker gain 1D
{43,0x3D},         // Speaker gain 1D
{44,0xC0},         // Speaker unmute
/* ---------- Route DAC → Speaker ---------- */
{38,0x80},
{39,0x80},
/* ---------- MIC (optional) ---------- */
{46,0x00},         // MICBIAS 2.5V 0x0A
{47,0x00},         // MIC gain
{48,0x00},        //0x40
{49,0x00},        //0x40
i m usinf nrf54l15  and codec is TLV320AIC3111
  • Hi Maria,
    1. my i2s is slave and codec is master
    2.I tried Thread creation and Working queue methord but same issue is face.
    3.I2c is used for register write ans I2s is used for Tx .
    4.i2c is initialization is done , I2s Tx happen some buffer after its goes to Buffer Error .
    5. I tried different methird and Verify - MCLK,BCLK,LRCK is proper
    6. when i check Din - it shows Millivolt range
    I will share my Entire Code below For your Reference
     * nRF54Lx DK
    //audio
    #define SAMPLE_BIT_WIDTH   16
    #define CHANNELS           2
    #define NUM_BLOCKS         120
    // #define AUDIO_THREAD_STACK 2048
    // #define AUDIO_THREAD_PRIO  -2
    // K_THREAD_STACK_DEFINE(audio_stack, AUDIO_THREAD_STACK);
    // static struct k_thread audio_thread;
    // K_THREAD_STACK_DEFINE(i2s_stack, I2S_THREAD_STACK);
    // static struct k_thread i2s_thread_data;
    //sine
    //      0,
    //  23170,
    //  32767,
    //  23170,
    //      0,
    // -23170,
    // -32768,
    // -23170
    // Fill block
            buf[2 * i] = s;
            buf[2 * i + 1] = s;
            // buf[i] = 28000;
    // // thread creation
    // void audio_thread_fn(void *a, void *b, void *c)
    //     while (1)
    //         void *block;
    //         int ret;
    //         ret = k_mem_slab_alloc(&i2s_tx_slab, &block, K_NO_WAIT);
    //         if (ret != 0)
    //             k_yield();   // allow DMA + ISR
    //             continue;
    //         fill_block((int16_t *)block);
    //         ret = i2s_buf_write(i2s_dev, block, BLOCK_SIZE);
    //         if (ret == -ENOMEM)
    //             k_mem_slab_free(&i2s_tx_slab, block);
    //         else if (ret < 0)
    //             printk("I2S error %d\n", ret);
        int ret;
        ret = pwm_4mhz();
        if (ret < 0)
            return ret;
            if (ret == 0)
            k_msleep(5);
        if (ret < 0)
            return ret;
        k_msleep(10);
            return -ENODEV;
        // I2S CONFIG
        if (ret < 0)
            return ret;
    /* Prefill */
        // for (int i = 0; i < 30; i++)
        //     void *block;
        //     if (k_mem_slab_alloc(&i2s_tx_slab, &block, K_NO_WAIT) == 0)
        //         i2s_buf_write(i2s_dev, block, BLOCK_SIZE);
        // /* Start DMA */
        // i2s_trigger(i2s_dev, I2S_DIR_TX, I2S_TRIGGER_START);
        // /* Create REALTIME audio thread */
        // k_thread_create(&audio_thread,
        //                 audio_stack,
        //                 K_THREAD_STACK_SIZEOF(audio_stack),
        //                 audio_thread_fn,
        //                 NULL, NULL, NULL,
        //                 AUDIO_THREAD_PRIO,
        //                 0,
        //                 K_NO_WAIT);
        //prefill
            void *block;
        if (ret < 0)
            return ret;
        while (1)
            void *block;
            if (ret < 0)
               continue;
            if (ret == -ENOMEM)
                continue;
            else if (ret < 0)
                k_sleep(K_MSEC(5));
                k_sleep(K_MSEC(2));
                continue;
    and codec file
    codec.c
    #include <zephyr/drivers/i2c.h>
    #include "codec.h"
    #include <zephyr/drivers/pwm.h>
    #define CODEC_ADDR 0x18 // i2c slave adress
    #define RESET_NODE DT_NODELABEL(led0)  // reset pin node
    #define PWM_PERIOD_NS 250U   // 4 MHz
    #define PWM_PULSE_NS  125U   // 50% duty
    const struct gpio_dt_spec codec_reset_pin = GPIO_DT_SPEC_GET(DT_NODELABEL(codec_reset), gpios); // for reset pin
    static const struct i2c_dt_spec dev_i2c = I2C_DT_SPEC_GET(DT_NODELABEL(audiocodec));    // i2c device tree
    static const struct pwm_dt_spec pwm_led0 = PWM_DT_SPEC_GET(DT_ALIAS(pwm_led0));       //    pwm device tree
    {1,0x01},
    {6,0x20},          // J=32
    {7,0x00},          // D MSB
    {8,0x00},          // D LSB
    {60,0x00},   // Disable miniDSP, DAC input from serial port
    {61,0x00},
    {63,0xD6},         // Soft stepping  D4
    {64,0x00},         // Left DAC unmutes
    {66,0x00},         // DAC volume 00 dB
    // {71,0x82},    // beep
    // {72,0x82},
    // {81,0x80},
    // {82,0x00},
    // {83,0x00},
    {38,0x80},
    {39,0x80},
    {48,0x00},        //0x40
    {49,0x00},        //0x40
    const register_value REGISTER_DATA[];
    static const struct gpio_dt_spec rst = GPIO_DT_SPEC_GET(RESET_NODE, gpios); // for reset pin
    const size_t REGISTER_LEN = sizeof(REGISTER_DATA) / sizeof(register_value);  // length of register data
    uint32_t cfg = I2C_MODE_CONTROLLER | I2C_SPEED_SET(I2C_SPEED_STANDARD); // configration of i2c
     * @brief codec_i2c_write
     * @param
     * device tree
     * adress
     * buffer
     * length of message
    static int codec_i2c_write(const struct device *dev,
                               uint8_t addr, uint8_t *buf, uint32_t len)
        struct i2c_msg msg = {
            .buf = buf,
            .len = len,
            .flags = I2C_MSG_WRITE | I2C_MSG_STOP,
        return i2c_transfer(dev, &msg, 1, addr);
     *brief codec_i2c_write_read
        *param device tree
        *param address
        *param write buffer
        *param number of bytes to write
        *param read buffer
        *param number of bytes to read
    static int codec_i2c_write_read(const struct device *dev,
                                    uint16_t addr,
                                    const void *write_buf, size_t num_write,
                                    void *read_buf, size_t num_read)
        struct i2c_msg msg[2];
        msg[0].buf = (uint8_t *)write_buf;
        msg[0].len = num_write;
        msg[0].flags = I2C_MSG_WRITE;
        msg[1].buf = (uint8_t *)read_buf;
        msg[1].len = num_read;
        msg[1].flags = I2C_MSG_READ | I2C_MSG_STOP;
        return i2c_write_read_dt(dev, write_buf, num_write, read_buf, num_read); // perform i2c write read
    brief codec_reset_pulse
    param none
    int codec_reset_pulse(void)
        int ret;
        ret = gpio_pin_set_dt(&codec_reset_pin, 1); // LOW → reset active
        k_msleep(10); /* HIGH → reset released */
        ret = gpio_pin_set_dt(&codec_reset_pin, 0); // HIGH → reset released
        k_msleep(20);
        return ret;
     * brief codec_write_register
     * param page
     * param reg
     * param val
    static int codec_write_register(uint8_t page, uint8_t reg, uint8_t val)
        static uint8_t last_page = 0xFF; // invalid page at start
        uint8_t tx_buf[2]; // transmit buffer
        uint8_t rx_buf[2];  // receive buffer
        int err;
        /* Only update page register if page actually changed */
        if (page != last_page)
            tx_buf[0] = 0x00; // Page Select Register
            tx_buf[1] = page; // New Page Number
            err =codec_i2c_write_read(&dev_i2c, CODEC_ADDR, tx_buf, 2, rx_buf, 2); // write page select register
            if (err)
                printk("I2C: page switch failed (page=%u) err=%d\n", page, err); // log error
                return err;
            last_page = page; // update page tracking
            k_msleep(1);      // small delay for codec stability
        /* Now write the actual register */
        tx_buf[0] = reg;
        tx_buf[1] = val;
        err =codec_i2c_write_read(&dev_i2c, CODEC_ADDR, tx_buf, 2, rx_buf, 2); // write register
        if (err)
             printk("[PAGE %u] REG 0x%02X <= 0x%02X  \n",
               page, reg, val);
        return err;
     * brief codec_write_table
     * param table
     * param length of table
    static int codec_write_table(const register_value *table, size_t len)
        uint8_t current_page = 0x00; // start on page 0
        int err;
        for (size_t i = 0; i < len; i++)
            uint8_t reg = table[i].reg_no;  // register number
            uint8_t val = table[i].reg_value;  // register value
            /* Page change */
            if (reg == 0x00)
                uint8_t new_page = val; // new page number
                /* Always change page through page 0 register 0 */
                err = codec_write_register(0x00, 0x00, new_page);   // write page select register
                if (err)
                    return err;
                current_page = new_page;  // update current page
                continue;
            /* Normal register write on current page */
            err = codec_write_register(current_page, reg, val);
            printk("reg=0x%02X val=0x%02X err=%d\n", reg, val, err);
            if (err)
                return err;
            k_msleep(1);
        return 0;
     *brief codec_probe
     param none
    static bool codec_probe(void)
        uint8_t reg0 = 0x00;
        uint8_t read_back = 0;
        int err = codec_i2c_write_read(&dev_i2c, CODEC_ADDR, &reg0, 1, &read_back, 1); // write and read reg 0
        if (err)
            printk("I2C probe failed err=%d\n", err);
            return false;
        printk("Codec responded: reg0 = 0x%02X\n", read_back); //   log reg 0 value
        return true;
    brief codec_i2c_config
    param none
    static int codec_i2c_config(void)
        if (!device_is_ready(dev_i2c.bus)) //   check i2c bus ready
            printk("Error: I2C bus %s is not ready!\n", dev_i2c.bus->name);
            return -1;
        printk("I2C bus ready, addr=0x%02x\n", dev_i2c.addr);  //   log i2c bus ready
        return 0;
    //pwm 4mhz generation
    brief pwm_4mhz
    param none
    int pwm_4mhz()
        int ret;
        if (!pwm_is_ready_dt(&pwm_led0)) // check pwm device ready
            printk("PWM device not ready\n");
            return 0;
        ret = pwm_set_dt(&pwm_led0, PWM_PERIOD_NS, PWM_PULSE_NS); // configure pwm for 4 MHz
        if (ret)
            printk("PWM cannot generate 4 MHz (ret=%d)\n", ret);
            return -1; // Some error code
        printk("PWM configured: period=%dns pulse=%dns\n", PWM_PERIOD_NS, PWM_PULSE_NS);
        return ret;
    brief codec_gpios_config
    param none
    static int codec_gpios_config(void)
        int ret;
        if (!gpio_is_ready_dt(&codec_reset_pin)) // check reset pin ready
            printk("Error: Codec reset pin not ready\n");
            return -1;
        ret = gpio_pin_configure_dt(&codec_reset_pin,
                                    GPIO_OUTPUT_ACTIVE | GPIO_ACTIVE_LOW); // configure reset pin
        if (ret < 0)
            printk("Error %d: Failed to configure codec reset pin\n", ret);
            return -1;
        return 0;
    brief i2c_init_codec
    param none
    int i2c_init_codec()
        int err;
        int ret;
        ret = codec_gpios_config(); // codec gpio config
        if (ret != 0)               //    check gpio config error
            return ret;
        k_msleep(20);
            printk("I2C bus %s is not ready!\n", dev_i2c.bus->name);
            return -1;
        k_msleep(20);
        printk("I2C bus ready, addr=0x%02x\n",dev_i2c.addr);
        // reset pin config
        codec_reset_pulse();
        /*codec address check*/
        if (!codec_probe())
            printk("Codec not found on I2C address 0x%02X\n", CODEC_ADDR);
            return -EIO;
       //  k_msleep(20);
        printk("Writing codec register table...\n");
        err = codec_write_table(REGISTER_DATA, REGISTER_LEN); // write codec register table
        if (err)
            printk("Codec register table FAILED: %d\n", err);
            return err;
        k_msleep(20);
        printk("Codec init DONE.\n");
        printk("I2C ready\n");
        return 0;
    Overlay file
    &pinctrl {
       i2s20_default: i2s20_default {
    		group1 {
            psels = <
                NRF_PSEL(I2S_SDOUT, 1, 7)
                NRF_PSEL(I2S_SDIN,  1, 6)
                NRF_PSEL(I2S_SCK,   1, 4)
                NRF_PSEL(I2S_LRCK,  1, 5)
               NRF_PSEL(I2S_MCK,   1, 8)
    	i2s20_sleep: i2s20_sleep {
    		group1 {
            psels = <
    			low-power-enable;
        i2c21_default: i2c21_default {
            group1 {
                psels =
                        <NRF_PSEL(TWIM_SCL, 1, 12)>,
                        <NRF_PSEL(TWIM_SDA, 1, 13)>;
                        bias-pull-up;
        i2c21_sleep: i2c21_sleep {
            group1 {
                psels = <NRF_PSEL(TWIM_SCL, 1, 12)>,
                        low-power-enable;
    	pwm20_default: pwm20_default {
    		group1 {
    				psels = <NRF_PSEL(PWM_OUT0, 1, 11)>;
    	pwm20_sleep: pwm20_sleep {
    		group1 {
    			low-power-enable;
    	model = "ISC54L15 EVK (Custom)";
    	compatible = "nordic,nrf54l15-cpuapp";
    	chosen {
    		zephyr,console = &uart20;
    		zephyr,shell-uart = &uart20;
    		zephyr,uart-mcumgr = &uart20;
    		zephyr,bt-c2h-uart = &audiocodec;
    		zephyr,bt-hci = &audiocodec;
    		zephyr,bt-mon-uart = &audiocodec;
    		zephyr,code-partition = &audiocodec;
    	custom_pins {
    		compatible = "gpio-keys";
    		codec_reset: codec_reset {
    			gpios = <&gpio1 9 GPIO_ACTIVE_HIGH>;
    			label = "Codec Reset";
    	leds {
    		compatible = "gpio-leds";
    		led0: led_0 {
    			gpios = <&gpio1 0 GPIO_ACTIVE_HIGH>;
    			label = "User LED 0";
    		led1: led_1 {
    			gpios = <&gpio1 8 GPIO_ACTIVE_HIGH>;
    			label = "PWM LED 1";
    	pwmleds {
    		compatible = "pwm-leds";
    		pwm_led0: pwm_led0 {
    			pwms = <&pwm20 0 PWM_USEC(1) PWM_POLARITY_NORMAL>;
    &i2s20 {
    	pinctrl-0 = <&i2s20_default>;
    	pinctrl-names = "default";
    	status = "okay";
    	zephyr,pm-device-runtime-auto;
    &i2c21{
        pinctrl-0 = <&i2c21_default>;
        pinctrl-1 = <&i2c21_sleep>;
        audiocodec: audiocodec@18 {
            compatible = "i2c-device";
            status = "okay";
            reg = < 0x18 >;
    &gpio0 {
    	status = "okay";
    // &led0 {
    // 	gpios = <&gpio1 9 0>;
    &pwm20 {
    	status = "okay";
    	pinctrl-0 = <&pwm20_default>;
    	pinctrl-1 = <&pwm20_sleep>;
     * nRF54Lx DK
    //audio
    #define CHANNELS           2
    //sine
    //      0,
    //  23170,
    //  32767,
    //  23170,
    //      0,
    // -23170,
    // -32768,
    // -23170
    // Fill block
            buf[2 * i] = s;
            buf[2 * i + 1] = s;
            // buf[i] = 28000;
    //     while (1)
    //         void *block;
    //         int ret;
    //         if (ret != 0)
    //             continue;
        int ret;
        ret = pwm_4mhz();
        if (ret < 0)
            return ret;
            if (ret == 0)
            k_msleep(5);
        if (ret < 0)
            return ret;
        k_msleep(10);
            return -ENODEV;
        // I2S CONFIG
        if (ret < 0)
            return ret;
    /* Prefill */
        //     void *block;
        // /* Start DMA */
        //                 audio_stack,
        //                 audio_thread_fn,
        //                 0,
        //                 K_NO_WAIT);
        //prefill
            void *block;
        if (ret < 0)
            return ret;
        while (1)
            void *block;
            if (ret < 0)
               continue;
            if (ret == -ENOMEM)
                continue;
            else if (ret < 0)
                k_sleep(K_MSEC(5));
                k_sleep(K_MSEC(2));
                continue;
    and codec file
    codec.c
    #include "codec.h"
    {1,0x01},
    {6,0x20},          // J=32
    {7,0x00},          // D MSB
    {8,0x00},          // D LSB
    {61,0x00},
    // {72,0x82},
    // {81,0x80},
    // {82,0x00},
    // {83,0x00},
    {38,0x80},
    {39,0x80},
    {48,0x00},        //0x40
    {49,0x00},        //0x40
     * @param
     * device tree
     * adress
     * buffer
     * length of message
            .buf = buf,
            .len = len,
        *param device tree
        *param address
        *param write buffer
        *param read buffer
                                    uint16_t addr,
    param none
        int ret;
        k_msleep(20);
        return ret;
     * param page
     * param reg
     * param val
        int err;
            if (err)
                return err;
        tx_buf[0] = reg;
        tx_buf[1] = val;
        if (err)
               page, reg, val);
        return err;
     * param table
        int err;
            /* Page change */
            if (reg == 0x00)
                if (err)
                    return err;
                continue;
            if (err)
                return err;
            k_msleep(1);
        return 0;
     *brief codec_probe
     param none
        if (err)
            return false;
        return true;
    param none
            return -1;
        return 0;
    brief pwm_4mhz
    param none
    int pwm_4mhz()
        int ret;
            return 0;
        if (ret)
        return ret;
    param none
        int ret;
            return -1;
        if (ret < 0)
            return -1;
        return 0;
    param none
        int err;
        int ret;
            return ret;
        k_msleep(20);
            return -1;
        k_msleep(20);
        // reset pin config
        if (!codec_probe())
            return -EIO;
       //  k_msleep(20);
        if (err)
            return err;
        k_msleep(20);
        return 0;
    Overlay file
    &pinctrl {
    		group1 {
            psels = <
    		group1 {
            psels = <
    			low-power-enable;
            group1 {
                psels =
                        bias-pull-up;
            group1 {
                        low-power-enable;
    		group1 {
    		group1 {
    			low-power-enable;
    	chosen {
    	custom_pins {
    	leds {
    		led0: led_0 {
    		led1: led_1 {
    	pwmleds {
    &i2s20 {
    	status = "okay";
    &i2c21{
            status = "okay";
            reg = < 0x18 >;
    &gpio0 {
    	status = "okay";
    // &led0 {
    &pwm20 {
    	status = "okay";
    Thank you for sharing code with Insert->Code.
    You have some instance collisions in your overlay, i.e. uart20, i2s20 and pwm20. Please choose unique instances for all your peripherals.
    Maria
  • Hi mam,
    I am currently generating Sine sound using nrf as slave and codec has master -
    so any issue have for this config.
    i am connecting my nrf Sdout - to codec Sdin
    Bclk ,mclk,wclk generated by codec now config as nrf -slave
    I got mic sound from codec - But i did not get proper out -
    Dout shows .5v only
  • *** Booting nRF Connect SDK v3.2.1-d8887f6f32df ***
    reg=0x3C val=0x00 err=0
    reg=0x3D val=0x00 err=0
    reg=0x3F val=0xD6 err=0
    reg=0x42 val=0x00 err=0
    Codec init DONE.
    I2C ready
    Start streaming
    [00:04:02.658,525] <dbg> i2s_nrfx: i2s_nrfx_write: Queued TX 0x200070d8
    [00:04:02.658,775] <dbg> i2s_nrfx: i2s_nrfx_write: Queued TX 0x200075d8
    [00:04:02.659,020] <dbg> i2s_nrfx: i2s_nrfx_write: Queued TX 0x20007ad8
    [00:04:02.659,262] <dbg> i2s_nrfx: i2s_nrfx_write: Queued TX 0x20007fd8
    [00:04:02.659,507] <dbg> i2s_nrfx: i2s_nrfx_write: Queued TX 0x200084d8
    [00:04:02.659,751] <dbg> i2s_nrfx: i2s_nrfx_write: Queued TX 0x200089d8
    [00:04:02.659,996] <dbg> i2s_nrfx: i2s_nrfx_write: Queued TX 0x20008ed8
    [00:04:02.660,240] <dbg> i2s_nrfx: i2s_nrfx_write: Queued TX 0x200093d8
    [00:04:02.660,484] <dbg> i2s_nrfx: i2s_nrfx_write: Queued TX 0x200098d8
    [00:04:02.660,729] <dbg> i2s_nrfx: i2s_nrfx_write: Queued TX 0x20009dd8
    [00:04:02.660,973] <dbg> i2s_nrfx: i2s_nrfx_write: Queued TX 0x2000a2d8
    [00:04:02.661,217] <dbg> i2s_nrfx: i2s_nrfx_write: Queued TX 0x2000a7d8
    [00:04:02.661,461] <dbg> i2s_nrfx: i2s_nrfx_write: Queued TX 0x2000acd8
    [00:04:02.661,702] <dbg> i2s_nrfx: i2s_nrfx_write: Queued TX 0x2000b1d8
    [00:04:02.661,943] <dbg> i2s_nrfx: i2s_nrfx_write: Queued TX 0x2000b6d8
    [00:04:02.662,184] <dbg> i2s_nrfx: i2s_nrfx_write: Queued TX 0x2000bbd8
    [00:04:02.662,425] <dbg> i2s_nrfx: i2s_nrfx_write: Queued TX 0x2000c0d8
    [00:04:02.662,666] <dbg> i2s_nrfx: i2s_nrfx_write: Queued TX 0x2000c5d8
    [00:04:02.667,909] <dbg> i2s_nrfx: i2s_nrfx_write: Queued TX 0x2000cad8
    [00:04:02.668,153] <dbg> i2s_nrfx: i2s_nrfx_write: Queued TX 0x2000cfd8
    [00:04:02.668,398] <dbg> i2s_nrfx: i2s_nrfx_write: Queued TX 0x2000d4d8
    [00:04:02.668,642] <dbg> i2s_nrfx: i2s_nrfx_write: Queued TX 0x2000d9d8
    [00:04:02.668,886] <dbg> i2s_nrfx: i2s_nrfx_write: Queued TX 0x2000ded8
    [00:04:02.669,131] <dbg> i2s_nrfx: i2s_nrfx_write: Queued TX 0x2000e3d8
    [00:04:02.669,375] <dbg> i2s_nrfx: i2s_nrfx_write: Queued TX 0x2000e8d8
    [00:04:02.669,618] <dbg> i2s_nrfx: i2s_nrfx_write: Queued TX 0x2000edd8
    [00:04:02.669,859] <dbg> i2s_nrfx: i2s_nrfx_write: Queued TX 0x2000f2d8
    [00:04:02.670,100] <dbg> i2s_nrfx: i2s_nrfx_write: Queued TX 0x2000f7d8
    [00:04:02.670,340] <dbg> i2s_nrfx: i2s_nrfx_write: Queued TX 0x2000fcd8
    [00:04:02.670,581] <dbg> i2s_nrfx: i2s_nrfx_write: Queued TX 0x200101d8
    [00:04:02.670,853] <dbg> i2s_nrfx: i2s_nrfx_write: Queued TX 0x200106d8
    [00:04:02.671,107] <dbg> i2s_nrfx: [00:04:02.671,260] <dbg> i2s_nrfx: supply_next_buffers: Next buffers: 0x200075d8/(nil)
    [00:04:02.671,623] <dbg> i2s_nrfx: i2s_nrfx_write: Queued TX 0x200110d8
    [00:04:02.676,870] <dbg> i2s_nrfx: i2s_nrfx_write: Queued TX 0x200115d8
    [00:04:02.709,809] <dbg> i2s_nrfx: free_tx_buffer: Freed TX 0x200070d8
    [00:04:02.710,047] <dbg> i2s_nrfx: supply_next_buffers: Next buffers: 0x20007ad8/(nil)
    [00:04:02.710,285] <dbg> i2s_nrfx: i2s_nrfx_write: Queued TX 0x20011ad8
    [00:04:02.748,371] <dbg> i2s_nrfx: free_tx_buffer: Freed TX 0x200075d8
    [00:04:02.748,608] <dbg> i2s_nrfx: supply_next_buffers: Next buffers: 0x20007fd8/(nil)
    [00:04:02.748,849] <dbg> i2s_nrfx: i2s_nrfx_write: Queued TX 0x20011d58
    [00:04:02.786,924] <dbg> i2s_nrfx: free_tx_buffer: Freed TX 0x20007ad8
    [00:04:02.787,161] <dbg> i2s_nrfx: supply_next_buffers: Next buffers: 0x200084d8/(nil)
    [00:04:02.787,402] <dbg> i2s_nrfx: i2s_nrfx_write: Queued TX 0x20011fd8
    [00:04:02.825,457] <dbg> i2s_nrfx: free_tx_buffer: Freed TX 0x20007fd8
    [00:04:02.825,695] <dbg> i2s_nrfx: supply_next_buffers: Next buffers: 0x200089d8/(nil)
    [00:04:02.825,935] <dbg> i2s_nrfx: i2s_nrfx_write: Queued TX 0x20012258
    [00:04:02.864,014] <dbg> i2s_nrfx: free_tx_buffer: Freed TX 0x200084d8
    [00:04:02.864,250] <dbg> i2s_nrfx: supply_next_buffers: Next buffers: 0x20008ed8/(nil)
    [00:04:02.864,490] <dbg> i2s_nrfx: i2s_nrfx_write: Queued TX 0x200124d8
    [00:04:02.902,563] <dbg> i2s_nrfx: free_tx_buffer: Freed TX 0x200089d8
    [00:04:02.902,800] <dbg> i2s_nrfx: supply_next_buffers: Next buffers: 0x200093d8/(nil)
    [00:04:02.903,041] <dbg> i2s_nrfx: i2s_nrfx_write: Queued TX 0x20012758
    [00:04:02.941,131] <dbg> i2s_nrfx: free_tx_buffer: Freed TX 0x20008ed8
    [00:04:02.941,368] <dbg> i2s_nrfx: supply_next_buffers: Next buffers: 0x200098d8/(nil)
    [00:04:02.941,609] <dbg> i2s_nrfx: i2s_nrfx_write: Queued TX 0x200129d8
    [00:04:02.979,687] <dbg> i2s_nrfx: free_tx_buffer: Freed TX 0x200093d8
    [00:04:02.979,925] <dbg> i2s_nrfx: supply_next_buffers: Next buffers: 0x20009dd8/(nil)
    [00:04:02.980,165] <dbg> i2s_nrfx: i2s_nrfx_write: Queued TX 0x20012c58
    [00:04:03.018,230] <dbg> i2s_nrfx: free_tx_buffer: Freed TX 0x200098d8
    [00:04:03.018,466] <dbg> i2s_nrfx: supply_next_buffers: Next buffers: 0x2000a2d8/(nil)
    [00:04:03.018,704] <dbg> i2s_nrfx: i2s_nrfx_write: Queued TX 0x20012ed8
    [00:04:03.056,802] <dbg> i2s_nrfx: free_tx_buffer: Freed TX 0x20009dd8
    [00:04:03.057,038] <dbg> i2s_nrfx: supply_next_buffers: Next buffers: 0x2000a7d8/(nil)
    [00:04:03.057,276] <dbg> i2s_nrfx: i2s_nrfx_write: Queued TX 0x20013158
    [00:04:03.095,357] <dbg> i2s_nrfx: free_tx_buffer: Freed TX 0x2000a2d8
    [00:04:03.095,593] <dbg> i2s_nrfx: supply_next_buffers: Next buffers: 0x2000acd8/(nil)
    [00:04:03.095,832] <dbg> i2s_nrfx: i2s_nrfx_write: Queued TX 0x200133d8
    [00:04:03.133,902] <dbg> i2s_nrfx: free_tx_buffer: Freed TX 0x2000a7d8
    [00:04:03.134,140] <dbg> i2s_nrfx: supply_next_buffers: Next buffers: 0x2000b1d8/(nil)
    [00:04:03.134,380] <dbg> i2s_nrfx: i2s_nrfx_write: Queued TX 0x20013658
    [00:04:03.172,445] <dbg> i2s_nrfx: free_tx_buffer: Freed TX 0x2000acd8
    [00:04:03.172,682] <dbg> i2s_nrfx: supply_next_buffers: Next buffers: 0x2000b6d8/(nil)
    [00:04:03.172,921] <dbg> i2s_nrfx: i2s_nrfx_write: Queued TX 0x200138d8
    [00:04:03.211,010] <dbg> i2s_nrfx: free_tx_buffer: Freed TX 0x2000b1d8
    [00:04:03.211,246] <dbg> i2s_nrfx: supply_next_buffers: Next buffers: 0x2000bbd8/(nil)
    [00:04:03.211,486] <dbg> i2s_nrfx: i2s_nrfx_write: Queued TX 0x20013b58
    [00:04:03.249,578] <dbg> i2s_nrfx: free_tx_buffer: Freed TX 0x2000b6d8
    [00:04:03.249,815] <dbg> i2s_nrfx: supply_next_buffers: Next buffers: 0x2000c0d8/(nil)
    [00:04:03.250,056] <dbg> i2s_nrfx: i2s_nrfx_write: Queued TX 0x20013dd8
    [00:04:03.288,126] <dbg> i2s_nrfx: free_tx_buffer: Freed TX 0x2000bbd8
    [00:04:03.288,364] <dbg> i2s_nrfx: supply_next_buffers: Next buffers: 0x2000c5d8/(nil)
    [00:04:03.288,604] <dbg> i2s_nrfx: i2s_nrfx_write: Queued TX 0x20014058
    [00:04:03.326,686] <dbg> i2s_nrfx: free_tx_buffer: Freed TX 0x2000c0d8
    [00:04:03.326,924] <dbg> i2s_nrfx: supply_next_buffers: Next buffers: 0x2000cad8/(nil)
    [00:04:03.327,162] <dbg> i2s_nrfx: i2s_nrfx_write: Queued TX 0x200142d8
    [00:04:03.365,230] <dbg> i2s_nrfx: free_tx_buffer: Freed TX 0x2000c5d8
    [00:04:03.365,468] <dbg> i2s_nrfx: supply_next_buffers: Next buffers: 0x2000cfd8/(nil)
    [00:04:03.365,708] <dbg> i2s_nrfx: i2s_nrfx_write: Queued TX 0x20014558
    [00:04:03.403,790] <dbg> i2s_nrfx: free_tx_buffer: Freed TX 0x2000cad8
    [00:04:03.404,027] <dbg> i2s_nrfx: supply_next_buffers: Next buffers: 0x2000d4d8/(nil)
    [00:04:03.404,266] <dbg> i2s_nrfx: i2s_nrfx_write: Queued TX 0x200147d8
    [00:04:03.442,371] <dbg> i2s_nrfx: free_tx_buffer: Freed TX 0x2000cfd8
    [00:04:03.442,608] <dbg> i2s_nrfx: supply_next_buffers: Next buffers: 0x2000d9d8/(nil)
    [00:04:03.442,849] <dbg> i2s_nrfx: i2s_nrfx_write: Queued TX 0x20014a58
    [00:04:03.480,943] <dbg> i2s_nrfx: free_tx_buffer: Freed TX 0x2000d4d8
    [00:04:03.481,180] <dbg> i2s_nrfx: supply_next_buffers: Next buffers: 0x2000ded8/(nil)
    [00:04:03.481,419] <dbg> i2s_nrfx: i2s_nrfx_write: Queued TX 0x20014cd8
    [00:04:03.519,494] <dbg> i2s_nrfx: free_tx_buffer: Freed TX 0x2000d9d8
    [00:04:03.519,732] <dbg> i2s_nrfx: supply_next_buffers: Next buffers: 0x2000e3d8/(nil)
    [00:04:03.519,972] <dbg> i2s_nrfx: i2s_nrfx_write: Queued TX 0x20014f58
    [00:04:03.558,068] <dbg> i2s_nrfx: free_tx_buffer: Freed TX 0x2000ded8
    [00:04:03.558,304] <dbg> i2s_nrfx: supply_next_buffers: Next buffers: 0x2000e8d8/(nil)
    [00:04:03.558,545] <dbg> i2s_nrfx: i2s_nrfx_write: Queued TX 0x200151d8
    [00:04:03.596,598] <dbg> i2s_nrfx: free_tx_buffer: Freed TX 0x2000e3d8
    [00:04:03.596,836] <dbg> i2s_nrfx: supply_next_buffers: Next buffers: 0x2000edd8/(nil)
    [00:04:03.597,077] <dbg> i2s_nrfx: i2s_nrfx_write: Queued TX 0x20015458
    [00:04:03.635,159] <dbg> i2s_nrfx: free_tx_buffer: Freed TX 0x2000e8d8
    [00:04:03.635,396] <dbg> i2s_nrfx: supply_next_buffers: Next buffers: 0x2000f2d8/(nil)
    [00:04:03.635,634] <dbg> i2s_nrfx: i2s_nrfx_write: Queued TX 0x200156d8
    [00:04:03.673,719] <dbg> i2s_nrfx: free_tx_buffer: Freed TX 0x2000edd8
    [00:04:03.673,957] <dbg> i2s_nrfx: supply_next_buffers: Next buffers: 0x2000f7d8/(nil)
    [00:04:03.674,197] <dbg> i2s_nrfx: i2s_nrfx_write: Queued TX 0x20015958
    [00:04:03.712,268] <dbg> i2s_nrfx: free_tx_buffer: Freed TX 0x2000f2d8
    [00:04:03.712,505] <dbg> i2s_nrfx: supply_next_buffers: Next buffers: 0x2000fcd8/(nil)
    [00:04:03.712,746] <dbg> i2s_nrfx: i2s_nrfx_write: Queued TX 0x20015bd8
    [00:04:03.750,833] <dbg> i2s_nrfx: free_tx_buffer: Freed TX 0x2000f7d8
    [00:04:03.751,071] <dbg> i2s_nrfx: supply_next_buffers: Next buffers: 0x200101d8/(nil)
    [00:04:03.751,310] <dbg> i2s_nrfx: i2s_nrfx_write: Queued TX 0x20015e58
    [00:04:03.789,400] <dbg> i2s_nrfx: free_tx_buffer: Freed TX 0x2000fcd8
    [00:04:03.789,638] <dbg> i2s_nrfx: supply_next_buffers: Next buffers: 0x200106d8/(nil)
    [00:04:03.789,876] <dbg> i2s_nrfx: i2s_nrfx_write: Queued TX 0x200160d8
    [00:04:03.827,970] <dbg> i2s_nrfx: free_tx_buffer: Freed TX 0x200101d8
    [00:04:03.828,208] <dbg> i2s_nrfx: supply_next_buffers: Next buffers: 0x20010bd8/(nil)
    [00:04:03.828,448] <dbg> i2s_nrfx: i2s_nrfx_write: Queued TX 0x20016358
    [00:04:03.866,527] <dbg> i2s_nrfx: free_tx_buffer: Freed TX 0x200106d8
    [00:04:03.866,765] <dbg> i2s_nrfx: supply_next_buffers: Next buffers: 0x200110d8/(nil)
    [00:04:03.867,005] <dbg> i2s_nrfx: i2s_nrfx_write: Queued TX 0x200165d8
    [00:04:03.905,088] <dbg> i2s_nrfx: free_tx_buffer: Freed TX 0x20010bd8
    [00:04:03.905,324] <dbg> i2s_nrfx: supply_next_buffers: Next buffers: 0x200115d8/(nil)
    [00:04:03.905,565] <dbg> i2s_nrfx: i2s_nrfx_write: Queued TX 0x20016858
    [00:04:03.943,635] <dbg> i2s_nrfx: free_tx_buffer: Freed TX 0x200110d8
    [00:04:03.943,872] <dbg> i2s_nrfx: supply_next_buffers: Next buffers: 0x20011ad8/(nil)
    [00:04:03.944,111] <dbg> i2s_nrfx: i2s_nrfx_write: Queued TX 0x20016ad8
    [00:04:03.982,205] <dbg> i2s_nrfx: free_tx_buffer: Freed TX 0x200115d8
    [00:04:03.982,443] <dbg> i2s_nrfx: supply_next_buffers: Next buffers: 0x20011d58/(nil)
    [00:04:03.982,683] <dbg> i2s_nrfx: i2s_nrfx_write: Queued TX 0x20016d58
    [00:04:04.020,775] <dbg> i2s_nrfx: free_tx_buffer: Freed TX 0x20011ad8
    [00:04:04.021,011] <dbg> i2s_nrfx: supply_next_buffers: Next buffers: 0x20011fd8/(nil)
    [00:04:04.021,248] <dbg> i2s_nrfx: i2s_nrfx_write: Queued TX 0x20016fd8
    [00:04:04.059,333] <dbg> i2s_nrfx: free_tx_buffer: Freed TX 0x20011d58
    [00:04:04.059,569] <dbg> i2s_nrfx: supply_next_buffers: Next buffers: 0x20012258/(nil)
    [00:04:04.059,808] <dbg> i2s_nrfx: i2s_nrfx_write: Queued TX 0x20017258
    [00:04:04.097,885] <dbg> i2s_nrfx: free_tx_buffer: Freed TX 0x20011fd8
    [00:04:04.098,121] <dbg> i2s_nrfx: supply_next_buffers: Next buffers: 0x200124d8/(nil)
    [00:04:04.098,357] <dbg> i2s_nrfx: i2s_nrfx_write: Queued TX 0x200174d8
    [00:04:04.136,452] <dbg> i2s_nrfx: free_tx_buffer: Freed TX 0x20012258
    [00:04:04.136,690] <dbg> i2s_nrfx: supply_next_buffers: Next buffers: 0x20012758/(nil)
    [00:04:04.136,930] <dbg> i2s_nrfx: i2s_nrfx_write: Queued TX 0x20017758
    [00:04:04.175,015] <dbg> i2s_nrfx: free_tx_buffer: Freed TX 0x200124d8
    [00:04:04.175,251] <dbg> i2s_nrfx: supply_next_buffers: Next buffers: 0x200129d8/(nil)
    [00:04:04.175,491] <dbg> i2s_nrfx: i2s_nrfx_write: Queued TX 0x200179d8
    [00:04:04.213,583] <dbg> i2s_nrfx: free_tx_buffer: Freed TX 0x20012758
    [00:04:04.213,821] <dbg> i2s_nrfx: supply_next_buffers: Next buffers: 0x20012c58/(nil)
    [00:04:04.214,061] <dbg> i2s_nrfx: i2s_nrfx_write: Queued TX 0x20017c58
    [00:04:04.252,153] <dbg> i2s_nrfx: free_tx_buffer: Freed TX 0x200129d8
    [00:04:04.252,390] <dbg> i2s_nrfx: supply_next_buffers: Next buffers: 0x20012ed8/(nil)
    [00:04:04.252,629] <dbg> i2s_nrfx: i2s_nrfx_write: Queued TX 0x20017ed8
    [00:04:04.290,698] <dbg> i2s_nrfx: free_tx_buffer: Freed TX 0x20012c58
    [00:04:04.290,936] <dbg> i2s_nrfx: supply_next_buffers: Next buffers: 0x20013158/(nil)
    [00:04:04.291,176] <dbg> i2s_nrfx: i2s_nrfx_write: Queued TX 0x20018158
    [00:04:04.329,235] <dbg> i2s_nrfx: free_tx_buffer: Freed TX 0x20012ed8
    [00:04:04.329,472] <dbg> i2s_nrfx: supply_next_buffers: Next buffers: 0x200133d8/(nil)
    [00:04:04.329,713] <dbg> i2s_nrfx: i2s_nrfx_write: Queued TX 0x200183d8
    [00:04:04.367,778] <dbg> i2s_nrfx: free_tx_buffer: Freed TX 0x20013158
    [00:04:04.368,016] <dbg> i2s_nrfx: supply_next_buffers: Next buffers: 0x20013658/(nil)
    [00:04:04.368,255] <dbg> i2s_nrfx: i2s_nrfx_write: Queued TX 0x20018658
    [00:04:04.406,335] <dbg> i2s_nrfx: free_tx_buffer: Freed TX 0x200133d8
    [00:04:04.406,573] <dbg> i2s_nrfx: supply_next_buffers: Next buffers: 0x200138d8/(nil)
    [00:04:04.406,810] <dbg> i2s_nrfx: i2s_nrfx_write: Queued TX 0x200188d8
    [00:04:04.444,879] <dbg> i2s_nrfx: free_tx_buffer: Freed TX 0x20013658
    [00:04:04.445,117] <dbg> i2s_nrfx: supply_next_buffers: Next buffers: 0x20013b58/(nil)
    [00:04:04.445,357] <dbg> i2s_nrfx: i2s_nrfx_write: Queued TX 0x20018b58
    [00:04:04.483,440] <dbg> i2s_nrfx: free_tx_buffer: Freed TX 0x200138d8
    [00:04:04.483,678] <dbg> i2s_nrfx: supply_next_buffers: Next buffers: 0x20013dd8/(nil)
    [00:04:04.483,918] <dbg> i2s_nrfx: i2s_nrfx_write: Queued TX 0x20018dd8
    [00:04:04.522,019] <dbg> i2s_nrfx: free_tx_buffer: Freed TX 0x20013b58
    [00:04:04.522,255] <dbg> i2s_nrfx: supply_next_buffers: Next buffers: 0x20014058/(nil)
    [00:04:04.522,496] <dbg> i2s_nrfx: i2s_nrfx_write: Queued TX 0x20019058
    [00:04:04.560,566] <dbg> i2s_nrfx: free_tx_buffer: Freed TX 0x20013dd8
    [00:04:04.560,803] <dbg> i2s_nrfx: supply_next_buffers: Next buffers: 0x200142d8/(nil)
    [00:04:04.561,041] <dbg> i2s_nrfx: i2s_nrfx_write: Queued TX 0x200192d8
    [00:04:04.599,132] <dbg> i2s_nrfx: free_tx_buffer: Freed TX 0x20014058
    [00:04:04.599,370] <dbg> i2s_nrfx: supply_next_buffers: Next buffers: 0x20014558/(nil)
    [00:04:04.599,610] <dbg> i2s_nrfx: i2s_nrfx_write: Queued TX 0x20019558
    [00:04:04.637,698] <dbg> i2s_nrfx: free_tx_buffer: Freed TX 0x200142d8
    [00:04:04.637,936] <dbg> i2s_nrfx: supply_next_buffers: Next buffers: 0x200147d8/(nil)
    [00:04:04.638,176] <dbg> i2s_nrfx: i2s_nrfx_write: Queued TX 0x200197d8
    [00:04:04.676,266] <dbg> i2s_nrfx: free_tx_buffer: Freed TX 0x20014558
    [00:04:04.676,486] <dbg> i2s_nrfx: supply_next_buffers: Next buffers: 0x20014a58/(nil)
    [00:04:04.676,735] <dbg> i2s_nrfx: i2s_nrfx_write: Queued TX 0x20014558
    [00:04:04.714,832] <dbg> i2s_nrfx: free_tx_buffer: Freed TX 0x200147d8
    [00:04:04.715,051] <dbg> i2s_nrfx: supply_next_buffers: Next buffers: 0x20014cd8/(nil)
    [00:04:04.753,394] <dbg> i2s_nrfx: free_tx_buffer: Freed TX 0x20014a58
    [00:04:04.753,614] <dbg> i2s_nrfx: supply_next_buffers: Next buffers: 0x20014f58/(nil)
    [00:04:04.753,863] <dbg> i2s_nrfx: i2s_nrfx_write: Queued TX 0x20014a58
    [00:04:04.791,948] <dbg> i2s_nrfx: free_tx_buffer: Freed TX 0x20014cd8
    [00:04:04.792,167] <dbg> i2s_nrfx: supply_next_buffers: Next buffers: 0x200151d8/(nil)
    [00:04:04.830,527] <dbg> i2s_nrfx: free_tx_buffer: Freed TX 0x20014f58
    [00:04:04.830,747] <dbg> i2s_nrfx: supply_next_buffers: Next buffers: 0x20015458/(nil)
    [00:04:04.830,996] <dbg> i2s_nrfx: i2s_nrfx_write: Queued TX 0x20014f58
    [00:04:04.869,096] <dbg> i2s_nrfx: free_tx_buffer: Freed TX 0x200151d8
    [00:04:04.869,313] <dbg> i2s_nrfx: supply_next_buffers: Next buffers: 0x200156d8/(nil)
    [00:04:04.907,632] <dbg> i2s_nrfx: free_tx_buffer: Freed TX 0x20015458
    [00:04:04.907,851] <dbg> i2s_nrfx: supply_next_buffers: Next buffers: 0x20015958/(nil)
    [00:04:04.908,097] <dbg> i2s_nrfx: i2s_nrfx_write: Queued TX 0x20015458
    [00:04:04.946,197] <dbg> i2s_nrfx: free_tx_buffer: Freed TX 0x200156d8
    [00:04:04.946,415] <dbg> i2s_nrfx: supply_next_buffers: Next buffers: 0x20015bd8/(nil)
    [00:04:04.984,770] <dbg> i2s_nrfx: free_tx_buffer: Freed TX 0x20015958
    [00:04:04.984,990] <dbg> i2s_nrfx: supply_next_buffers: Next buffers: 0x20015e58/(nil)
    [00:04:04.985,239] <dbg> i2s_nrfx: i2s_nrfx_write: Queued TX 0x20015958
    [00:04:05.023,316] <dbg> i2s_nrfx: free_tx_buffer: Freed TX 0x20015bd8
    [00:04:05.023,533] <dbg> i2s_nrfx: supply_next_buffers: Next buffers: 0x200160d8/(nil)
    [00:04:05.061,887] <dbg> i2s_nrfx: free_tx_buffer: Freed TX 0x20015e58
    [00:04:05.062,105] <dbg> i2s_nrfx: supply_next_buffers: Next buffers: 0x20016358/(nil)
    [00:04:05.062,353] <dbg> i2s_nrfx: i2s_nrfx_write: Queued TX 0x20015e58
    [00:04:05.100,432] <dbg> i2s_nrfx: free_tx_buffer: Freed TX 0x200160d8
    [00:04:05.100,650] <dbg> i2s_nrfx: supply_next_buffers: Next buffers: 0x200165d8/(nil)
    [00:04:05.138,977] <dbg> i2s_nrfx: free_tx_buffer: Freed TX 0x20016358
    [00:04:05.139,197] <dbg> i2s_nrfx: supply_next_buffers: Next buffers: 0x20016858/(nil)
    [00:04:05.139,446] <dbg> i2s_nrfx: i2s_nrfx_write: Queued TX 0x20016358
    [00:04:05.177,542] <dbg> i2s_nrfx: free_tx_buffer: Freed TX 0x200165d8
    [00:04:05.177,760] <dbg> i2s_nrfx: supply_next_buffers: Next buffers: 0x20016ad8/(nil)
    [00:04:05.216,098] <dbg> i2s_nrfx: free_tx_buffer: Freed TX 0x20016858
    [00:04:05.216,316] <dbg> i2s_nrfx: supply_next_buffers: Next buffers: 0x20016d58/(nil)
    [00:04:05.216,565] <dbg> i2s_nrfx: i2s_nrfx_write: Queued TX 0x20016858
    [00:04:05.254,647] <dbg> i2s_nrfx: free_tx_buffer: Freed TX 0x20016ad8
    [00:04:05.254,865] <dbg> i2s_nrfx: supply_next_buffers: Next buffers: 0x20016fd8/(nil)
    [00:04:05.293,199] <dbg> i2s_nrfx: free_tx_buffer: Freed TX 0x20016d58
    [00:04:05.293,419] <dbg> i2s_nrfx: supply_next_buffers: Next buffers: 0x20017258/(nil)
    [00:04:05.293,668] <dbg> i2s_nrfx: i2s_nrfx_write: Queued TX 0x20016d58
    [00:04:05.331,752] <dbg> i2s_nrfx: free_tx_buffer: Freed TX 0x20016fd8
    [00:04:05.331,971] <dbg> i2s_nrfx: supply_next_buffers: Next buffers: 0x200174d8/(nil)
    [00:04:05.370,317] <dbg> i2s_nrfx: free_tx_buffer: Freed TX 0x20017258
    [00:04:05.370,536] <dbg> i2s_nrfx: supply_next_buffers: Next buffers: 0x20017758/(nil)
    [00:04:05.370,786] <dbg> i2s_nrfx: i2s_nrfx_write: Queued TX 0x20017258
    [00:04:05.408,874] <dbg> i2s_nrfx: free_tx_buffer: Freed TX 0x200174d8
    [00:04:05.409,093] <dbg> i2s_nrfx: supply_next_buffers: Next buffers: 0x200179d8/(nil)
    [00:04:05.447,435] <dbg> i2s_nrfx: free_tx_buffer: Freed TX 0x20017758
    [00:04:05.447,654] <dbg> i2s_nrfx: supply_next_buffers: Next buffers: 0x20017c58/(nil)
    [00:04:05.447,901] <dbg> i2s_nrfx: i2s_nrfx_write: Queued TX 0x20017758
    [00:04:05.485,992] <dbg> i2s_nrfx: free_tx_buffer: Freed TX 0x200179d8
    [00:04:05.486,211] <dbg> i2s_nrfx: supply_next_buffers: Next buffers: 0x20017ed8/(nil)
    [00:04:05.524,539] <dbg> i2s_nrfx: free_tx_buffer: Freed TX 0x20017c58
    [00:04:05.524,759] <dbg> i2s_nrfx: supply_next_buffers: Next buffers: 0x20018158/(nil)
    [00:04:05.525,008] <dbg> i2s_nrfx: i2s_nrfx_write: Queued TX 0x20017c58
    [00:04:05.563,086] <dbg> i2s_nrfx: free_tx_buffer: Freed TX 0x20017ed8
    [00:04:05.563,303] <dbg> i2s_nrfx: supply_next_buffers: Next buffers: 0x200183d8/(nil)
    [00:04:05.601,649] <dbg> i2s_nrfx: free_tx_buffer: Freed TX 0x20018158
    [00:04:05.601,868] <dbg> i2s_nrfx: supply_next_buffers: Next buffers: 0x20018658/(nil)
    [00:04:05.602,118] <dbg> i2s_nrfx: i2s_nrfx_write: Queued TX 0x20018158
    [00:04:05.640,204] <dbg> i2s_nrfx: free_tx_buffer: Freed TX 0x200183d8
    [00:04:05.640,420] <dbg> i2s_nrfx: supply_next_buffers: Next buffers: 0x200188d8/(nil)
    [00:04:05.678,771] <dbg> i2s_nrfx: free_tx_buffer: Freed TX 0x20018658
    [00:04:05.678,991] <dbg> i2s_nrfx: supply_next_buffers: Next buffers: 0x20018b58/(nil)
    [00:04:05.679,240] <dbg> i2s_nrfx: i2s_nrfx_write: Queued TX 0x20018658
    [00:04:05.717,322] <dbg> i2s_nrfx: free_tx_buffer: Freed TX 0x200188d8
    [00:04:05.717,540] <dbg> i2s_nrfx: supply_next_buffers: Next buffers: 0x20018dd8/(nil)
    [00:04:05.755,891] <dbg> i2s_nrfx: free_tx_buffer: Freed TX 0x20018b58
    [00:04:05.756,110] <dbg> i2s_nrfx: supply_next_buffers: Next buffers: 0x20019058/(nil)
    [00:04:05.756,360] <dbg> i2s_nrfx: i2s_nrfx_write: Queued TX 0x20018b58
    [00:04:05.794,457] <dbg> i2s_nrfx: free_tx_buffer: Freed TX 0x20018dd8
    [00:04:05.794,676] <dbg> i2s_nrfx: supply_next_buffers: Next buffers: 0x200192d8/(nil)
    [00:04:05.833,007] <dbg> i2s_nrfx: free_tx_buffer: Freed TX 0x20019058
    [00:04:05.833,224] <dbg> i2s_nrfx: supply_next_buffers: Next buffers: 0x20019558/(nil)
    [00:04:05.833,473] <dbg> i2s_nrfx: i2s_nrfx_write: Queued TX 0x20019058
    [00:04:05.871,568] <dbg> i2s_nrfx: free_tx_buffer: Freed TX 0x200192d8
    [00:04:05.871,786] <dbg> i2s_nrfx: supply_next_buffers: Next buffers: 0x200197d8/(nil)
    [00:04:05.910,127] <dbg> i2s_nrfx: free_tx_buffer: Freed TX 0x20019558
    [00:04:05.910,346] <dbg> i2s_nrfx: supply_next_buffers: Next buffers: 0x20014558/(nil)
    [00:04:05.910,596] <dbg> i2s_nrfx: i2s_nrfx_write: Queued TX 0x20019558
    [00:04:05.948,688] <dbg> i2s_nrfx: free_tx_buffer: Freed TX 0x200197d8
    [00:04:05.948,907] <dbg> i2s_nrfx: supply_next_buffers: Next buffers: 0x20014a58/(nil)
    [00:04:05.987,245] <dbg> i2s_nrfx: free_tx_buffer: Freed TX 0x20014558
    [00:04:05.987,465] <dbg> i2s_nrfx: supply_next_buffers: Next buffers: 0x20014f58/(nil)
    [00:04:05.987,713] <dbg> i2s_nrfx: i2s_nrfx_write: Queued TX 0x20014558
    [00:04:06.025,811] <dbg> i2s_nrfx: free_tx_buffer: Freed TX 0x20014a58
    [00:04:06.026,028] <dbg> i2s_nrfx: supply_next_buffers: Next buffers: 0x20015458/(nil)
    [00:04:06.064,392] <dbg> i2s_nrfx: free_tx_buffer: Freed TX 0x20014f58
    [00:04:06.064,610] <dbg> i2s_nrfx: supply_next_buffers: Next buffers: 0x20015958/(nil)
    [00:04:06.064,858] <dbg> i2s_nrfx: i2s_nrfx_write: Queued TX 0x20014f58
    [00:04:06.102,965] <dbg> i2s_nrfx: free_tx_buffer: Freed TX 0x20015458
    [00:04:06.103,183] <dbg> i2s_nrfx: supply_next_buffers: Next buffers: 0x20015e58/(nil)
    [00:04:06.141,520] <dbg> i2s_nrfx: free_tx_buffer: Freed TX 0x20015958
    [00:04:06.141,739] <dbg> i2s_nrfx: supply_next_buffers: Next buffers: 0x20016358/(nil)
    [00:04:06.141,989] <dbg> i2s_nrfx: i2s_nrfx_write: Queued TX 0x20015958
    [00:04:06.180,082] <dbg> i2s_nrfx: free_tx_buffer: Freed TX 0x20015e58
    [00:04:06.180,298] <dbg> i2s_nrfx: supply_next_buffers: Next buffers: 0x20016858/(nil)
    [00:04:06.218,658] <dbg> i2s_nrfx: free_tx_buffer: Freed TX 0x20016358
    [00:04:06.218,878] <dbg> i2s_nrfx: supply_next_buffers: Next buffers: 0x20016d58/(nil)
    [00:04:06.219,127] <dbg> i2s_nrfx: i2s_nrfx_write: Queued TX 0x20016358
    [00:04:06.257,229] <dbg> i2s_nrfx: free_tx_buffer: Freed TX 0x20016858
    [00:04:06.257,447] <dbg> i2s_nrfx: supply_next_buffers: Next buffers: 0x20017258/(nil)
    [00:04:06.295,797] <dbg> i2s_nrfx: free_tx_buffer: Freed TX 0x20016d58
    [00:04:06.296,017] <dbg> i2s_nrfx: supply_next_buffers: Next buffers: 0x20017758/(nil)
    [00:04:06.296,265] <dbg> i2s_nrfx: i2s_nrfx_write: Queued TX 0x20016d58
    [00:04:06.334,347] <dbg> i2s_nrfx: free_tx_buffer: Freed TX 0x20017258
    [00:04:06.334,565] <dbg> i2s_nrfx: supply_next_buffers: Next buffers: 0x20017c58/(nil)
    [00:04:06.372,898] <dbg> i2s_nrfx: free_tx_buffer: Freed TX 0x20017758
    [00:04:06.373,116] <dbg> i2s_nrfx: supply_next_buffers: Next buffers: 0x20018158/(nil)
    [00:04:06.373,362] <dbg> i2s_nrfx: i2s_nrfx_write: Queued TX 0x20017758
    [00:04:06.411,476] <dbg> i2s_nrfx: free_tx_buffer: Freed TX 0x20017c58
    [00:04:06.411,695] <dbg> i2s_nrfx: supply_next_buffers: Next buffers: 0x20018658/(nil)
    [00:04:06.450,044] <dbg> i2s_nrfx: free_tx_buffer: Freed TX 0x20018158
    [00:04:06.450,262] <dbg> i2s_nrfx: supply_next_buffers: Next buffers: 0x20018b58/(nil)
    [00:04:06.450,511] <dbg> i2s_nrfx: i2s_nrfx_write: Queued TX 0x20018158
    [00:04:06.488,589] <dbg> i2s_nrfx: free_tx_buffer: Freed TX 0x20018658
    [00:04:06.488,808] <dbg> i2s_nrfx: supply_next_buffers: Next buffers: 0x20019058/(nil)
    [00:04:06.527,147] <dbg> i2s_nrfx: free_tx_buffer: Freed TX 0x20018b58
    [00:04:06.527,366] <dbg> i2s_nrfx: supply_next_buffers: Next buffers: 0x20019558/(nil)
    [00:04:06.527,616] <dbg> i2s_nrfx: i2s_nrfx_write: Queued TX 0x20018b58
    [00:04:06.565,705] <dbg> i2s_nrfx: free_tx_buffer: Freed TX 0x20019058
    [00:04:06.565,924] <dbg> i2s_nrfx: supply_next_buffers: Next buffers: 0x20014558/(nil)
    [00:04:06.604,295] <dbg> i2s_nrfx: free_tx_buffer: Freed TX 0x20019558
    [00:04:06.604,515] <dbg> i2s_nrfx: supply_next_buffers: Next buffers: 0x20014f58/(nil)
    [00:04:06.604,765] <dbg> i2s_nrfx: i2s_nrfx_write: Queued TX 0x20019558
    [00:04:06.642,852] <dbg> i2s_nrfx: free_tx_buffer: Freed TX 0x20014558
    [00:04:06.643,071] <dbg> i2s_nrfx: supply_next_buffers: Next buffers: 0x20015958/(nil)
    [00:04:06.681,413] <dbg> i2s_nrfx: free_tx_buffer: Freed TX 0x20014f58
    [00:04:06.681,633] <dbg> i2s_nrfx: supply_next_buffers: Next buffers: 0x20016358/(nil)
    [00:04:06.681,882] <dbg> i2s_nrfx: i2s_nrfx_write: Queued TX 0x20014f58
    [00:04:06.719,971] <dbg> i2s_nrfx: free_tx_buffer: Freed TX 0x20015958
    [00:04:06.720,190] <dbg> i2s_nrfx: supply_next_buffers: Next buffers: 0x20016d58/(nil)
    [00:04:06.758,531] <dbg> i2s_nrfx: free_tx_buffer: Freed TX 0x20016358
    [00:04:06.758,751] <dbg> i2s_nrfx: supply_next_buffers: Next buffers: 0x20017758/(nil)
    [00:04:06.759,000] <dbg> i2s_nrfx: i2s_nrfx_write: Queued TX 0x20016358
    [00:04:06.797,119] <dbg> i2s_nrfx: free_tx_buffer: Freed TX 0x20016d58
    [00:04:06.797,337] <dbg> i2s_nrfx: supply_next_buffers: Next buffers: 0x20018158/(nil)
    [00:04:06.835,696] <dbg> i2s_nrfx: free_tx_buffer: Freed TX 0x20017758
    [00:04:06.835,916] <dbg> i2s_nrfx: supply_next_buffers: Next buffers: 0x20018b58/(nil)
    [00:04:06.836,165] <dbg> i2s_nrfx: i2s_nrfx_write: Queued TX 0x20017758
    [00:04:06.874,263] <dbg> i2s_nrfx: free_tx_buffer: Freed TX 0x20018158
    [00:04:06.874,482] <dbg> i2s_nrfx: supply_next_buffers: Next buffers: 0x20019558/(nil)
    [00:04:06.912,836] <dbg> i2s_nrfx: free_tx_buffer: Freed TX 0x20018b58
    [00:04:06.913,055] <dbg> i2s_nrfx: supply_next_buffers: Next buffers: 0x20014f58/(nil)
    [00:04:06.913,300] <dbg> i2s_nrfx: i2s_nrfx_write: Queued TX 0x20018b58
    [00:04:06.951,422] <dbg> i2s_nrfx: free_tx_buffer: Freed TX 0x20019558
    [00:04:06.951,640] <dbg> i2s_nrfx: supply_next_buffers: Next buffers: 0x20016358/(nil)
    [00:04:06.989,991] <dbg> i2s_nrfx: free_tx_buffer: Freed TX 0x20014f58
    [00:04:06.990,211] <dbg> i2s_nrfx: supply_next_buffers: Next buffers: 0x20017758/(nil)
    [00:04:06.990,460] <dbg> i2s_nrfx: i2s_nrfx_write: Queued TX 0x20014f58
    [00:04:07.028,551] <dbg> i2s_nrfx: free_tx_buffer: Freed TX 0x20016358
    [00:04:07.028,768] <dbg> i2s_nrfx: supply_next_buffers: Next buffers: 0x20018b58/(nil)
    [00:04:07.067,107] <dbg> i2s_nrfx: free_tx_buffer: Freed TX 0x20017758
    [00:04:07.067,325] <dbg> i2s_nrfx: supply_next_buffers: Next buffers: 0x20014f58/(nil)
    [00:04:07.067,573] <dbg> i2s_nrfx: i2s_nrfx_write: Queued TX 0x20017758
    [00:04:07.105,674] <dbg> i2s_nrfx: free_tx_buffer: Freed TX 0x20018b58
    [00:04:07.105,892] <dbg> i2s_nrfx: supply_next_buffers: Next buffers: 0x20017758/(nil)
    [00:04:07.144,230] <dbg> i2s_nrfx: free_tx_buffer: Freed TX 0x20014f58
    [00:04:07.144,464] <dbg> i2s_nrfx: i2s_nrfx_write: Queued TX 0x20014f58
    [00:04:07.144,675] <dbg> i2s_nrfx: i2s_nrfx_write: Next TX 0x20014f58
    [00:04:07.144,881] <dbg> i2s_nrfx: supply_next_buffers: Next buffers: 0x20014f58/(nil)
    [00:04:07.182,796] <dbg> i2s_nrfx: free_tx_buffer: Freed TX 0x20017758
    [00:04:07.221,344] <err> i2s_nrfx: Next buffers not supplied on time
    [00:04:07.221,560] <dbg> i2s_nrfx: free_tx_buffer: Freed TX 0x20014f58
    [00:04:07.221,803] <err> i2s_nrfx: Cannot write in state: 4
    I2S error -5
    [00:04:07.222,272] <err> os: r0/a1: 0x00000004 r1/a2: 0x000001b7 r2/a3: 0x00000000
    [00:04:07.222,507] <err> os: r3/a4: 0x00000004 r12/ip: 0x0000000a r14/lr: 0x00007f41
    [00:04:07.222,734] <err> os: xpsr: 0x09000000
    [00:04:07.222,907] <err> os: Faulting instruction address (r15/pc): 0x0000e38a
    [00:04:07.223,118] <err> os: >>> ZEPHYR FATAL ERROR 4: Kernel panic on CPU 0
    [00:04:07.223,330] <err> os: Current thread: 0x20000a28 (main)
    [00:04:07.223,526] <err> os: Halting system
    this is log when i am update - instance
